Eversolo DMP-A8 Gen 2 Series Debuts at High End Vienna 2026 with AKM DAC and SFP Fiber Networking
Eversolo’s DMP-A8 Gen 2 adds AKM DAC architecture, SFP fiber networking, Wi-Fi 6, SSD storage, and Master Edition CD playback.
2026 Eversolo DMP-A8 Gen 2 Music Streamer
Eversolo opened High End Vienna 2026 this morning with the DMP-A8 Gen 2 Series, a more ambitious follow-up to the streamer/DAC/preamp that helped establish the brand as a real player in digital audio. The new DMP-A8 Gen 2 is not a radical reinvention of the platform. It is a broader, more polished version of the same idea: a digital audio hub that combines streamer, DAC, preamplifier, music library manager, digital transport, and system control center in one chassis.
That is a lot of responsibility for one chassis. Most audiophiles would normally need multiple boxes, a few apps, a small cable farm, and at least one evening of questioning their network settings to get there.
DMP-A8 Gen 2 Series
eversolo-dmp-a8-gen-2-versions
Eversolo DMP-A8 Master Edition Gen 2 (left) and DMP-A8 Gen 2 (right)
There will be two versions: the standard DMP-A8 Gen 2 and the DMP-A8 Master Edition Gen 2. Both share the same core architecture, but the Master Edition adds upgrades aimed at more advanced systems, including enhanced clocking, external clock input, and a custom-grade CD playback system for disc playback and ripping.
The standard version measures 388 mm x 265 mm x 88 mm, or roughly 15.3 x 10.4 x 3.5 inches. The Master Edition measures 388 mm x 265 mm x 98.5 mm, or about 15.3 x 10.4 x 3.9 inches. Both versions move to a wider, more horizontally stretched chassis design, which gives the unit a more traditional component footprint and provides more internal space for layout, thermal management, and power-supply separation.
It is still compact enough for a normal rack, but it no longer looks like someone tried to shrink a full component into a desktop streamer and hoped nobody would ask questions.
Bigger Display, Cleaner Interface, Fewer Excuses
One of the most visible changes is the new 8.6-inch LCD touchscreen. Eversolo has leaned heavily into front-panel interaction with its streamers, and the DMP-A8 Gen 2 continues that approach with a redesigned UI and more visual playback modes.
The unit supports VU meters, dynamic spectrum analysis, album artwork, and multiple interface styles. None of that improves the signal path, but usability matters. A streamer you enjoy using gets used more. A streamer with a miserable interface becomes a very expensive black rectangle that makes everyone reach for Bluetooth.
The Gen 2 interface is designed to make browsing, playback control, system management, and library navigation faster and more direct. That matters because the DMP-A8 Gen 2 is not just a streamer. It is designed to manage streaming services, local files, digital inputs, analog inputs, subwoofer output, and preamp duties inside a single system.
AKM DAC Architecture: AK4191EQ + AK4499EX
eversolo-dmp-a8-gen-2-akm-dac
At the center of the DMP-A8 Gen 2 is an AKM-based DAC architecture using the AK4191EQ digital processor and AK4499EX DAC.
That combination separates digital processing from analog conversion, which is the core idea behind AKM’s newer flagship DAC architecture. The AK4191EQ handles the digital processing stage, while the AK4499EX performs the conversion stage. The goal is lower noise, cleaner separation between processing and conversion, and more precise reconstruction of the audio signal.
Eversolo pairs that DAC section with a fully balanced analog preamplifier architecture and an R-2R volume control system. The R-2R volume system matters because it is designed to preserve channel balance, dynamic integrity, and tonal consistency across different listening levels.
That is especially important if the DMP-A8 Gen 2 is being used as the main preamp feeding a power amplifier or active loudspeakers. A digital streamer with preamp outputs is one thing. A digital streamer that can credibly serve as the control center of a proper two-channel system is another.
The published performance figures are strong: THD+N is rated as low as 0.000075%, with SNR and DNR up to 129 dB. Measurements do not tell the entire story, but they do tell us Eversolo is not treating this as a cosmetic update with a larger screen and upgraded hi-res playback support.
High-Resolution Playback: DSD512 and PCM 768kHz/32-bit
The DMP-A8 Gen 2 supports native stereo DSD512 and PCM playback up to 768kHz/32-bit. USB-B audio input supports Windows 10/11, Mac, Android, and iOS, with the same maximum stereo DSD512 and PCM 768kHz/32-bit capability.
USB audio output also supports stereo DSD512 native and PCM up to 768kHz/32-bit when connected to UAC-compliant DACs. The DMP-A8 Gen 2 also includes I²S digital output, supporting up to native DSD512 and PCM 768kHz/32-bit when used with a compatible DAC.
