4K Blu-ray Isn’t Dead as Magnetar ULTIMA Makes U.S. Debut at CEDIA 2026
Is 4K Blu-ray really dead? Magnetar’s ULTIMA reference transport makes its U.S. debut at CEDIA 2026 with an ambitious battery-assisted power design.
2026 Magnetar Ultima Reference Transport
Magnetar is bringing its most ambitious disc player yet to the United States, and anyone still preparing a funeral for 4K Blu-ray may want to hold off on ordering the flowers. Making its U.S. debut at CEDIA 2026, the new Magnetar ULTIMA Ultra HD Blu-ray Reference Transport is a flagship universal media transport designed for high-end home theaters, custom installations, and collectors who want substantially more from physical media than a streaming box can deliver.
Magnetar describes ULTIMA as the world’s first luxury universal media transport with a battery-assisted DC power architecture, using dedicated lithium-based power stages to isolate critical processing and signal paths from electrical noise.
Find out what eCoustics Editor-at-Large Chris Boylan had to say about the Magnetar Ultima when he saw it at the Vienna High-End show earlier this year.
That engineering is important, but the larger story might be even more interesting. Streaming now dominates home entertainment, yet premium 4K Ultra HD Blu-ray releases continue to target enthusiasts who want higher bitrates, lossless audio, ownership, and consistent playback quality without wondering whether a movie will disappear from a service next Tuesday.
ULTIMA takes that argument to its logical, and presumably expensive, extreme. In the world of six-figure home theaters being showcased at CEDIA, spending a fortune on the display, projection, processing, amplification, and loudspeakers only to feed the entire system heavily compressed streaming video has always been a slightly strange place to start saving money.
One Transport for Discs, Files, and Reference Home Theater
Magnetar positions ULTIMA as the pinnacle of its universal media transport technology, designed to establish a new benchmark for reference-level playback and demonstrate what is possible when engineering takes priority over cost and convenience.
Engineered as a pure reference source, ULTIMA is designed to perform one primary function without compromise: preserve source integrity from the disc or digital file to the display or external processor in demanding home cinema and high-performance audio systems.
Built on Magnetar’s MKII player platform, ULTIMA supports UHD Blu-ray, Blu-ray, DVD, CD, SACD, DVD-Audio, DSD/DoP via AES/EBU, USB media, and high-resolution network playback, along with Dolby Vision and HDR10+.
That broad format support means ULTIMA can handle nearly every premium physical and digital media format likely to appear in a modern custom theater or dedicated listening room, potentially eliminating the need for separate disc players and file transports within the same system.
magnetar-ultima-stacked-front
Why ULTIMA Uses a Separate DC Power Supply
One of the key differences between ULTIMA and Magnetar’s existing MKII platform is its use of a separate external DC power supply rather than relying exclusively on a conventional internal AC power architecture.
ULTIMA incorporates dedicated BYD lithium-based power stages designed to isolate critical transport, clocking, and signal pathways from electrical noise, voltage fluctuations, and other forms of contamination that can be present in conventional power environments. Basically, the same industrial strength lithium ion batteries used in BYD’s electric cars are being used here to provide stable, precision power for the disc transport.
The goal is to provide a more stable, low-noise operating environment for precision playback, particularly in reference home theater and high-end audio systems where minimizing electrical interference is part of the design brief. Magnetar positions this battery-assisted DC architecture as one of ULTIMA’s defining technical features and a significant step beyond its existing universal disc players.
A 10 MHz Master Clock Keeps ULTIMA in Sync
Complementing ULTIMA’s battery-assisted power architecture is a synchronized master clock system built around a unified 10 MHz reference clock. Its purpose is to maintain precise timing across the transport and provide stable, accurate signal transmission to downstream components such as external processors and DACs. ULTIMA itself does not include a built-in DAC.
Using a common reference allows the transport to operate from a single timing source, helping maintain consistent data flow and predictable timing relationships throughout the playback chain.
According to Magnetar, this approach is designed to improve overall system stability, signal integrity, and timing consistency while reducing phase noise and improving playback consistency. In a reference transport, where the goal is to deliver the cleanest and most precisely timed digital signal possible to an external processor or DAC, that clocking architecture is a meaningful part of the engineering rather than another box to tick on the specification sheet.
A Reinforced Chassis With Reference Grade Connectivity
The same attention Magnetar has given ULTIMA’s power supply and clock architecture extends to its physical construction. The transport uses a heavily reinforced chassis designed to reduce vibration and resonance, along with isolated and shielded internal circuit sections intended to minimize electrical interaction between critical components.
