High-end loudspeakers have a rather inconvenient habit of getting larger, heavier, and more expensive in the pursuit of deeper bass, greater scale, and lower distortion. But not every audiophile has a dedicated listening room or wants a pair of enormous cabinets dominating the living room. Linn’s new 343 compact floorstanding loudspeaker for 2026 tackles that problem with a design built around its proprietary Pistonik driver technology, promising reference-level performance without the physical bulk of the company’s flagship 360.
Back in May 2026, the Scottish manufacturer introduced Pistonik bass driver upgrades for its 360 loudspeakers, giving existing owners access to the latest technology without replacing their speakers. The new 343 takes a different approach. Rather than adapting Pistonik to an existing design, Linn engineered the cabinet, driver arrangement, bass system, and supporting electronics around the technology from the outset. The objective is deeper, more controlled bass, reduced distortion, and the kind of scale normally associated with considerably larger loudspeakers. Whether Linn has achieved that in a smaller package will ultimately come down to listening, not marketing claims.
The 343 is available in two configurations: Exakt Integrated, a fully active loudspeaker with built-in amplification and digital crossover technology, and Passive with Active Bass (PWAB), which uses external amplification for the upper-frequency drivers while retaining dedicated internal amplification for the bass. That gives buyers a choice between a more integrated Linn system and one that accommodates existing amplification.
Linn isn’t alone in pursuing this direction. High-end manufacturers including Wilson Audio and Audiovector have been incorporating flagship engineering into more compact, room-friendly loudspeakers. The trend isn’t necessarily about making high-end audio affordable. It’s about making reference-level performance more practical for people who live in actual homes rather than acoustically treated showrooms.
Related Reading:
- Linn 360 Loudspeakers Get 2026 Pistonik Driver Upgrade, Because Scotland Still Takes Bass Personally
- Linn Klimax System: T.H.E Show 2023
Pistonik Motor Technology
Pistonik is Linn’s proprietary motor system, designed to maintain consistent force throughout a driver’s full inward and outward excursion, even when reproducing demanding, bass-heavy material. The technology combines a long-stroke motor topology with an extended magnet gap, both intended to improve linearity and reduce distortion, particularly when the driver is working hardest at low frequencies.
Pistonik is designed to address the magnetic, mechanical, and thermal issues that can compromise driver linearity. The 343’s drivers are engineered to move more air with greater control, while Linn claims its Pistonik technology delivers the widest linear excursion of any of its low-frequency drive units to date. That’s Linn’s claim, of course, not a court ruling from Edinburgh.
Magnetic Stability: Linn says the Pistonik motor assembly operates in a state of permanent magnetic saturation, helping stabilize the magnetic field within the voice-coil gap while reducing the effects of eddy currents. The objective is lower distortion, improved responsiveness, and reduced magnetic drag, potentially easing the demands placed on the amplifier.
Ventilation: Pistonik incorporates a triple-layer ventilation network designed to reduce acoustic compression within the motor structure, which can contribute to distortion and unwanted noise. By allowing air to move more freely through the driver assembly, the system is intended to support smoother diaphragm movement while minimizing audible turbulence, particularly during demanding low-frequency passages.
Thermal Cooling: Heat buildup can increase voice-coil resistance and compromise driver performance during extended listening sessions, particularly at higher volume levels. Linn addresses this with carefully engineered ventilation paths that transfer heat into the surrounding steel and aluminum structures while continuously circulating cooler air through the driver assembly. The objective is more consistent performance, even after several hours of demanding playback.
Suspension: Linn pairs its Pistonik motor system with a bespoke suspension designed to maintain precise control throughout the driver’s operating range. By carefully managing the relationship between the driver, crossover, and amplification, Linn says it can optimize the suspension more precisely than would typically be possible in a conventional passive loudspeaker. The suspension remains linear through most of its travel before stiffening rapidly and predictably as it approaches maximum excursion. This helps prevent excessive movement, reduce distortion, and protect the driver from mechanical stress at higher output levels.
Aluminum Diaphragm: Linn developed rigid, lightweight aluminum diaphragms for both its 7.5-inch and 8.7-inch drive units. Their construction is intended to push unwanted breakup modes beyond the drivers’ operating frequency ranges while keeping moving mass relatively low for improved efficiency. Linn has also optimized the connection between the diaphragm, surround, and Pistonik motor system to move resonances higher in frequency while reducing their magnitude. The goal is cleaner bass reproduction with greater control and less unwanted coloration.
