CD Players
NAD C 569 CD Player Puts Flagship Digital Technology Into a $999 Package
NAD’s mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C 589?
2026 NAD C 569 CD Player
NAD apparently didn’t receive the memo that compact discs were supposed to be dead. Only six months after introducing the C 589, the Canadian manufacturer is back with the new C 569 CD Player ($999), a less expensive Classic Series model that borrows some of its flagship sibling’s most interesting digital technologies.
The C 569 sits between the entry-level C 538 and the more expensive C 589, combining a modern ESS SABRE DAC with QRONO d2a processing, Dynamic Digital Headroom (DDH), and a redesigned analog output stage.
There is no streaming, app integration, or touch-sensitive interface to complicate things. Just a traditional CD player designed to get the most from a format that millions of music listeners never abandoned.
At $999, however, NAD needs to offer something more convincing than nostalgia and a reasonably quiet disc tray.
nad-c-569-cd-player-angle
What’s Different About the NAD C 569?
The biggest development is the combination of two digital processing technologies previously introduced in the C 589.
QRONO d2a, developed by MQA Labs under Lenbrook Media Group, uses digital filtering and noise shaping techniques intended to improve impulse response and timing accuracy during digital-to-analog conversion.
The objective is to reduce unwanted time-domain artifacts while preserving transient information and low-level musical detail. Importantly, QRONO d2a operates with conventional PCM recordings and does not require an MQA-encoded CD.
The second technology, Dynamic Digital Headroom (DDH), addresses inter-sample clipping. Digital recordings mastered close to maximum level can produce reconstructed peaks that exceed the nominal digital ceiling, potentially creating distortion during playback.
DDH provides additional digital headroom to help prevent that problem. It’s a useful engineering approach, particularly with aggressively mastered CDs, but don’t expect it to restore the missing dynamics from a recording that was compressed within an inch of its life. Even NAD can’t perform that kind of miracle.
At the center of the conversion stage is an ESS ES9039Q2M SABRE DAC, supported by upgraded operational amplifiers and a carefully regulated analog output section. Unlike the C 589’s fully balanced implementation, the C 569 employs a symmetrical stereo analog circuit with short signal paths and dedicated power regulation intended to minimize noise and interference.
The disc mechanism also deserves attention. NAD uses a conventional tray-loading transport controlled by an NXP-based servo system responsible for spindle speed, laser focus, and tracking. The transport, power supply, and sensitive analog circuitry are physically arranged to help reduce unwanted electrical interference.
None of this guarantees superior sound quality, but it suggests NAD has concentrated its engineering budget on the signal path rather than another collection of features that most CD owners won’t use.
Built for People Who Actually Listen to Albums
The front panel incorporates a 3.7-inch full-color LCD, with CD-Text support for displaying available album and track information. Gapless playback is included, which should be a basic requirement for anyone listening to live recordings, classical music, or albums where the songs flow together.
The C 569 also supports MQA-CD playback, although the format remains a tiny niche proposition compared with conventional Red Book CDs.
Stereo RCA outputs allow owners to use the internal ESS DAC, while optical and coaxial digital outputs provide the option of connecting an external DAC or using the C 569 purely as a transport.
There are no announced provisions for SACD playback, USB music files, or a headphone amplifier. NAD is clearly prioritizing CD playback over versatility, an approach that will appeal to some listeners while leaving others wondering what happened to the rest of their $999.
nad-c-569-cd-player-right-buttons
NAD C 569 CD Player Specifications:
  • Price: $999 USD / $1,199 CAD
  • Type: Single-disc CD player
  • DAC: ESS ES9039Q2M SABRE
  • Digital processing: QRONO d2a, Dynamic Digital Headroom (DDH)
  • Disc features: Conventional CD playback, MQA-CD, CD-Text, gapless playback
  • Transport: Tray-loading mechanism with NXP-based servo control
  • Display: 3.7-inch full-color LCD
  • Analog outputs: Stereo RCA
  • Digital outputs: Optical and coaxial
  • Analog output level: 2.2V ±0.2V
  • Frequency response: 20Hz – 20kHz (±0.5dB)
  • Total harmonic distortion: ≤0.006% at 1kHz
  • Signal-to-noise ratio: ≥110dB (A-weighted)
  • Channel separation: ≥110dB
  • Channel balance: 0.5dB
  • Dimensions (WxHxD): 435 x 83 x 294mm
  • Weight: 4.2kg (9.2 lbs)
  • Idle power consumption: ≤20W
  • Standby consumption: Less than 0.5W
  • Included accessory: IR remote control
  • Finish: Black
NAD C 538 vs. C 569 vs. C 589: Which One Makes Sense?
NAD now has three CD players serving rather different customers, although the differences between the C 569 and C 589 are particularly interesting.