Magnetar has also paid particular attention to the disc mechanism itself, including its servo control and vibration management. The objective is greater mechanical stability during playback and more consistent disc reading, particularly with demanding formats such as Ultra HD Blu-ray, SACD, and DVD-Audio. Even the support feet have been designed as part of the vibration control strategy.
ULTIMA’s rear panel reinforces its role as a dedicated digital transport. It provides two HDMI outputs, including a main output for audio and video and a second audio-only HDMI output, allowing video to be sent directly to a projector or display while audio is routed separately to an AV processor.
Digital audio connectivity includes AES/EBU and coaxial S/PDIF, while USB 3.0 and Gigabit Ethernet support file and network playback. There is also a 10 MHz clock connection for compatible external clock systems and RS-232C for integration into more sophisticated custom installations.
What you will not find are analog audio outputs. ULTIMA does not contain a DAC and is designed specifically to hand digital audio and video signals off to an external DAC, AV processor, or display. That makes it fundamentally different from Magnetar’s UDP900 MKII, which includes its own extensive analog audio section.
“With ULTIMA, we set out to answer one question: what does a universal media transport solution look like when every possible limitation is challenged?” said Rob Jones, President of Magnetar North America. “At a time when manufacturers are turning away from reference-grade physical media playback, Magnetar is doubling down. ULTIMA is our definitive statement piece. ULTIMA is a purpose-built reference source for those who understand that true reference performance is achieved through relentless attention to detail and uncompromising execution.”
magnetar-ultima-stacked-front-angle
The Bottom Line
When Oppo ended production of its Blu-ray and Ultra HD Blu-ray players in 2018, many enthusiasts wondered whether that was the final nail in the coffin for high-end disc playback. Magnetar has since emerged as a worthy successor, and with 4K Ultra HD Blu-ray showing renewed signs of life, the company appears to be in the right place at the right time.
ULTIMA takes that commitment to an entirely different level. Its two-chassis design, battery-assisted DC power architecture, 10 MHz master clock, reinforced construction, and pure digital transport architecture make it unlike anything else in Magnetar’s lineup. It is also expected to cost around $12,000, which is a substantial jump from the UDP800 MKII and UDP900 MKII, currently priced at $1,899.99 and $3,399.99, respectively.
Pro Tip: Check out some of the Best Ultra HD Blu-ray Disc Titles So Far in 2026.
For enthusiasts looking for the best possible movie playback experience, the choices are becoming increasingly distinct. You can build a Kaleidescape movie server system, buy Panasonic’s excellent DP-UB820 for $549.99, move up to Magnetar’s UDP800 MKII or UDP900 MKII, or head straight into reference territory with ULTIMA.
What makes ULTIMA unique is that Magnetar is not trying to build another feature-packed universal player. It is building an extremely specialized digital transport for people who already own the processor, DAC, display, and home theater system capable of taking advantage of it. At roughly $12,000, that is a very small audience, but nobody can accuse Magnetar of believing that 4K Blu-ray is dead.
Pricing & Availability
The Magnetar ULTIMA is shipping and available through Magnetar’s authorized dealer and distributor network at an MSRP of $12,000. Should full specs become available, a chart will be added to this article. The ULTIMA is on display at CEDIA Expo 2026 in booth #4103 from Sept 2-4.
Can RayNeo turn AR glasses into a private home theater? GT Max offers a 307-inch virtual screen, 120Hz Micro-OLED and Dolby Vision via Pocket...
Can a new 4K restoration and Dolby Atmos mix make Queen Budapest the definitive home release of Freddie Mercury’s last filmed Queen concert?
CD Players
CDs are making a comeback, and Esoteric isn't holding back. The $45,000 Grandioso K1XE SACD player adds a new G2 DAC and an optional...
CD Players
Musical Fidelity's B1xcd CD player arrives as CD sales surge, offering a dedicated transport, ESS DAC, and serious hi-fi engineering without streaming distractions.
Movies
Universal confirms The Odyssey's November 17 4K Blu-ray release with a BD-100 disc, 1.78:1 video, DTS-HD 5.1 audio, and exclusive IMAX extras.
As physical media (both CDs and vinyl) continues its surge in 2026, eCoustics Editor-in-Chief, Ian White takes a look at what's happening behind the...
Apple's 2026 Apple TV 4K adds Siri AI, A19 power and four-HomePod surround. At $299, does it offer enough to justify upgrading?
