Esoteric N-01XE Brings Grandioso Technology to a $28,000 Network Player/DAC With Five Power Supplies Because Of Course It Does
Esoteric’s $28,000 N-01XE inherits the Grandioso N1’s discrete DAC and G4 network engine. Is flagship digital performance getting cheaper?
2026 Esoteric N-01XE Network Player/DAC
The streaming market has become remarkably good at convincing audiophiles that they need another box between their router and amplifier. Esoteric has taken a somewhat different approach with the new $28,000 N-01XE Network Player/DAC. Rather than pile on features and hope someone notices, the Japanese manufacturer has pulled two of its most important digital technologies from the flagship Grandioso N1 and dropped them into its 01 Series.
The result is a $28,000 network player/DAC weighing more than 61 pounds, with five independent linear power supplies, a fully discrete DAC architecture and optical network connectivity. Because apparently streaming music from Qobuz needed its own power station.
The Grandioso Connection Is the Real Story
The most significant changes are the Master Sound Discrete DAC G2 and fourth-generation Esoteric Network Engine G4, both derived from the Grandioso N1.
That makes the N-01XE more than the usual evolutionary product refresh. Esoteric is moving its newest digital conversion and network technologies into the 01 Series while retaining the kind of mechanical and power-supply engineering that has become part of the brand’s identity.
The DAC deserves most of the attention. Rather than using a conventional DAC chipset from ESS, AKM or another semiconductor manufacturer, Esoteric builds its Master Sound Discrete DAC G2 in-house around an FPGA-based, multilevel delta-sigma architecture.
esoteric-n-01xe-rear
The implementation uses 32 discrete elements per channel, ultra-high-precision MELF resistors and Esoteric’s IDM-01 amplification elements. Separate FPGA algorithms handle PCM and DSD conversion, with support for PCM up to 768 kHz and DSD up to 22.5 MHz.
The G2 revision also redesigns the flip-flop circuitry controlling the resistor elements and further separates the power supplies for the FPGA, other digital circuitry and the analog stages. Esoteric has even added capacitors close to the resistor elements to improve current delivery and reduce noise.
That level of engineering is what separates the N-01XE from the ocean of network players built around increasingly similar chipsets and streaming platforms. Whether you can hear $28,000 worth of separation is another discussion entirely.
esoteric-n-01xe-inside
Five Linear Power Supplies Inside a Streamer
Esoteric has never been particularly interested in doing things halfway.
Although the N-01XE is a stereo component, the DAC section uses a fully dual-mono architecture, with independent transformers for the left and right channels. Additional dedicated supplies serve the network engine, digital circuitry and microcontroller, bringing the total to five independent linear power supplies.
There is also a multilayer chassis, semi-floating top panel and Esoteric’s isolation feet. The finished component measures approximately 17 5/8 x 6 1/2 x 17 1/4 inches and weighs 61 3/8 pounds.
Sixty-one pounds for a network player sounds ridiculous until one looks inside an Esoteric component. Nobody in Tokyo received the memo about making streamers small enough to hide behind the sofa.
The Network Engine G4 Takes Fiber Seriously
Esoteric’s new Network Engine G4 also deserves more attention than the usual “improved streaming platform” language. The G4 has its own dedicated linear power supply and incorporates both conventional RJ45 Ethernet and an SFP port, allowing the N-01XE to connect to a network using optical fiber.
The potential advantage is electrical isolation. A fiber connection can break the conductive path between the audio component and upstream network hardware, preventing electrical noise from traveling along that connection.
Esoteric also gives the G4 its own built-in network switch functionality, and the RJ45 and SFP connections can be operated simultaneously. The network section uses a toroidal transformer, custom capacitors and Schottky barrier diodes rather than a basic switching supply.
Streaming support includes TIDAL, TIDAL Connect, Qobuz, Qobuz Connect, Roon, Spotify and QQ Music. USB storage can be connected directly for local playback, and supported formats include DSF, DSDIFF, FLAC, ALAC, WAV, AIFF, MQA, MP3 and AAC.
esoteric-n-01xe-rear-closeup
Connectivity
Esoteric has also retained plenty of options for owners with serious digital systems.
Digital inputs include ES-Link5, USB Type-B, balanced XLR digital, coaxial RCA and optical, while analog output is provided through RCA and balanced XLR/ES-Link Analog connections.
There is also a 10 MHz BNC clock input for use with external master clocks such as Esoteric’s G-01XD and G-05. ES-Link5 permits connection to compatible Esoteric SACD transports, while ES-Link Analog provides the company’s proprietary current-transmission connection to compatible electronics.
This is where the N-01XE starts making considerably more sense for someone who already owns other Esoteric components. System integration is clearly part of the proposition.
Some Useful Perspective From My Own Listening Room
I am currently reviewing two components that put the $28,000 Esoteric N-01XE into rather useful perspective: the $6,500 MOON 371 Network Player/Amplifier and Esoteric’s own $13,000 N-05XE Network DAC Preamplifier.
