Monitor Audio Silver Series 8G Debuts With 7 New Speakers for Music and Home Theater
2026 Monitor Audio Silver Series 8G Loudspeaker Family
British loudspeaker manufacturer Monitor Audio has introduced the eighth generation of its popular Silver Series, expanding the lineup with seven new models designed for both two-channel music systems and home theater applications.
The new Silver Series 8G is built around Monitor Audio’s Transparent Design Philosophy and represents the company’s most extensively refined Silver platform to date. With updated driver technology, cabinet engineering, and acoustic optimization carried across the range, Monitor Audio is positioning the 8G lineup as a meaningful step forward in performance while keeping the Silver Series firmly aimed at the highly competitive midrange loudspeaker market.
The series also includes a dedicated On-Wall model designed for more discreet stereo, surround, and home theater installations where floor space or visual impact may be a concern.
monitor-audio-silver-8g-500-tower-speakers-walnut
Monitor Audio 500 8G Floorstanding Loudspeaker in Walnut
What’s New in the Monitor Audio Silver Series 8G
The Silver Series 8G introduces a number of technological upgrades over the previous Silver Series 7G, with refinements to the driver technology, crossover design, and cabinet construction intended to deliver improved clarity, control, and overall acoustic performance.
C-CAM With RST III
Over its 40-year history, Monitor Audio has been at the forefront of metal-cone driver technology. The Silver Series 8G incorporates Monitor Audio’s proprietary C-CAM (Ceramic-Coated Aluminium/Magnesium) driver technology, along with the latest generation of RST III (Rigid Surface Technology) improvements.
The latest cone geometry is designed to increase structural rigidity while minimizing unwanted resonances, supporting greater accuracy, control, and transparency across the frequency range.
C-CAM Gold Dome Tweeter
For improved high-frequency performance, Monitor Audio has refined the latest generation of its C-CAM Gold Dome tweeter, a technology the company first introduced in the 1980s. The redesigned tweeter incorporates an optimized vented rear chamber, a newly engineered shorting ring, and the latest UD Waveguide II. Together, these refinements are designed to deliver smoother, more natural treble reproduction with improved clarity, consistency, and dispersion.
‘Silent Flow’ Port Technology
The Silver Series 8G also introduces a new port technology designed to significantly improve bass performance over the outgoing range. Inspired by the interlocking wing feathers of an owl, the new “Silent Flow” port combines an enlarged diameter with an innovative flare geometry that guides airflow more smoothly and quietly, reducing turbulence while supporting cleaner, deeper, and more controlled bass response.
monitor-audio-silver-8g-300-tower-speakers-white
Monitor Audio 300 8G Floorstanding Loudspeaker in White
New Crossover Design
Monitor Audio has also redesigned the crossover network for the Silver Series 8G, with the goal of providing more precise signal division, lower coloration, and a cleaner, more transparent signal path. The updated crossover is designed to improve integration between the drivers while contributing to a tighter, more coherent soundstage.
Engineered Wood
The Silver Series 8G is available in a European Walnut veneer crafted from real, engineered wood layered from sustainably sourced timber to replicate the rich grain and color associated with more exotic species. The result is a consistent, premium finish without relying on rare or endangered woods.
Through-Bolt Driver Bracing
Utilizing through-Bolt Driver Bracing, the Silver 8G’s speaker drivers are securely braced to the rear of the cabinet and tightened to a specific torque, ensuring structural rigidity between driver and cabinet while eliminating unwanted chassis resonances.
New Outrigger Feet
Taking a cue from the flagship Platinum Series 3G, the Silver Series 8G includes new outrigger feet designed to deliver a wider, more stable foundation. A discreet top-adjust mechanism allows precise levelling, and spikes can be switched out for integrated rubber feet to protect hard floors.
