Ferrum BROEN Network Streaming Transport Brings Volumio and SFP Networking to the WANDLA Ecosystem
Can Ferrum BROEN turn Volumio, SFP networking, and WANDLA integration into a serious high-end streaming transport for external DACs?
Ferrum Broen Streaming Transport under WANDLA DAC
Ferrum Audio has spent the past few years building a very specific lane for itself: compact, serious, modular high-end components for listeners who care about digital architecture, headphone systems, and two-channel flexibility. The Polish manufacturer is now extending that idea into network streaming with the BROEN, its first dedicated network streaming transport.
And no, this is not another “streamer/DAC/preamp/headphone amp/coffee grinder” trying to do twelve things while doing only six of them properly. BROEN is a transport. It is designed to get music from your network, local storage, USB drives, NAS, or streaming services to an external DAC with as little digital nonsense as Ferrum can manage.
That matters because Ferrum already has the DAC side covered with WANDLA, WANDLA HP, WANDLA GoldenSound Edition Gen 2, and ERCO. BROEN is the missing source component in that ecosystem, and Ferrum has clearly designed it to make the most sense when paired with WANDLA.
A Streaming Transport, Not a DAC
ferrum-broen-frontjpg
Ferrum BROEN
Ferrum describes BROEN as a network streaming transport, and the distinction matters. There is no analog output stage here. BROEN is intended to feed an external DAC through digital outputs including S/PDIF coaxial, optical, AES/EBU, I2S over HDMI, and dedicated USB DAC outputs via Type-A and Type-C.
That makes the product more focused than a conventional streamer with an onboard DAC. It also means BROEN is not trying to replace your DAC. If you already own a WANDLA, ERCO, Chord, RME, Holo Audio, dCS, or another serious DAC, this is the kind of box that sits upstream and lets the converter do the heavy lifting.
Ferrum is positioning BROEN as the digital bridge between network audio and external DACs. The name means “the bridge” in Danish, which is not the first language one expects from a Polish manufacturer, but the meaning fits the product.
SERCE DDC and Digital Isolation
The more interesting part of BROEN is not that it streams Qobuz or TIDAL. A Raspberry Pi can do that if you are patient, brave, and enjoy punishment.
The engineering story is the SERCE DDC module. Ferrum says BROEN uses a new SERCE DDC architecture designed specifically for digital-to-digital conversion, with FPGA-based reclocking and a clear separation between the input domain and output domain. In practical terms, Ferrum is trying to isolate the streaming and control side of the device from the audio output side.
Ferrum also lists ultra-low jitter clocks for the synchronous outputs, which include coaxial, optical, AES/EBU, and I2S. All audio outputs sit behind a galvanic isolation barrier, including the synchronous outputs and USB DAC outputs. BROEN also includes a dedicated clean VBUS supply for USB DAC connections.
ferrum-broen-rear
Powered by Volumio
Ferrum did not build its own streaming platform from scratch, which is probably a smart decision. BROEN is powered by Volumio, giving users access to Spotify and Spotify Connect, TIDAL and TIDAL Connect, Qobuz and Qobuz Connect, AirPlay via Shairport Sync, UPnP/DLNA, web radio, CD playback and ripping, Bluetooth A2DP playback, and playback from USB drives, internal SSD storage, or NAS.
Ferrum also lists support for streaming to Sonos and Chromecast, multi-room playback for up to six synchronized zones, AI-powered SuperSearch, Infinity Playback, extended album and artist metadata, 29-language support, alarm functions, and sleep functions.
Control is available through iOS and Android apps, a web browser, or basic front-panel buttons. That should make BROEN easier to live with than some high-end streamers that sound impressive in theory but punish the owner with software that feels like it was coded during a hostage situation.
Volumio is not a minor detail. In 2026, software is not the accessory. It is the product experience. A streamer with great hardware and unreliable software becomes an expensive paperweight with Ethernet. Ferrum leaning on an established platform gives BROEN a more credible foundation.
WANDLA Integration Is the Hook
BROEN will work with third-party DACs, but the real pitch is Ferrum’s own ecosystem.
Using Ferrum Streaming Control Technology, BROEN can integrate with WANDLA so that artist and track information appear on WANDLA’s screen. Users can also control BROEN through WANDLA’s touchscreen or remote.
