Audio Cables
QED Performance Range Gives First-Time Hi-Fi Buyers One Less Thing to Overspend On
QED refreshes its Performance cables with speaker, RCA, Ethernet and USB options from $49. Who says wiring your first serious system has to hurt?
2026 QED Performance Cables
There is a point in almost every first serious hi-fi system where somebody asks the question nobody enjoys answering: how much should I spend on the cables?
The correct answer is usually less than the internet would have you believe.
British cable specialist QED has refreshed its Performance range for 2026 with a 13-product family covering loudspeaker, analog, subwoofer, digital, optical, Ethernet, and USB connections. The idea is straightforward: give buyers one sensibly priced ecosystem for connecting everything from a turntable and CD player to a network streamer, DAC, television, and amplifier without requiring a separate financing application for the wire.
That has always been one of QED’s strengths.
We’ve used and reviewed QED cables extensively at eCoustics, including the Golden Anniversary XT, Reference XT40i, Signature Revelation, Reference Audio 40, Performance J2P, and Reference USB and Ethernet models. The recurring theme has been rather boring in the best possible way: solid construction, sensible pricing, predictable performance, and no suggestion that your $1,000 amplifier requires $3,000 worth of cables to achieve enlightenment.
For someone assembling a first proper system, boring can be beautiful.
What Has Changed?
qed-performance-speaker-cables
QED Performance speaker cables
The new Performance range gets a cleaner visual identity with silver-grey connectors and a softer, more flexible TPE jacket on most models, which should make routing behind equipment racks less like wrestling garden hose. QED says the new styling will eventually carry into its more expensive Reference and Signature ranges.
The underlying materials remain appropriately serious for the price. Most of the range uses 99.999% oxygen-free copper, with 24K gold-plated contacts on analog models; USB connectors use nickel plating instead.
The new Performance Speaker Cable uses a substantial 2.5mm² conductor area with QED’s X-Tube Plus geometry, which is designed to maintain more consistent current density across the conductor as frequency rises. Factory-fitted Airloc banana plugs or spades provide cold-welded terminations rather than leaving new owners to discover how surprisingly annoying bare speaker wire can become behind a crowded rack.
The matching Performance Audio interconnect uses QED’s Solid Complementary Conductor Technology, OFC conductors, shielding, and Ferrite Insulation Technology to reduce high-frequency interference.
This is not exotic metallurgy harvested during a lunar eclipse. That may disappoint some corners of the cable industry.
Digital Finally Gets More Attention
qed-performance-digital-cables-group
The biggest expansion is on the digital side.
QED has added USB configurations covering USB Type-A to Type-B, USB Type-A to Type-C, USB Type-C to Type-C, and USB Type-C to Type-B, with U.S. pricing beginning at $49. The USB models carry independent USB-IF compliance certification, which is considerably more useful than a brochure promising improved emotional connection with your DAC.
Performance Ethernet also starts at $49, while coaxial digital and optical cables begin at $69 and $79 respectively.
That makes the revised lineup considerably more relevant to modern systems built around streamers, network amplifiers, and USB DACs rather than just turntables and CD players.
QED Performance Range Pricing
U.S. availability begins in late November 2026.
Some representative prices:
  • Performance Speaker Cable: $209 / 2m pair; $229 / 3m; $309 / 5m
  • Performance Bi-Wire Links: $169
  • Performance Audio RCA: $89 / 0.75m; $99 / 1.5m
  • Performance Subwoofer: $99 / 3m
  • Performance 3.5mm to RCA: from $69
  • Performance Digital Audio: from $69
  • Performance Optical: from $79
  • Performance Ethernet: from $49
  • Performance USB: from $49
The speaker cable is obviously the largest investment, but even a system using QED speaker cables, an analog interconnect, Ethernet, and USB could remain well below what some manufacturers charge for a single pair of interconnects.
Perspective is useful.
qed-performance-analog-cables-group
Why Is The Performance Range Different?
QED’s strongest argument has never been that cables should become the most expensive part of your system.
The company has spent decades pursuing an evidence-led approach to cable design, including research summarized in its Genesis Report, which examined measurable electrical characteristics and how conductor geometry, resistance, capacitance, and inductance can influence performance. The original QED 79 Strand from 1979 helped establish the concept of specialist loudspeaker cable in the first place.
The Performance range takes that engineering downstream to prices that make sense for a $1,000 amplifier, $1,500 pair of loudspeakers, or modest streaming system.
That makes it particularly appealing to listeners entering hi-fi for the first time. Spend money on better speakers, amplification, cartridges, or room acoustics first. You can always discover $5,000 speaker cables later if retirement planning becomes too predictable.
