Panasonic DMR-4X1010 Is the 10TB 4K Blu-ray Recorder America Wishes It Had
2026 Panasonic DMR-4X1010 10TB 4K Blu-ray Player and Recorder
The U.S. 4K Blu-ray player market has become fairly easy to understand. Panasonic still sells excellent conventional players, Magnetar will happily sell you something substantially more ambitious, and almost everyone else has either left the building or is standing suspiciously close to the exit.
Japan apparently did not get that memo.
Panasonic’s new DMR-4X1010 is not merely an Ultra HD Blu-ray player. It combines a 10TB internal hard drive, 11 television tuners, automatic multi-channel recording, Ultra HD Blu-ray playback and recording, cloud storage support, remote viewing and extensive program management inside one component.
In other words, Japan gets a 10TB home video command center, while America gets another notification asking whether we are still watching.
panasonic-dmr-4×1010-front
This Is Not Just a 4K Blu-ray Player
Calling the DMR-4X1010 a disc player misses most of the point.
Panasonic has equipped its flagship new DIGA recorder with 10TB of internal storage and 11 tuners covering Japan’s terrestrial digital, BS/CS satellite and BS/110-degree CS 4K broadcasts. Eight tuners are dedicated to automatic recording, two can switch between automatic and conventional recording duties, and one is reserved for conventional recording.
With the appropriate recording settings, Panasonic says the DMR-4X1010 can automatically retain as many as eight HD channels for approximately 28 days, while an additional allocation can capture either one 4K channel for approximately 13 days or two additional HD channels for roughly the same period.
Older recordings can then be automatically deleted as space is required.
panasonic-dmr-4×1010-rear
10TB Is Only the Beginning
The internal hard drive can store approximately 390 hours of native 4K broadcast material at 33Mbps, according to Panasonic. Longer-duration compression modes stretch that dramatically further, although image quality naturally becomes part of the trade-off.
Users can also archive compatible recordings to recordable Blu-ray media. The DMR-4X1010 supports BD-RE discs up to 100GB and BD-R media up to 128GB, along with recordable DVD formats.
That combination of enormous local storage and removable physical media already distinguishes the DIGA from virtually anything available to U.S. home theater buyers.
Panasonic then added the cloud.
Cloud Recording Without Surrendering Everything to Streaming
Panasonic describes one of the DMR-4X1010’s major new features as Cloud Recording, although the terminology requires some explanation.
The machine records television programming locally first. Selected recordings can then be copied to Microsoft OneDrive or Google Drive, allowing users to free space on the internal hard drive, protect important recordings from a hardware failure and access stored programs remotely.
Panasonic says as much as 10TB of recorded programming can be stored in the cloud, subject, obviously, to whatever storage plan the user has purchased from Microsoft or Google.
Cloud-based recordings can also be viewed from a smartphone through Panasonic’s DIGA Anywhere app. Panasonic specifically cautions that cloud services can change, suffer outages or disappear entirely, so the feature should not be confused with guaranteed permanent archival storage.
Physical media just quietly cleared its throat.
The DMR-4X1010 also introduces playlist editing, allowing users to assemble favorite portions of recordings without deleting the original program, along with custom program tags for sorting material by performers, music or other criteria.
That sounds almost quaint until you remember how often a show disappears from a streaming service because somebody in a conference room changed a licensing agreement.
And Yes, It Still Plays 4K Blu-ray Discs
For all of the recording technology packed inside, the DMR-4X1010 remains a serious disc machine.
It supports Ultra HD Blu-ray, Blu-ray, Blu-ray 3D, DVD-Video and CD playback, along with BD-R/RE and multiple recordable DVD formats. Panasonic also includes its 4K Real Chroma Processor, HDR brightness adjustment and 4K direct chroma upconversion.
High-resolution audio file playback includes WAV up to 32-bit/384kHz, AIFF up to 32-bit/384kHz, FLAC up to 24-bit/192kHz, ALAC up to 32-bit/192kHz and DSD up to 11.2MHz.