Optical and coaxial inputs support up to PCM 192kHz/24-bit and DoP64, while AES, optical, and coaxial outputs also support PCM up to 192kHz/24-bit and DoP64. HDMI ARC input supports stereo PCM up to 192kHz/24-bit.
More Processing Power for Large Music Libraries
Eversolo has also upgraded the internal computing platform. The DMP-A8 Gen 2 uses a 64-bit octa-core main processor with 8GB of DDR4 RAM and 64GB of eMMC internal storage.
Local library handling is one of the pain points with many network players, especially for listeners with large digital collections. Eversolo says the Gen 2 can scan and organize up to 200,000 tracks in approximately two hours. How that plays out in actual testing will be interesting.
That will not matter to someone who only uses TIDAL Connect from a phone. But for the listener with a NAS, ripped CDs, downloaded hi-res files, DSD albums, and folder structures that look like they survived three computers and one bad marriage, better indexing and faster navigation are useful.
The upgraded Eversolo AuralEngine USB audio processor is also designed to improve audio data transmission and scheduling, especially with high-resolution files. The goal is greater stability during playback and input handling, not merely faster menu animations.
Streaming Support: TIDAL, Qobuz, Apple Music, Amazon Music, and More
The DMP-A8 Gen 2 integrates a broad range of music services, including TIDAL, Qobuz, HIGHRESAUDIO, Amazon Music, IDAGIO, Calm Radio, Internet Radio, TuneIn, Radio Paradise, Deezer, SoundCloud, Presto Music, and Apple Music.
It also supports TIDAL Connect, Qobuz Connect, Spotify Connect Lossless, DLNA, and additional streaming options.
That is a major part of the appeal. A component like this has to work for both the listener who wants app-based control from a phone or tablet and the listener who wants to manage a local library from the component itself. Eversolo is clearly aiming at both.
Cross-platform playlist integration, global search, and intelligent categorization are also part of the updated library system. The goal is to unify content from different sources into a single browsing and playback environment. Whether Eversolo gets that exactly right in daily use remains something we need to test, but the direction makes sense.
Connectivity: Analog, Digital, USB, AES, ARC, and SFP Fiber
The DMP-A8 Gen 2 is built to sit at the center of a system, and the rear-panel connectivity reflects that.
eversolo-dmp-a8-gen-2-rear-angle
Digital inputs include optical and coaxial for sources such as TVs and CD transports. USB-B input allows the unit to function as an external DAC for computers and mobile devices. HDMI ARC is also included, allowing stereo PCM connection from a TV.
Analog input is handled through balanced XLR and RCA pre-inputs, which makes it possible to integrate external analog sources. Analog output is available through balanced XLR and RCA pre-outs.
Digital outputs include USB Audio, AES, optical, coaxial, and I²S . That gives users the option of using the DMP-A8 Gen 2 purely as a transport or front-end controller with an external DAC.
There is also a dedicated subwoofer output with adjustable crossover frequency from 40Hz to 500Hz. That is a very practical addition for real rooms, especially with bookshelf loudspeakers, active monitors, or compact systems where pretending bass extension goes to 30Hz is a hobby, not a measurement.
The other notable addition is SFP fiber networking. The DMP-A8 Gen 2 supports Gigabit single-mode single-fiber and single-mode dual-fiber optical modules, although the SFP module is not included. This gives users an optical network option that can provide better electrical isolation between network hardware and the audio component.
Will every system benefit from SFP fiber networking? No.
Will the people already experimenting with optical isolation, network switches, and cleaner digital front ends immediately notice the SFP slot and start rearranging their rack? Almost certainly. Eversolo knows exactly who is staring at the back panel.
Wi-Fi 6 and Internal SSD Support
The DMP-A8 Gen 2 includes dual-band Wi-Fi 6 across 2.4GHz and 5GHz, along with RJ-45 Ethernet. For a product designed to handle high-resolution streaming and large libraries, stronger network support is not optional anymore.
There is also an internal M.2 NVMe PCIe 3.0 2280 SSD slot supporting drives up to 8TB. The SSD is not included, but the option is important. It allows the DMP-A8 Gen 2 to become a self-contained local music server without relying entirely on USB drives, NAS storage, or external computers.
For anyone moving away from computer-based audio but still committed to local files, that could be one of the most useful upgrades.
Master Edition Gen 2: CD Playback, OCXO Clocking, and External Clock Input
eversolo-dmp-a8-master-edition-gen-2-cd-open
The DMP-A8 Master Edition Gen 2 is the more ambitious version, and its upgrades are aimed at users building more complex digital systems.
The Master Edition adds an in-house CD playback function described as ultra-quiet and optimized for CD playback. It is intended for both CD playback and ripping, with improved reading stability and error correction compared with general-purpose optical drive solutions.
