LUMIN S2 Network Player Adds Trickle-Down Technology and Something New: Digital Inputs
LUMIN’s S2 includes DAC technology from its X1 Network Music Player and new digital inputs, but there’s no HDMI or wireless connectivity.
2026 Lumin S2 Network Audio Player Silver
High-end network players have reached the point where some cost more than a decent used car, yet many still behave as though streaming is the only digital source anyone owns.
The new LUMIN S2 Network Player takes a different approach. It revives the company’s S-Series with technology derived from the flagship X1, including dual ESS ES9038PRO DACs, Lundahl output transformers, dual femto clocks, and a dual-toroidal linear power supply. More importantly, LUMIN has added coaxial and optical digital inputs, allowing a CD transport, television, computer, or other digital source to use the S2’s internal DAC.
LUMIN describes this as the first of its “Players” to offer digital inputs. There is a little marketing taxonomy involved there: the company’s P1 and newer P2 Network Music Hubs already accept external digital sources. The difference is that LUMIN has now brought that flexibility into the more traditional S-Series network player format.
Better late than pretending everyone threw away their CD transport in 2014.
lumin-s2-black-inside
X1 Architecture Moves Down the Range
The heart of the S2 is a pair of ESS ES9038PRO 32-bit, eight-channel DACs operated in dual-mono configuration, with one chip dedicated to each channel. LUMIN pairs those with a fully balanced analog output stage using the same Lundahl LL7401 output transformers found in its upper-tier products.
Power comes from two internally mounted and shielded toroidal transformers, with separate analog and digital power circuitry and low-noise regulation. LUMIN has also moved the S2 to its latest processing platform, which provides additional processing and storage headroom for streaming, resampling, and future firmware development.
Network playback supports PCM up to 32-bit/384kHz and DSD512, while users can optionally upsample content to PCM 384kHz or DSD256. Streaming support includes Qobuz Connect, TIDAL Connect, Spotify Connect, Amazon Music, Roon Ready, AirPlay, Audirvāna, JPLAY, KKBOX, and internet radio, along with LUMIN’s own control app.
The S2 also retains Leedh Processing lossless digital volume control, allowing it to drive a power amplifier or active loudspeakers directly in an all-digital system.
lumin-s2-silver-rear
Digital Inputs Are the Big Addition
The Lumin S2 Network Player provides one RCA coaxial S/PDIF input and one TOSLINK optical input. Both accept PCM up to 24-bit/192kHz and DSD64 via DoP.
That may not sound revolutionary — plenty of considerably cheaper streamers have offered digital inputs for years but it changes what the S2 can do inside a high-end system. A CD transport or other digital component can now take advantage of the S2’s dual-mono DAC and analog output stage rather than requiring a separate DAC.
LUMIN also includes a USB digital output supporting PCM up to 32-bit/384kHz and native DSD512 for listeners who prefer an external DAC. A shared USB connection can be used with external storage devices as well.
Network connectivity is also rather useful, with both Gigabit Ethernet and an SFP optical-network connection that can be used simultaneously. The latter allows users with compatible networking hardware to electrically isolate the player from the rest of the network.
What Is Missing?
For something being positioned as a more flexible digital source, LUMIN has left several increasingly common connections on the table.
There is no HDMI ARC/eARC input, no USB audio input for connecting a computer directly to the DAC, and no AES/EBU input. LUMIN also does not list Wi-Fi or Bluetooth; network connectivity remains wired through Ethernet or SFP. There are no analog inputs, headphone output, phono stage, subwoofer output, room correction, or internal music storage.
That does not make the S2 incomplete so much as very specifically LUMIN. This is a network player and high-end DAC with volume control, not an attempt to replace every component between your turntable and loudspeakers.
Still, HDMI would have been useful. Even audiophiles own televisions now.
lumin-s2-silver-iso-facing-left
LUMIN S2 Specifications:
  • Type: Network music player, DAC, digital preamplifier
  • DAC: Dual ESS ES9038PRO, dual-mono configuration
  • Analog Stage: Fully balanced with dual Lundahl LL7401 output transformers
  • Clocking: Dual femto clock system with FPGA distribution
  • Network Playback: PCM up to 32-bit/384kHz; DSD512, MQA Full Decoding
  • Upsampling: PCM up to 384kHz; DSD256
  • Digital Inputs: 1x coaxial RCA S/PDIF; 1x optical TOSLINK
  • Digital Input Resolution: PCM up to 24-bit/192kHz; DSD64 via DoP
  • Digital Output: USB; PCM up to 32-bit/384kHz; native DSD512
  • Analog Outputs: Balanced XLR, 6Vrms; RCA, 3Vrms
  • Networking: Gigabit Ethernet RJ45; Gigabit SFP optical
  • USB Storage: Supported
  • Streaming: Qobuz Connect, TIDAL Connect, Spotify Connect, Amazon Music, Roon Ready, AirPlay, Audirvāna, JPLAY, KKBOX
  • Volume Control: Leedh Processing
  • Power Supply: Internal dual-toroidal supply with separate analog and digital circuitry
  • Dimensions (W x D x H): 350 x 380 x107 mm (13.8 x 15 x 4.2 inches)
  • Weight: 8 kg (17.6 lbs)
  • Finishes: Black anodized aluminum or raw aluminum
Alternatives
At $3,680, Eversolo DMP-A10 combines network playback with extensive connectivity, room correction, internal storage capability, a 6.5-inch touchscreen, preamplifier functionality, and the ability to rip CDs when connected to an external optical drive. It is less purist and considerably more interested in being the digital Swiss Army knife of your system.
