Hegel H200 and A200 Integrated Amplifiers Make You Choose Between Streaming and Pure Analog
Hegel’s H200 and A200 share a 150-watt Class AB platform, but buyers must choose between built-in streaming or a fully analog signal path.
2026 Hegel H200 Integrated Streaming Amplifier Lifestyle Black
Hegel has spent nearly four decades quietly producing some of the best high-end electronics in Scandinavia, yet the Norwegian manufacturer still manages to fly under the radar compared with louder brands from Denmark, the United Kingdom, Japan, and North America.
That feels increasingly strange.
Founded in 1988 by Bent Holter, Hegel has built its reputation around high-current amplification, unusually high damping factors, minimalist industrial design, and its proprietary SoundEngine distortion-reduction technology. Its products are now sold through dealers in 63 countries, so this is hardly three engineers working beside a frozen fjord while waiting for the fishing boats to return with Lord Erling and his supply of cowboy hats.
The new Hegel H200 and A200 integrated amplifiers are unlikely to change the company’s preference for visual understatement, but they offer one of its clearest product choices yet.
Both use the same 150-watt-per-channel Class AB output stage. The $4,995 H200 adds an internal DAC, network streaming, USB playback, and digital connectivity. The $3,995 A200 removes all of that and focuses exclusively on analog sources and external components.
Same engine. Two different roads.
One Amplifier Platform With Two Personalities
hegel-a200-front-angle
The Hegel H200 and A200 look identical in the front.
The H200 and A200 deliver 150 watts per channel into 8 ohms and are rated to remain stable with loudspeaker loads down to 2 ohms. Both use Hegel’s SoundEngine2 circuitry, which is designed to identify and reduce distortion as it occurs rather than relying on large amounts of conventional global feedback afterward.
Hegel also claims a damping factor greater than 4,000, giving both amplifiers considerable electrical control over loudspeaker drivers. That figure does not guarantee great sound by itself, but it helps explain why Hegel amplifiers have developed a reputation for controlled bass, strong dynamics, and an ability to drive more demanding loudspeakers without becoming flustered.
Both models include a Moving Magnet phono stage derived from the MM section of Hegel’s standalone V10 phono preamplifier. The circuit uses hand-matched FET gain stages and selected operational amplifiers rather than the inexpensive phono board that sometimes gets tossed into an integrated amplifier so the marketing department can check another box.
A front-panel headphone output, fixed RCA output, variable RCA output, configurable input levels, home-theater bypass functionality, TV remote learning, automatic standby, and adjustable display brightness are also included on both models.
The real difference is everything that happens before the analog amplifier stage.
Hegel H200: The Connected Option
hegel-h200-front
H200
The H200 is designed to function as the center of a complete two-channel system.
Its internal DAC supports coaxial, optical, USB-B, USB-A, and network sources. Resolution reaches 24-bit/192kHz through coaxial, USB-B, and network playback, while the two optical inputs support up to 24-bit/96kHz.
The USB-A port can play music directly from storage devices containing libraries of up to 10,000 songs. Supported streaming formats include FLAC, WAV, ALAC, AIFF, AAC, MP3, PCM, and Ogg.
Streaming support includes Spotify Connect Lossless, TIDAL Connect, Qobuz Connect, Apple AirPlay, Google Cast, UPnP, Roon Ready, and airable internet radio and podcasts. The Hegel Control app handles volume, source selection, playback, and browsing of compatible network and USB libraries.
The H200 also includes a coaxial digital output and Hegel’s DAC Loop feature. This allows owners to send a digital signal to an external DAC and route its analog output back into the amplifier, providing an upgrade path without abandoning the H200’s streaming platform, source control, or power amplifier.
That is a smart addition. Buying an all-in-one amplifier should not require swearing lifelong allegiance to its internal DAC.
There is no HDMI eARC input, which feels increasingly conspicuous on a $4,995 connected amplifier. Television audio can still be handled through optical or coaxial digital inputs, and the amplifier can learn commands from many TV remotes, but buyers looking for HDMI switching or automatic eARC integration will need to look elsewhere.
Hegel A200: Digital Need Not Apply
hegel-a200-front
A200
The A200 uses the same core amplifier platform but removes the DAC, streamer, network connection, USB ports, and every other digital input.
That will sound backward to some buyers and entirely sensible to others.
Many audiophiles already own a DAC or network streamer they prefer. Others upgrade digital components more frequently than amplification or build systems around turntables, CD players, tuners, tape decks, and other analog sources. For those listeners, paying extra for a digital section they have no intention of using makes very little sense.
The removal of the H200’s digital circuitry also makes room for a second balanced XLR input. The A200 therefore offers two balanced inputs, two unbalanced RCA inputs, the MM phono stage, headphone output, and fixed and variable RCA outputs.