Comparison (Floorstanding & Bookshelf Models)
monitor-audio-silver-8g-loudspeakers
Monitor Audio Model Silver 500 8GSilver 300 8GSilver 100 8GSilver 50 8G
Product TypeFloorstanding SpeakerFloorstanding SpeakerBookshelf SpeakerBookshelf Speaker
MSRP (Pair)£2650.00
€3100.00
$3300.00
£2000.00
€2400.00
$2600.00
£1500.00
€1800.00
$2000.00
£800.00
€1000.00
$1250.00
System Format3-way3-way3-way2 -way
Frequency Response (-6dB)28Hz – 35kHz30Hz – 35kHz33Hz – 35kHz43Hz – 35kHz
Sensitivity (2.83 Vrms @ 1m, Free Field)N/AN/A87 dB86.5 dB
Sensitivity (2.83 Vrms @ 1m, Installed)90dB88dBN/AN/A
Nominal Impedance8 Ohms8 Ohms8 Ohms8 Ohms
Maximum Impedance (2-Hz to 20kHz)3.6 Ohms @ 2 kHz3.9 Ohms @ 3 kHz3.7 Ohms @ 140Hz3.8 Ohms @ 240Hz
Maximum Peak SPL (AES75, Z-weighted)119 dB116 dB114 dB110 dB
Continuous Power Handling (CTA 420-B)250 Watts200 Watts200 Watts100 Watts
Recommended Amplifier Power (RMS, Music Signal)125-500 Watts in 4 Ohms
60-250 Watts into 8 Ohms
100-400 Watts in 4 Ohms
50-200 Watts into 8 Ohms
50-200 Watts in 4 Ohms
25-100 Watts into 8 Ohms
Bass Alignment Silent  Flow Port TechnologySilent  Flow Port TechnologySilent  Flow Port TechnologySilent  Flow Port Technology
Port Tuning Frequency33Hz41Hz37Hz52Hz
Crossover FrequencyLF/MF 640Hz
MF/HF 2.8 kHz
LF/MF 610Hz
MF/HF 3.3kHz
LF/MF 610Hz
MF/HF 2.9kHz
LF/HF 2.6 kHz
Driver Unit Complement 2 x 8” C-CAM RST III Bass Driver
1 x 3”  C-CAM RST III Midrange Driver
1 x 25mm C-CAM Gold Dome  Tweeter
2 x 6” C-CAM RST III Bass Driver
1 x 8” C-CAM RST III Mid-Bass Driver
1 x 6” C-CAM RST III Mid-Bass Driver
External Dimensions with all Accessories Fitted (HWD)1120 x 340 x 432 mm
44 ⅛ x 13 ⅜ x 17 Inches
1120 x 295 x 410 mm
40 3/16 x 11 5/8 x 16 1/8 Inches
440 x 230 x 354 mm
17 5/16 x 9 1/16 x 13.1 5/16 inches
335 x 185 x 332 mm
13 3/16 x 7 5/16 x 13 1/16 inches
Weight (Product, Each)24.3 kg (53 lb 9 oz)19.3 kg (42 lb 9 oz)12.1 kg (26 lb 11 oz)8.2 kg (18 lb 1 oz)
FinishesSatin White
High Gloss
Black
European Walnut
Satin White
High Gloss Black
European Walnut
Satin White
High Gloss Black
European Walnut
Satin White
High Gloss Black
European Walnut
Comparison (On-Wall, Center, and Upfiring Models)
monitor-audio-silver-8g-on-wall-cent-upfiring
Monitor Audio Model Silver On-Wall 8GSilver Center 8GSilver AMS 8G
Product TypeOn-Wall Speaker Center Channel SpeakerUpfiring Speaker
MSRP (each)£450.00
€550.00
$575.00
£800.00
€1000.00
$1050.00
£900.00
€1100.00
$1200.00
System Format2-way 3-way2-way
Frequency Response (-6dB)44Hz – 35kHz66Hz – 35kHz82Hz – 35kHz
Sensitivity (2.83 Vrms @ 1m, Free Field)N/AN/AN/A
Sensitivity (2.83 Vrms @ 1m, Installed)88dB89dB85.5dB
Minimum Impedance (2-Hz to 20kHz)5.5 Ohms @ 20Hz4.0 Ohms @ 160Hz3.5 Ohms @ 160Hz
Maximum Peak SPL (AES75, Z-weighted)112 dB120 dB111 dB
Continuous Power Handling (CTA 420-B)100 Watts 200 Watts60 Watts
Recommended Amplifier Power (RMS, Music Signal)50-200 Watts in 4 Ohms
30-120 Watts in 4 Ohms
15-60 Watts into 8 Ohms
Bass Alignment Silent Flow Port TechnologySealedSealed
Port Tuning Frequency47 HzN/AN/A
Crossover FrequencyLF/HF 2.9 kHzLF/MF 620Hz
MF/HF 3.0 kHz
LF/HF 2.8 kHz
Driver Unit Complement 1 x 6” C-CAM RST III Mid-Bass Driver
1 x 5.25” C-CAM RST III Mid-Bass Driver
1 x 25mm C-CAM Gold Dome Tweeter with Optimized Waveguide
External Dimensions with all Accessories Fitted (HWD)465 x 300 x 135 mm
18 5/16 x 22 13/16 x 5 5/16 inches
205 x 511 x 272 mm
8 1/16 x 20 1/8 x 10 11/16 inches
185 x 185 x 312 mm
7 5/16 x 7 5/16 x 12 6/16 inches
Weight (Product, Each)8.9 kg (19 lb 10 oz)11.7 kg (25 lb 13 oz)4.5 kg (9 lb 15 oz)
FinishesSatin White
High Gloss Black
European Walnut
Satin White
High Gloss Black
European Walnut
Satin White
High Gloss Black
European Walnut
monitor-audio-silver-8g-on-wall-speaker
monitor-audio-silver-8g-50-bookshelf-speakers-white
monitor-audio-silver-8g-av-setup
The Bottom Line
The Monitor Audio Silver Series 8G is more than a cosmetic update, with revised C-CAM drivers, an improved Gold Dome tweeter, new crossover networks, cabinet refinements, and the Silent Flow port all aimed at delivering better performance than the outgoing 7G range. Its biggest advantage is flexibility, with models suited to traditional stereo systems, compact surround setups, and larger Dolby Atmos installations.
