CD Players
Esoteric Grandioso K1XE SACD Player Makes a $45,000 Case for Keeping Your CDs
CDs are making a comeback, and Esoteric isn’t holding back. The $45,000 Grandioso K1XE SACD player adds a new G2 DAC and an optional $19,000 power supply.
Esoteric K1XE CD Player and PS1XE Power Supply
We’ve spent much of 2026 documenting the compact disc’s rather inconvenient comeback, and the numbers are getting difficult for streaming evangelists to ignore. According to the RIAA’s latest midyear figures, U.S. CD sales increased 45.7% to 17.5 million units, while wholesale revenue jumped 58.6% to $171.1 million. We’ve covered everything from FiiO’s $170 DP11 to Accuphase’s DP-470, proving that the little silver disc is enjoying a resurgence at both ends of the market.
Esoteric, however, has decided that this comeback needs a considerably more expensive dress code. The Japanese high-end manufacturer has introduced the Grandioso K1XE, a $45,000 flagship SACD/CD player and DAC featuring its latest discrete conversion technology and an elaborate mechanical transport. And because spending that much on a disc player might leave you feeling dangerously undercommitted, there’s an optional $19,000 PS1XE external power supply that brings the complete package to $64,000. The compact disc may be enjoying a second life, but Esoteric seems determined to make sure it retires somewhere considerably nicer than the rest of us.
The new K1XE combines Esoteric’s massive VRDS-ATLAS disc transport with its second-generation Master Sound Discrete DAC G2, independent power supplies, and expanded digital connectivity. The optional Grandioso PS1XE takes the power supply architecture further, separating the analog conversion and output buffer stages from the player’s internal power system.
We’ve covered Esoteric extensively throughout 2026, including the $13,000 N-05XE Network DAC/Preamplifier, the $28,000 N-01XE Network Player/DAC, and the rather imposing $50,000 T-01 MagneDrive turntable. More recently, the company introduced Black Editions of its F-01 and F-02 integrated amplifiers, demonstrating that Japanese audio engineering can embrace a little visual theater without abandoning its technical priorities.
The Grandioso K1XE represents a different level of investment. It’s designed for serious physical-media collectors who want a reference-level disc player that can also function as the digital conversion centerpiece of a much larger Esoteric system.
The VRDS-ATLAS Transport Is an Exercise in Mechanical Obsession
esoteric-k1xe-vrds-atlas-angle
VRDS-ATLAS
Esoteric’s VRDS technology has been central to its reputation for decades, and the Grandioso K1XE employs the company’s most elaborate VRDS-ATLAS mechanism.
VRDS stands for Vibration-Free Rigid Disc-Clamping System, an approach that secures a CD or SACD to a precision turntable approximately matching the disc’s diameter. The design is intended to reduce rotational vibration, improve disc flatness, and maintain more accurate alignment between the optical pickup and the recorded surface.
Unlike conventional disc-loading mechanisms, the VRDS-ATLAS is a substantial piece of precision engineering. The mechanism alone weighs approximately 6.6kg (14.6 pounds), rising to 13.5kg (29.8 pounds) when its mounting base is included.
The structure incorporates SS400 steel side panels and bridge components, a duralumin turntable, and a specialized thrust-bearing system supporting the spindle. Esoteric has also positioned the motor beneath the turntable to lower the center of gravity and provide a shorter mechanical path for unwanted vibration.
All of this is intended to stabilize the disc-reading process and reduce mechanical noise. Whether these refinements translate into an audible improvement over less elaborate transports requires careful comparison, particularly because modern digital error correction already performs remarkably well.
Still, it’s difficult not to admire the construction. Most manufacturers would consider a 30-pound disc transport an engineering problem. Esoteric considers it the foundation.
Master Sound Discrete DAC G2: The Real Digital Upgrade
The K1XE’s most significant electronic development is the adoption of Esoteric’s Master Sound Discrete DAC G2, a second-generation conversion platform built entirely around the company’s proprietary circuitry.