ModelMSRPDACKey Differences
C 538$499Wolfson 24-bitBasic CD playback, CD-R/RW and MP3/WMA disc support
C 569$999ESS ES9039Q2MQRONO d2a, DDH, MQA-CD, 3.7-inch display
C 589$1,699ESS ES9039PROFully balanced conversion, XLR outputs, AES/EBU digital, 6.1-inch display
The C 538 remains NAD’s affordable option for music lovers who simply want to play their discs without spending a fortune. Its $499 price makes it considerably more accessible, and it already provides optical and coaxial digital outputs.
At the other end, the C 589 uses the more advanced ES9039PRO DAC, a fully balanced conversion architecture, XLR analog outputs, and an AES/EBU digital connection. NAD also specifies a slightly lower distortion figure of 0.005% and a signal-to-noise ratio of at least 115dB.
Those are genuine technical differences, but whether they justify the additional expense will depend on the rest of the system and listening results.
When we originally covered the C 589 in April 2026, its announced U.S. price was $1,399. NAD now lists it at $1,699, making the C 569 a full $700 less expensive.
For listeners using conventional RCA connections, the C 569 offers much of the same processing technology without charging for the flagship’s balanced circuitry and additional connectivity.
Competition: Marantz and Rotel Aren’t Going Anywhere
The $999 price also places the NAD against two established CD players that deserve consideration.
The Marantz CD 60 ($1,100) uses the company’s proprietary HDAM analog circuitry and selectable digital filters. It also offers a dedicated headphone output and front-panel USB playback for high-resolution music files. Marantz has a more versatile package, while NAD counters with its QRONO d2a and DDH processing.
The Rotel CD14MKII ($1,099) takes another traditional approach, employing a Texas Instruments 32-bit/384kHz-capable DAC, independent power supplies for critical circuitry, and a dedicated CD mechanism. It offers RCA analog and coaxial digital outputs, along with MP3 disc playback. Rotel also includes 12V trigger and RS232 connections for system integration.
Both are credible alternatives with established engineering pedigrees. More importantly, neither requires buyers to accept the claim that a particular DAC chipset automatically sounds better simply because its model number is higher.
nad-c-569-c-359s-side-by-side
NAD C 569 CD player with new C 359S Integrated Amplifier
The Bottom Line
The NAD C 569 makes a compelling argument for spending less without necessarily giving up the most important digital technologies found in the company’s flagship CD player.
QRONO d2a, DDH, a current-generation ESS SABRE DAC, and a carefully engineered analog output stage are meaningful additions. The simplified connectivity makes sense for listeners who use conventional RCA connections and have no intention of building a fully balanced system.
The missing SACD and USB playback options are harder to ignore at $999, particularly when competing players offer greater flexibility. And as always, the real test will be whether NAD’s engineering choices translate into audible improvements over less expensive alternatives.
For collectors with hundreds or thousands of CDs, however, the C 569 looks like a potentially sensible upgrade without going completely overboard.
Pricing & Availability:
The NAD C 569 will be available in late November 2026 for $999 in the United States and $1,199 in Canada through authorized NAD dealers, the NAD website, and Amazon.
For more information: nadelectronics.com
2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
2026 NAD C 569 CD Player 2026 NAD C 569 CD Player
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
2026 Sony Walkmans 2026 Sony Walkmans
DAPs
Sony's new Walkmans for 2026 include the ZX900, WM1AM3 and WM1ZM3 hi-res digital audio players (DAPs) packed with performance and priced at a premium.
Rega Replay Turntable Rega Replay Turntable
Rega Replay turntable weighs just 2.2 kg and reportedly costs £259. How does its skeletal design compare with the Planar 1 and its rivals?
2026 Linn 343 Floorstanding Loudspeakers Lifestyle Single Malt Glasgow Collection 2026 Linn 343 Floorstanding Loudspeakers Lifestyle Single Malt Glasgow Collection
Linn's new 343 brings Pistonik bass to a compact floorstander, with Exakt Integrated and powered-bass versions starting at $67,500 per pair. Worth the premium?
2027 Naim Mu-so Utopia Lifestyle Speaker 2027 Naim Mu-so Utopia Lifestyle Speaker
CD Players
Musical Fidelity's B1xcd CD player arrives as CD sales surge, offering a dedicated transport, ESS DAC, and serious hi-fi engineering without streaming distractions.
As physical media (both CDs and vinyl) continues its surge in 2026, eCoustics Editor-in-Chief, Ian White takes a look at what's happening behind the...
CD Players
FiiO’s $170 DP11 adds AES, a CS43198 DAC, CD ripping and USB conversion because apparently nobody told the compact disc it was dead.
NAD expands Dirac Live Room Correction to its CI SA2-120 and CI S2, adding automated acoustic optimization to its BluOS custom install lineup.
Marantz MCR 60n combines a CD player and streaming amplifier with HDMI eARC, MM phono and optional Dirac Live. Is this the all-in-one hi-fi...
What is Josh.ai VoiceCast, and how will it let existing Bluesound, NAD, PSB and other BluOS systems become part of a smarter home?
CD Players
Accuphase's DP-470 CD player adds ANCC, an MDS+ DAC and hi-res USB support as U.S. CD sales surge 16%. U.S. pricing is still pending.
