Amphion A15 Active Speakers Bring Studio Monitor Thinking Home Without the Wireless Baggage
Amphion A15 Active Speakers White Lifestyle
Finnish loudspeaker manufacturer Amphion has spent more than 25 years building loudspeakers around a fairly consistent idea: minimize the theatrics, control dispersion, and let the recording do most of the talking. Its professional studio monitors have subsequently found their way into rooms used by engineers and producers working with artists including Billie Eilish, Beck, and Kendrick Lamar, while its home loudspeakers have become more widely available in North America through Playback Distribution.
The new Amphion A15 brings those two sides of the company much closer together. This compact two-way active loudspeaker takes obvious inspiration from Amphion’s One15 nearfield studio monitor, adds dedicated internal amplification, and packages the concept specifically for home listeners. What it does not add may be just as important: there is no built-in streaming platform, Wi-Fi, Bluetooth, HDMI, USB input, or elaborate app ecosystem listed in Amphion’s current specifications. Instead, each A15 provides a single balanced XLR analog input.
In a market increasingly filled with active speakers trying to become your streamer, DAC, preamplifier, television audio system, and possibly your therapist, Amphion has chosen a considerably narrower job description.
amphion-a15-active-speaker-white-on-black-song
Studio DNA Moves Into the Living Room
The connection between the A15 and Amphion’s established One15 studio monitor is difficult to miss. Both use a 1-inch titanium tweeter, 5.25-inch aluminum woofer, 5.25-inch aluminum passive radiator, and 1,600Hz crossover point, and both measure 12.44 x 6.3 x 10.43 inches. The One15 is a passive professional monitor requiring external amplification; the A15 integrates its own amplifiers and is specifically positioned for home audio.
The passive radiator is particularly important to Amphion’s design approach. Rather than using a conventional bass-reflex port, Amphion has employed passive radiators across both its professional and consumer products to control low-frequency behavior while avoiding some of the airflow and placement issues associated with traditional ports. We heard that same philosophy at work with the Argon7LX at AXPONA 2026, where bass control, imaging, and overall coherence were among the things that stood out.
The A15’s internal amplification provides 125 watts for the woofer and 22 watts for the tweeter, while Amphion specifies a frequency response of 55Hz to 40kHz at -6dB. Each loudspeaker weighs 20 pounds and will initially be offered in Snow White and Jet Black finishes.
Amphion A15 Specifications:
  • Design: Two-way active loudspeaker
  • Tweeter: 1-inch titanium
  • Woofer: 5.25-inch aluminum
  • Passive Radiator: 5.25-inch aluminum
  • Crossover: 1,600Hz
  • Frequency Response: 55Hz to 40kHz (-6dB)
  • Amplification: 125 watts bass, 22 watts treble
  • Input: 1 x balanced XLR analog
  • Dimensions: 12.44 x 6.3 x 10.43 inches
  • Weight: 20 pounds each
  • Finishes: Snow White, Jet Black
amphion-a15-active-speakers-white-back-front
What Makes the Amphion A15 Different?
The A15 occupies an interesting space between professional active monitors and consumer wireless loudspeakers.
KEF’s LS50 Wireless II, for example, combines amplification with Wi-Fi, Bluetooth, AirPlay 2, Google Cast, Roon, HDMI eARC, multiple digital inputs, streaming services, and an app. Dynaudio’s Focus 10 follows a similarly integrated philosophy with wireless connectivity and substantial onboard amplification.
The Amphion A15 goes in almost the opposite direction.
Its current specification sheet lists one analog XLR input and nothing else. That means owners can choose their own streamer, DAC, analog preamplifier, or combination of those components and replace them independently as formats and streaming platforms change.
That approach is hardly unprecedented in professional audio. Neumann’s KH 150 and Genelec’s 8341A demonstrate just how sophisticated active studio monitors have become, although both add DSP and room-optimization capabilities that Amphion has not announced for the A15. ATC’s SCM20ASL also takes the more traditional active-loudspeaker route and is specifically offered for high-quality domestic listening as well as ATC’s professional monitoring applications.
What makes the A15 interesting is Amphion taking its studio-monitor philosophy and deliberately packaging it for the audiophile living room without turning it into another wireless lifestyle system.