Rather than using a conventional DAC chipset from ESS, AKM, or another semiconductor manufacturer, Esoteric employs a field-programmable gate array (FPGA) and carefully selected discrete components in a multilevel delta-sigma conversion architecture.
We’ve already explored this technology in our N-05XE and N-01XE coverage, but its implementation in the Grandioso K1XE is particularly ambitious.
esoteric-k1xe-cd-player-internal
The new G2 design includes a redesigned low-noise resistor network with simplified switching circuitry and additional capacitors positioned close to the conversion elements. Separate regulation for the FPGA, other digital circuitry, and the positive and negative analog supply rails is intended to reduce electrical interference.
Esoteric has also upgraded the analog output stage with a dual-buffer configuration derived from its flagship Grandioso D1X SE. The proprietary High Current Line Driver (HCLD) uses four buffer circuits per channel and has a specified slew rate of 2,000 V/μs.
The resulting DAC architecture supports PCM signals up to 768kHz and DSD up to 22.5MHz through compatible digital inputs. These are the conversion platform’s capabilities, not the native resolutions of commercially released CDs or SACDs.
There’s an important distinction here: the G2 is a genuine architectural update over the original Master Sound Discrete DAC, but the published specifications alone don’t establish an audible advantage over the previous K1X SE. That will require direct comparison rather than another enthusiastic reading of the engineering brochure.
esoteric-ps1xe-interior
PS1XE power supply
Five Internal Power Supplies. Because Three Would Be Too Reasonable.
The Grandioso K1XE employs a fully dual-mono DAC configuration, with independent circuitry for the left and right channels despite sharing a single chassis.
Esoteric has incorporated five independent linear power supply systems dedicated to the left and right DAC sections, disc transport, digital audio circuitry, and microcomputer control. The objective is to isolate circuit sections with different electrical demands, reducing the possibility of noise and interference affecting the analog output.
A proprietary Master Sound Discrete Clock is also included, along with a 10MHz synchronization input for connection to a compatible external master clock such as the Grandioso G1X.
Build quality receives the customary Grandioso treatment, including a multilayer chassis, semi-floating top panel, and specialized isolation feet. The K1XE weighs 34.3kg (75.6 pounds), so make sure your equipment rack is rather more substantial than something assembled with leftover IKEA hardware.
Grandioso PS1XE: A $19,000 Power Supply That Actually Changes the Architecture
The optional PS1XE isn’t simply another box containing a larger transformer and a reassuringly expensive power cord.
It contains four independent power transformers dedicated to the left and right D/A conversion stages and their corresponding analog output buffers. When connected, the relevant internal analog power transformers in the K1XE are disabled, allowing the external unit to assume those duties while the player’s remaining internal supplies continue operating.
That distinction is important because the PS1XE changes how power is distributed to the analog circuitry. It isn’t required for the player to function, and it doesn’t replace every internal power supply.
Esoteric says the arrangement provides improved electrical isolation, reduced magnetic interference, and more stable operation of the DAC and output stages.
The PS1XE is also compatible with the Grandioso N1 network player and earlier Grandioso K1X and K1X SE models, giving owners of those components another potential upgrade path.
Of course, the PS1XE weighs another 23.3kg (51.4 pounds). Together, the player and external supply weigh approximately 127 pounds, which is a considerable amount of Japanese engineering dedicated to spinning a five-inch disc.
At this price, the audible benefit needs to be demonstrated rather than taken on faith. A carefully controlled comparison of the K1XE with and without the external supply would be considerably more useful than another claim about hearing deeper into the recording.
esoteric-k1xe-cd-player-rear
esoteric-ps1xe-rear
The K1XE Is More Than an SACD Player
One of the more useful changes is the addition of an ES-Link 5 digital input, allowing the K1XE to work with Esoteric’s Grandioso N1T network streaming transport.
That creates a system combining physical-disc playback and network streaming through the same digital-to-analog conversion platform. The K1XE also includes USB-B, balanced XLR digital, and optical inputs for other compatible digital sources.
