In-Ceiling Speakers
Monitor Audio Creator Series Expands with C2L-A Angled In-Ceiling Speaker for Improved Home Theater Sound
The $750 Monitor Audio C2L-A angled in-ceiling speaker offers improved directional clarity and placement flexibility, especially for Dolby Atmos height channels.
Monitor Audio Creator Series C2L-A Angled In-Ceiling Speakers Lifestyle
Monitor Audio has announced the Creator Series In-Ceiling C2L-A, an angled architectural speaker, which expands its C2L range. The new angled version offers more precise placement and improved performance in custom installed home audio and theater systems.
Architectural audio, specifically in-wall and in-ceiling, has quietly shifted from compromise to a legitimate high-performance category. The reasons are fairly obvious. Sound quality has improved dramatically over the past decade, closing the gap with traditional loudspeakers, while more listeners want superior audio performance without turning their living spaces into showrooms. You can hear it, you just don’t have to look at it. That alone has helped reduce a lot of the domestic pushback that tends to follow large speaker purchases.
The Creator Series itself is Monitor Audio’s fourth-generation architectural lineup, covering both in-wall and in-ceiling designs aimed at custom installation. Within the ceiling category, the range is structured into three performance tiers, giving installers and buyers flexibility depending on room size, budget, and how far down the rabbit hole they want to go.
monitor-audio-c2l-a-in-ceiling-speaker-front-angle
Monitor Audio Creator Series C2L-A in-ceiling speaker
Three Tiers from Background Audio to High Performance Home Theater
Tier 1: Small, medium, and large models built for cost-effective installs, focusing on straightforward design and dependable acoustic performance.
  • Two-way configuration ​
  • C-CAM mid-bass drivers​
  • C-CAM tweeter with ​UD Waveguide ​
  • Tri-Grip II ​
  • Quik-Link
Tier 2: Small, medium, and large in-ceiling models that build on Tier 1 with upgraded acoustic performance and added flexibility, including features like boundary correction and a dual-stereo C2L-T2X option for more versatile placement.
  • RST II mid-bass drivers​
  • C-CAM tweeter with UD Waveguide II​
  • Controlled Performance​
  • Tri-Grip II ​
  • Quik-Link
Tier 3: High-performance medium and large in-ceiling models that build on Tier 2 with further acoustic refinement and advanced tuning options, including boundary compensation, mid/high-frequency cut and boost, and more sophisticated driver technologies for greater placement flexibility.
  • Three-way configuration
  • RDT III bass drivers​
  • IDC II coaxial mid/tweeter drivers​ with UD Waveguide II​
  • Tri-Grip II ​
  • Quik-Link
Pro Tip: Monitor Audio brings angled in-ceiling design down to Tier 2, adding installation flexibility and performance value without stepping up to Tier 3.
monitor-audio-c2l-a-in-ceiling-speaker-rear-angle
Why the C2L-A Is a Smart In-Ceiling Option
The C2L-A is part of the Tier 2 in-ceiling line-up for situations where standard ceiling speakers lose focus. With its angled design, it brings better clarity and direction whether it’s handling height duties in a Dolby Atmos system or anchoring a more precise multi-channel music setup.
The Basics
The C2L-A pairs a 9-inch C-CAM bass-mid driver with RST II cone geometry and a 1.25-inch C-CAM gold dome tweeter. The tweeter is mounted on a central bridge at the acoustic core of the driver and angled at 25 degrees, helping steer high frequencies toward the listening position instead of firing straight down into the carpet.
Acoustic Performance
The C2L-A provides a suite of intelligent installation features and advanced acoustic technologies, including High-frequency (HF) adjustment and boundary compensation. This enables added flexibility in speaker placement, as well as allowing it to be ‘tuned’ to the room to achieve the desired performance. This is optimal for rooms where desired placement might be difficult.
C-CAM
At the core of the C2L-A is a 9-inch C-CAM (Ceramic-Coated Aluminium/Magnesium) driver. It’s light, rigid, and responsive, which translates into lower distortion and cleaner, more detailed sound without adding unnecessary weight or sluggishness.
RST II Cone Geometry
This isn’t just cosmetic. The C2L-A uses RST (Rigid Surface Technology) II cone geometry—a hexagonal dimpled structure designed to increase stiffness and control flex across the driver. The goal is straightforward: reduce breakup and distortion so the driver stays more linear under load. In practice, that translates into tighter low-end control, cleaner midrange, and better overall clarity.
Gold Dome Tweeter
A newly designed bridge houses the angled C-CAM 1.25-inch gold dome tweeter, set at a precise 25-degree angle to focus high-frequency energy directly into the desired listening area with precise accuracy.
Installation
Monitor Audio has engineered the C2L-A for easy installation. The speaker features Monitor Audio’s patent-pending Quik-Link speaker cable connector, which supports ease and speed of installation. The Tri-Grip II dog-leg fixings have been re-engineered for a more robust, reliable, and secure fit. The “dog-leg” mechanism allows the C2L-A to be easily secured to plasterboard or dry-lined walls and ceilings.
monitor-audio-quick-link
Design
The C2L-A requires a 248mm (9.76-inch) cut-out, keeping the visual footprint relatively low for its size. It uses near-flush magnetic grilles available in black or white, with an optional square grille for more flexibility in matching room design.
