CD Players
Marantz Launches MODEL 70 Integrated Amplifier and CD 70 CD Player but North America Only Gets Half the System
Entry-level Marantz MODEL 70 adds HDMI ARC, aptX Adaptive Bluetooth and 50 watts per channel, while the CD 70 substantially undercuts the existing CD 60.
Marantz Model 70 Integrated Amplifier on the left and CD 70 on the right
North American buyers interested in the new Marantz MODEL 70 Integrated Amplifier can put their wallets away. Marantz has confirmed that the €850 component will not be sold in North America, leaving customers on this side of the Atlantic with only the matching CD 70 CD Player.
That is disappointing because the MODEL 70 looks like a thoughtful modernization of the long-running PM6007 formula, adding HDMI ARC, improved Bluetooth support and a more contemporary industrial design without turning the amplifier into another app-dependent streaming box.
North American buyers are not entirely out of options, however. The roughly $1,000 Marantz MODEL M1 Network Amplifier earned our 2025 Editor’s Choice Award and remains a compact, streaming-focused alternative worth considering.
European buyers will be able to purchase the MODEL 70 for €850 or £749. The CD 70 will be offered more broadly for $750 USD, $999 CAD, €600 or £499, with availability beginning August 15, 2026.
Marantz describes both components as successors to the PM6007 integrated amplifier ($750) and CD6007 CD player ($650), two of the brand’s most successful entry-level products. The new models retain the traditional full-width component format but adopt the cleaner design language used by Marantz’s more expensive MODEL Series products.
Both will be available in Black and Silver/Gold finishes.
marantz-model-70-silver-gold-front
The MODEL 70 is a conventional two-channel integrated amplifier built around an upgraded current-feedback Class A/B output stage delivering 50 watts per channel.
That represents a modest increase over the PM6007, which is rated at 45 watts per channel into 8 ohms. More importantly, Marantz says the MODEL 70 uses an enhanced power supply and larger toroidal transformer intended to improve dynamics, loudspeaker control and overall authority.
Marantz has not disclosed the impedance or distortion conditions attached to the 50-watt rating, so it would be premature to draw conclusions about how much usable power the amplifier can deliver into more demanding 4-ohm loudspeakers.
The analog section incorporates Marantz’s proprietary HDAM circuitry, along with an internal DAC for digital sources. An MM phono stage allows a turntable to be connected directly, although moving-coil cartridge users will still require an external phono preamplifier or step-up device.
Where the MODEL 70 separates itself most clearly from the PM6007 is connectivity.
marantz-model-70-rear
An HDMI ARC input allows the amplifier to handle television audio, with HDMI CEC providing volume control from a compatible TV remote. Marantz has also expanded Bluetooth functionality to support both transmission and reception.
Supported codecs include aptX Adaptive, aptX HD, AAC and SBC. Music can therefore be streamed from compatible phones and tablets, while the amplifier can also transmit audio to Bluetooth headphones for private music or television listening.
The MODEL 70 includes analog and digital inputs, along with preamplifier and subwoofer outputs. Marantz has not yet provided the number or type of each connection, nor has it disclosed the DAC chipset, maximum PCM and DSD resolutions, dimensions, weight or complete amplifier measurements.
Marantz has not mentioned HEOS, Wi-Fi, Ethernet, AirPlay 2 or integrated network streaming in the initial launch material. That may reflect an incomplete specification list, because a new Marantz integrated amplifier arriving in 2026 without HEOS would make very little sense. If those features are genuinely absent, the MODEL 70 would feel needlessly limited rather than refreshingly traditional, particularly when network playback has become central to Marantz’s modern product ecosystem.
MODEL 70 vs. STEREO 70s
Marantz STEREO 70s Receiver Front Silver
The naming will inevitably create some confusion because Marantz already sells the STEREO 70s Network Stereo Receiver in North America for $1,200.
Despite their similar names and HDMI connectivity, these are not variations of the same product.
The STEREO 70s delivers 75 watts per channel and includes six HDMI inputs, three of which support 8K video. It also offers HEOS streaming, Wi-Fi, Ethernet, AirPlay 2, an AM/FM tuner, two subwoofer outputs and extensive television and gaming support.
The MODEL 70 is rated at 50 watts per channel and appears to offer a single HDMI ARC connection rather than functioning as a video-switching hub. It focuses more narrowly on two-channel audio, with a toroidal transformer, current-feedback amplification, HDAM circuitry, Bluetooth transmission and a built-in MM phono stage.
