Bose Returns to Wired Earbuds After 11 Years With Noise Cancellation and USB Type-C
$99 Bose Noise Cancelling Wired Earbuds arrive in 2026 with ANC, USB-C and no battery. Did the company that helped kill the cable just make it cool again?
2026 Bose Noise Cancelling Wired Earbuds Lifestyle
Bose spent much of the past decade helping convince consumers that wires were something personal audio could happily live without. Apparently somebody forgot to tell the next generation.The new Bose Noise Cancelling Wired Earbuds mark the company’s first new wired earphones in 11 years, combining a USB Type-C connection with Bose QuietControl active noise cancellation, Aware Mode, lossless audio support, and no battery that needs to be charged.
At $99, they arrive at a moment when wired headphones and IEMs are enjoying a very real resurgence rather than merely becoming another retro fashion accessory.
We saw that firsthand at CanJam NYC 2026, where roughly three dozen IEM brands crowded the show floor and the listening tables remained packed throughout the weekend. Wireless earbuds still dominate mainstream portable audio, but younger listeners and audiophiles are increasingly rediscovering what a cable offers: simplicity, low latency, potentially better sound quality, and freedom from wondering whether the left earbud remembered to charge overnight.
The timing makes Bose’s move even more interesting. Just 11 days earlier, the company introduced two new wireless open-ear models — the $199 Sport Open Earbuds and $299 Ultra Open Earbuds (2nd Gen). Bose is therefore not abandoning wireless listening; it is covering both sides of a personal-audio market that suddenly looks a lot less interested in choosing sides.
There is some historical symmetry here as well. Bose introduced the QuietComfort 20 wired noise-cancelling earphones in 2013 and updated them in 2015, long before true wireless earbuds became the default choice for millions of listeners. More than a decade later, Bose is returning to the cable with a much simpler proposition: plug them in, turn on the noise cancellation, and listen.
Everything old is new again. This time it has USB Type-C.
bose-noise-cancelling-wired-earbuds-white-smoke-in-hand
Bose Calls It a Renaissance
“Wired earbuds are experiencing a cultural renaissance, and when we decided to bring them back, we knew we had to make them even better than before,” said Raza Haider, president of Bose Premium Consumer Audio. “Technology has come a long way since our last wired earbuds, allowing us the opportunity to bring our latest advancements to the category and set a new standard for what wired earbuds can be.”
No Pairing, No Charging, No Problem
bose-noise-cancelling-wired-earbuds-black
The Bose Noise Cancelling Wired Earbuds connect directly to supported USB Type-C phones, tablets, and computers, with no Bluetooth pairing or app required. Power comes from the source device itself, so there is no internal battery to charge — even when active noise cancellation is running.
Pro Tip: The earbuds do not include Bluetooth, but that does not limit access to streaming services. Connect them to a smartphone, tablet, or computer over USB Type-C and Spotify, Apple Music, Qobuz, TIDAL, and other streaming apps work exactly as they normally would.
Bose Brings QuietControl to the Cable
Bose has adapted its QuietControl noise-cancellation system for the wired earbuds, using four microphones — two per earbud — to monitor and reduce surrounding noise with three listening modes:
  • Quiet Mode: Maximum noise reduction
  • Aware Mode: Lets outside sound in when you need to hear your surroundings
  • ANC Off: Conventional wired listening without active noise cancellation
bose-noise-cancelling-wired-earbuds-dewdrop-mint-with-case
Bose Sound Without the Bluetooth Layer
Bose uses its SoundDesign DSP with USB Audio Class 2 support for lossless playback. The earbuds can accept a range of source formats, but output is fixed at 24-bit/48kHz. The wired USB Type-C connection also reduces latency for video, gaming, and content creation.
Control
The supplied cable includes an in-line remote with tactile buttons for volume, playback, calls, and cycling through noise-cancellation modes.
A dedicated microphone on the back of the remote is positioned to reduce clothing noise while keeping voice pickup clear, so there is no need to hold it up to your mouth like a 1998 headset. Sometimes buttons are better.
Fit, Finish and a Little ’90s Energy
The Bose Noise Cancelling Wired Earbuds use a 4.2-foot cable and include silicone eartips in small, medium, and large sizes, plus medium and large stability wings. The pieces can be mixed and matched to improve comfort and security.