Exakt Technology: Linn also incorporates its proprietary Exakt technology, which takes driver optimization beyond conventional factory tolerances. Each drive unit is individually measured using laser-based equipment to identify its specific performance characteristics. Those measurements are used to create a dedicated Exakt profile for that particular driver, allowing the system to compensate for individual manufacturing variations. It’s an unusually meticulous approach, but when you’re paying for reference-level performance, hoping that every driver behaves exactly like the one beside it isn’t much of an engineering strategy.
The Bass Driver
Pistonik gives the Linn 343 a more capable 8.7-inch bass driver than the one used in the 360, with exceptional linearity, greater excursion, and the precise control needed to deliver substantial low-frequency performance from a single drive unit. According to Linn, the improvements allow the 343 to produce deeper, more authoritative bass without sacrificing accuracy or control.
The driver is mounted in a down-firing configuration, positioned close to the floor to take advantage of the reflective acoustic boundary and distribute low-frequency energy efficiently throughout the room. This orientation also allows the full mass of the loudspeaker to resist the reactive forces generated by the bass driver, helping maintain stability during demanding passages. The objective is bass reproduction with the depth, authority, and scale normally associated with considerably larger loudspeakers, while preserving the precision and composure expected from a reference-level design.
The 7.5-inch Pistonik upper bass driver applies the same principles of low distortion, linear performance, and controlled output to the frequencies responsible for much of music’s body, weight, and presence. Its role is particularly important in reproducing the warmth and impact of instruments and vocals without sacrificing clarity or definition.
Together, the 343’s two low-frequency drivers handle approximately 70% of the loudspeaker’s acoustic workload, according to Linn. That means the benefits of Pistonik extend well beyond deep bass, influencing the speaker’s overall presentation through the upper bass and lower midrange. The objective is a more cohesive, full-bodied sound that maintains control and clarity even when the music becomes demanding.
Cabinet Design
Packing the 343’s advanced drivers, integrated electronics, and reference-level performance into a compact floorstanding speaker required some clever engineering. Linn designed the cabinet to balance acoustic performance, structural rigidity, and understated styling without allowing one to compromise the others.
The 343’s curved cabinet is designed to reduce diffraction, allowing sound to disperse more evenly while minimizing the acoustic effects that can reveal a loudspeaker’s position in the room. Linn says reflected sound also retains a tonal character closer to the direct sound, improving imaging stability, spatial precision, and consistency across a wider listening area.
The cabinet’s distinctive sine wave-inspired lower edge is more than a styling exercise. It plays an integral role in the 343’s down-firing bass architecture while giving the loudspeaker some welcome visual personality. Not every high-end speaker needs to resemble a refrigerator with expensive drivers.
The 343’s 8.7-inch down-firing Pistonik bass driver requires carefully controlled internal volume and geometry, which Linn accommodates without widening the front baffle. A glass-fiber-reinforced molding compound provides the stiffness and density needed for thinner cabinet walls, freeing up space for the bass system and integrated electronics while maintaining structural integrity.
Exakt Integrated
The Linn 343 Exakt Integrated is a fully active, four-way floorstanding loudspeaker with its amplification, digital crossover, DACs, and power supply built directly into each speaker. Its rear electronics module houses Linn’s Utopik power supply, Exakt digital crossover, Organik DACs, Power DAC technology for the bass system, and Class A/B amplification with Adaptive Bias Control for the upper-frequency drivers.
This eliminates the need for external power amplifiers, separate DACs, or a conventional speaker crossover. The 343 receives its digital audio signal through Exakt Link, which requires a compatible Linn network music player or System Hub. Linn’s electronics then handle signal processing, digital-to-analog conversion, and amplification for the individual drivers. It’s a tightly integrated approach designed to minimize signal degradation while giving Linn precise control over the entire loudspeaker system.
The Passive with Active Bass (PWAB) variant shares the same Pistonik 7.5-inch and 8.7-inch drive units with the Exakt Integrated variant, and Utopik and Power DAC for the bass system, with the 343 array comprising upper bass, midrange and tweeter units driven instead by external amplification. A PWAB pair requires an Exaktbox and six channels of amplification to operate in an Exakt system.