The practical difference is simpler: European buyers will receive a modern replacement for the PM6007, while North American customers looking for a Marantz amplifier with HDMI will have to consider the more feature-heavy and more expensive STEREO 70s.
Marantz CD 70 CD Player
marantz-cd-70-silver-gold-front
The CD 70 is the component North American customers will actually be able to purchase, and its $750 price makes it one of the more interesting Marantz digital products in recent memory.
At its core, the CD 70 is a dedicated compact disc player incorporating the same high-performance DAC used in the MODEL 70, along with Marantz HDAM circuitry in the analog output stage.
A front-panel USB-A input expands playback beyond compact discs, with support for FLAC HD, ALAC, AIFF and DSD files stored on compatible USB devices. Marantz has not yet disclosed the maximum sampling rates or DSD resolution.
Construction upgrades include an improved power supply, double-layered chassis base, rigid isolation feet and strategically positioned copper hardware intended to reduce noise, vibration and electrical interference.
The CD 70 also includes a fully discrete headphone amplifier using HDAM technology. Adjustable gain should make it suitable for a wider selection of headphones, while automatic detection activates the headphone output when a plug is inserted.
Marantz has not yet confirmed whether the CD 70 includes optical and coaxial digital outputs, selectable digital filters, CD-R and CD-RW compatibility or the ability to function as a standalone DAC for external digital sources.
Those details matter, particularly when comparing it with the existing CD 60.
CD 70 vs. CD 60
Marantz CD60 CD Player Silver Angle
Marantz CD 60 CD Player Silver Angle
The CD 70 will sell for $750 in the United States, making it $350 less expensive than the current $1,100 CD 60.
On the surface, the two players offer considerable feature overlap. Both use Marantz HDAM circuitry, include front-panel USB-A playback, support high-resolution PCM and DSD files and provide headphone amplifiers with adjustable gain.
The CD 60 supports CD and CD-R/RW playback, PCM files up to 24-bit/192kHz and DSD up to 5.6MHz. It also includes two selectable digital filters, fixed analog outputs and both optical and coaxial digital outputs. Its audio stage uses Marantz HDAM and HDAM-SA2 modules, while the chassis weighs 7.5 kilograms and includes an aluminum center panel.
Marantz has not provided enough information to determine how the CD 70’s transport mechanism, DAC implementation, analog output stage or overall construction compare with those of the CD 60.
marantz-cd-70-silver-gold-angle-headphones
Marantz CD 70
The lower price suggests that there will be differences, but it would be unwise to invent them before the complete specifications arrive. A less expensive product does not automatically mean a lesser-sounding one, especially when the newer model benefits from several years of component and manufacturing development.
The more logical comparison may ultimately be with the CD6007, which remains available in the United States for $650. The CD 70 costs only $100 more while adding the current Marantz design, revised internal construction and a new DAC and headphone platform.
That could make the CD 70 the new value option in the range rather than a direct replacement for the more substantially constructed CD 60.
Familiar Marantz Design Without the Premium Price
Marantz has adopted the visual language of its more expensive MODEL Series components, including a symmetrical front panel, circular center display and full-width chassis.
The company says both models use vibration-resistant construction, optimized internal layouts and carefully selected components. Packaging has also been revised with FSC-certified cardboard and paper-based protective materials to reduce plastic consumption.
There is a substantial amount of marketing language about “culture-driven consumers” and audio becoming part of the home environment, but the underlying strategy is sound. Entry-level components no longer need to resemble laboratory equipment designed during the Carter administration.
marantz-cd-70-model-70-black
The Bottom Line
The MODEL 70 may be the more interesting of the two products because it combines traditional Class A/B amplification, a toroidal transformer, MM phono stage, HDMI ARC and modern Bluetooth support in a relatively affordable full-size integrated amplifier.
Unfortunately, North American buyers will not get it.
The CD 70 is considerably better news. At $750, it lands only $100 above the CD6007 while undercutting the CD 60 by $350. Its combination of dedicated CD playback, high-resolution USB support, HDAM circuitry and a discrete headphone amplifier could make it one of the strongest values in the Marantz lineup.
There is still a lack of transparency surrounding the MODEL 70’s network capabilities. Marantz has not confirmed support for HEOS, AirPlay 2, Wi-Fi or Ethernet, which would be a surprising omission from a new integrated amplifier in 2026. It may simply be a case of incomplete launch specifications, but buyers should not have to guess whether a core part of the modern Marantz ecosystem is included.