Color options include Black with blue accents, White Smoke with lime green accents, and limited-edition Dewdrop Mint, which leans rather confidently into ’90s nostalgia. The earbuds are IPX4-rated for water resistance and include a zippered carrying case.
Specifications
Model NameBose Noise Cancelling Wired Earbuds
Price$99
Headphone FitIn Ear
Noise Control TypeAdjustable Noise Cancelling
Noise Cancellation ModesQuiet, Aware, ANC Off
Audio Listening ModeStereo
ControlIn-line remote
Connectivity Wired USB-C connection
IPX RatingIPX4 rated for water resistance
Cable Length 51 in (130cm)
FinishBlack, White Smoke, Dewdrop Mint
Product Material Plastic (PC-ABS), Silicone
Earbud Dimensions (WxHxD)0.8 x 1.2 x 0.9 inches
(2 x 3.1 x 2.3 cm)
Case Dimensions (WxHxD)5.591 x 1.181 x x 3.071 inches
(14.2 x 3 x 7.8 cm)
Weight 0.8oz (23g) each
What’s In The BoxBose Noise Cancelling Wired Earbuds
Wingtips (medium and large)
Eartips (small, medium, large)
Carry Case
Quick-start guide
Safety sheet
The Bottom Line
Bose picked a surprisingly good time to return to wired earphones. IEMs are enjoying renewed interest, and a direct USB-C connection offers some practical advantages wireless models cannot completely replicate: stable connectivity, low latency, lossless playback, and no battery waiting to die halfway through a flight.
The $99 Bose Noise Cancelling Wired Earbuds are not unique simply because they have a cable or ANC; both have existed before. What makes them interesting is the combination of Bose QuietControl noise cancellation, 24-bit/48kHz playback, plug-and-play operation, and no internal battery at a price that competes directly with conventional IEMs such as the ACTIVO Scoop ($99), Meze Audio ALBA S ($129), and SIVGA Lyrebird ($149).
Those competitors may appeal more to listeners focused primarily on traditional IEM tuning and passive isolation. Bose is targeting someone slightly different: commuters, travelers, gamers, content creators, and listeners who want the simplicity of wired audio without surrendering active noise cancellation.
There is no Bluetooth, no app to configure, and nothing to charge. Plug them in and listen.
Funny how advanced that suddenly sounds again.
Price & Availability
The Bose Noise Cancelling Wired Earbuds will start shipping on October 15, 2026 and are available for pre-order now for $99 at Bose.com. Launching in Black or  White Smoke, the earbuds are also available in limited-edition Dewdrop Mint.
2026 Nagra AMP II-S Stereo Power Amplifier
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro
Can RayNeo turn AR glasses into a private home theater? GT Max offers a 307-inch virtual screen, 120Hz Micro-OLED and Dolby Vision via Pocket...
Grado Signature S150 Headphones Grado Signature S150 Headphones
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
2026 Schiit Mani 3 Phono Preamp 2026 Schiit Mani 3 Phono Preamp
Schiit Mani 3 phono preamp adds front-panel controls, MM/MC cartridge flexibility, and improved circuitry without raising the price.
2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle 2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle
Head Units
Pioneer's 2026 Heritage Collection in-dash head unit and box speaker set combines retro looks with modern convenience for your car.
2027 Technics SL-1210MKX DJ Turntable Lifestyle 2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
After years of hands-on testing, these are the soundbars and speaker bar systems for home theater that impressed us most in 2026.
Developers have found a way to restore Dolby Atmos height effects from Blu-ray soundtracks on Apple TV 4K. It's an impressive technical achievement, but...
Bose acquires Skullcandy after their Sound by Bose partnership. Here's why the deal matters for headphones, McIntosh, Sonus faber, and the audio industry.
Apple Music finally comes to Bluesound and BluOS with native streaming and multiroom playback. But what about lossless and hi-res audio?
The $519 EPZ 550 pairs five balanced-armature drivers with striking metalwork and refined sound, but its polite bass won't satisfy everyone.
DUNU PRS6 brings MEMS technology to a refined tribrid IEM with strong resolution, clean treble and a clear focus on competitive gaming.
DAPs
The $80 Fosi Audio DAP Neo delivers iPod nostalgia, lossless playback, Bluetooth and expandable storage. Can it win over the streaming generation?
Can Sony’s $120 IER-M500 professional in-ear monitors deliver the sound, comfort, and durability working musicians need?
