Andover-One DD Direct Drive Turntable Has More Tech Than Your Average $999 Deck
2026 Andover-One DD Direct Drive Turntable Lifestyle
The $1,000 turntable category has become one of the more interesting battlegrounds in analog audio. Buyers no longer have to choose between stripped-down audiophile decks that require a weekend of setup and feature-heavy consumer models that treat cartridge alignment like an activity best left to licensed professionals.
Andover Audio is stepping directly into that fight with the new Andover-One DD Direct Drive, its highest-performance component turntable to date. Priced at $999, the Boston-designed deck combines digitally controlled direct drive, a carbon-fiber tonearm, three-speed playback, adjustable VTA, a removable SME-style headshell, semi-automatic operation, and a factory-installed Audio-Technica AT-VM520xEB moving-magnet cartridge.
That represents a fairly substantial move upstream for a company many listeners associate with easy-to-use vinyl systems.
Earlier this year, I reviewed the $729 Andover SpinPlay, an all-in-one record player that was considerably better than its category suggested it had any right to be. Its combination of build quality, connectivity, and genuinely enjoyable sound earned an Editors’ Choice and reinforced something Andover has been doing rather consistently with products such as the SpinStage and SpinBase MAX 2: making vinyl easier without assuming the customer should never be allowed near a counterweight.
The Andover-One DD takes that philosophy into much more conventional hi-fi territory.
Andover-One DD
Andover Finally Goes Direct Drive
At the heart of the Andover-One DD is a digitally controlled direct-drive motor supporting 33⅓, 45, and 78 rpm. Andover specifies speed accuracy within 0.2% and wow and flutter below 0.15%.
Rather than using a higher-speed motor connected to the platter by a belt or idler mechanism, the DD’s motor operates at the platter’s rotational speed. Andover says this arrangement reduces the high-frequency motor vibration that can contribute to audible rumble.
Direct drive is hardly new technology; Technics owners may lower their pitchforks, but its appearance here is significant because Andover has previously focused much more heavily on integrated and lifestyle-oriented vinyl products.
The DD is a proper component turntable intended to work with the amplifier, phono stage, and loudspeakers of your choosing.
A Carbon-Fiber Arm With Actual Adjustability
andover-one-dd-direct-drive-turntable-speeds
The 8.8-inch straight tonearm uses a lightweight carbon-fiber armtube with a cast-aluminum removable headshell. Tracking force, anti-skating, and vertical tracking angle (VTA) are all adjustable.
The VTA adjustment is particularly welcome at this price. Plenty of affordable turntables technically allow cartridge replacement while providing very little flexibility when cartridges differ in height.
The headshell attaches through an industry-standard SME-style twist-lock connection, which makes cartridge swapping significantly easier and allows owners to keep additional cartridge-and-headshell combinations ready to go. That should prove especially useful for anyone playing 78 rpm records with a dedicated stylus. Compatible cartridge weight ranges from 2.5 to 6.2 grams.
Anyone who has installed a cartridge on a fixed headshell while holding a flashlight between their teeth already understands why this matters.
A Better Cartridge Than The Usual Starter Option
andover-one-dd-direct-drive-turntable-cartridge
Audio-Technica AT-VM520xEB Phono Cartridge
The Andover-One DD comes fitted with the Audio-Technica AT-VM520xEB, part of the company’s current VMx moving-magnet family rather than one of its entry-level cartridges. Andover specifically selected it as part of the turntable’s factory configuration.
The cartridge uses a bonded 0.3 x 0.7 mil elliptical stylus on an aluminum-pipe cantilever, with a recommended tracking force of 2.0 grams. Output is rated at 5.0mV, channel separation at 24dB at 1kHz, and Audio-Technica recommends a 47k-ohm load with 150–250pF capacitance. Frequency response is specified from 20Hz to 20kHz.
The VMx generator uses two coils per channel in a paratoroidal arrangement, with a central shielding plate between the channels to reduce crosstalk. Audio-Technica also uses PCUHD copper in the coils and fewer coil turns than previous designs as part of its effort to improve transient response.