Complete specifications will determine whether the CD 70 is merely a better-dressed CD6007 replacement or something capable of making the more expensive CD 60 rather uncomfortable. They will also reveal whether the MODEL 70 is a genuinely modern integrated amplifier or a product undermined by connectivity decisions that make little sense at this stage.
Pricing & Availability
Both new 2026 Marantz hi-fi products will be available in Black or Silver/Gold finishes at the following prices:
  • Marantz MODEL 70 Integrated Amplifier – €850, £749 (a release date hasn’t been set at this time, but won’t be available in the North America)
  • Marantz CD 70 CD Player – $750 USD, $999 CAD, €600, £499 (available August 15, 2026)
2 Comments
2 Comments
  1. ORT
    July 15, 2026 at 1:36 pm
    I own and regularly use a Marantz CD 60 mostly via the headphone output. I have it hooked into a Denon Home Amp. I have 2 Home Amps, one for the “media” room and another for a bedroom. If I had not already bought 2 of them the media room would definitely have a Marantz Stereo 70 instead. Looks are important and to be honest, they are more often than not indicative of quality. Don’t believe me? Just feast your senses upon anything Yorx.
    Marantz is a high quality manufacturer as is Denon and that quality along with their superb implementation of HEOS is why I own Marantz and Denon products. Hopefully, Marantz will not go further (price-wise) “upscale” as I am retired and may wish to acquire something else from them. I recently ordered a Pro-Ject Peanuts 75th Anniversary Turntable. Pro-Ject is a favorite for me as like Marantz/Denon, they have never let me down and the quality (and looks) is outstanding. Yeah…I am the “Shallow Hal” of Audio/Video.
    Plus, the founder is a true gentleman whom I have exchanged emails with for years now and the new importer is also a good man.
    Yeah…It may appear I am “name dropping” but the reality is, I know and respect Marantz/Denon as much as I do Pro-Ject because of the people I know in both companies.
    El salvaje ORTo blanco de la selva
    • Ian White
      July 15, 2026 at 2:07 pm
      ORT,
      Now that Marantz and Denon are owned by Samsung, it will be interesting to see how the quality holds up. The Model 10 is a very serious piece of kit. I was skeptical when we covered it initially, but have now listened to it in 3 systems and it’s possibly the best class D amplifier I’ve heard. Built like a Sherman and hopefully more reliable.
      IW
2026 FiiO DP11 CD Player Silver
CD Players
FiiO’s $170 DP11 adds AES, a CS43198 DAC, CD ripping and USB conversion because apparently nobody told the compact disc it was dead.
2026 TRIBIT FlyBuds C3 Wireless Earbuds Woman Lifestyle 2026 TRIBIT FlyBuds C3 Wireless Earbuds Woman Lifestyle
TRIBIT's $39.99 wireless earbuds come feature packed with noise cancellation, Bluetooth 6.0, multipoint and 5-hour battery life per earbud.
SOUNDBOKS Rider Party Speaker on Bike SOUNDBOKS Rider Party Speaker on Bike
The $599 SOUNDBOKS Rider delivers 118dB, a swappable battery and IP66 protection without requiring a hand truck to move it.
2026 Cayin HA-1A MK3 Tube Headphone Amplifier 2026 Cayin HA-1A MK3 Tube Headphone Amplifier
Cayin's HA-1A MK3 features pure Class A tube amplification with 2.7W output, impedance matching and preamp functionality for $999.
2026 FiiO M25 Veritas and M25-R2R DAPs 2026 FiiO M25 Veritas and M25-R2R DAPs
DAPs
FiiO’s M25 VERITA and M25 R2R finally launch with AKM or resistor-ladder DACs, 1.7W per channel, 31-band PEQ and the same price.
Silent Angel H1 Silent Angel H1
Silent Angel’s $849 H1 combines dual ESS DACs, streaming, local storage, high-res playback, and VitOS in one compact digital hub.
CD Players
Marantz MCR 60n combines a CD player and streaming amplifier with HDMI eARC, MM phono and optional Dirac Live. Is this the all-in-one hi-fi...
CD Players
Accuphase's DP-470 CD player adds ANCC, an MDS+ DAC and hi-res USB support as U.S. CD sales surge 16%. U.S. pricing is still pending.
Portable CD players are back in 2026. We compare 10 models from FiiO, Shanling, Moondrop, Cayin and Syitren, with prices and key features.
CD Players
Cayin's $699 CP6 portable CD player combines dual tubes, Class A power, balanced output, Bluetooth, USB DAC support and CD ripping.
12 gift ideas for the music and movie loving Dad that are guaranteed to delight this Father's Day.