Comparison
| LINN Model | 343 Exakt Integrated | 343 Passive with Active Bass (PWAB) |
| Product Type | Compact Floorstanding Speaker | Compact Floorstanding Speaker |
| Price (pair) | $97,500 | $67,500 |
| Speaker Type | 4-way floor-standing | 4-way floor-standing |
| Exakt | Yes | Yes – with ExaktboXLR (for Active Bass) x1 x and 6 amp channels |
| Crossover | Exakt Digital | Three-way analogue passive with active bass |
| 343 Array | Class AB with Adaptive Bias Control | Separate amplification required |
| Bass System | Power DAC and Pistonik motor system | Power DAC and Pistonik motor system |
| Room Correction | Space Optimization+ | Space Optimization with a Linn DSM |
| Tweeter | 19 mm (0.75-in) thin-ply woven carbon dome | 19 mm (0.75-in) thin-ply woven carbon dome |
| Midrange | 64 mm (2.25 inch thin-ply woven carbon dome | 64 mm (2.25 inch thin-ply woven carbon dome |
| Upper Bass | 190 mm (7.5-in) aluminium diaphragm with Pistonik | 190 mm (7.5-in) aluminium diaphragm with Pistonik |
| Lower Bass | Down-firing 220 mm (8.7 in) aluminium diaphragm with Pistonik | Down-firing 220 mm (8.7 in) aluminium diaphragm with Pistonik |
| Connections | Exakt Link x 2 Binding Post n/a XLR (for Active Bass) n/a | Exakt Link x1 (for external Exakt operation) Exakt Link x1 (for external Exakt operation) |
| Cabinet Volume | 43 litres | 43 litres |
| Dimensions (WHD (with Stand) | 338 x 1091 x 466 mm 13.31 x 42.95 x 18.35in | 338 x 1091 x 466 mm 13.31 x 42.95 x 18.35in |
| Weight (with stand) | 51.6 kg / 114 lbs | 45.5 kg / 100 lbs |
| Finish Options | The Glasgow Collection – Clyde Built, Single Malt, Linn Heritage The Signature Collection -Triton The Classic Collection – Piano Black, Alpine White Custom – n/a Trim – Black | The Glasgow Collection – Clyde Built, Single Malt, Linn Heritage The Signature Collection -Triton The Classic Collection – Piano Black, Alpine White Custom – n/a Trim – Black |
The Bottom Line
Following the successful Pistonik upgrade for its flagship 360, Linn has taken the next logical step with the new 343. This is the first loudspeaker designed around Pistonik technology from the outset, rather than adapting it to an existing platform. The redesigned bass architecture replaces the 360’s two front-facing woofers with a single 8-inch nominal down-firing driver, supported by a dedicated upper-bass unit. At approximately 43 inches tall, the 343 is only two inches shorter than the 360, but its narrower cabinet and smaller footprint make it easier to accommodate in a domestic listening space.
Of course, Linn’s definition of compact comes with a rather substantial price tag. The 343 Exakt Integrated costs $97,500 per pair, while the Passive with Active Bass (PWAB) version is $67,500 per pair. The fully active model includes Linn’s proprietary digital crossover, DACs, and amplification, while PWAB gives owners greater flexibility to use external amplification for the upper-frequency drivers. Adding Exakt processing and suitable amplification to PWAB can narrow that $30,000 price difference considerably, although the final cost depends on the components selected.
Competition at this level is hardly insignificant. The Steinway & Sons Model C offers elegant styling, extraordinary output capability, sophisticated room calibration, and a fully active architecture. Meanwhile, the ATC EL50 Anniversary ($99,999 per pair) takes another approach with proprietary drivers, discrete Class A/B amplification, and the studio heritage that has made ATC a reference for decades.
The 343’s greatest strength may be how thoroughly Linn has integrated its technologies into a relatively compact loudspeaker. Pistonik, Exakt, Organik, and the company’s active bass architecture are designed to operate as a complete system rather than a collection of expensive components. Whether that integration delivers superior sound quality remains to be heard, particularly against such formidable competitors.
For affluent music lovers who want a reference-level system without surrendering the entire living room, the 343 is certainly worth investigating. Linn has managed to shrink the loudspeaker’s footprint. The invoice, unfortunately, remains full-sized.
Pricing & Availability
Both 343 Exakt Integrated and Passive with Active Bass (PWAB) models are available to order in six finishes: Triton, Single Malt, Clyde Built, Linn Heritage, Piano Black and Alpine White. All six finishes are available exclusively with black array trims.
- Linn 343 Exakt Integrated – US $97,500 (pr)
- Linn 343 PWAB – US $67,500 (pr)
Many Linn specialists across the company’s global dealer and distribution network have already taken delivery of 343, providing prospective customers the ability to experience the loudspeaker at their convenience.
Related Reading:
- Best Floorstanding Loudspeakers: Editors’ Choice 2025
- Fyne Audio F1-10 Anniversary Puts Glass and SuperTrax Into Its $50,000 Scottish Flagship
- Audiovector R 5 Arreté Floorstanding Speaker Debuts with Flagship R 10 Technology for $24,500
- AUER Acoustics Brings Versura Speakers to America: German Tankwood Cabinets Hit the US High-End Scene
