Marantz’s MCR 60n Is a $1,000 All-in-One Hi-Fi System With CD, HEOS, Phono and Dirac Live
Marantz MCR 60n combines a CD player and streaming amplifier with HDMI eARC, MM phono and optional Dirac Live. Is this the all-in-one hi-fi system to beat?
2026 Marantz MCR 60n CD Player and Streaming Amplifier in Black
The compact all-in-one hi-fi category is getting crowded for a very good reason. A growing number of listeners want serious two-channel performance without a rack full of components, but they also aren’t necessarily willing to abandon CDs, vinyl, streaming or their television just to simplify the system.
That has created an interesting opening between traditional integrated amplifiers and the new generation of streaming amps from Eversolo, WiiM and others. Marantz is jumping directly into that space with the new MCR 60n, a $1,000 compact all-in-one hi-fi system designed to handle both physical media and modern streaming without requiring consumers to build an entire stack of separate components. Marantz calls it its most capable compact music system to date.
More importantly, the MCR 60n arrives at exactly the same $1,000 price as the Marantz MODEL M1, which raises an obvious question: does Marantz now have two very different answers for the same customer?
marantz-mcr-60n-front
Marantz MCR 60n (front)
Marantz MCR 60n: More Than Just Another Streaming Amplifier
According to Marantz, the MCR 60n is its most capable compact music system to date.
Inside its durable and stylish chassis, the MCR 60n combines CD playback, network streaming, HDMI eARC compatibility, turntable connectivity, and premium amplification designed to deliver Marantz sound quality without unnecessary user complexity. With amplification built in, all you need is a good pair of speakers and you are ready to go.
Tuned by the Marantz Sound Master, the MCR 60n combines decades of hi-fi heritage with the latest streaming technologies in a single component.
Whether you are streaming hi-res music, playing discs from a CD collection, connecting a turntable, or upgrading your TV sound, the MCR 60n brings multiple sources together within one intuitive system designed to fit naturally into modern living spaces. Its compact footprint makes it equally suitable for a dedicated listening room, home office, bedroom, or living room, while Matte Black and Marantz Champagne Gold finishes provide two distinct design options. Champagne Gold, however, will not be available in North America.
Output Power & Speaker Configuration
To optimally support the Marantz sound, its new power supply is designed to provide greater current capability and increased amplifier headroom compared with older models. According to Marantz, this results in improved dynamics, stronger bass performance, and greater control across a wider range of loudspeakers.
Output power has been increased to 65 watts per channel into 4 ohms, providing a substantial performance improvement over its predecessor while maintaining the warm, detailed, and emotionally engaging Marantz sound signature.
With four channels of amplification, including Bi-Amp, Parallel Bridge-Tied Load (BTL), and dual speaker outputs, the MCR 60n allows users to optimize performance for different loudspeaker configurations or power two independent listening zones from a single compact amplifier.
marantz-mcr-60n-rear
Marantz CD 60n (rear)
Content Access
For additional audio input flexibility, the MCR 60n also includes HDMI eARC. This allows easy integration with modern TVs, enabling high-quality stereo playback of TV sound while supporting HDMI-CEC volume control and Dolby Digital and Dolby Digital Plus decoding.
Pro Tip: Keep in mind that Dolby Digital and Dolby Digital Plus are mixed down to two channels by the MCR 60n.
For vinyl enthusiasts, an included MM phono stage makes connecting a turntable easy, while a precision-engineered front-loading CD mechanism continues Marantz’s longstanding tradition of compact disc playback.
High-resolution music streaming is supported with PCM up to 384kHz/32-bit and DSD up to 11.2MHz, all powered by the latest HEOS networking platform. Built around the latest generation of HEOS, the MCR 60n provides a faster, more intuitive setup experience, along with access to streaming services, internet radio, and whole-home multi-room audio.
Spotify, TIDAL, and Qobuz Connect are supported, along with AirPlay 2 and Roon Ready, giving users plenty of flexibility in how they choose to stream music wirelessly.
