Audiovector R 5 Arreté Floorstanding Speaker Debuts with Flagship R 10 Technology for $24,500
Audiovector R 5 Arreté brings R 10 flagship tech, 23 Hz bass, and Danish build quality to a new high-end floorstanding loudspeaker.
Audiovector R 5 Arrete Loudspeakers Lifestyle
Audiovector has added another serious floorstanding loudspeaker to its Arreté lineup, and no, “middle of the line” does not mean modest. The Danish brand, already known for models such as the R 10, R 8, R 6 Arreté, and the Trapeze Reimagined that we reviewed, has introduced the new R 5 Arreté at $24,500 per pair. It sits below the larger models in the range, but borrows key technology and design thinking from the flagship R 10 in a smaller, more room friendly package. This is Danish restraint, not Danish charity.
3.5-Way Design with Serious Bass Firepower
The R 5 Arreté uses a 3.5-way configuration, with its twin bass drivers assigned different roles rather than simply doubling up. One driver, labeled as the lower mid, covers the full bass range, while the second bass driver is dedicated to the deepest low frequencies. That is where the extra “.5” comes in. Two rear-facing ports provide additional low-frequency support, so placement will matter.
audiovector-r5-arrete-loudspeaker
The bass driver and rear port system are designed to deliver what Audiovector describes as bass that is both “deep and powerful,” while the dedicated midrange driver is intended to keep the presentation “clean, fast, and transparent.” The goal is not just more low end for the sake of it, but bass with better control, speed, and less muddiness bleeding into the midrange. Because nobody spends $24,000 to hear the speaker trip over its own trousers.
Audiovector also uses its Accelerated Force Concept for the bass and midrange driver structure. The company says this helps the drivers start and stop with greater precision, reducing distortion and improving physical impact without slowing the presentation down. In practical terms, the engineering is intended to keep the bass from overwhelming the midrange, which matters when a speaker is trying to sound big without turning vocals into soup.
The R 5’s drivers also use titanium voice coils, along with carbon fiber and natural resin sandwich cone materialsinherited from the flagship R 10.
AMT Tweeter
Moving up top, the R 5 Arreté uses an AMT tweeter, inspired by Dr. Oskar Heil’s original Air Motion Transformer design. Audiovector integrates it with its Soundstage Enhancement Concept, which is designed to manage rear radiation and improve dispersion. The goal is cleaner, more open treble with better soundstage width and focus.
audiovector-r5-arrete-tweeter
The R 5’s AMT tweeter covers a claimed 2,800 Hz to 53,000 Hz range, extending well beyond the limits of human hearing. That does not mean listeners will hear 53 kHz, but it can indicate a tweeter designed for wide bandwidth, low distortion, and cleaner behavior within the audible range. The goal is high-frequency detail, precise imaging, and a more open soundstage without turning the treble into a spotlight.
Controlled Damping
The R 5 Arreté also uses a flexible damping system designed to control cabinet resonance and manage how stored energy is released. The goal is a quieter, more stable enclosure that lets the drivers do the work without the cabinet adding its own commentary. The result should be a cleaner, calmer presentation with less unwanted coloration.
Damping feature settings include:
  • Position 1: Optimized for use with transistor amplifiers with a medium damping factor.
  • Position 2: Optimized for high-power transistor amplifiers with a high damping factor.
  • Position 3: Optimized for tube amplifiers with a low damping factor.
audiovector-r5-arrete-loudspeaker-rear-inputs
Danish Craftsmanship
Each R 5 Arreté cabinet is hand built in Denmark with a narrow front baffle designed to reduce edge diffraction and support more precise imaging. The plinths, precision milled spikes, and integrated decoupling system are also intended to control unwanted resonance and improve mechanical stability.
The enclosure is heavily braced and constructed from high density hardwood fibreboard, combining rigidity with internal damping. Audiovector also uses mechanical grounding and precision driver mounting to reduce unwanted energy transfer between the cabinet, drivers, and supporting structure.
Just as important, the internal damping is optimized rather than overdone. The goal is to suppress cabinet resonance without choking dynamics. The narrow baffle further helps with smoother off axis response and sharper stereo focus, allowing the R 5 Arreté to disappear more effectively into the soundstage when properly positioned.