More important for long-term ownership is the interchangeable stylus system. The same VMx cartridge body can accept more advanced compatible styli, including nude elliptical, MicroLinear, Shibata, and Special Line Contact designs.
Semi-Automatic Without Taking Over
Andover has also resisted the idea that convenience and serious analog playback are mutually exclusive. Moving the tonearm over the record starts the platter automatically. At the end of the side, Auto Stop halts rotation, but the arm itself does not return to its rest. Cueing remains entirely in the listener’s hands.
Both functions rely on contact-free optical sensing, so there is no mechanical mechanism dragging against or restricting the tonearm during playback.
It is a sensible compromise. You still get to lower the stylus manually and participate in the sacred vinyl ritual, but falling asleep during side two does not leave the stylus tracing the run-out groove until breakfast.
Built For A Real System
andover-one-dd-direct-drive-turntable-speaker-base
Andover-One DD atop Speaker Base
The Andover-One DD uses a thick MDF plinth finished in matte black, adjustable vibration-absorbing rubber feet, and a damped cast-aluminum platter topped by an anti-resonant silicone-rubber mat. A hinged dustcover is included.
Andover has also designed the turntable to integrate with the existing Andover-One SB powered speaker base, creating an alternative to the company’s Andover-One Mk2 all-in-one system. Pairing the DD with the SB retains the compact, room-friendly concept while giving owners a separate turntable with greater cartridge and setup flexibility.
Owners of conventional component systems can simply ignore that option and connect the DD to their preferred phono stage.
Which is precisely the point.
What Makes The Andover-One DD Different?
None of the individual technologies here are revolutionary. Direct drive, carbon-fiber tonearms, interchangeable headshells, 78 rpm playback, adjustable VTA, and Auto Stop have all existed before.
The interesting part is how Andover has combined them for $999.
Many turntables at this price force buyers to choose between audiophile adjustability and everyday convenience. The DD provides both without becoming fully automatic or locking owners into the factory cartridge.
Its position inside Andover’s lineup is equally important. The SpinPlay is aimed at someone who wants to open a box and start playing records with minimal fuss. The Andover-One DD is for the listener who wants that same lack of unnecessary aggravation but has begun thinking about cartridges, phono stages, and whether 78s deserve their own headshell.
Andover-One DD Specifications
  • Drive System: Digitally controlled direct drive
  • Speeds: 33⅓, 45, and 78 rpm
  • Speed Accuracy: Within 0.2%
  • Wow & Flutter: Less than 0.15%
  • Platter: Damped cast aluminum
  • Platter Mat: Anti-resonant silicone rubber
  • Tonearm: 8.8-inch straight carbon-fiber arm
  • Headshell: Removable cast aluminum
  • Headshell Connection: SME-style twist-lock
  • Tonearm Adjustments: Tracking force, anti-skating, VTA
  • Compatible Cartridge Weight: 2.5–6.2 grams
  • Factory Cartridge: Audio-Technica AT-VM520xEB moving magnet
  • Automatic Functions: Auto-start and end-of-record Auto Stop
  • Sensing: Contact-free optical
  • Plinth: Thick MDF
  • Finish: Matte Black
  • Feet: Adjustable, vibration absorbing
  • Dustcover: Hinged, included
  • Dimensions: 16.5 x 4.875 x 14 inches / 420 x 124 x 355mm
  • Weight: 12.8 pounds / approximately 5.8 kg
  • Price: $999
  • Availability: October 2026
Other Options?
The $899.99 Technics SL-40CBT, which we covered earlier this year, approaches the same price point from a more lifestyle-oriented direction. It combines Technics’ coreless direct-drive motor with 33⅓, 45, and 78 rpm playback, a removable headshell, built-in MM phono stage, and Bluetooth with aptX Adaptive.
The Andover gives up Bluetooth and the internal phono stage but counters with a carbon-fiber tonearm, adjustable VTA, optical Auto Stop, and the considerably more ambitious Audio-Technica AT-VM520xEB cartridge.