That is the kind of integration that makes sense if someone already owns a WANDLA or is considering building a full Ferrum digital front end. BROEN plus WANDLA becomes a compact streaming DAC/preamp stack, and adding HYPSOS pushes the system further into Ferrum’s modular upgrade path.
Ferrum includes a DC power adapter with BROEN, but the unit can also be upgraded with HYPSOS through Ferrum Power Link. The required FPL cable is sold separately. That last part is important because Ferrum’s ecosystem is modular, but not inexpensive once you start stacking boxes.
ferrum-hypsos-wandla-broen-stack-front
Ferrum HYPSOS, WANDLA, BROEN (top to bottom)
SFP Networking and Local Storage
BROEN includes dual-band Wi-Fi as standard and an SFP socket for optional RJ45 Ethernet or fiber optic modules. Ferrum says those modules are not included.
That is a slightly unusual but potentially useful approach. Fiber networking is not a magic wand, but it can help reduce electrical noise carried over copper network connections. In a revealing system, that can matter. In a bad room with cheap speakers and a glass coffee table, not so much. Polish engineering can solve a lot of problems; your untreated living room may not be one of them.
BROEN also includes an internal M.2 NVMe SSD slot for local music storage. The drive is user-supplied and supports 80 mm or 110 mm NVMe SSDs. That gives BROEN some music server functionality without turning it into a full-blown computer-based server.
There are also two USB 3.0 ports, Type-A and Type-C, for media drives and service use, plus an HDMI video output for screen display and system interface.
Ferrum BROEN Specifications
  • Product type: Network streaming transport
  • DAC: None
  • Streaming platform: Volumio
  • Streaming services: Spotify, Spotify Connect, TIDAL, TIDAL Connect, Qobuz, Qobuz Connect
  • Other playback support: AirPlay via Shairport Sync, UPnP/DLNA renderer, web radio, Bluetooth A2DP, CD playback and ripping
  • Local playback: USB drives, NAS via DLNA, internal M.2 NVMe SSD
  • Internal storage slot: M.2 NVMe SSD, user-supplied, 80 mm or 110 mm
  • Network connectivity: Dual-band Wi-Fi 2.4/5 GHz, SFP socket for optional RJ45 Ethernet or fiber optic modules
  • USB ports: 2 x USB 3.0, Type-A and Type-C
  • Digital audio outputs: S/PDIF coaxial, S/PDIF optical, AES/EBU, I2S over HDMI with configurable pinout, USB DAC output via Type-A and Type-C
  • Control: iOS/Android app, web browser, basic front-panel controls, WANDLA touchscreen and remote when using Ferrum Streaming Control Technology
  • Ferrum integration: FSCT support for WANDLA, compatibility with WANDLA and ERCO, HYPSOS upgrade path
  • Clocking: Ultra-low jitter clocks on synchronous outputs
  • Isolation: Galvanically isolated audio outputs, including synchronous outputs and USB DAC outputs
  • USB power: Dedicated clean VBUS for USB DAC output
  • Firmware: OTA updates, plugin-capable platform
  • Multi-room: Up to 6 synchronized zones
  • Dimensions: 21.7 x 20.6 x 5 cm / 8.6 x 8.1 x 2.0 inches
  • Weight: 1.90 kg / 4.19 lb
For more information: ferrum.audio
Where BROEN Fits
The high-end streaming transport market has become more interesting because more listeners already own DACs they like. That creates room for products that do not waste money on redundant analog stages.
BROEN is not chasing the budget streamer crowd. The WiiM Ultra, Bluesound NODE, Cambridge MXN10, and Eversolo DMP-A6 Gen 2 already own that fight. Ferrum is aiming at the listener who already has a serious DAC, possibly already owns WANDLA, and wants a compact transport with strong output flexibility, optical networking options, Volumio software, and a clear upgrade path.
The closest philosophical rivals include the Eversolo T8, TEAC NT-507T, Lumin U2 Mini, AURALiC ARIES S1, Innuos PULSE, and HiFi Rose RS130. Each approaches the category differently. Eversolo brings aggressive pricing, touchscreen control, SFP fiber, PEQ, and strong app support. TEAC takes a purist USB transport approach with linear power supply design. Lumin brings a mature streaming ecosystem and SFP networking. Innuos leans into server architecture and software. HiFi Rose goes big with a massive display and extensive digital connectivity.