According to Renaissance Managing Director John Carroll: “We are delighted to launch the R5 Arreté. It’s a Danish masterclass in sound, styling, and design that really hits the sweet spot.
Audiovector Arreté Speaker Line Comparison
Audiovector ModelR 5 Arreté (2026)R 10 Arreté (2025)R 8 Arrêté (2019)R 6 Arrêté (2020)R 3 Arrêté (2019/2020)R 1 Arrêté (2020)
Product TypeFloorstanding SpeakerFloorstanding SpeakerFloorstanding SpeakerFloorstanding SpeakerFloorstanding SpeakerBookshelf Speaker
Price (pair)$24,500 $160,000$70,000/$90,000$19,000/$39,000$10,000/$13,500+$7,900/$8,100
Driver Configuration3.5 Way3-way /Bass Reflex5-way / Bass Reflex4.5-way /Basds Reflex2.5-way /Bass Refex2-way / Bass Reflex
Frequency Response23-53 kHz21 Hz – 53 kHz 22-52 kHz23 Hz – 52 kHz23-53 kHz38-53 kHz
Average Impedance8 Ohms8 Ohms 8 Ohms8 Ohms8 Ohms 8 Ohms
Minimum Impedance6.5 Ohms5 Ohms 2.5 ohmsNot Indicated3.9 ohmsNot Indicated
Sensitivity90 dB/W90 dB / 1W 92,5 dB/W/m91,5 dB/W/m90.5 dB/W/m87 dB/W/m
Crossover Frequencies200 Hz
600 Hz
2.800 Hz
180 Hz
450 Hz
3,000 Hz
20,000 Hz
100 Hz
250 Hz
3000 Hz
100 Hz
350 Hz
3000 Hz
320 Hz
2900 Hz
2900 Hz
Bass Drivers1 x 6.5″ AFC carbon sandwich8 × 5″ long-throw, low-distortion 8+6,5” Isobaric Bass System8+6,5” Isobaric Bass ReflexFloor bass reflexBass reflex
Lower Mid/Upper Bass drivers1 x 6.5” AFC carbon sandwich2 × 6.5″ AFC carbon sandwich 6.5 “ Carbon6.5“ Carbon2 x 6.5 “ Carbon1 x 6.5 “ Carbon
Mid Drivers1 x 6.5” AFC carbon sandwich1 × 6.5″ AFC carbon sandwich 1 x 4” Rear Driver1 x 3” Rear Firing midrange driver PaperN/AN/A
Tweeter1 x 3800mm2 AMT N511 x Main Tweeter: 3,800 mm AMT N51
1 x Extended Tweeter: 3,800 mm² AMT N51
1 x Front AMT Tweeter
1 x Rear R 8 AMT Quasi Tweeter
1 x Front R R AMT Arreté 1 x Front R R AMT Arreté1 x Front R R AMT Arreté
Connection TerminalsHigh Current Gold-plated copper/brass binding posts for 4mm plugs or spadeHigh Current Nextgen Bi-Wire (compatible with 4mm plugs or spades High Quality – Bi-Wire (compatible with 4mm plugs or spades High Quality – Bi-Wire (compatible with 4mm plugs or spades 5-Way Binding Posts3-Way Binding Posts
Dimensions (HWD)111 x 22 x 41cm
43.7 x 8.66 x 16.1 inches
(with plinth width and depth 26cm x 48cm)
156  × 36.5  × 62.7 cm
61.4 x 14.37 x 24.69 inches
(without spikes)
144.2 x 32.7 x 53.3 cm
56.8 x 12.9 x 21 inches
123.4 x 27.8 x 43.1 cm
48.85 x 10.94 x  16.97 inches
103.4 x 23 x 36 cm
40.71 x 9.06 x 14.42 inches
37 x 19,6 x 29 cm
14.6 x 7.72 x 11.4 inches
Weight (each)32.1 kg
70lbs 12oz
95 kg
209 lbs
72.6 kg
160 lbs
39.3 kg
88 lbs
22.67-24kg
49.9 to 53lbs
10 kg
22 lbs
FinishesPiano Black
White Silk
African Mahogany
Piano
Italian Walnut
Custom paint finishes available on request.
