Audio Cables
Esprit Generation 10 Cables Arrive in America With a $59,999 Flagship
Esprit Generation 10 cables arrive in the U.S. with redesigned conductors, connectors, and insulation. Nine ranges span $499 to $59,999.
The French have a rather interesting relationship with luxury. They produce some of the world’s finest wines, watches, loudspeakers, and automobiles, including the Bugatti Chiron. They’re also rarely embarrassed to charge accordingly. French high-end audio manufacturer Esprit is continuing that tradition with its new Generation 10 cable lineup, also known as Generation X, which is arriving in the United States with prices ranging from $499 to a rather ambitious $59,999 for a pair of speaker cables. At least the Bugatti comes with an engine.
The company’s tenth generation represents its most extensive cable redesign to date, covering everything from affordable by high-end standards speaker cables to reference-level products that cost more than many complete stereo systems. But unlike the usual audiophile exercise of changing the jacket, adding a new connector, and raising the price, Esprit has made substantial changes to the underlying construction.
Founded in 1997 by Richard Cesari in Confolens, France, Esprit began with handmade cables that Cesari originally developed for his own system. Almost three decades later, the company manufactures a broad range of cables, power accessories, and loudspeakers, with engineering and assembly remaining in France.
esprit-generation-10-alpha-speaker-cable
Esprit Generation 10 Alpha Speaker Cable is the least expensive model starting at $499.
What’s Actually Different About Generation 10?
The most significant change involves conductor geometry. In certain Generation 9 designs, Esprit used symmetrical arrangements of 0.08 mm copper strands. Generation 10 introduces an asymmetrical construction in applicable cables, combining 0.08 mm strands for the positive conductor with larger 0.30 mm strands for the negative conductor.
Esprit says this revised architecture improves dynamics and produces a more natural presentation. Changing conductor geometry can alter a cable’s electrical characteristics, but whether those changes produce audible improvements depends on the design and the equipment being connected. We’re not prepared to declare a revolution without listening or meaningful comparative measurements.
The company has also redesigned its connectors to reduce the amount of material in the signal path. Depending on the cable range, these use pure copper, silver-plated copper, or pure silver center pins. At the upper end of the lineup, including the GAÏA and L’ESPRIT XLR models, Esprit uses pure silver pins. Revised aluminum connector housings replace previous sleeves on applicable designs, providing additional mechanical protection.
Insulation receives attention as well. Esprit now applies rigid insulating material under vacuum to create a more stable structure, which the company claims improves low-frequency control and definition. Partial shielding continues from Generation 9 where applicable, while selected ranges that already employed polarization now incorporate double polarization.
l-esprit-generation-10-cables
L’ESPRIT Generation 10 top-of-the-line cable range
Esprit Also Makes Loudspeakers
Esprit isn’t exclusively a cable manufacturer, something that may surprise American audiophiles encountering the brand for the first time.
Its loudspeaker portfolio includes the Stella two-way standmount, featuring an Air Motion Transformer (AMT) tweeter and a 15 cm midwoofer, and the Amelia floorstanding speaker, which pairs an AMT tweeter with a 20 cm Alnico-magnet midwoofer. Larger models include the Lisa and Alicia.
The loudspeakers reflect Cesari’s broader approach to system design, emphasizing driver integration, crossover components, cabinet construction, and acoustic performance. That gives Esprit experience at both ends of the signal chain, although making excellent loudspeakers doesn’t automatically validate the price of an expensive cable.
l-esprit-generation-10-speaker-cable
L’ESPRIT Generation 10 top-of-the-line speaker cable for $59,999 for a 2 meter pair.
Nine Cable Ranges for Almost Every Connection
Generation 10 encompasses nine families: ALPHA, BETA, CELESTA, ETERNA, AURA, LUMINA, EURÊKA, GAÏA, and L’ESPRIT.
Across the collection, Esprit offers speaker cables and jumpers, RCA and XLR analog interconnects, phono cables, S/PDIF and AES/EBU digital cables, USB, Ethernet, master clock connections, and AC power cords. Multiple lengths are available, with cable types and termination options varying by range.
Esprit has also redesigned its connectors, using pure copper, silver-plated pure copper, or pure silver center pins, depending on the product. The objective is to reduce the amount of material in the signal path while maintaining reliable electrical connections.
U.S. pricing starts at $499 for a 2-meter pair of ALPHA speaker cables and reaches $59,999 for a 2-meter pair of flagship L’ESPRIT speaker cables. Additional lengths and configurations are available, with pricing and ordering information provided through authorized U.S. dealers and Playback Distribution.
For enthusiasts maintaining systems with separate DACs, streamers, preamplifiers, monoblock amplifiers, and turntables, the extensive lineup offers the option of building a complete Esprit cable system rather than mixing products from multiple manufacturers.
