64 Audio Ocean Flagship IEM Brings 32 Tuning Options to CanJam SoCal 2026
Can 64 Audio’s $3,999 Ocean flagship IEM justify its price with isobaric bass and 32 passive tuning combinations?
64 Audio Ocean IEMS in-hand
Buying a flagship IEM usually means accepting somebody else’s idea of what $4,000 worth of “perfect” should sound like. Want a little more bass or less treble afterward? Welcome to EQ, tip rolling, cable swapping, and the kind of late-night Head-Fi behavior that makes normal people question our priorities.
64 Audio’s new Ocean takes a different approach. The $3,999 universal-fit flagship combines six drivers, dual isobaric dynamic woofers, the company’s tia and apex technologies, and a new Passive Acoustic Control system that offers as many as 32 acoustic configurations without DSP or electronic EQ.
Ocean will be available to audition at CanJam SoCal 2026, August 29–30 at the Irvine Marriott.
Who Is 64 Audio?
Founded by Vitaliy Belonozhko, 64 Audio began life as 1964 Ears and grew from a family-run custom-monitor business into one of the more influential American IEM manufacturers.
64 Audio Logo
Products including the U12t, Nio, Fourté, and A12t helped build the brand, but its real calling card has been proprietary technology. tia removes conventional acoustic tubing from portions of the driver path, apex manages pneumatic pressure inside the ear canal, and LID is designed to minimize frequency-response changes caused by different source impedances.
The Fourté, introduced during 64 Audio’s original tia push in 2016, has remained one of its best-known flagships. Ocean now sits above it in the universal lineup.
Six Drivers, But That Is Not the Main Story
64audio-ocean-iems-back
Ocean uses a 6-driver, 4-way architecture:
  • Two cone-to-cone isobaric dynamic drivers for bass
  • Two balanced-armature midrange drivers
  • One balanced-armature high-mid driver
  • One tia high-frequency driver
64 Audio specifies a 5Hz-22kHz frequency response, 9.5-ohm impedance, and 103.7dB/mW sensitivity.
The dual dynamic woofers operate in a cone-to-cone isobaric configuration, which 64 Audio says provides powerful low-frequency output while maintaining control and reducing unwanted distortion.
Driver count alone, however, stopped being especially meaningful somewhere around the time manufacturers began treating IEM shells like Manhattan studio apartments.
What makes Ocean more interesting is what surrounds those drivers.
64audio-ocean-iems-nozzle
64 Audio’s new Passive Acoustic Control system lets users physically change several aspects of the IEM’s acoustic behavior.
Two interchangeable tia screens adjust high-frequency damping. Four rear vent filters alter the pneumatic loading of the isobaric bass drivers. Four interchangeable apex modules — mX, m12, m15, and m20 — change isolation and pressure relief.
Taken together, those components create up to 32 possible combinations.
Ocean is not magically 32 completely different IEMs, but the system gives owners considerably more control over bass response, upper-frequency energy, isolation, and pressure without depending on an app or digital processing.
For a $3,999 IEM, that flexibility makes considerably more sense than being locked into one tuning and hoping your ears agree with the engineer who designed it.
64audio-ocean-iems-wired-coil
Design and Accessories
Ocean uses a T6061 aluminum shell with a machined faceplate finished in Champagne Copper. Its pattern is inspired by aeolian ripples formed when wind moves across sand.
Compared with some flagship IEMs covered in gemstones, exotic woods, and enough decorative metal to furnish a casino lobby, the Ocean looks relatively restrained.
It uses standard 0.78mm two-pin connectors and ships with both 3.5mm and 4.4mm balanced cables constructed from silver-plated UP-OCC copper.
The package also includes TrueFidelity foam tips, SpinFit silicone tips, standard silicone tips, a carrying case, cleaning accessories, and all four apex modules.
Specifications
  • Model: 64 Audio Ocean
  • Type: Universal-fit IEM
  • Drivers: 6, four-way architecture
  • Bass: Dual isobaric dynamic drivers
  • Midrange: 2 balanced-armature drivers
  • High-Mid: 1 balanced-armature driver
  • Treble: 1 tia driver
  • Frequency Response: 5Hz–22kHz
  • Impedance: 9.5 ohms at 1kHz
  • Sensitivity: 103.7dB/mW at 1kHz
  • Isolation: 10-20dB depending on apex module
  • Connector: 0.78mm two-pin
  • Included Cables: 3.5mm and 4.4mm balanced
  • Finish: Champagne Copper
Competition
At $3,999, Ocean swims in very expensive water.
For a thousand dollars less, the UE Premiere feature 21 drivers per earpiece with a five-way crossover, and come in universal and custom fit options.
The Noble Audio Kronos at $4,500 combines dual dynamic woofers with balanced-armature and electrostatic drivers, putting it squarely in the same ultra-premium category.
Ocean also competes with 64 Audio’s own products.
The Astell&Kern x 64 Audio XIO costs $3,000 and uses ten drivers, while the long-running Fourté remains available for $3,599. Anyone already considering either model will need to decide whether Ocean’s adjustable acoustic system is worth moving further up the ladder.
And that is really the point: at this level, counting drivers is pointless. The meaningful difference is what a manufacturer does with them.
64audio-ocean-iems-lifestyle
64 Audio Ocean
The Bottom Line
The 64 Audio Ocean is entering a flagship IEM market where $3,000-plus products have become surprisingly common and manufacturers need more than extravagant materials and large driver counts to stand out.
Ocean’s dual isobaric bass system, tia architecture, apex modules, and LID technology give it serious technical credentials, but Passive Acoustic Control is its most distinctive feature. Being able to tailor the physical acoustic system without DSP gives buyers unusual flexibility at a price where flexibility should probably be expected.
Whether Ocean actually sounds better than the Fourté, XIO, FiR Redux 6, or Noble Viking Prestige will require listening rather than counting acronyms.
Fortunately, CanJam SoCal begins this weekend.
For more information: 64audio.com
The $519 EPZ 550 pairs five balanced-armature drivers with striking metalwork and refined sound, but its polite bass won't satisfy everyone.
DUNU PRS6 brings MEMS technology to a refined tribrid IEM with strong resolution, clean treble and a clear focus on competitive gaming.
Can Sony’s $120 IER-M500 professional in-ear monitors deliver the sound, comfort, and durability working musicians need?
Melody Wings’ $188 Uranus delivers airy, resolving sound from a quadbrid driver array, but BCD ringing and sharp treble may divide listeners.
The Juzear Light Shuttle combines tribrid drivers, strong sub-bass, clear mids and smooth treble in a competitive sub-$200 IEM.
$99 Bose Noise Cancelling Wired Earbuds arrive in 2026 with ANC, USB-C and no battery. Did the company that helped kill the cable just...
Affordable IEMs for musicians and audio professionals feature balanced tuning, durable construction, and a stage-ready design.