Canadian Birdseye
Maple
African MahoganyCrotch
Italian Walnut Burl
All piano lacquered; custom finishes are available on request
Italian Walnut
Burl Piano
Italian Grey Piano
Black Piano
White Piano
African Rosewood
Piano
Black Piano
Italian Walnut Matte
White Piano
African Rosewood
Black Ash
Italian Walnut
White Silk
 All piano lacquered custom finishes are available on request
African Rosewood
Black Ash
Italian Walnut
White Silk
audiovector-r5-arrete-loudspeakers-front-back
The Bottom Line
The Audiovector R 5 Arreté is not the flagship, but that is also the point. At $24,500 per pair, it brings several technologies from the $160,000 R 10 Arreté into a smaller, more attainable floorstanding loudspeaker. “Attainable” is doing some heavy lifting, but after hearing so many six figure loudspeakers at AXPONA 2026, the R 5 almost looks restrained. Almost.
What makes the R 5 interesting is the combination of 3.5 way architecture, AMT tweeter with SEC, carbon fiber and natural resin sandwich cone materials, titanium voice coils, rear ported bass support, and a hand built Danish cabinet with serious resonance control. On paper, the 23 Hz to 53 kHz frequency response and 90 dB sensitivity suggest a speaker designed for scale, speed, and detail without requiring a nuclear reactor in the equipment rack.
Who is it for? Serious audiophiles with real rooms, real systems, and the budget to shop in the $20,000 to $30,000 loudspeaker category. The R 5 will have to compete with strong options from Wilson Audio, DALI, ATC, Dynaudio, and others, but based on our experience with Audiovector’s other models, this one belongs on the audition list. At this level, the spec sheet opens the door. The listening room decides whether it stays there.
Price & Availability
The R 5 Arreté will be available at Audiovector Authorized Dealers starting July 2026, in Piano Black, White Silk, African Mahogany Piano, and Italian Walnut finishes, priced at £17,950 ($24,500 US). Custom paint finishes are available on request.
Pro Tip: All other Audiovector speakers are currently available through Authorized Dealers
Coastal Source Outdoor Speaker with VIA Lighting
Can Coastal Source turn the backyard into a true high-end system? Its CEDIA 2026 lineup combines outdoor audio, lighting and simplified power.
IDEON Audio Nous Streamer / DAC / Preamplifier Front View IDEON Audio Nous Streamer / DAC / Preamplifier Front View
Can IDEON justify $35,000 for the Nous streamer/DAC/preamp when so many capable digital front ends cost far less?
Monitor Audio Creator Series In-Wall Speakers and Subwoofer Monitor Audio Creator Series In-Wall Speakers and Subwoofer
In-Wall Speakers
Can Monitor Audio hide serious home theater bass? Creator Series in-wall subs use 10- and 12-inch drivers with DSP amplification up to 750 watts.
2026 TCL A300L Art TV Lifestyle Front 2026 TCL A300L Art TV Lifestyle Front
Which TCL Designer Series Art TV fits your room better: the ultra-matte A300L QLED or the higher-performance A400U QD-Mini LED?
Sonance SBXL-100 Soundbar Lifestyle with 65-inch TV Sonance SBXL-100 Soundbar Lifestyle with 65-inch TV
Can serious home theater disappear into the room? Sonance pairs an 82.7-inch soundbar with redesigned PowerPipe X hidden subwoofers.
TAD A1000D-S Front With Remote Control TAD A1000D-S Front With Remote Control
Can TAD modernize a high-end integrated amp without turning it into a streamer? The 250W A1000D adds DSD256 and D700 clock technology.
Can 64 Audio’s $3,999 Ocean flagship IEM justify its price with isobaric bass and 32 passive tuning combinations?
What did Focal and Naim bring to Audio Advice Live 2026? A $210K Diva Alta Utopia, Scala’s North American debut, Hekla and a $5,297...
What is Playback Distribution bringing to Audio Advice Live 2026? Three rooms featuring a Vienna Acoustics North American loudspeaker debut, PMC Speakers, CANVAS HiFi,...
Loudspeakers
Can OJAS bring new listeners to high-end audio? Devon Turnbull’s Cooper Hewitt listening room shows why the industry needs to leave its bubble.
