Esoteric T-01 Turntable Brings Grandioso MagneDrive Technology Down to $50,000
Can Esoteric’s $50,000 T-01 deliver Grandioso-level analog performance with MagneDrive, Magne-Float and 10MHz clock sync?
2026 Esoteric T-01 Turntable
Esoteric has never approached analog playback like a company interested in keeping things simple. Its first turntable, the Grandioso T1, incorporated a contactless magnetic induction drive system, magnetic platter support, an external power supply and the ability to synchronize the motor to a 10MHz master clock.
Four years later, Esoteric is taking the most interesting technology from that flagship platform and putting it into the new T-01, a somewhat smaller and easier to install turntable that still weighs more than some loudspeakers and costs $50,000 with its TA-9D tonearm.
“More attainable” requires some perspective here.
What Exactly Is MagneDrive?
The T-01 is not a belt-drive turntable, nor is it a conventional direct-drive design.
esoteric-t-01-turntable-motor
Esoteric mounts a dome-shaped magnetic driver with alternating north and south poles to the motor. Around the lower circumference of the non-magnetic aluminum platter is a soft-iron induction wheel. As the magnetic driver rotates beside it, magnetic induction causes the platter to rotate synchronously without the motor or drive assembly physically touching the platter.
The objective is to isolate the platter from motor vibration and rumble while retaining sufficient torque and precise control over rotational speed. Esoteric says it spent more than five years developing and commercializing the system, which is now patented.
That is the genuinely interesting part of the T-01. There is no belt to stretch or replace and the motor is not mechanically coupled to the platter in the conventional sense.
But we would stop short of suggesting that Esoteric invented contactless magnetic turntable drive technology as a category. Clearaudio has used magnetic decoupling in products including the Master Innovation, where a belt-driven lower flywheel magnetically transfers rotation to the playback platter. Esoteric’s induction-based implementation is different, and remains extremely unusual, but magnetic isolation itself is not exclusive to Esoteric.
Magne-Float Takes Some Weight Off
esoteric-magnedrive-diagram
The physical platter still weighs 13 kilograms, or almost 29 pounds, but Esoteric’s Magne-Float system uses opposing magnetic force to reduce the effective load on the spindle bearing to approximately 4 kilograms.
The T-01 still uses an inverted bearing, so this is not a completely levitated platter spinning in mid-air. The magnetic assistance reduces the load placed on that bearing, which is intended to lower friction and mechanical noise.
The Grandioso T1 applied the same basic idea to an even heavier 19-kilogram platter. The T-01 therefore looks less like an entirely new design philosophy and more like Esoteric figuring out how to package its flagship analog engineering in something that does not require quite as much floor space, hardware or financial anesthesia.
esoteric-t-01-turntable-front
esoteric-t-01-turntable-top
Smaller Than the Grandioso T1 Is Still Not Small
One of the biggest changes involves the motor architecture.
The Grandioso T1 uses a separate motor assembly, while the T-01 integrates its MagneDrive motor into the main chassis and houses it inside what Esoteric calls a Vibration Absorber Case. The power supply remains external, but it is a compact 7-kilogram unit rather than another imposing full-width component.
The turntable itself weighs 35 kilograms, including the 13-kilogram platter, so the complete T-01 and power supply combination comes in at approximately 42 kilograms, or almost 93 pounds. The chassis uses three layers of aluminum and MDF with a piano-lacquered center layer, while the feet combine a spike, spike pad and damper into a single isolation assembly.
Buy a strong rack. Your IKEA Kallax has suffered enough.
esoteric-t-01-turntable-angle-right
Yes, Your Turntable Can Use a 10MHz Clock
The T-01 includes Esoteric’s Master Sound Discrete Clock motor driver and accepts an external 10MHz reference clock through a 50-ohm BNC input. It can therefore be synchronized with Esoteric’s G-01XD or G-05 master clocks.
Yes, Esoteric has found a way to make a turntable care about an external 10MHz clock. Anyone familiar with the company’s digital products should be completely unsurprised.
Whether adding an external reference clock produces an audible improvement over the T-01’s internal motor control is something we would want to test rather than accept on faith. What is clear is that the feature allows an all-Esoteric system to share the company’s clocking architecture across both digital and analog playback.
The T-01 supports 33 1/3 and 45 RPM playback, offers ±12 percent speed adjustment in 0.1 percent increments and specifies wow and flutter at 0.06 percent W.R.M.S. Up to two tonearms can be installed with the appropriate arm bases.
How Does the T-01 Compare?
At $50,000 with its Esoteric tonearm, the T-01 lands in a rather interesting part of the ultra-high-end turntable market.