QED Is Part Of Something Bigger
QED is one of three audio brands owned by Armour Home Electronics, alongside Q Acoustics and Goldring. Armour Home also distributes brands including Grado, Burson Audio, and XGIMI in the UK.
The larger company has been going through a noticeable leadership and growth push in 2026. Former Cambridge Audio CMO and Naim Audio Managing Director Charlie Henderson became Armour Home’s Managing Director in May, while longtime leader George Dexter moved into the Chairman role. Armour has subsequently added new global sales and marketing leadership and recently promoted Anca Popa to lead EMEA sales across QED, Q Acoustics, and Goldring.
We spoke with Henderson this summer about rebuilding visibility in North America after QED, Q Acoustics, and Goldring had become surprisingly quiet in the market. American Audio & Video — part of Exertis | JAM USA — now handles North American distribution for all three brands.
The refreshed Performance range therefore arrives at a useful moment: Armour Home wants QED in front of more mainstream music listeners, and a $49 USB cable is a considerably easier introduction than asking someone to begin with the Signature range.
qed-performance-range
The Bottom Line
The new QED Performance range is not aimed at audiophiles who enjoy explaining why their cable risers require cryogenic treatment.
It is for people building real systems with real budgets.
The technology is credible, the construction looks substantially better than generic accessory-bin cables, USB and Ethernet have finally been brought fully into the family, and prices remain low enough that newcomers can wire a serious system without wondering whether they should have bought better loudspeakers instead.
We’ve used QED cables for years precisely because they tend to offer performance without financial theater. For anyone building their first serious hi-fi or home theater system, that remains a very good place to start.
For more information: qed.co.uk
2026 Chord Electronics Ultimatum Amplifier Silver Front
Chord Electronics ULTIMATUM delivers up to 9,000 watts with 96 MOSFETs and a £120,000 price per monoblock. Who actually needs this much power?
2026 Sendy Peacock Pro Open-Back Headphones Earcup Open 2026 Sendy Peacock Pro Open-Back Headphones Earcup Open
Sendy Audio's $1,999 Peacock Pro flaunts its feathers with tiger maple, gold accents, and 88mm planar drivers. But does it have the sound to...
Gadhouse Eric Portable CD Player Lifestyle Gadhouse Eric Portable CD Player Lifestyle
CD Players
The Gadhouse Eric portable CD player offers Bluetooth CD listening, HQCD support, FM radio and wall mounting for under $90. Is it worth buying?
Waiting for Ideas PP-2 turntable hand pointing Waiting for Ideas PP-2 turntable hand pointing
At nearly $10,000, the second-generation PP-2 replaces conventional cartridge expectations with an optical pickup, a revised direct-drive motor, and a minimalist design that hides...
2026 Noble Audio Paladin IEMs Top 2026 Noble Audio Paladin IEMs Top
Noble Audio Paladin combines 12 drivers, bone conduction and planar technology. Is this $3,500 tribrid IEM the new benchmark for neutrality?
2026 HEDD Audio HEDDphone DX Open-Back Headphones Side Lifestyle 2026 HEDD Audio HEDDphone DX Open-Back Headphones Side Lifestyle
HEDDphone DX adds a high-excursion carbon driver, 20Hz bass and improved comfort. Is this $1,199 dynamic headphone a threat to planar rivals?
Black Friday Gift Guide 2026
Black Friday gift ideas and real deals on headphones, speakers, hi-fi and home theater you'd actually enjoy at the lowest prices all year.
Audio Cables
Esprit Generation 10 cables arrive in the U.S. with redesigned conductors, connectors, and insulation. Nine ranges span $499 to $59,999.
Loudspeakers
Armour Home boss Charlie Henderson explains how Q Acoustics, Goldring and QED plan to rebuild U.S. visibility, expand products and reach younger listeners.
A skeptical, experience-driven take on hi-fi accessories that actually work—QED, Advance Paris, IsoAcoustics, IsoTek, iFi, ddHiFi—minus the snake oil.
Our favorite audio accessories can make your turntable, speakers or headphones sound even better.
Loudspeakers
Highly acclaimed Q Acoustics loudspeakers, QED cables, and Golding phono cartridges to see wider availability across the United States.
Audio Cables
High-end cables made in France? Do British and American manufacturers need to be concerned? The Advance Paris LINK have us excited to try them.
Audio Cables
QED's top-of-the-line speaker cables priced from $2,100 to $3,900 feature high-quality zirconia plugs and barrels.
QED and Chord Company proved to us you don't need to spend exorbitant amounts of money on speaker cables to get great sound.