Whether that approach delivers a worthwhile improvement over carefully selected alternatives remains a question for listening, electrical compatibility, and system matching. Spending nearly $60,000 on speaker cables certainly raises expectations, but the price tag alone doesn’t establish better performance.
Competition: Advance Paris and AudioQuest
Esprit faces some serious competition, including another French brand we’ve already spent considerable time reviewing.
The Advance Paris LINK cables impressed us with their construction, OCC copper conductors, quality connectors, and relatively sensible prices. Its speaker cable models were listed between $399 and $549, with a presentation that offered a touch of warmth and body without sacrificing too much clarity.
Advance Paris doesn’t compete with the most expensive Esprit products, but its LINK range makes a compelling argument for buying well-engineered cables without spending more than the components they connect.
At the other end, the AudioQuest Lone Ranger ZERO-Tech speaker cables start at $2,990 for an eight-foot pair. They employ Perfect-Surface Copper+ conductors, extensive noise-dissipation materials, and AudioQuest’s 72V Dielectric-Bias System.
AudioQuest takes a different engineering approach, making it a more relevant comparison for Esprit’s ambitious middle and upper ranges. Neither brand gets a free pass simply because its technical explanation is longer than a restaurant wine list.
esprit-generation-10-lumina-speaker-cable-bundle
The Bottom Line
Esprit deserves credit for doing considerably more than dressing up its existing cables with new connectors and a fancier jacket. Generation 10 represents a serious engineering effort, and given the company’s experience and attention to detail, we suspect there’s some genuine sonic magic to be found here.
As for the $59,999 flagship? Esprit isn’t alone in this rather exclusive corner of the audiophile universe. Ted Denney’s Synergistic Research offers its SRX XL speaker cables for $50,000 per eight-foot pair, while Siltech’s Royal Triple Crown and certain configurations of AudioQuest’s Dragon cables can cost considerably more. Apparently, there is no shortage of audiophiles willing to spend the price of a luxury automobile connecting their amplifiers to their loudspeakers.
But here’s what makes Esprit interesting. With nine ranges starting at $499, the company offers a path into its engineering philosophy without requiring a second mortgage or an uncomfortable conversation with your financial adviser.
Our advice? Start with ALPHA and work your way up. There’s probably something special happening further up the lineup, but we’d rather discover where the meaningful improvements begin to diminish than assume the most expensive option is automatically the best. If Esprit has managed to trickle down some of its reference-level engineering into the affordable ranges, that might be the real story here.
And if you eventually decide that $59,999 speaker cables are the missing ingredient in your system, we’d love to hear the demonstration. We’d also love to know what you told your therapist.
Pricing & U.S. Availability
Esprit Generation 10 cables are available to order through authorized American dealers, with U.S. distribution handled by Playback Distribution.
Pricing for a two-meter pair of speaker cables starts at $499 for ALPHA and climbs to $59,999 for the flagship L’ESPRIT. Multiple lengths are available, with prices for interconnects, digital cables, and power cords varying by range and configuration.
For more information: esprit-audio.fr
2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle
Head Units
Pioneer's 2026 Heritage Collection in-dash head unit and box speaker set combines retro looks with modern convenience for your car.
2027 Technics SL-1210MKX DJ Turntable Lifestyle 2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
Esoteric K1XE CD Player and PS1XE Power Supply Esoteric K1XE CD Player and PS1XE Power Supply
CD Players
CDs are making a comeback, and Esoteric isn't holding back. The $45,000 Grandioso K1XE SACD player adds a new G2 DAC and an optional...
Bumpboxx Retroboom Portable Boombox in Red, Silver, Black Bumpboxx Retroboom Portable Boombox in Red, Silver, Black
The $299 Bumpboxx Retroboom packs 200 watts of peak power, Bluetooth, RGB lighting and 30-hour battery life into a retro boombox without tapes or...
Esprit Generation 10 Cables Esprit Generation 10 Cables
Audio Cables
2026 Goldmund Mimesis Statement Preamplifier 2026 Goldmund Mimesis Statement Preamplifier
Goldmund's Mimesis Statement uses three chassis, separate channel power supplies and redesigned analog circuitry. A flagship with a startling price.
CD Players
Musical Fidelity's B1xcd CD player arrives as CD sales surge, offering a dedicated transport, ESS DAC, and serious hi-fi engineering without streaming distractions.
Fyne Audio celebrates a decade with its most advanced IsoFlare driver, integrated SuperTrax and just 30 pairs of the $50,000 F1-10 Anniversary.
Magico rebuilds the A3 with M9-derived engineering, new drivers and a new cabinet. The other upgrade? Entry-level Magico now costs $25,000.
Audio Cables
QED refreshes its Performance cables with speaker, RCA, Ethernet and USB options from $49. Who says wiring your first serious system has to hurt?
