C SEED Bugatti N1 Folding MicroLED TV Brings Hypercar Excess to Home Cinema
C SEED and Bugatti turn a folding 4K MicroLED television into a 137-inch kinetic sculpture with Tourbillon design and Wisdom Audio.
C Seed Bugatti TV at CEDIA Expo 2026
There are expensive televisions, there are enormous televisions, and then there are televisions designed for people who regard a 100-inch flagship from Samsung, Sony or LG as something for the guest bedroom.
C SEED lives rather comfortably in that third category.
The Austrian manufacturer has formally announced the C SEED Bugatti N1, a motorized folding 4K MicroLED television created with Bugatti and inspired by the new Bugatti Tourbillon hypercar. Available in 110-inch and 137-inch sizes, the N1 transforms from what looks like an extremely expensive sideboard into a massive MicroLED display in approximately 45 seconds.
We actually saw the Bugatti N1 in person at CEDIA Expo 2026 in Denver, so its existence is not entirely new. C SEED previewed the collaboration at the show in September after displaying it alongside Bugatti at Monterey Car Week. What is new is the formal rollout and a much clearer picture of exactly what separates this version from the already rather insane C SEED N1.
And no, apparently the regular N1 was not sufficiently conspicuous.
c-seed-bugatti-tv-front
C SEED Bugatti N1 at CEDIA Expo 2026
From Bugatti Tourbillon to Television
The Bugatti N1 draws heavily from the design language of the Bugatti Tourbillon, including the automaker’s signature C-line profile, sculpted metallic surfaces, carbon-fiber elements and finishes derived from the hypercar itself.
C SEED says the television is engineered and manufactured in Austria, with Sculpture Silver and bespoke color configurations available alongside original Bugatti materials and finishes.
When switched off, the display panels fold completely into the freestanding base. Press the button and five MicroLED sections rise and unfold into the finished screen, with C SEED claiming the entire transformation takes about 45 seconds.
c-seed-bugatti-folding
Folding panels
The display can also rotate after deployment, allowing considerably more placement flexibility than a conventional 137-inch television bolted to a wall. The system supports up to 180 degrees of rotation in one direction or 90 degrees to either side, depending on its configuration.
That might sound like technological theater.
It is.
Just make sure the family is not standing beside it when 1,500 pounds of Austrian engineering starts rotating, and perhaps move the solid-gold bust of Nicolas Cage somewhere safely out of range.
More Than a Bugatti Badge
Luxury collaborations have a habit of becoming a normal product with different paint, some carbon fiber and a price increase large enough to require smelling salts.
The Bugatti N1 goes somewhat further.
At its heart is C SEED’s folding 4K MicroLED platform, but the Bugatti edition uses what the company calls next-generation MiP technology, with smaller MicroLED chips intended to increase the proportion of black surface surrounding the emitters. C SEED says that improves perceived contrast while also reducing power consumption and heat at the screen surface.
The display supports HDR10+, 16-bit-per-color processing and a claimed 64 billion colors, with peak brightness specified at 1,000 nits and contrast at 30,000:1. Viewing angles are rated at 170 degrees horizontally and vertically.
c-seed-bugatti-panels-folded
Folded panels twist 90-degrees before lowering
One of C SEED’s more important technologies is its patented Adaptive Gap Calibration (AGC) system. The five-panel architecture creates an obvious engineering problem: panel seams. AGC uses high-resolution sensors to detect tiny alignment differences between sections and adjusts specific LED brightness levels to make those transitions visually disappear.
A folding television is considerably less impressive if every movie looks like it is being shown through a window frame.
c-seed-bugatti-lowering
c-seed-bugatti-folded
Wisdom Audio Joins the Party
The Bugatti N1 also receives an integrated audio system developed with Wisdom Audio, using the company’s planar magnetic technology.
Unlike conventional TV speakers permanently squeezed into a thin enclosure, the speakers remain hidden inside the N1’s sculptural base when the television is off and extend into position when needed.
C SEED’s technical specifications list four broadband channels for the 110-inch version and six for the 137-inch model, accompanied by a 200-watt subwoofer. The system also provides 9.2-channel preamp outputs, so owners building a serious theater can connect a much more elaborate external audio system.
Considering the likely customer, we suspect Wisdom Audio dealers will not have much trouble making that second option sound appealing.
c-seed-bugatti-control-unit
Connections from outboard control unit.
C SEED Bugatti N1 Specifications
  • Display Sizes: 110 inches / 137 inches
  • Display Technology: Direct-view MicroLED with MiP technology
  • Resolution: 4K UHD
  • HDR: HDR10+
  • Brightness: 1,000 nits
  • Contrast Ratio: 30,000:1
  • Color Processing: 16-bit per color
  • Color Palette: Claimed 64 billion colors
  • Pixel Pitch: 0.6 mm (110-inch) / 0.7 mm (137-inch)
  • Viewing Angle: 170° horizontal / 170° vertical
  • LED Lifespan: 100,000 hours
  • Unfolding Time: Approximately 45 seconds
  • Adaptive Gap Calibration: Yes
  • Screen Rotation: Up to 180° counterclockwise or 90° left/right
  • Video Inputs: 3 x HDMI 2.0 with HDCP 2.2
  • USB: 2
  • Network: RJ45 Ethernet
  • Audio Output: 9.2-channel preamp output plus independent subwoofer output
  • Integrated Audio: Wisdom Audio planar magnetic system with integrated subwoofer
  • TV Tuner: None
  • 110-inch Weight: 1,058 pounds / 480 kg
  • 137-inch Weight: 1,500 pounds / 680 kg
  • Typical Power Consumption: 550 watts (110-inch) / 900 watts (137-inch)
  • Manufacturing: Austria
C SEED also specifies an LED refresh rate of 3,840 Hz. That is the display system’s internal LED refresh specification, not an indication that your Apple TV has suddenly discovered 3,840 fps video.
