Cambridge Audio Spira $499 Turntable Arrives to Match Its New L/R Wireless Speakers
Cambridge Audio’s $499 Spira turntable pairs Bluetooth, a steel platter and five colorful finishes with its new L/R active speaker lineup.
2026 Cambridge Audio Spira 1 Turntable Colors
Cambridge Audio has spent much of 2026 convincing music lovers that a serious stereo system doesn’t need six separate components, a rack the size of a refrigerator, or a second mortgage. Following the introduction of its colorful L/R Active Speaker Series at CES 2026, the British manufacturer has unveiled the Spira turntable, a $499 belt-drive model that looks suspiciously like the missing piece of that particular puzzle.
Cambridge Audio L/R S, L/R M, L/R X Active Wireless Speakers Orange
Left to right: Cambridge Audio L/R S, L/R M, L/R X Wireless Speakers
Available in Black, White, Blue, Green, and Orange, Spira shares the color palette of Cambridge’s new L/R speakers and includes Bluetooth transmission, an integrated phono preamplifier, and a preinstalled Audio-Technica cartridge. The emphasis is on making vinyl accessible to buyers who want a compact stereo system without surrendering an entire room to audio equipment.
Make no mistake: Spira is aimed squarely at customers considering Cambridge’s L/R S, L/R M, and L/R X active speakers. It isn’t limited to those products, but matching finishes and simple connectivity make the intended relationship rather obvious. Cambridge has finally given its new loudspeakers a turntable companion, and mercifully, it doesn’t look like another gray component borrowed from an office supply catalog.
Related Reading: Cambridge Audio Launches L/R Active Wireless Speakers At CES 2026 To Take On KEF
cambridge-audio-spira-1-turntable-green-lifestyle
More Than a Matching Paint Job
Underneath the colorful lacquered wooden plinth is a belt-drive system with a 1.8 kg (approximately 4-pound) steel platter, driven through a sub-platter. Cambridge says the additional mass improves rotational stability and reduces unwanted vibration. A felt mat, vibration-absorbing feet, and a conventional ground connection complete the mechanical package.
An aluminum-alloy tonearm includes adjustable tracking force and anti-skate, along with a removable headshell that makes cartridge replacement less intimidating for newcomers. Cambridge supplies an aligned Audio-Technica cartridge, with an upgrade path to the company’s ATN3600LE elliptical stylus.
Electronic switching between 33⅓ and 45 RPM also eliminates the need to move the belt manually when switching between albums and singles. A smoked, hinged dust cover finishes the package.
cambridge-audio-spira-1-turntable-orange-lifestyle
Cambridge Audio Spira with L/R M wireless speakers
Built for Cambridge’s L/R Speaker Family
The Spira’s appeal becomes clearer when you consider how it integrates with Cambridge’s new L/R active loudspeakers.
The L/R S ($549/pair) offers Bluetooth and a stereo RCA line input but lacks an integrated phono stage. Spira supplies the missing phono amplification, allowing a direct wired connection without another component. Buyers can also use its Bluetooth transmitter for a wireless audio connection.
The larger L/R M ($1,599/pair) and L/R X ($2,399/pair) already include moving-magnet phono inputs. Owners can bypass Spira’s internal phono stage and use the circuitry inside the speakers instead, or connect through a conventional line-level input with Spira’s preamp engaged.
One caveat: Cambridge has not disclosed Spira’s supported Bluetooth codecs. That matters because its more expensive Alva turntables offer aptX HD, and buyers should not assume the same capability here.
For listeners who prioritize sound quality, a wired connection remains the sensible starting point. Bluetooth offers flexibility, but converting vinyl playback for wireless transmission introduces another stage of digital processing. The convenience is real; the claims of pure analog magic are best left to the marketing department.
cambridge-audio-spira-1-cartridge
How Does Spira Compare With Cambridge’s Alva Turntables?
We’ve covered Cambridge’s Alva ST and Alva TT V2 previously, and Spira occupies a distinctly more affordable position.
The Alva ST, currently listed at $699 in the U.S., is also a belt-drive model with an integrated phono stage and Bluetooth. However, it includes an Audio-Technica AT-VM95E cartridge, an aluminum platter, and confirmed aptX HD wireless transmission.
The higher-end Alva TT V2, originally priced at $1,999 now appears to be discontinued. However, it took a different approach with direct drive, a high-output moving-coil cartridge, and a substantial POM platter.