Four customizable Smart Select presets provide instant recall of favorite sources, listening modes, and volume settings with a single press of a button on the remote control.
Bluetooth functionality has also been expanded with both receive and transmit modes. This means you can send music from your phone to the MCR 60n or use wireless headphones to listen to music and TV content without disturbing anyone else.
marantz-mcr-60n-remote
Optimization for Any Room
A configurable subwoofer output with adjustable crossover settings is provided for more precise low-frequency integration, while Dirac Live Room Correction is available as an optional upgrade for stereo playback. If users take advantage of that option, they can calibrate the system for their listening environment to improve imaging, tighten bass response, and achieve greater tonal accuracy.
For added setup flexibility, variable audio outputs are also included. This allows the MCR 60n to function as a streaming preamplifier, making it equally suitable for driving active loudspeakers or integrating with existing Marantz components and vintage hi-fi systems. An Ethernet network port, USB input, optical digital input, and DAB tuner (Europe only) round out the feature set.
MCR 60n Specifications
Marantz ModelMCR60n
Product Type All-in-One Hi-Fi System, Streaming Amplifier, Network Audio Player
Price $1,000
Number of Channels 2 or 4
Power Output2 x 65 W or 4 x 33 W
CD Compatibility CD / CD-R/RW / WMA / MP3
TunerFM / AM (US)
DAB / DAB+ (Europe)
Network audio streaming Yes
Streaming SupportSpotify Connect / TIDAL / Deezer / Amazon Prime Music / Pandora
AirPlay 2 Yes
Roon Ready Yes
Internet Radio TuneIn
HEOS Multiroom and Streaming Yes
Bluetooth Yes – Includes AptX
Bluetooth Headphone Transmission Yes
USB AudioDSD / WAV / FLAC / AIFF / ALAC
Lossy formats MP3 / WMA / AAC
Lossless formats DSD / WAV / FLAC / AIFF / ALAC
Gapless Playback Yes (FLAC, WAV, DSD)
Dirac Live Upgradability Yes
Tone ControlBass / Treble / Balance
Low Noise OLED display3  line
Clock Yes – with programmable timer and sleep timer
Audio Inputs1 x Analog
1 x Digital Optical
1 x HDMI-eARC
Audio Outputs1 x Analog
1 x Subwoofer
1 x Main/Preout (AUX Assignable)
1 x Headphone
Speaker OutputsScrew Type Terminals
Speaker A/B with individual volume control
Bi-amp
Parallel BTL
Freq. Response (Analogue In) 10Hz – 40kHz
Signal to Noise Ratio (audio) 90 dB
Input sensitivity/impedance (Analogue In) 200mV / 30 kohms
Total Harmonic Distortion 1 kHz, 5 W, 4 Ω / ohms 0.1%
Remote Control Yes
Ethernet / WiFi Yes
Power Consumption 55 watts
Standby Consumption 0.3 watts
Dimensions (WDH) 280 x 303 x 111 mm
11.0 x 11.9 x 4.4  inches
Weight4.2 kg
9 lbs 4 oz
Included in BoxMain unit
AC cord
Remote control, batteries
FM antenna
AM antenna
Quick start guide
Who Does the Marantz MCR 60n Compete With?
Eversolo Play CD Edition side angle
The Eversolo Play CD Edition (2025 model) is a challenger sitting across the table. At $799, it already combines streaming, amplification, HDMI ARC, a phono stage, room correction, a large touchscreen and a built-in CD drive. It delivers 60 watts per channel into 8 ohms and offers the kind of interface and feature set that has made Eversolo one of the fastest-moving brands in this category.
And here is where Marantz has to earn the extra $201.
The MCR 60n offers HDMI eARC, HEOS, AirPlay 2, Roon Ready support, Bluetooth transmit and receive capability, Dolby Digital and Dolby Digital Plus decoding, and optional Dirac Live. It also carries a name that has been sitting in hi-fi racks for more than 70 years, which still matters to a lot of consumers.
