Silent Angel’s Rhein ZX Takes Roon Server Obsession to Its Logical Extreme
$9,499 for the ultimate Roon music server includes OCXO clocking, DSD512 and up to 8TB storage because apparently ordinary music servers were getting complacent.
Silent Angel Rhein ZX Hi-Fi Digital Music Hub Top Angle
Music servers have become increasingly ambitious over the past few years, especially as manufacturers chase buyers with large local libraries, Roon installations, multiple listening zones, and DACs they have no intention of replacing.
The new $9,499 Silent Angel Rhein ZX is aimed squarely at audiophiles with deep pockets. The flagship digital music hub combines an Intel Core i5 processor, native Roon Server support, OCXO clocking, expandable NVMe storage, an internal linear power supply, and digital output up to PCM 768kHz/32-bit and DSD512.
Unlike the recently introduced $849 Silent Angel H1 Pure Music Hub, however, the Rhein ZX does not include a DAC or analog outputs. It exists to store, manage, process, and deliver digital audio to the converter already sitting in your rack.
And considering what some audiophiles spend on DACs, that’s probably the correct decision.
Related Reading:
H1 And Rhein ZX Serve Very Different Systems
The H1 was designed as an affordable all-in-one digital source. It combines streaming, local storage, dual ESS ES9039Q2M DACs, balanced and single-ended analog outputs, and a 5.5-inch display, allowing it to connect directly to an amplifier, preamplifier, or pair of active loudspeakers.
The Rhein ZX moves much further upstream. Silent Angel removes the internal DAC and concentrates instead on server performance, storage, clocking, electrical isolation, and digital connectivity. Buyers can configure the machine with 16GB, 32GB, or 64GB of DDR4 memory around an Intel Core i5-12450H processor with eight cores and 12 threads.
That processing power allows the ZX to run Roon Server locally, manage larger libraries, handle DSP and transcoding, and distribute independent lossless streams to as many as 10 endpoints simultaneously. Someone building a single-room system probably won’t need all 10, but the capability makes far more sense in a larger Roon installation.
silent-angel-rhein-zx-front-top
Storage And Cooling
Silent Angel includes a 500GB NVMe SSD and provides another M.2 slot supporting drives up to 8TB, giving owners plenty of room for local music without requiring a NAS for everyday playback. USB storage can also be added for collections that have already escaped reasonable boundaries.
Rather than cooling the Core i5 with a conventional fan, Silent Angel uses a CNC-machined copper heatsink coupled to the chassis. The passive design removes a potential source of mechanical noise while allowing the ZX to remain in the listening room rather than being banished to a closet with the router.
Anyone with a large ripped-CD collection will understand the storage appeal. Eight terabytes sounds excessive right up until it doesn’t.
OCXO Clocking And Digital Connectivity
The Rhein ZX uses a ±0.05 ppm OCXO master clock internally and also provides a 25MHz BNC input for an external clock. Silent Angel clearly expects some owners to integrate the server into more elaborate digital systems where clocking already extends beyond a single component.
USB audio uses the XMOS XU316 platform, with USB and I²S supporting PCM up to 768kHz/32-bit and DSD512. AES/EBU, coaxial, and optical connections support PCM up to 192kHz/24-bit.
Streaming support includes Roon, HQPlayer NAA, AirPlay 2, Qobuz Connect, TIDAL Connect, Spotify Connect, Amazon Music HD, and DLNA. Silent Angel’s own VitOS platform handles system operation and control.
The rear panel also includes two physically isolated Gigabit Ethernet connections, selectable grounding, USB storage ports, and the external clock input. Silent Angel uses an internal linear power supply rather than an external switching supply.