It is not the cheaper H200. It is the same amplifier aimed at someone who has already chosen the rest of the system.
hegel-a200-back
A200
hegel-h200-back
H200
Specifications: H200 vs. A200
H200A200
MSRP$4,995$3,995
TypeNetwork streaming integrated amplifierAnalog integrated amplifier
AmplifierClass AB with SoundEngine2Class AB with SoundEngine2
Power output2x150W into 8 Ohms @ 1kHz 1% THD, 100/120/230V AC2x150W into 8 Ohms @ 1kHz 1% THD , 100/120/230V AC
Minimum load2 ohms2 ohms
Analog inputs1x Balanced (XLR),
2x Unbalanced (RCA)
2x Balanced (XLR),
2x Unbalanced (RCA)
Phono input1 x Unbalanced (RCA) for Moving Magnet (MM)1 x Unbalanced (RCA) for Moving Magnet (MM)
Digital outputs1x Coaxial S/PDIF – 24/192–
Digital inputs1x Coaxial (RCA) S/PDIF – 24/192,
2x Optical S/PDIF – 24/96,
1x USB B- 24/192,
1x USB A 2.0 – USB Drives (10,000 songs),
1x Network – 24/192
Line level outputs1x Unbalanced variable (RCA),
1x Unbalanced fixed (RCA)
StreamingSpotify Connect (Lossless), Tidal Connect, Qobuz Connect, Apple AirPlay, Google Cast, airable Internet Radio and Podcast, UPnP–
Streaming formatsMP3, WAV, FLAC, ALAC, AIFF, AAC, PCM, Ogg–
Smart HomeControl4, Crestron Home, Crestron SIMPL–
Frequency response5Hz-100kHz5Hz-100kHz
Signal-to-noise ratioMore than 100dBMore than 100dB
CrosstalkLess than -100dBLess than -100dB
DistortionLess than 0.01% @ 50W 8 Ohms 1kHzLess than 0.01% @ 50W 8 Ohms 1kHz
IntermodulationLess than 0.01% (19kHz + 20kHz)Less than 0.01% (19kHz + 20kHz)
Damping factorMore than 4000 (main power output stage)More than 4000 (main power output stage)
Dimensions (WxDxH)43 x 41 x 12 cm
(17 x 16.2 x 4.7″)
43 x 41 x 12 cm
(17 x 16.2 x 4.7″)
Weight13.6 kg (30 lbs) 13.5 kg (29.8 lbs)
FinishesBlack, WhiteBlack
hegel-h200-white
Only the H200 is available in white.
The Bottom Line
Hegel’s decision to offer the same amplifier in connected and fully analog versions makes more sense than forcing every buyer into the same configuration.
The H200 is the obvious choice for listeners who want streaming, digital playback, vinyl, headphones, and loudspeaker amplification consolidated into one component. The A200 is aimed at owners who already have a preferred DAC, streamer, or collection of analog sources and would rather spend $1,000 less than pay for duplicated circuitry.
Neither model looks designed to attract attention from across the room. That has never been Hegel’s game. The company builds understated amplifiers that frequently outperform flashier competitors and then seems mildly surprised when someone notices.
Perhaps Norway needs to work on its bragging.
Pricing & Availability
  • The Hegel H200 will retail for $4,995 at Audio Advice, with shipping expected to begin in late August 2026. It will be available in black or white.
  • The Hegel A200 will retail for $3,995 at Audio Advice and is scheduled to follow in October 2026. It will be offered only in black.
For more information: hegel.com
2026 Fyne Audio F1-10 Anniversary Loudspeakers
Fyne Audio celebrates a decade with its most advanced IsoFlare driver, integrated SuperTrax and just 30 pairs of the $50,000 F1-10 Anniversary.
2026 Cambridge Audio Spira 1 Turntable Colors 2026 Cambridge Audio Spira 1 Turntable Colors
Cambridge Audio's $499 Spira turntable pairs Bluetooth, a steel platter and five colorful finishes with its new L/R active speaker lineup.
Lampizator Horizon 2 DAC Lampizator Horizon 2 DAC
LampizatOr’s Horizon 2 adds Aphrodite tech, a redesigned tube stage and upgrades for owners who already spent car money on a DAC.
C Seed Bugatti TV at CEDIA Expo 2026 C Seed Bugatti TV at CEDIA Expo 2026
C SEED and Bugatti turn a folding 4K MicroLED television into a 137-inch kinetic sculpture with Tourbillon design and Wisdom Audio.
2026 MartinLogan USR51 Slim 5.1-channel A/V Receiver 2026 MartinLogan USR51 Slim 5.1-channel A/V Receiver
MartinLogan's first-ever home theater receiver delivers 5.1 channels of surround sound in a compact form factor that may look familiar.
Apple TV 4K, HomeView, HomePod mini 2, and Home Collection 2026 Apple TV 4K, HomeView, HomePod mini 2, and Home Collection 2026
Apple launches a $299 Apple TV 4K, $149 HomePod mini 2, $299 HomeView and four-speaker surround.
Eversolo brings 180 watts of Class AB power while FiiO answers with EL34 tubes and pure Class A. Two Chinese amplifiers, two very different...
Loudspeakers
Diapason has built handcrafted Italian loudspeakers since 1987. With MoFi Distribution and Paolo Tezzon behind it, the U.S. may finally notice.
Can TAD modernize a high-end integrated amp without turning it into a streamer? The 250W A1000D adds DSD256 and D700 clock technology.
Can 20 watts be enough? The $11,828 Neoson Evolution pairs Class A KT88 tube power with rich tonality, and strong detail.
At $3,799, Musical Fidelity’s M6xi delivers 230 WPC with an onboard DAC, HDMI ARC, and MM/MC phono stage, offering a powerful and flexible solution...