C2L-A Angled In-Ceiling Speaker Specifications
Monitor Audio ModelCreator Series C2L-A
Product TypeAngled In-Ceiling Speaker
MSRP$750 each
Driver Configuration2-Way
Tweeter 1 x 1.25″ (32 mm) C-CAM tweeter
Woofer1 x 9″ (229 mm) RST II bass driver
Frequency Response, Installed (-6dB)30 Hz – 25 kHz​
Nominal Impedance8 ohm
Minimum Impedance (20Hz to 20kHz)6.4 Ohm @ 150 Hz
Sensitivity (2.83Vrms@1m, Installed)88 dB
Maximum Peak SPL* (single speaker @ 1m Z-Weighted)117 dB
Continuous Power Handling (RMS into Nominal Impedance, Pink Noise with 6dB Crest Factor)120 W
Recommended Amplifier Power (RMS into 8 OHM, Music Signal)60 – 240 W
Crossover FrequencyLF/HF: 2 kHz
Mounting Depth99 mm (37/8″)
Cut-Out Hole Diameter248 mm (93/4″)
External Dimensions (Including Grille (HWD)278 x 278 x 103​ mm
1015/16 x 1015/16 x 44/16 inches
Weight (each)2.5 kg (5 lb 8 oz)
Pre-Construction BracketCL-B
Cabinet FinishMatte black & Orange​ & Bronze
Sold AsSingle Unit with CL-Round Grille (white)
Corner SwitchOn/Off
HF Switch– /0/ +
WarrantyLifetime
The Bottom Line
In-wall and in-ceiling speakers aren’t the compromise they used to be, and Monitor Audio clearly understands where the category is headed. The C2L-A stands out because it brings an angled, more directional approach down to a Tier 2 price point, something that used to require stepping into more expensive territory. That matters if you actually care about where the sound lands, not just that it exists somewhere above your head.
That said, this is not a category with a lack of options. Brands like DALI, Focal, Theory Audio Design, KEF, and Q Acoustics are all taking this space seriously, and in some cases, pushing it hard. You still need to treat this like any other speaker purchase because once it’s in the ceiling, it’s not exactly a quick swap.
The C2L-A makes the most sense for listeners building a clean, visually unobtrusive system who still want control over imaging and placement—whether that’s for Dolby Atmos height channels or a more refined multi-room setup. Just don’t wing the install. Cutting holes first and asking questions later is a great way to learn expensive lessons.
Price & Availability
The Monitor Audio Creator C2L-A will be available in September 2026 for $750 USD per piece (£550 / €675) from Authorized Dealers. All Creator Series in-ceiling speakers come with white grilles. For those who want to ‘hide’ or ‘blend’ their integrated speakers with darker décor, black grilles are also available as an optional accessory in round and square designs. For more information, visit: monitoraudio.com.
2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
2026 NAD C 569 CD Player 2026 NAD C 569 CD Player
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
2026 Sony Walkmans 2026 Sony Walkmans
DAPs
Sony's new Walkmans for 2026 include the ZX900, WM1AM3 and WM1ZM3 hi-res digital audio players (DAPs) packed with performance and priced at a premium.
Rega Replay Turntable Rega Replay Turntable
Rega Replay turntable weighs just 2.2 kg and reportedly costs £259. How does its skeletal design compare with the Planar 1 and its rivals?
2026 Linn 343 Floorstanding Loudspeakers Lifestyle Single Malt Glasgow Collection 2026 Linn 343 Floorstanding Loudspeakers Lifestyle Single Malt Glasgow Collection
Linn's new 343 brings Pistonik bass to a compact floorstander, with Exakt Integrated and powered-bass versions starting at $67,500 per pair. Worth the premium?
2027 Naim Mu-so Utopia Lifestyle Speaker 2027 Naim Mu-so Utopia Lifestyle Speaker
In-Wall Speakers
Can Monitor Audio hide serious home theater bass? Creator Series in-wall subs use 10- and 12-inch drivers with DSP amplification up to 750 watts.
In-Ceiling Speakers
Wisdom Audio's ICS3FR in-ceiling speakers, SUB2 in-wall subwoofer and customizable P3m Series speakers enable audiophile sound that stays hidden.
What is Josh.ai VoiceCast, and how will it let existing Bluesound, NAD, PSB and other BluOS systems become part of a smarter home?
In-Ceiling Speakers
Theory Professional’s p9 Pendant Loudspeaker combines a 9-inch driver, Theorem waveguide, 120-degree dispersion, and 45Hz to 20kHz response.
Monitor Audio Radius Series 4G brings compact hi-fi speakers, on-wall models, and flexible mounting to modern homes and commercial spaces starting at $525 per...
In-Ceiling Speakers
Q Acoustics Easyfit in-ceiling speakers feature tool free spring mounting, pivoting tweeters, IPX4 rated models, and proven driver tech for Atmos and whole home...
JBL Synthesis rolls out 4 new in-wall speakers, 4 in-room speakers, 2 AV preamps, 1 AVR and 1 subwoofer. Is this the cleanest system-level...