But purely on features and price? Eversolo is not going to make this easy.
For buyers who want the touchscreen, CD ripping capability and maximum functionality for the money, the Play CD Edition looks very difficult to ignore.
The Bottom Line
Marantz has clearly noticed two things: compact streaming amplifiers are everywhere, and CDs have stubbornly refused to disappear.
The new Marantz MCR 60n is the company’s $1,000 answer to both trends, combining a front-loading CD player, HEOS network streaming, HDMI eARC, an MM phono stage, USB and optical inputs, subwoofer connectivity and 65 watts per channel into 4 ohms inside one compact chassis. Optional Dirac Live Room Correction is also part of the package, and the MCR 60n can even operate as a streaming preamplifier with active loudspeakers or an existing hi-fi system.
marantz-mcr-60n-angle-top
Marantz MCR 60n
That makes this considerably more interesting than another streaming amplifier with an app and a Class D output stage. Marantz is effectively betting that there is still a large group of listeners who stream Qobuz or TIDAL, watch television through HDMI eARC, own a turntable, and have a shelf full of CDs that they have absolutely no intention of throwing away. Considering where the market is going, that does not feel like a particularly risky wager.
And then things get slightly awkward.
The MCR 60n costs exactly the same $1,000 as the Marantz MODEL M1, one of our favorite compact streaming amplifiers and an Editors’ Choice winner earlier this year. The M1 offers considerably more amplifier power, but no CD player and no phono stage. The MCR 60n gives up some horsepower and responds with considerably greater source flexibility. Marantz has effectively created two different answers to the same $1,000 question.
Price & Availability
The Marantz MCR 60n is priced at $1,000 and is available from Marantz or Authorized Marantz Dealers.
Note: The similarly named Marantz Model 60n is a $1,600 streaming amplifier without CD playback released in 2024.
2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
Esoteric K1XE CD Player and PS1XE Power Supply Esoteric K1XE CD Player and PS1XE Power Supply
CD Players
CDs are making a comeback, and Esoteric isn't holding back. The $45,000 Grandioso K1XE SACD player adds a new G2 DAC and an optional...
Bumpboxx Retroboom Portable Boombox in Red, Silver, Black Bumpboxx Retroboom Portable Boombox in Red, Silver, Black
The $299 Bumpboxx Retroboom packs 200 watts of peak power, Bluetooth, RGB lighting and 30-hour battery life into a retro boombox without tapes or...
Esprit Generation 10 Cables Esprit Generation 10 Cables
Audio Cables
Esprit Generation 10 cables arrive in the U.S. with redesigned conductors, connectors, and insulation. Nine ranges span $499 to $59,999.
2026 Goldmund Mimesis Statement Preamplifier 2026 Goldmund Mimesis Statement Preamplifier
Goldmund's Mimesis Statement uses three chassis, separate channel power supplies and redesigned analog circuitry. A flagship with a startling price.
2026 Jamo HYG 5 WiFi Speaker Dark Grey Lifestyle 2026 Jamo HYG 5 WiFi Speaker Dark Grey Lifestyle
Jamo's $399 HYG 5 WiFi speaker offers Qobuz Connect, TIDAL Connect, AirPlay 2, Google Cast and three active drivers in a Scandinavian design.
CD Players
The $6,500 MOON 371 challenges expensive separates with exceptional sound, serious engineering, and a few surprises. Is this Simaudio’s finest value yet?
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
CD Players
Musical Fidelity's B1xcd CD player arrives as CD sales surge, offering a dedicated transport, ESS DAC, and serious hi-fi engineering without streaming distractions.
As physical media (both CDs and vinyl) continues its surge in 2026, eCoustics Editor-in-Chief, Ian White takes a look at what's happening behind the...
Hi-Fi Components
Can Fidelity Imports turn its U.S. and Canadian growth into a successful UK hi-fi operation when Fidelity Imports UK opens October 1?