Connectivity includes two HDMI outputs, three USB ports, Ethernet and built-in Wi-Fi. There are no analog, optical or coaxial audio outputs, which tells you fairly clearly how Panasonic expects the DMR-4X1010 to be used.
panasonic-dmr-4×1010-dimensions
Panasonic DMR-4X1010 Specifications
  • Product Type: 4K Blu-ray recorder/DVR
  • Internal Storage: 10TB HDD
  • Tuners: 11 total
  • Automatic Recording: Up to 8 HD channels for approximately 28 days
  • Additional Automatic Recording: Up to 1 4K channel or 2 HD channels for approximately 13 days
  • 4K Native Recording Capacity: Approximately 390 hours at 33Mbps
  • Cloud Services: Microsoft OneDrive, Google Drive
  • Maximum Supported Cloud Recording Storage: 10TB
  • Disc Playback: Ultra HD Blu-ray, Blu-ray, Blu-ray 3D, DVD-Video, CD
  • Recordable Blu-ray: BD-RE up to 100GB; BD-R up to 128GB
  • Video Processing: 4K Real Chroma Processor, HDR brightness adjustment, 4K direct chroma upconversion
  • Hi-Res Audio: WAV, FLAC, AIFF, ALAC, DSD
  • HDMI Outputs: 2
  • USB: 3; 1x USB 2.0, 2x USB 3.0
  • Networking: Ethernet, built-in Wi-Fi
  • Power Consumption: Approximately 54 watts
  • Dimensions: 430 x 66 x 239 mm (16.9 x 2.6 x 9.4 inches)
  • Weight: Approximately 4 kg (8.8 pounds)
  • Power: AC 100V, 50/60Hz
  • Japan Price: ¥434,500 including tax through Panasonic’s online channel
  • Availability: Japan, late October 2026
  • U.S. Availability: Not announced
The Bottom Line
The Panasonic DMR-4X1010 is unique because it combines an 11-tuner DVR, 10TB of local storage, recordable Blu-ray support, Ultra HD Blu-ray playback, cloud archiving, and remote viewing in one component. Very few manufacturers are still treating physical media, broadcast television, and local storage as parts of the same home entertainment system.
What is it missing? For North American buyers, the obvious answer is compatibility. The DMR-4X1010 is built around Japanese broadcast standards, uses B-CAS, runs on 100V power, and has no U.S. version announced.
That makes this a product Japanese home theater and physical media enthusiasts get to enjoy while the rest of us admire it from afar. Panasonic has built exactly the kind of all-in-one video machine many enthusiasts still want.
panasonic-dmr-4×410-4k-blu-ray-player
Price & Availability
Panasonic announced the DMR-4X1010 in Japan on September 14, 2026, with availability scheduled for late October 2026 at ¥434,500.
A less expensive DMR-4X410 version (¥209,000) reduces internal storage to 4TB while retaining 4K tuner capability and many of the same new cloud and organizational features.
There has been no announcement regarding U.S. or European availability.
2 Comments
2 Comments
  1. paul elm
    October 3, 2026 at 10:53 am
    If this comes to USA I’m buying one maybe 2 this is Wat I been looking for for years
    • Ian White
      October 3, 2026 at 11:12 am
      Paul,
      I’m on that list as well.
      IW
Linear Tube Audio Aero+ DAC Angle
2026 Adam Audio H715 Reference Open-back Studio Headphones 2026 Adam Audio H715 Reference Open-back Studio Headphones
AT $699, ADAM Audio's flagship H715 Reference headphones, combine Sonnox calibration, balanced Hi-Fi mode, and studio monitoring in one design.
2026 Audio-Technica ATH-AWX7000 Headphones 2026 Audio-Technica ATH-AWX7000 Headphones
Audio-Technica's $3,800 ATH-AWX7000 combines Japanese Cypress wood, luxury craftsmanship, and new 58mm drivers. Can it challenge the best closed-back headphones?
Can a new 4K restoration and Dolby Atmos mix make Queen Budapest the definitive home release of Freddie Mercury’s last filmed Queen concert?
Developers have found a way to restore Dolby Atmos height effects from Blu-ray soundtracks on Apple TV 4K. It's an impressive technical achievement, but...
Berliner Philharmoniker now streams live concerts in Dolby Atmos with 4K video, an extensive archive and no extra fee for subscribers.
Our picks for best televisions of 2025 offer the best picture quality and value at their price and size.
CD Players
Musical Fidelity's B1xcd CD player arrives as CD sales surge, offering a dedicated transport, ESS DAC, and serious hi-fi engineering without streaming distractions.
Movies
Universal confirms The Odyssey's November 17 4K Blu-ray release with a BD-100 disc, 1.78:1 video, DTS-HD 5.1 audio, and exclusive IMAX extras.