On the output side, it offers conventional balanced and unbalanced analog connections, along with Esoteric’s proprietary ES-Link Analog current-signal transmission for compatible preamplifiers and amplifiers.
It’s worth emphasizing that the K1XE is not a standalone network streamer. Owners who want integrated network playback will need a compatible external transport or another digital source.
The appeal is flexibility without compromising the dedicated disc mechanism. Someone with a substantial SACD collection can retain physical playback while adding network audio as a separate system component rather than replacing the player when streaming technologies change.
Esoteric Grandioso K1XE Specifications
  • Type: Flagship Super Audio CD/CD player and external DAC
  • Disc transport: Esoteric VRDS-ATLAS
  • Transport assembly weight: 13.5kg (29.8 pounds), including mounting base
  • DAC: Master Sound Discrete DAC G2
  • Conversion architecture: FPGA-based multilevel delta-sigma with discrete components
  • DAC channel configuration: Fully dual-mono
  • Maximum DAC resolution: PCM up to 768kHz; DSD up to 22.5MHz with compatible digital input signals
  • Internal power supplies: Five independent linear supply systems
  • Analog outputs: Balanced XLR/ES-Link Analog (L/R), RCA (L/R)
  • Digital inputs: ES-Link 5 (L/R), XLR, optical, USB Type-B
  • Digital output: XLR
  • External clock input: BNC, 10MHz
  • Frequency response: 5Hz–30kHz (-3dB)
  • Signal-to-noise ratio: 113dB
  • Distortion: 0.001% at 1kHz
  • Dimensions (W × H × D): 445 × 162 × 447mm (17⅝ × 6½ × 17⅝ inches)
  • Weight: 34.3kg (75.6 pounds)
  • U.S. MSRP: $45,000
Grandioso PS1XE External Power Supply Specifications
  • Type: Optional external analog power supply
  • Compatible products: Grandioso K1XE, N1, K1X SE, and K1X
  • Power transformers: Four independent transformers
  • Power distribution: Separate supplies for left/right DAC and analog output buffer stages
  • Chassis: Multilayer construction with semi-floating top panel
  • Isolation: Advanced isolation feet
  • Dimensions (W × H × D): 445 × 132 × 451mm (17⅝ × 5¼ × 17⅞ inches)
  • Weight: 23.3kg (51.4 pounds)
  • U.S. MSRP: $19,000
Both products are scheduled to begin worldwide shipments in November 2026.
What Competes With a $45,000 SACD Player?
At this level, buyers aren’t simply comparing transport mechanisms and distortion measurements. They’re choosing between different approaches to reference digital playback, and two alternatives deserve attention.
Accuphase DP-1000 Transport and DC-1000 Digital Processor: $49,950 Combined
Accuphase takes the traditional separates approach with its DP-1000 SACD/CD transport and matching DC-1000 digital processor. The transport incorporates a rigid precision-machined drive, while the DC-1000 employs an eight-channel parallel conversion architecture built around ESS ES9038PRO DAC technology.
The combination is listed at approximately $49,950 through U.S. dealers, positioning it directly against the K1XE before adding Esoteric’s optional power supply.
Accuphase emphasizes mechanical refinement and its proprietary MDSD/MDS++ conversion techniques, while Esoteric takes a more customized approach with its entirely discrete DAC architecture. Both are serious Japanese high-end digital systems, but their internal engineering philosophies are substantially different.
Playback Designs MPS-8 Dream Player: $27,000 – $30,000
The American-made Playback Designs MPS-8 offers another compelling approach by combining an SACD/CD transport, proprietary discrete DAC technology, and an optional internal network streaming module.
It supports digital inputs up to 384kHz PCM and 11.2MHz DSD, depending on the connection, and offers balanced and unbalanced analog outputs.
The MPS-8 is considerably less expensive than the K1XE, even when equipped with its optional streaming hardware. Its architecture also makes it a more compact solution for listeners who want physical media and network playback without assembling an increasingly elaborate collection of components.