Who Should Consider the Amphion A15?
The obvious customer is someone who already owns a quality streamer, DAC, or preamplifier with balanced outputs and wants to eliminate the separate power amplifier without surrendering control over the rest of the system.
It could also make considerable sense in smaller listening rooms, desktop systems, and dedicated nearfield setups where imaging and controlled dispersion matter more than subterranean bass. With a specified -6dB point of 55Hz, however, listeners who want genuine full-range extension for electronic music, large-scale orchestral recordings, or home theater will probably want to add a subwoofer.
The A15 is not aimed at buyers looking for the simplest possible all-in-one solution. If you want to open Spotify on your phone, select the speakers, and be finished, KEF, Dynaudio, and several other manufacturers offer considerably more integrated alternatives.
But that absence of software dependency may also be part of the appeal. Amplifiers and loudspeaker drivers generally have much longer useful lives than streaming platforms, wireless standards, and apps. Amphion specifically emphasizes longevity in its A15 announcement, and keeping those rapidly changing technologies outside the loudspeaker could make upgrading considerably easier down the road.
amphion-a15-active-speaker-white-stand
The Bottom Line
The Amphion A15 is not trying to win the active-speaker feature war. That may be precisely why it stands out.
By combining internal amplification with the driver architecture and design philosophy Amphion has developed for professional monitoring, the A15 offers audiophiles a more modular approach to active loudspeakers. You supply the streamer, DAC, and volume control; Amphion handles the amplification and loudspeaker integration.
We already came away impressed by the Argon7LX at AXPONA 2026, and eCoustics has previously covered Amphion’s much larger One25A active studio monitor. The A15 now looks like the clearest bridge yet between those professional and consumer worlds.
The unanswered question is price. If Amphion gets that right, the A15 could become a very interesting alternative for listeners who want active-speaker simplicity without handing the entire system over to an app.
Price & Availability
Amphion has not announced pricing or a firm shipping date as of August 16, 2026. The company says additional information is coming.
Buchardt E50S Passive Bookshelf / Stand-mount Speaker Lifestyle in Natural Oak
Buchardt Audio’s E50-S adds a larger Satori woofer, higher sensitivity and new tuning as an alternative to the acclaimed E50.
Meze Audio Alba IEMs Lifestyle Woman Listening Meze Audio Alba IEMs Lifestyle Woman Listening
Meze Audio’s ALBA S keeps the original driver, tuning and metal shell but drops the bundled USB-C DAC adapter to cut the price.
Canvas HiF Oak with System Audio Silverback On-Wall Surround Speakers Canvas HiF Oak with System Audio Silverback On-Wall Surround Speakers
Can CANVAS HiFi turn BACCH 3D into a true Dolby Atmos theater? Almando InMedio adds 7.1.4 expansion, WiSA HT and open speaker support at...
2026 XGIMI Aura 3 MAX 4K/120Hz UST Projector 2026 XGIMI Aura 3 MAX 4K/120Hz UST Projector
Can the XGIMI AURA 3 Max challenge giant TVs with 5,700 ISO lumens, dual-iris contrast, Dolby Vision and 4K/120Hz gaming?
Accuphase DP-470 CD Player Accuphase DP-470 CD Player
CD Players
Accuphase's DP-470 CD player adds ANCC, an MDS+ DAC and hi-res USB support as U.S. CD sales surge 16%. U.S. pricing is still pending.
2026 Esoteric T-01 Turntable 2026 Esoteric T-01 Turntable
Are the ATC SCM20ASL worth $10,999? These British active loudspeakers deliver world-class sound, brutal honesty, and serious built-in power.
Loudspeakers
Armour Home boss Charlie Henderson explains how Q Acoustics, Goldring and QED plan to rebuild U.S. visibility, expand products and reach younger listeners.
What is Playback Distribution bringing to Audio Advice Live 2026? Three rooms featuring a Vienna Acoustics North American loudspeaker debut, PMC Speakers, CANVAS HiFi,...
Would you spend $5,000 on a CANVAS HiFi all-in-one soundbar system without hearing it? Playback Distribution is bringing the Danish TV audio system to...
Are the $1,499 Wharfedale Super Denton truly the British Bulldog of standmount speakers, and do they justify their place in the Heritage lineup?