Ferrum’s angle is narrower but potentially more convincing for the right buyer: BROEN is designed to complete the Ferrum digital stack.
The Bottom Line
The Ferrum BROEN is not the streamer for someone looking for the cheapest way to add Qobuz Connect to an older integrated amplifier. That customer should buy a WiiM, Bluesound, Cambridge, or Eversolo and spend the rest on music.
BROEN is for the listener who already owns a serious DAC, cares about digital output quality, and wants a purpose-built transport with Volumio, SFP networking options, galvanically isolated outputs, internal SSD support, and tight integration with Ferrum’s WANDLA ecosystem.
If the $2,275 U.S. dealer-listed price holds, BROEN lands in a competitive but sensible position. It is more expensive than the Eversolo T8 at $1,380, close to the TEAC NT-507T at $2,499, and below heavier hitters like the Innuos PULSE at $3,799 and HiFi Rose RS130 at $5,895. The Lumin U2 Mini and AURALiC ARIES S1 also belong on the audition list.
For WANDLA owners, BROEN could be the missing piece that turns Ferrum’s compact stack into a serious streaming front end. For everyone else, the value will depend on whether Ferrum’s digital architecture and Volumio implementation outperform the increasingly capable competition. The category is not short on choices. Ferrum just made it more interesting.
Where to buy: $2,275 at Audio46
2027 Onkyo HA-70 Headphone Amplifier Front
Onkyo returns to desktop headphone audio with the $650 HA-70, dual ESS DACs and balanced outputs. Is 80 years of HiFi experience enough to...
2026 Audiolab 3000A and 3000CD Silver Front 2026 Audiolab 3000A and 3000CD Silver Front
CD Players
Audiolab's new 3000A amplifier and 3000CD player cost $699 each, with the DAC living in the CD player. Is this a smarter way to...
2026 iBasso DC-Tonfa Dongle DAC Lifestyle 2026 iBasso DC-Tonfa Dongle DAC Lifestyle
Dongle DACs
The $359 iBasso DC-Tonfa combines an R2R DAC, 800mW headphone output and S/PDIF connectivity in one compact device.
2026 Vincent Audio SA-32MK and SV-737MK 2026 Vincent Audio SA-32MK and SV-737MK
Vincent Audio updates its SV-737MK and SA-32MK with HDMI ARC and Bluetooth while retaining hybrid tube circuitry. Is losing Wi-Fi a mistake?
2026 ELAC Debut Reference 3.0 DBR63 stand-mount loudspeaker lifestyle 2026 ELAC Debut Reference 3.0 DBR63 stand-mount loudspeaker lifestyle
ELAC's $899 Debut Reference 3.0 DBR63 gets an aluminum tweeter, new aramid woofer, and premium styling. Is this the bookshelf speaker to beat?
2026 Fluance RT86 Turntable Angle Black Lifestyle 2026 Fluance RT86 Turntable Angle Black Lifestyle
The Fluance RT86 offers a carbon fiber tonearm, acrylic platter, and cartridge choices in a single-plinth design. Is saving $100 over the RT87 worth...
Black Friday Gift Guide 2026
Black Friday gift ideas and real deals on headphones, speakers, hi-fi and home theater you'd actually enjoy at the lowest prices all year.
Volumio Rivo Ultra makes a $4,999 leap into high-end streaming with a 12-inch touchscreen, seven digital outputs, and no DAC.
Volumio’s third-generation Primo V3 adds a faster processing platform, ESS ES9039Q2M DAC, NOS mode, eight DAC filters, selectable RCA and XLR output levels, and...
Could Eversolo’s T10 be a more affordable rival to Innuos and Aurender, with OCXO clocking, SFP fiber, dual SSD storage, and DSD512?
Ferrum debuts the WANDLA GoldenSound Edition Gen 2 at CanJam NYC 2026 with Tube Mode, Impact+ bass tuning, and new spatial audio controls.
Eversolo T8 streaming transport delivers ultra-precise digital audio with DSD512/PCM 768kHz support, Wi-Fi 6, SFP fiber, Roon Ready, and full DAC flexibility for audiophiles.
The Ferrum Audio WANDLA joins a growing list of DAC/preamplifiers that can be used as part of a desktop headphone rig or with external...
The Ferrum ERCO made its N. American debut at CanJam NYC 2022 last weekend and it's another new Polish manufacturer in the Head-Fi space.
