Goldmund’s $500,000 Telos 9800 Delivers Over 1,500 Watts Because Apparently Power Has a Penthouse
Goldmund’s Telos 9800 delivers 1,560 watts into 8 ohms and costs about $500,000 per amplifier. What makes this Swiss flagship different?
Goldmund Telos 9800 Amplifier - Front, Front Angle, Rear Views
Goldmund has introduced the Telos 9800, a new flagship mono power amplifier that delivers more than 1,500 watts and represents the most advanced amplifier the Swiss company has developed to date. With a $500,000 asking price, one might reasonably wonder whether it also includes a chalet in Gstaad, a numbered bank account, and someone to explain the purchase to your mistress in Geneva.
The Telos 9800 builds on the foundation of the Telos 8800, introduced in 2023, while incorporating new design and engineering developments that move it above both that model and the recently launched “midrange” Telos 4800. Goldmund does not replace its flagship amplifiers very often, so the Telos 9800 will likely remain at the top of the company’s lineup for several years.
The Swiss Touch
Engineered and assembled in Switzerland, the Telos 9800 is built around an entirely new amplification platform. Its power supply and amplification stages are housed in separate but interconnected units, allowing each section to operate under optimal conditions while reinforcing the system’s overall mechanical and electrical integrity.
goldmund-telos-9800-amplifier-power-supply-separation
Designed with a symmetrical signal path from input to output, the Telos 9800 is intended to preserve signal integrity while minimizing electromagnetic interference and unwanted noise. It remains stable into loads as low as 1 ohm and incorporates comprehensive protection systems designed to maintain reliability under demanding operating conditions.
Developed in collaboration with designer Cécile Barani, the Telos 9800 introduces a new visual direction for Goldmund. Its two-part form mirrors the physical separation of the power supply and amplification stages, giving the amplifier a functional relationship between its internal architecture and exterior design. Precision-machined aluminum surfaces, a new digital interface, and a restrained gold accent complete a look that is notably more architectural than Goldmund’s previous flagship amplifiers.
Taken together, Goldmund says these design and engineering changes allow the Telos 9800 to deliver high output with greater control, particularly during demanding musical passages and large dynamic swings. The company also claims improvements in low-level detail, clarity, and overall precision, although those performance claims will ultimately depend on the associated system, loudspeakers, and listening environment.
goldmund-telos-9800-inputs
What Makes the Goldmund Telos 9800 Different
Power Output: The Telos 9800 delivers 1,560 watts RMS into 8 ohms, with a specified total harmonic distortion (THD) of 0.005% from 20 Hz to 20 kHz.
Dynamic Range: Goldmund specifies a dynamic range of 117 dB, measured with a 22 kHz bandwidth, which is intended to preserve low-level detail across a wide range of listening levels.
Damping Factor: The Telos 9800 has a specified damping factor of 900 at 1 kHz and an output noise floor of less than 3 μV, both of which are intended to support low noise and strong loudspeaker control.
Gain: Amplifier gain is adjustable in 3 dB increments, allowing users to better match the Telos 9800 with different source components and system configurations.
Analog Signal Path: The Telos 9800 uses a fully analog signal path from input to output and incorporates thermal and short-circuit protection. An automatic shutdown system is designed to protect both the amplifier and connected loudspeakers in the event of an operating fault.
Connections: The Telos 9800 includes analog and digital inputs, including RCA and XLR connections. The rear panel also features multiple loudspeaker binding posts, a ground-lift switch, a universal power connection, and a 12-volt trigger input for external control.
Power Management System: Goldmund’s proprietary power-management system combines 10 kVA of transformer capacity with the largest capacitor bank the company has developed to date, providing 648 mF of stored energy. Custom capacitors, in-house-designed transformers, and a redesigned amplification stage using next-generation power boards are intended to improve stability, instantaneous current delivery, and loudspeaker control under demanding loads.