silent-angel-rhein-zx-rear
Silent Angel Rhein ZX Specifications
  • Type: Digital music server and transport
  • Operating System: Silent Angel VitOS
  • Roon: Native Roon Server
  • Processor: Intel Core i5-12450H
  • CPU: 8 cores / 12 threads
  • Memory: 16GB / 32GB / 64GB DDR4
  • USB Processor: XMOS XU316
  • Internal Clock: ±0.05 ppm OCXO
  • External Clock Input: 25MHz BNC
  • Internal Storage: 500GB NVMe SSD
  • Storage Expansion: NVMe up to 8TB
  • Ethernet: Dual physically isolated Gigabit Ethernet
  • USB / I²S: PCM up to 768kHz/32-bit, DSD512
  • AES/EBU / Coaxial / Optical: PCM up to 192kHz/24-bit
  • Multi-Room Playback: Up to 10 simultaneous lossless endpoints
  • Cooling: Fanless passive design
  • Power Supply: Internal linear power supply
  • Grounding: Ground/Floating selectable
  • Dimensions: 439 x 63 x 250mm
  • Gross Weight: 9.4 kg / 20.7 pounds
Silent Angel Rhein ZX Hi-Fi Digital Music Hub Rear Angle
What Makes The Rhein ZX Different?
None of the individual technologies inside the Rhein ZX are revolutionary. High-end digital servers with SSD storage, linear power supplies, precision clocks, and Roon compatibility have been around for years.
Silent Angel’s decision to leave the DAC out is more important.
A buyer using a Mola Mola Tambaqui, Chord DAVE, LampizatOr Horizon, dCS Bartók, or another high-end converter has little reason to pay for another DAC inside the server. The Rhein ZX devotes its hardware instead to processing, storage, clocking, network isolation, and digital output.
It is therefore much closer to a dedicated digital front end than a conventional streamer. The H1 tries to reduce the number of boxes in a system, while the ZX accepts that this particular customer stopped counting boxes several purchases ago.
What Does The Rhein ZX Compete With?
Much of the competition seems affordable by comparison. Most Roon users may want to start with a Roon Nucleus Music Server ($919 – $4,999) and add a streaming transport like $2,180 Eversolo T10. It offers OCXO clocking, 10/25MHz external clock support, SFP fiber networking, dual NVMe storage up to 16TB and PCM 768kHz/DSD512 output for considerably less money.
The $3,900 Innuos STREAM1 is particularly relevant because it can serve as both a music server and streamer, run Roon Core or operate as a Roon endpoint, accept internal NVMe storage, and feed an external DAC. Innuos takes a more modular approach, allowing owners to add storage, upgraded digital-output boards, DAC modules and an external linear power supply as required.
The $3,850 Aurender N150 targets the same external-DAC customer with a linear power supply, isolated Ethernet, user-installable storage and dedicated USB audio output. Aurender now supports Roon Ready playback, although the N150 still requires a separate Roon Server elsewhere on the network. Step up to the $6,950 N200 and Aurender adds additional storage and digital connectivity.
Audiophiles love choices. Manufacturers apparently love making those choices progressively more expensive.
The Bottom Line
The Rhein ZX is Silent Angel’s flagship music server aimed at audiophiles who already own the DAC, already have the library, and probably already know what an OCXO does.
Price & Availability
The Silent Angel Rhein ZX officially launched on September 28, 2026 for $9,499 USD MSRP and is available for pre-order through authorized North American audio dealers.
For more information: silentangel.com/zx/
Schiit Audio is finally building a music streamer with Forkbeard and 10 years of software support. Hell hasn't frozen over, but CanJam Dallas might...
Amphion's A15 active speakers bring studio engineering home for €2,500 per pair, with optional 24-bit/192kHz wireless audio. Is less really more?
Audio Cables
Esprit Generation 10 cables arrive in the U.S. with redesigned conductors, connectors, and insulation. Nine ranges span $499 to $59,999.
The Druid R2R DAC delivers smooth, fluid sound, balanced outputs, and swappable op-amps without the usual high-end price.
Silent Angel’s $849 H1 combines dual ESS DACs, streaming, local storage, high-res playback, and VitOS in one compact digital hub.
Playback is now Dual’s exclusive U.S. distributor as the app-controlled CS 629Q clears FCC certification. Is automatic vinyl playback ready for a comeback?
Hi-Fi Components
Why has Fidelity Imports UK selected Matrix Audio as its second brand, and what does the digital audio specialist add to its UK launch?
