Archive through September 18, 2005
Closed: New threads not accepted on this page
  Thread Last Poster Posts Last Post
Cadence Z7000Jack4
Won't Power UpTyler7
AMP SUGGESTIONS FOR MY NEW SYSTEM MuddyWaters2
Cummins amp?Quick Shot 4ever9
No Power going to ampJoe Fazio4
Honda CRV 2001 Replace Front Speaker Wire helpEddie5
Best Amp For Infinity Perfects??mike09787O212
No powermixneffect3
HELP!!!!!!!!!!!!2000 sunfiremixneffect2
Hifonics vs MA Audio vs Power Acoustik vs SoundStream !Rovin12
HelpJoe Fazio1
Need adviceRyan2
MB Quart / Rockford Fosgate / Rovin Rovin2
Amp TuningMatt Kitzis1
Amps and subs and stuffTyler6
My Amp Has Gone CrazyBrad Kennedy11
Amp helpjacobb2
Thoughs on Helix/Dark BlueSeth Lowe10
What should I get?Ryan Cham7
Thoughts on US Amps IS seriesMuddyWaters3
Need help with amp turning off because of current (?)GlassWolf7
Does this look right????GlassWolf3
Difference between Mono and 2 channel ampGlassWolf2
Setting the gain to match my HUGlassWolf10
Amp and sub and stuffbrad from PA1
Need amp matched Please help, Glass/Muddy/IsaacRovin6
Amp clipping problemRobert C.11
Orion vs KickerJake Hill3
Which is better ?Rovin5
Orion 1200D, Kicker 1200.1, RE 12.1Quick Shot 4ever6
Making sure I'm set...Rovin4
What kind of amp should i get?Joe Smoe7
VERY URGENT CAR ELECTRICAL SYSTEM HELP! SORRY FOR ALL CAPS!Simon J Casey9
Amp problemmatthew4
STOCK HU..GlassWolf6
Kenwood amp vs alpine amp my situation?Brandon Worcester7
Calling All Troubleshooting Experts! My system doesn't urn on!david clark7
Problem with Alpine MRD-M605 amp...Brandon Worcester16
Problems adjusting ampsmith esco6
Using a capacitor?GlassWolf4
Hooking up a mono amp with two subs?MuddyWaters15
Xtant A6001 amp Isaac W.4
1000 RMS x 1 @ 1 ohm ampsJack20
Is this goodJack18
Installation (how to install) GWolf?GlassWolf3
Amp kit for kicker 1200.1GlassWolf4
Help on everything would be a good start.GlassWolf6
Installing two amps, new subs and a capacitorGlassWolf4
Explain to me how a gain works?Justin Bailey13
Yo rovin!Rovin6
Which amp?MuddyWaters5
RE 12.1marshall white2
Kicker KX600.1 is there anyhting better than this for under $230GlassWolf4
Input SensitivityGlassWolf5
Mono Amp to Two SubsRovin3
What is your opinion on Earthquake PH2200W.4 amplifier?GlassWolf2
Good set up?GlassWolf2
Little amp to power small eclipseYoung James2
What are "Subwoofer preamp outputs"?Matt f7
Amplifierjason collins4
Help! amp has power speaker wont playjason collins4
Gain control settingsGlassWolf5
IPod boombox ?GlassWolf6
I was wonderingGlassWolf10
Cuspid 1600 ampGlassWolf6
How to hook up amp Bty mutlow2
Multi Ampsty mutlow2
Whats a Better set-up... Glass, Isaac or MuddyMuddyWaters43
Urgent help needed - clarion ampmichael mahony3
Need your advice on amp fans?mikechec92
Orion hccajayvin tonn6
Needing a cheap 1000@2ohm amp..Chauncey Brown3
Really really new and bought some stuffs I don't even know.. Rovin10
Xtant 121m?Matt f4
Installation helpTyler8
Subwoofer forum dissapeared!!???Robert3
Stuff to sell you want... JL ampscourtney W6
Hey which one of thses would i use?Anonymous22
Amp HelpMoey7
Zapco Symbilink - Just want to understandGlassWolf3
Torn between two ampsCasey Compton8
Check my new boxThrush15
What rivals this amp? glasswolf?MazdaMan9
3 subs into 1 amp (2 channel)GlassWolf4
Understanding 4 channel ampGlassWolf3
Help wiring ampRovin5
WattsGlassWolf11
??did i make a good choice??Adam7
I NEED ALOT OF HELP GlassWolf3
Hey guys, check out this crap about PPI amps and laugh!!!GlassWolf7
Glasswolf......2 sec. of your time pleaseGlassWolf2
Pioneer amplifier DIN connector diagramFraz Habib1
Help on best decisionRovin2
Question about pioneer ampRovin8
BridgingGlassWolf6