The Technics is easier to drop into almost any modern system. The Andover is aimed more directly at the listener who expects to start changing things.
The $1,299 Audio-Technica AT-LP8X is also a three-speed semi-automatic direct-drive turntable with an interchangeable headshell and adjustable tonearm geometry. Audio-Technica uses a 9.7-inch J-shaped aluminum tonearm, damped die-cast aluminum platter, and an AT-VM95E moving-magnet cartridge.
Its end-of-record mechanism lifts the arm and stops the motor, while published wow and flutter is below 0.1%.
The Andover costs $300 less, supplies the higher-tier AT-VM520xEB cartridge, uses a carbon-fiber tonearm, and adds automatic platter start when the arm is moved into position.
Competition around $1,000 has become rather brutal.
Nobody with a record collection should complain.
The Bottom Line
Andover’s best vinyl products have succeeded by removing unnecessary friction without removing the things enthusiasts actually care about.
The SpinPlay demonstrated that philosophy exceptionally well at $729. The Andover-One DD moves it into serious component territory with a more sophisticated cartridge, meaningful tonearm adjustment, interchangeable headshells, three-speed direct drive, and semi-automatic features that remain largely invisible during playback.
It is not the least expensive turntable in the category, nor do its published speed figures threaten to cause insomnia at Technics headquarters. What it does offer is a thoughtful balance of performance, flexibility, and convenience at a price where buyers increasingly expect all three.
For more information: andoveraudio.com
5 Comments
5 Comments
  1. Silvio Dante III
    October 1, 2026 at 12:34 pm
    When does this review come out?
    • Ian White
      October 1, 2026 at 8:54 pm
      Silvio,
      Review sample arrives next week so this month.
      IW
  2. ORT
    October 1, 2026 at 10:02 pm
    I will give this consideration. I own and use 2 or the original Andover Audio SpinBase with my rotating ‘tables. They are wonderful. I like Direct-Drive and should never have given away my fully automatic DD turntable…What a maroon was I.
    If this were fully automatic I would not be so reticent about buying one. I already have 2 fully auto ‘tables but both are rubberba…errrr…belt driven. Direct Drive doesn’t introduce anything but consistent speeds. Not noise. Not interference. Not stretchy belts. I like both methods but want a nice, relatively heave, affordable fully auto DD turntable. Hmmmmm…”DD”. I wonder if someone will license and make a DD Dolly Parton ‘table?
    ORT
    • Ian White
      October 2, 2026 at 6:26 pm
      ORT,
      My review sample will be here in a few days. Expect a review within 2 weeks.
      IW
  3. ORT
    October 2, 2026 at 9:23 pm
    Ian –
    Thanks! I look forward to it!
    ORT
2026 Audio-Technica ATH-AWX7000 Headphones
Audio-Technica’s $3,800 ATH-AWX7000 combines Japanese Cypress wood, luxury craftsmanship, and new 58mm drivers. Can it challenge the best closed-back headphones?
2026 Final A8000 DC IEM Back Front 2026 Final A8000 DC IEM Back Front
Canor Crius H5S Preamp DAC Headphone Amp with Headphones and Tablet Canor Crius H5S Preamp DAC Headphone Amp with Headphones and Tablet
2026 Nagra AMP II-S Stereo Power Amplifier 2026 Nagra AMP II-S Stereo Power Amplifier
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro
Can RayNeo turn AR glasses into a private home theater? GT Max offers a 307-inch virtual screen, 120Hz Micro-OLED and Dolby Vision via Pocket...
Grado Signature S150 Headphones Grado Signature S150 Headphones
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
Thee Sinseers’ Love Stories delivers irresistible East L.A. soul, gorgeous harmonies, and vintage R&B magic. Even the vinyl packaging deserves applause.
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
Goldmund's Mimesis Statement uses three chassis, separate channel power supplies and redesigned analog circuitry. A flagship with a startling price.
Rega Replay turntable weighs just 2.2 kg and reportedly costs £259. How does its skeletal design compare with the Planar 1 and its rivals?
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