That is an interesting move because CD never actually disappeared. It just got pushed into the corner while vinyl got expensive and streaming became the default. A streamer with strong local library support and integrated CD playback/ripping makes sense for listeners who still own large CD collections and do not want another separate transport on the rack.
eversolo-dmp-a8-master-edition-gen-2-clock
The Master Edition also receives an upgraded clocking system with a high-precision OCXO crystal oscillator using temperature control for improved frequency stability. PLL technology is included to further synchronize and optimize clock behavior.
It also supports external clock input, allowing integration with standalone master clock systems. That feature will not matter to casual users, but for advanced digital systems with external DACs, transports, and clock distribution, it gives the DMP-A8 Master Edition Gen 2 a more credible role in a higher-end rack.
It also gives the external-clock crowd something new to point at while explaining jitter to someone who made the mistake of asking.
The Bottom Line
The Eversolo DMP-A8 Gen 2 Series is not just a streamer with a nicer screen. Its real appeal is consolidation: streamer, DAC, preamp, local music server, digital transport, HDMI ARC input, subwoofer control, and SFP fiber networking.
The standard DMP-A8 Gen 2 is aimed at listeners who want a modern digital hub with balanced analog outputs, high-resolution playback, strong streaming support, internal SSD storage, and enough connectivity to anchor a real two-channel system. The Master Edition is for the more committed crowd: CD owners, large-library users, external DAC loyalists, clock-curious audiophiles, and anyone already thinking about optical network isolation before breakfast.
What we still need are final U.S. pricing, dealer timing, and exact shipping dates. Eversolo says Q3, but Q3 can mean July optimism or September availability. On paper, the DMP-A8 Gen 2 looks like a meaningful evolution of the original DMP-A8 ($1,980). Now it has to prove that the upgraded hardware, software, clocking, and system flexibility deliver real gains in daily use.
3 Comments
3 Comments
  1. Kim Skov
    June 8, 2026 at 6:21 pm
    No offense, but a lot of this “information” is nonsense. The current DMP-A8 already has both the AKM AK4499/AK4191 DAC chipset and a built-in SSD slot. The linear PSU and R2R volume control are also included. Most of the I/Os and most (if not all) of the streaming platforms are also supported by the current version, so what are the real upgrades here?
    • Ian White
      June 8, 2026 at 9:00 pm
      Kim,
      I don’t think you actually read this carefully enough. My opening was rather clear; “The new DMP-A8 Gen 2 is not a radical reinvention of the platform. It is a broader, more polished version of the same idea.”
      You’re assuming that everyone reading the article has heard of the product, listened to it, or bought one. For that reason, I have to cover everything that it offers and highlight what is new.
      The physical changes will matter to some (size and screen size), and the Master Edition with its internal CD player.
      IW
  2. Felix banks
    June 30, 2026 at 11:43 pm
    How soon will it be available!
    Second is cost.
Linear Tube Audio Aero+ DAC Angle
2026 Adam Audio H715 Reference Open-back Studio Headphones 2026 Adam Audio H715 Reference Open-back Studio Headphones
AT $699, ADAM Audio's flagship H715 Reference headphones, combine Sonnox calibration, balanced Hi-Fi mode, and studio monitoring in one design.
2026 Audio-Technica ATH-AWX7000 Headphones 2026 Audio-Technica ATH-AWX7000 Headphones
Audio-Technica's $3,800 ATH-AWX7000 combines Japanese Cypress wood, luxury craftsmanship, and new 58mm drivers. Can it challenge the best closed-back headphones?
Eversolo brings 180 watts of Class AB power while FiiO answers with EL34 tubes and pure Class A. Two Chinese amplifiers, two very different...
WiiM Bar debuts at High End Vienna 2026 with Dolby Atmos, DTS:X, RoomFit, HDMI eARC, and expandable 3.0.2 surround from $479.
Whole-home budget priced music streaming solutions are coming from WiiM this fall. Should Sonos be worried?
Naim’s CI-Uniti 102 combines 150 watts per channel, streaming, HDMI eARC, and multiroom flexibility in a compact amplifier that raises awkward questions for the...
Is the $999 xDuoo DP-10 a better digital transport for audiophiles who already own a DAC than an Eversolo or WiiM streamer?
WiiM is bringing its streamers, amplifiers, speakers, and home theater products to Best Buy nationwide. The bigger question is whether the retailer can properly...
Volumio’s third-generation Primo V3 adds a faster processing platform, ESS ES9039Q2M DAC, NOS mode, eight DAC filters, selectable RCA and XLR output levels, and...
Luxsin X8 and X9 desktop DAC and headphone amps arrive in North America with HP-EQ, touchscreens, serious output power, and AI-assisted EQ on the...