At the other end sits the Marantz LINK 10n, now priced at $14,000. It is a full streaming preamplifier with balanced and unbalanced analog inputs, MM/MC phono, HDMI ARC, coaxial and optical digital inputs, headphone output, subwoofer output, Wi-Fi, Bluetooth, and HEOS streaming. It does substantially more than the S2, although at a price that may encourage a brief conversation with whoever shares your bank account.
The Bottom Line
The LUMIN S2 Network Player is interesting because it moves the company’s traditional network-player formula closer to becoming the digital center of a serious two-channel system without turning it into an everything-in-one box.
Its dual ES9038PRO DACs, Lundahl transformer-coupled output stage, optical networking, dual-toroidal power supply, and very broad streaming support put the emphasis squarely on high-end digital playback. The new coaxial and optical inputs finally allow other sources to benefit from that hardware as well.
The omissions are equally deliberate. Buyers looking for HDMI, Wi-Fi, Bluetooth, room correction, analog inputs, or a giant touchscreen will find competitors that provide them.
At about $9,000 USD, Lumin seems to position S2 between its T3X ($6,000) and flagship X2 ($16,800) in the company’s current network player lineup.
Lumin clearly is not trying to win a features-per-dollar contest. The S2 is aimed at listeners willing to pay for its dual ES9038PRO architecture, Lundahl transformer-coupled output stage, serious power supply, optical networking, and focused approach to high-end digital playback.
It is an impressively serious digital source.
At $8,990, it had better be.
For more information: luminmusic.com
1 Comment
1 Comment
  1. Alex
    October 16, 2026 at 12:12 pm
    Note that the new LUMIN P2 has those HRMI/ARC connections (and more inputs) for those wanting to use it as more of a hub.
2026 Vincent Audio SA-32MK and SV-737MK
Vincent Audio updates its SV-737MK and SA-32MK with HDMI ARC and Bluetooth while retaining hybrid tube circuitry. Is losing Wi-Fi a mistake?
2026 ELAC Debut Reference 3.0 DBR63 stand-mount loudspeaker lifestyle 2026 ELAC Debut Reference 3.0 DBR63 stand-mount loudspeaker lifestyle
ELAC's $899 Debut Reference 3.0 DBR63 gets an aluminum tweeter, new aramid woofer, and premium styling. Is this the bookshelf speaker to beat?
2026 Fluance RT86 Turntable Angle Black Lifestyle 2026 Fluance RT86 Turntable Angle Black Lifestyle
The Fluance RT86 offers a carbon fiber tonearm, acrylic platter, and cartridge choices in a single-plinth design. Is saving $100 over the RT87 worth...
2026 Volumio Rivo Ultra Streaming Transport 2026 Volumio Rivo Ultra Streaming Transport
Volumio Rivo Ultra makes a $4,999 leap into high-end streaming with a 12-inch touchscreen, seven digital outputs, and no DAC.
2026 Campfire Audio Cascara Mk2 IEMs 2026 Campfire Audio Cascara Mk2 IEMs
At $549, Campfire Audio Cascara Mk2 IEMs retain its 10mm dynamic driver with revised tuning, a new design, and upgraded accessories.
2026 Eversolo DAC-R8 and C10 Master Clock 2026 Eversolo DAC-R8 and C10 Master Clock
Eversolo's $1,280 DAC-R8 packs proprietary R2R conversion and serious DSP, while its $1,880 C10 promises precision clocking. Is the extra box worth it?
Black Friday Gift Guide 2026
Black Friday gift ideas and real deals on headphones, speakers, hi-fi and home theater you'd actually enjoy at the lowest prices all year.
From affordable hi-fi music streamers to premium network audio players, our 2026 Editors’ Choice picks focus on sound quality, compatibility, and value.
Bluesound NODE ICON delivers warmer sound, dual DACs, balanced XLR, and BluOS streaming for $1,099. Is it worth the upgrade over the standard NODE?
Schiit Audio is finally building a music streamer with Forkbeard and 10 years of software support. Hell hasn't frozen over, but CanJam Dallas might...
Apple Music finally comes to Bluesound and BluOS with native streaming and multiroom playback. But what about lossless and hi-res audio?
DAPs
Sony's new Walkmans for 2026 include the ZX900, WM1AM3 and WM1ZM3 hi-res digital audio players (DAPs) packed with performance and priced at a premium.
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
$9,499 for the ultimate Roon music server includes OCXO clocking, DSD512 and up to 8TB storage because apparently ordinary music servers were getting complacent.