The Silver Series 8G is aimed at buyers who want a higher-performance loudspeaker system without moving into true high-end pricing, and it competes directly with offerings from KEF, Bowers & Wilkins, DALI, Focal, Q Acoustics, and Klipsch. There is no matching Silver Series subwoofer, but Monitor Audio’s Vestra models provide an obvious option, and buyers are free to use a subwoofer from another brand.
monitor-audio-silver-8g-100-stand-mount-speakers-black
Monitor Audio 100 8G Stand-mount Loudspeaker in Black
Price & Availability
The  Monitor Audio Silver 8G Series will be available beginning sometime in August 2026 from authorized dealers and installers at the following MSRP guidelines:
  • Silver 500 8G (floorstanding)  – £2650.00 / €3100.00 / $3300.00 (Pair)
  • Silver 300 8G (floorstanding) – £2000.00 / €2400.00 / $2600.00 (Pair)
  • Silver 100 8G (bookshelf) – £1500.00 / €1800.00 / $2000.00 (Pair)
  • Silver 50 8G (bookshelf) – £800.00 / €1000.00 / $1250.00 (Pair)
  • Silver On-Wall 8G – £450.00 / €550.00 / $575.00 (Each)
  • Silver Centre 8G – £800.00 / €1000.00 / $1050.00 (Each)
  • Silver AMS 8G – £900.00 / €1100.00 / $1200.00 (Pair)
3 Comments
3 Comments
  1. David
    August 17, 2026 at 1:29 pm
    The sensitivity rating on the Silver 50 is 80.5 dB. That seems very low. Could it be a misprint?
    • Ian White
      August 17, 2026 at 1:32 pm
      David,
      Let me check with Monitor Audio.
      IW
    • Ian White
      August 17, 2026 at 1:45 pm
      David,
      86.5 dB. Will correct.
      IW
2026 Triangle Borea BR05 Stand-mount Loudspeakers
Triangle’s Borea BR05 combines retro styling, an 8-inch woofer, and serious cabinet engineering. Who decided bookshelf speakers had to be so small?
Moon 341 Integrated Amplifier Black Angle Moon 341 Integrated Amplifier Black Angle
2026 Audiolab PPA7 Phono Preamp Black LIfestyle 2026 Audiolab PPA7 Phono Preamp Black LIfestyle
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
2026 T+A Solitaire T Pro Wireless Headphones 2026 T+A Solitaire T Pro Wireless Headphones
T+A Solitaire T Pro adds Dolby Atmos, aptX Lossless and premium DAC technology, but are luxury wireless headphones becoming too expensive?
2026 Vinnie Rossi Canta Integrated Amplifier Angle 2026 Vinnie Rossi Canta Integrated Amplifier Angle
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
2026 NAD C 359S Integrated Amplifier 2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
Linn's new 343 brings Pistonik bass to a compact floorstander, with Exakt Integrated and powered-bass versions starting at $67,500 per pair. Worth the premium?
Fyne Audio celebrates a decade with its most advanced IsoFlare driver, integrated SuperTrax and just 30 pairs of the $50,000 F1-10 Anniversary.
Can Castle’s new Tintagel and Walmer speakers challenge established rivals with ribbon tweeters, real wood cabinetry, and pricing from $2,749?
Can a $1,100 Canadian standmount really embarrass pricier rivals? Paradigm’s 220B v2 makes a surprisingly convincing case and looks the part.
Loudspeakers
Diapason has built handcrafted Italian loudspeakers since 1987. With MoFi Distribution and Paolo Tezzon behind it, the U.S. may finally notice.
Is the Triangle Borea BR04 a true upgrade over the BR03? We compare soundstage, bass, dynamics, RoomFit, and value.
In-Wall Speakers
Can Monitor Audio hide serious home theater bass? Creator Series in-wall subs use 10- and 12-inch drivers with DSP amplification up to 750 watts.