The MOON 371 attacks the problem from almost the opposite direction. For less than one-quarter of the N-01XE’s price, it combines MiND 2 network streaming, DAC, preamplification, MM/MC phono and 100 watts per channel into 8 ohms, doubling to 200 watts into 4 ohms. Add loudspeakers and you essentially have a complete system.
The N-05XE is an even more interesting comparison because it comes from Esoteric’s own stable. At $13,000, it combines network streaming, the Master Sound Discrete DAC G2, Network Engine G4, a fully balanced dual-mono preamplifier and headphone amplification. It even supports the same SFP optical networking concept found in the new N-01XE.
So why spend another $15,000 on the N-01XE and give up the preamplifier and headphone amplifier?
That question gets to the heart of this product. The N-01XE is not Esoteric’s value proposition or its answer for somebody trying to eliminate boxes. It takes the streaming and conversion side much further, with the more elaborate dual-mono DAC implementation, five independent linear power supplies, more ambitious chassis construction and deeper integration with Esoteric transports, external clocks and ES-Link Analog.
Having the MOON 371 and N-05XE here for review should make that distinction especially interesting. One represents how much functionality and amplification $6,500 can buy in 2026; the other demonstrates how much of Esoteric’s digital technology is already available for $13,000.
The N-01XE has to make the case for spending $28,000 just on the digital front end.
And at that price, it had better be one hell of a case.
What Competes With the Esoteric N-01XE?
Innuos takes a very different approach with the $24,100 ZENith Next-Gen. Like Esoteric, the Portuguese manufacturer has gone to considerable lengths to address power-supply noise, processing architecture and digital signal integrity, but the ZENith is a server/streamer rather than a network player with a reference DAC built in. Add 2TB of internal storage and Innuos’ $1,950 PhoenixUSB output board and the package rises to $27,150, putting it almost directly against the $28,000 N-01XE on price. The catch? You still need a DAC.
The other obvious rival is the dCS Bartók APEX, priced at $20,950, or $22,950 with its headphone amplifier. It combines network streaming, DAC, upsampling and preamplifier functionality around dCS’s proprietary Ring DAC APEX architecture.
That creates a fascinating philosophical comparison.
dCS has its Ring DAC. Esoteric has its Master Sound Discrete DAC G2. Neither relies on an off-the-shelf converter chipset, and both companies have spent decades developing their own solutions to the same problem.
Neither solution comes cheap.
esoteric-n-01xe-front
The Bottom Line
The Esoteric N-01XE isn’t interesting because it streams Spotify, Qobuz and TIDAL. Products costing 97% less can manage that rather well. What separates it is the hardware behind the streaming.
The second-generation discrete DAC, G4 network engine with optical connectivity, five independent linear power supplies, dual-mono construction and Esoteric system integration make this a very different animal from the typical premium streamer/DAC.
The $28,000 price narrows the audience rather dramatically, and the MOON 891 and dCS Bartók APEX both offer considerably more system functionality for less money. Buyers choosing the Esoteric are therefore making a very deliberate decision: they already have the rest of the system and want the digital source treated with the same level of excess normally reserved for amplifiers and turntables.
A 61-pound network player might sound absurd.
In the context of Esoteric, it almost seems inevitable.
Pricing & Availability
The Esoteric N-01XE Network Player/DAC will carry a U.S. MSRP of $28,000, with international shipments scheduled to begin in November 2026.
For more information: esoteric.jp
2026 Audiolab PPA7 Phono Preamp Black LIfestyle
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
2026 T+A Solitaire T Pro Wireless Headphones 2026 T+A Solitaire T Pro Wireless Headphones
T+A Solitaire T Pro adds Dolby Atmos, aptX Lossless and premium DAC technology, but are luxury wireless headphones becoming too expensive?
2026 Vinnie Rossi Canta Integrated Amplifier Angle 2026 Vinnie Rossi Canta Integrated Amplifier Angle
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
2026 NAD C 359S Integrated Amplifier 2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
2026 NAD C 569 CD Player 2026 NAD C 569 CD Player
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
2026 Sony Walkmans 2026 Sony Walkmans
DAPs
Sony's new Walkmans for 2026 include the ZX900, WM1AM3 and WM1ZM3 hi-res digital audio players (DAPs) packed with performance and priced at a premium.
CD Players
Musical Fidelity's B1xcd CD player arrives as CD sales surge, offering a dedicated transport, ESS DAC, and serious hi-fi engineering without streaming distractions.
Fyne Audio celebrates a decade with its most advanced IsoFlare driver, integrated SuperTrax and just 30 pairs of the $50,000 F1-10 Anniversary.
Magico rebuilds the A3 with M9-derived engineering, new drivers and a new cabinet. The other upgrade? Entry-level Magico now costs $25,000.
$9,499 for the ultimate Roon music server includes OCXO clocking, DSD512 and up to 8TB storage because apparently ordinary music servers were getting complacent.