Spira isn’t intended to replace either design on technical merit. Its less expensive cartridge platform and simpler feature positioning make it the entry point into Cambridge’s turntable range, while the heavier steel platter, adjustable tonearm, and upgrade options offer more flexibility than a disposable beginner’s record player.
cambridge-audio-spira-1-turntable-black-rear
Cambridge Audio Spira Specifications
  • Type: Belt-drive stereo turntable
  • Speeds: 33⅓ and 45 RPM, electronically selectable
  • Platter: 1.8 kg engineered steel
  • Drive: Belt-driven sub-platter
  • Tonearm: Aluminum alloy with removable headshell
  • Adjustments: Tracking force and anti-skate
  • Cartridge: Preinstalled and aligned Audio-Technica cartridge
  • Stylus Upgrade: Audio-Technica ATN3600LE elliptical
  • Phono Stage: Integrated, bypassable
  • Wireless: Bluetooth audio transmitter
  • Wired Output: Phono/line-level audio, with ground connection
  • Plinth: Solid lacquered wood
  • Isolation: Vibration-absorbing feet
  • Accessories: Felt platter mat and hinged smoked dust cover
  • Finishes: Black, White, Blue, Green, Orange
  • U.S. Price: $499
  • Availability: October 14, 2026
Cambridge has not disclosed detailed performance measurements, complete Bluetooth codec support, overall dimensions, or total turntable weight.
Two Competitors Worth Considering
The Spira enters a crowded segment, and Cambridge isn’t the only company offering a Bluetooth turntable with a built-in phono stage.
Sony’s PS-LX5BT belt-drive turntable ($499) offers fully automatic operation, Bluetooth with aptX and aptX Adaptive, an integrated phono preamp, and USB output for digitizing records. That’s considerably more convenience for buyers who don’t want to fuss with manual cueing or cartridge adjustments. Spira counters with a removable headshell, adjustable tonearm settings, and a heavier platter.
The fully automatic Audio-Technica AT-LP3XBT ($399) is another credible alternative, offering a removable headshell, adjustable tracking force, switchable phono stage, and Bluetooth supporting aptX Adaptive. Its AT-VM95C cartridge also provides access to Audio-Technica’s extensive VM95 stylus upgrade family. That makes the Spira’s higher price harder to justify on features alone.
Neither competitor offers the same deliberately coordinated aesthetic relationship with Cambridge’s L/R speakers. Whether that matters depends on how much you value visual consistency alongside the sound.
cambridge-audio-spira-1-turntable-tonearms
The Bottom Line
Cambridge Audio’s Spira makes sense as part of a broader strategy rather than an isolated turntable launch. The company has already introduced the amplification, speakers, wireless connectivity, and streaming platform. Now it has a vinyl source that fits the same design language without requiring customers to assemble a traditional component system.
At $499, however, Spira has to compete on more than good looks. Sony and Audio-Technica offer compelling alternatives, and Cambridge hasn’t disclosed enough technical information to declare a sonic advantage.
Still, there’s something appealing about a British hi-fi company offering a proper turntable with adjustable tracking force, a replaceable cartridge, and a choice of five colors. Nobody needs another cheap record player designed to destroy a collection while looking attractive on Instagram.
Spira at least appears to understand which end of the tonearm is supposed to matter.
Price & Availability:
Cambridge Audio Spira will be available October 14, 2026, for $499 at Amazon in the U.S , £329 at Amazon.co.uk, and €349 in Europe through Cambridge Audio and authorized retailers.
For more information: cambridgeaudiousa.com
2026 Nagra AMP II-S Stereo Power Amplifier
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro
Can RayNeo turn AR glasses into a private home theater? GT Max offers a 307-inch virtual screen, 120Hz Micro-OLED and Dolby Vision via Pocket...
Grado Signature S150 Headphones Grado Signature S150 Headphones
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
2026 Schiit Mani 3 Phono Preamp 2026 Schiit Mani 3 Phono Preamp
Schiit Mani 3 phono preamp adds front-panel controls, MM/MC cartridge flexibility, and improved circuitry without raising the price.
2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle 2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle
Head Units
Pioneer's 2026 Heritage Collection in-dash head unit and box speaker set combines retro looks with modern convenience for your car.
2027 Technics SL-1210MKX DJ Turntable Lifestyle 2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
Rega Replay turntable weighs just 2.2 kg and reportedly costs £259. How does its skeletal design compare with the Planar 1 and its rivals?
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
Beck’s $110 Ride Lonesome One-Step uses 24/96 files sourced from analog masters because audiophiles needed something new to argue about.
Playback is now Dual’s exclusive U.S. distributor as the app-controlled CS 629Q clears FCC certification. Is automatic vinyl playback ready for a comeback?
Is the Triangle Borea BR04 a true upgrade over the BR03? We compare soundstage, bass, dynamics, RoomFit, and value.
Does Verve’s new 2LP edition of John Coltrane’s Ascension finally offer the definitive vinyl version of his 1966 free jazz landmark?