The Clearaudio Master Innovation Wood starts around $37,500 in the U.S. without a tonearm and is probably the most interesting comparison from an engineering perspective. Its belt-driven architecture uses magnetic decoupling between its flywheel and platter, along with Clearaudio’s Ceramic Magnetic Bearing and optical speed control. Similar objective; very different execution.
The TechDAS Air Force III Premium, currently listed around $42,525, attacks mechanical isolation from another direction entirely. Its massive 29-kilogram platter rides on an air bearing, the record is held flat using vacuum pressure, and an external synchronous motor drives the platter by belt. It is a far more complex mechanical ecosystem but arguably one of the T-01’s most obvious Japanese competitors.
VPI’s Titan Direct sits above the Esoteric at $64,000 and combines magnetic direct drive with air-suspension isolation and support for as many as three tonearms. It represents the American answer to the same basic problem: eliminate as much unwanted mechanical behavior as possible and control platter rotation with extreme precision.
Then there is the SME Model 60, which arrived in North America at $71,900 with its Series VA tonearm. SME uses a sophisticated belt-drive system, electronic speed controller, suspended chassis and separate power supply. It is more expensive, but anyone contemplating a $50,000 Esoteric is unlikely to stop comparison shopping because another contender costs twenty grand more. That ship left the marina several components ago.
The other competitor is sitting inside Esoteric’s own catalog. The Grandioso T1 was priced at $80,000 with its TA-9D tonearm when reviewed in 2023, making the T-01 roughly $30,000 less while retaining MagneDrive, Magne-Float and 10MHz clock capability.
esoteric-t-01-tonearm
The Bottom Line
The Esoteric T-01 is not unique because nobody else has experimented with magnetic isolation, oversized platters or elaborate speed control. Clearaudio, TechDAS, SME, VPI and others have been attacking those problems for years with very different engineering solutions.
What makes the T-01 interesting is that Esoteric has taken the defining technology of the Grandioso T1 — its patented induction-based MagneDrive system — and engineered it into a considerably less complicated and less expensive platform without abandoning Magne-Float, external clock synchronization, an outboard power supply or multiple tonearm capability.
At $50,000 with the TA-9D tonearm, this remains a turntable for a very small group of vinyl listeners with equally ambitious cartridges, phono stages and systems. But compared with the Grandioso T1, the T-01 is easier to install, considerably less expensive and still unlike almost anything else in its price range.
Apparently $50,000 is what passes for Esoteric becoming practical.
esoteric-t-01-turntable-angle-left
Price & Availability
The Esoteric T-01 will begin shipping internationally at the end of September 2026.
  • T-01 with tonearm: $50,000 USD / €48,000 / £41,999
  • T-01AL without tonearm: $46,000 USD / €45,000 / £38,999
A phono cartridge is not included. Ouch.
4 Comments
4 Comments
  1. ORT
    August 21, 2026 at 6:04 pm
    Hmmmmmmm…I have a Espresso Machine with a milk frother that uses similar tech to, well…froth the milk. It didn’t cost me $50,000. Yes. I drink espresso and frothy milk not milque,
    I refuse to cry over frothed milk but while some folk will happily buy one of these I am far from being “some folk”. Shallow Hal needs a ‘table. Oh! I’m awake and no longer find this thing attractive in the least. Not that I have ever found any of the high end tables to be good looking. Most resemble a magnetized Medieval Keep. I am not quite a fan of the looks of a lot of turntables across the graph of affordability and while I wouldn’t mind an integrated TUBE amp that paid homage to the silent film “Metropolis”, I think turntables should turn heads, not stomachs.
    ORTnofun
    • Ian White
      August 21, 2026 at 6:14 pm
      ORT,
      50,000 buys a lot of milk and espresso, not to mention around 1,500 albums.
      My final table is going to be a NEW Thorens…to sit next to my restored Thorens. I will tell you…the Esoteric network streamer/DAC/pre-amp/headphone amp currently under review is about as good as it gets. And it’s $37,000 LESS than this turntable.
      IW
  2. ORT
    August 22, 2026 at 1:51 am
    Ian, would that happen to be a new N-05XE Headphone Amplifier, USB DAC and Network Player? What a beauty that one is!
    HUZZAH!!
    ORT
    • Ian White
      August 22, 2026 at 2:06 am
      ORT,
      Indeed it is. And she’s a beauty.
      IW
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
Goldmund's Mimesis Statement uses three chassis, separate channel power supplies and redesigned analog circuitry. A flagship with a startling price.
Rega Replay turntable weighs just 2.2 kg and reportedly costs £259. How does its skeletal design compare with the Planar 1 and its rivals?
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
Cambridge Audio's $499 Spira turntable pairs Bluetooth, a steel platter and five colorful finishes with its new L/R active speaker lineup.