Neither alternative makes the Grandioso irrelevant, but both demonstrate how much competition exists at the upper end of digital playback.
esoteric-k1xe-cd-player-front
Who Is the Grandioso K1XE For?
The obvious customer is a serious CD and SACD collector who already owns an exceptionally capable system and wants physical media reproduction treated with the same engineering priorities normally reserved for reference turntables.
There’s also a strong argument for longevity. Unlike a streaming platform tied to software services and constantly changing network requirements, a dedicated disc transport remains useful as long as the mechanism can be maintained and replacement parts remain available.
The K1XE’s digital inputs provide additional flexibility, allowing owners to use its conversion circuitry with external transports and digital sources. That doesn’t make it a universal solution, particularly when very capable SACD players and standalone DACs are available for a fraction of the price. Nor does the elaborate construction establish that the K1XE will sound better than less expensive competitors.
But Esoteric isn’t competing for customers who prioritize minimizing the number of boxes or maximizing features per dollar. The Grandioso customer is making a deliberate investment in a specific approach to mechanical engineering, digital conversion, and system architecture.
esoteric-k1xe-cd-player-angle
The Bottom Line
The Grandioso K1XE is significant because Esoteric has updated the parts that matter most rather than simply giving an existing player a new badge and another anniversary finish. The G2 discrete DAC, revised analog circuitry, improved power-supply architecture, and expanded digital connectivity make this a substantial technical development.
The VRDS-ATLAS transport remains one of the most elaborate mechanisms in consumer digital audio, although Esoteric still needs to demonstrate how its engineering translates into measurable and audible advantages over competing SACD players.
At $45,000, the K1XE is already operating in a very exclusive market. Spending another $19,000 on the PS1XE raises the obvious question of diminishing returns, particularly when the complete system approaches the price of a rather nice automobile.
But there’s something refreshing about a manufacturer continuing to develop serious physical-media hardware when much of the industry has decided that renting access to music is the only sensible future.
2026 Nagra AMP II-S Stereo Power Amplifier
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro
Can RayNeo turn AR glasses into a private home theater? GT Max offers a 307-inch virtual screen, 120Hz Micro-OLED and Dolby Vision via Pocket...
Grado Signature S150 Headphones Grado Signature S150 Headphones
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
2026 Schiit Mani 3 Phono Preamp 2026 Schiit Mani 3 Phono Preamp
Schiit Mani 3 phono preamp adds front-panel controls, MM/MC cartridge flexibility, and improved circuitry without raising the price.
2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle 2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle
Head Units
Pioneer's 2026 Heritage Collection in-dash head unit and box speaker set combines retro looks with modern convenience for your car.
2027 Technics SL-1210MKX DJ Turntable Lifestyle 2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
CD Players
Musical Fidelity's B1xcd CD player arrives as CD sales surge, offering a dedicated transport, ESS DAC, and serious hi-fi engineering without streaming distractions.
As physical media (both CDs and vinyl) continues its surge in 2026, eCoustics Editor-in-Chief, Ian White takes a look at what's happening behind the...
Can MoFi turn Michael Jackson’s 16-bit/48kHz BAD master into audiophile vinyl? A new $125 One-Step pressing and $35 SACD are coming.
CD Players
FiiO’s $170 DP11 adds AES, a CS43198 DAC, CD ripping and USB conversion because apparently nobody told the compact disc it was dead.
Marantz MCR 60n combines a CD player and streaming amplifier with HDMI eARC, MM phono and optional Dirac Live. Is this the all-in-one hi-fi...
Is 4K Blu-ray really dead? Magnetar’s ULTIMA reference transport makes its U.S. debut at CEDIA 2026 with an ambitious battery-assisted power design.
Esoteric’s $28,000 N-01XE inherits the Grandioso N1’s discrete DAC and G4 network engine. Is flagship digital performance getting cheaper?