Goldmund Telos Mono Power Amps Comparison
goldmund-telos-9800-8800-4800
Telos 9800 (2026)Telos 8800 (2023)Telos 4800 (2024)
PriceUS – $500,000
CHF – 400,000
GB – £370,000
AUS – $800,000
US – $366,000
CHF – 320,000
GB – £350,000
AUS – $650,000
US – $260,000
CHF – 220,000
GB – £235,000
AUS – $445,000
Amplifier TypeMono Power AmplifierMono Power AmplifierMono Power Amplifier
Power Output (IEC60065)1560 Wrms on 8 Ω / 1 % THD1400 Wrms on 8 Ω / 1 % THD1400 Wrms on 8 Ω / 1 % THD
Dynamic RangeNot Provided22 kHz measurement bandwidth (flat), true RMS unloaded: 117 dB22 kHz measurement bandwidth (flat), true RMS unloaded: 117 dB
Damping Factor900 at 1 kHz / 8 Ω 600 at 1 kHz / 8 Ω600 at 1 kHz / 8 Ω
DistortionIMD (SMPTE), unloaded: < 0.01 %
THD+N unloaded: < 0.005 % from 20 Hz to 20 kHz at 30 Vrms output
Output Noise FloorAnalog input terminated with RCA Shorting Caps, unloaded: < 3 V from 20 Hz to 20 kHz Analog input terminated with RCA Shorting Caps, unloaded: < 3 μV from20 Hz to 20 kHzAnalog input terminated with RCA Shorting Caps, unloaded: < 3 μV from 20Hz to 20 kHz
Gain35 dB, +/- 9 dB (adjustable in steps of 3 dB for each input)35 dB, +/- 9 dB (adjustable in steps of 3 dB for each input)35 dB, +/- 9 dB (adjustable in steps of 3 dB for each input)
Input LevelsMax level before clipping
Analog input: 2 Vrms
Digital input: 0 dBFS
Output LevelsMax level before clipping: 1% THD, unloaded: 375 Vpp Max level before clipping: 1% THD, unloaded: 300 VppMax level before clipping: 1% THD, unloaded: 300 Vpp
Audio Inputs Analog input RCA unbalanced connector
Analog input XLR balanced connector
Digital input (RCA connector)
Audio Outputs2 x speaker output binding posts (red & black)
1 x output Goldmund speaker 4B type connector
Digital Output (RCA Connector)
Additional Rear Panel ConnectionsPower cord: universal socket 3 lugs, 16 A
Main fuses
AC black GND
Binding post (with bridge connection)
Green-yellow AC earth binding post (with bridge connection)
RS232 command connector
Main fuses
AC black GND binding post (with bridge connection)
Main fuses (F1: 2.5A ; F2: 1A F3: 8A)
Ground lift switch.
Jack connector for 12 Volt Trigger
Power SupplyNominal line voltage: 115 V or 230 V
Input voltage range: +/- 5 %
Input voltage range: +/- 10 %
Power ConsumptionNot ProvidedIEC 60065, 1/8 Output Power at 8 Ω: 750 WIEC 60065, 1/8 Output Power at 8 Ω: 680 W
Finish OptionsNot ProvidedBlack,  Silver GreyStandard – Grey
On Request – Black
Dimensions (WxHxD)
50 x 136.7 x 50 cm
20 x 63.18 x 20 inches
42 x 113 x 47 cm
16.6 x 44.5  x 18.5 inches
42 x 82.6 x 50 cm
16.6 x 32.6 x 20 inches
Weight360 kg
794 lbs
265 kg
584 lbs
195 kg
430 lbs
The Bottom Line
The Goldmund Telos 9800 occupies a rather lonely corner of the high-end audio market where 1,560 watts into 8 ohms, stability down to 1 ohm, a 10 kVA power supply and 648 mF of energy storage are considered reasonable engineering targets. Its new two-unit architecture, which physically separates the power supply from the amplification stage, is arguably more interesting than the headline power figure because it shows how far Goldmund was willing to go to improve isolation, current delivery and thermal management.
There are alternatives at this level, most notably the Dan D’Agostino Relentless Epic 1600, Boulder 3050 and CH Precision M10, although each approaches the problem somewhat differently. Anyone spending $500,000 on amplification is well beyond conventional notions of value, and system matching becomes far more important than shopping from a specification sheet.
For that reason, Goldmund’s own passive loudspeakers are probably the safest and most logical place to start. Models such as the Tethys Passive keep the amplifier and loudspeaker within the same engineering ecosystem, whereas Goldmund’s flagship Gaia and Apologue speakers already incorporate their own Telos amplification and therefore do not require the 9800.
Is the Telos 9800 necessary? Of course not. Neither is a penthouse overlooking Lake Geneva. At this altitude, that stopped being the point several hundred thousand dollars ago.
Price & Availability
The Goldmund Telos 9800 is priced at CHF 400,000 per unit, approximately £370,000, €430,000, or $500,000 USD.
For more information: goldmund.com
2026 Steinway & Sons Model O Loudspeaker near wall lifestyle
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
Goldmund's Mimesis Statement uses three chassis, separate channel power supplies and redesigned analog circuitry. A flagship with a startling price.
Can 64 Audio’s $3,999 Ocean flagship IEM justify its price with isobaric bass and 32 passive tuning combinations?
What did Focal and Naim bring to Audio Advice Live 2026? A $210K Diva Alta Utopia, Scala’s North American debut, Hekla and a $5,297...
What is Playback Distribution bringing to Audio Advice Live 2026? Three rooms featuring a Vienna Acoustics North American loudspeaker debut, PMC Speakers, CANVAS HiFi,...
Loudspeakers
Can OJAS bring new listeners to high-end audio? Devon Turnbull’s Cooper Hewitt listening room shows why the industry needs to leave its bubble.
Klipsch debuts Reference Premiere III at Audio Advice Live 2026 with Onkyo, a 7.4.4 Atmos system, anniversary Klipschorn and Rebellion.