How Is It Different From the Regular C SEED N1?
The standard N1 already performs the principal party trick.
C SEED’s existing model is offered in 110-, 137- and 165-inch sizes, unfolds its five MicroLED panels in 45 seconds, uses Adaptive Gap Calibration and provides the same basic architectural freedom of a freestanding display that disappears when it is not being watched.
We covered the earlier N1 in 2025, when pricing started at approximately $190,000 in the U.S. The current standard model remains one of the most unusual residential display systems on the market.
c-seed-bugatti-tv-front-angle
C SEED Bugatti N1
The Bugatti version changes the proposition from extreme television to collectible design object.
Beyond the styling inspired by the Tourbillon, it adds Bugatti materials and finishes, carbon-fiber detailing, MiP display technology and the retractable Wisdom Audio system. It is also currently limited to 110 and 137 inches rather than offering the standard N1’s 165-inch option.
C SEED has not announced pricing for the Bugatti N1.
If you have to ask?
You know the rest.
c-seed-bugatti-rear-angle
C SEED Bugatti N1 – rear angle with control unit on left
Why Is the Bugatti N1 Unique?
You can already buy enormous direct-view LED and MicroLED displays. The problem is that they tend to remain enormous when you are not watching them.
A 137-inch black rectangle tends to have opinions about interior design.
The N1’s real achievement is therefore not simply image size. It is the mechanical engineering required to make a five-panel MicroLED display disappear into furniture, return to position, correctly align itself and reproduce a seamless 4K image repeatedly.
The Bugatti edition takes that concept further by treating the television as an architectural object rather than an appliance.
That also explains why comparing it directly with a conventional television based on brightness, HDMI count or price-per-inch rather misses the point. Nobody is deciding between this and a 98-inch TCL after discovering both in the Best Buy circular.
Who Is Actually Buying This?
Not us.
Probably not you either.
c-seed-bugatti-tv-showing-tourbillon
The Bugatti N1 is aimed at the same type of client who commissions kitchens, lighting systems, furniture and home theaters rather than simply buying them. C SEED distributes the model through selected dealers and partners, and the product makes the most sense in luxury residences where architects and interior designers do not want a gigantic fixed display dominating the room.
Bugatti ownership is obviously not required, although parking a Tourbillon in the garage probably removes some anxiety from the television-shopping process.
More importantly, the N1 solves a legitimate design problem for an extremely small group of customers: how do you install a truly gigantic direct-view display in a highly designed living space without having to look at it all day?
C SEED’s answer is to make the television disappear. Bugatti’s contribution is making sure everyone notices when it comes back.
For more information: cseed.com
2 Comments
2 Comments
  1. Asa
    October 13, 2026 at 10:09 pm
    “C SEED’s answer is to make the television disappear”…and your wallet!
    Sadly, the ones that can afford such things won’t actually see it in action except maybe once every few years when they visit one of twenty-five homes they have. Maybe the ‘staff’ can enjoy it. A large yacht might be good venue.
    Thanks as always, Ian, for exposing us to cool tech even if it’s unobtainable or even unecessary. I’m waiting for the trickle-down model…Toyota N-1. 😉
    • Ian White
      October 13, 2026 at 10:13 pm
      Asa,
      I wouldn’t buy something like this even if I could afford it. It doesn’t make sense to me. I’d rather have an apartment in Turin or Bologna for the same price.
      IW
2026 Vinnie Rossi Canta Integrated Amplifier Angle
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
2026 NAD C 359S Integrated Amplifier 2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
2026 NAD C 569 CD Player 2026 NAD C 569 CD Player
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
2026 Sony Walkmans 2026 Sony Walkmans
DAPs
Sony's new Walkmans for 2026 include the ZX900, WM1AM3 and WM1ZM3 hi-res digital audio players (DAPs) packed with performance and priced at a premium.
Rega Replay Turntable Rega Replay Turntable
Rega Replay turntable weighs just 2.2 kg and reportedly costs £259. How does its skeletal design compare with the Planar 1 and its rivals?
2026 Linn 343 Floorstanding Loudspeakers Lifestyle Single Malt Glasgow Collection 2026 Linn 343 Floorstanding Loudspeakers Lifestyle Single Malt Glasgow Collection
Linn's new 343 brings Pistonik bass to a compact floorstander, with Exakt Integrated and powered-bass versions starting at $67,500 per pair. Worth the premium?
Apple may unveil a new Apple TV 4K, HomePod mini and smart home hub on October 13, potentially creating its most complete living room...
Apple TV is adding Dolby Atmos to Formula 1 beginning with the 2026 U.S. Grand Prix, creating a serious 4K Dolby Vision home theater...
Priced from $2,300 to $3,800, Hisense C3 lifestyle 4K projectors offer triple laser imaging, up to 5,000 lumens, Dolby Vision and 240Hz gaming.
Sony's flagship True RGB TV for 2026 offers excellent performance for an LCD TV, but can it challenge OLED where it matters?
