In-Wall Speakers
Focal, Naim and Barco Bring 171-Inch LED Wall and 7.0.4 Home Theater to CEDIA Expo 2026
What happens when Barco, Focal, and Naim combine a 171-inch LED wall with a 7.0.4 Focal Utopia home theater and Naim electronics at CEDIA 2026?
Focal 1000 Series In-Wall Speakers Lifestyle
Following Barco’s acquisition of VerVent Audio Holding, parent company of Focal and Naim, the three brands are bringing their combined expertise to CEDIA Expo 2026 in Denver with a high-end home theater demonstration built around premium projection, loudspeakers, electronics, and custom integration.
The showcase provides an early look at what Barco had in mind when it acquired VerVent: combining its expertise in premium visualization with Focal’s loudspeaker engineering and Naim’s high-end electronics to create a more complete luxury home entertainment platform.
Barco, Focal, and Naim will participate across two demonstrations. The first is a dedicated home theater built around the 171-inch Barco Runar HDR and Focal’s architectural Utopia system, while the second pairs Barco’s Vali NT0.9-I LED wall with the $210,000 Focal Diva Alta Utopia active wireless loudspeakers in a more contemporary living room setting.
A 7.0.4 System With Subwoofers? Yes, There Is an Explanation
The first demonstration brings Barco, Focal, and Naim together in a 7.0.4-channel home theater system built around the Barco Runar LED Wall, Focal Astral 16 AV processor and amplifier, Focal 1000 Series integrated loudspeakers, and Naim CI Series amplification and source components. The Astral 16 supports 16 channels, including 12 amplified channels and four balanced preamp outputs, making it particularly well suited to ambitious custom home theater installations.
At first glance, the 7.0.4 designation suggests that no subwoofers are being used. That is not actually the case, and Focal provided some useful clarification about how the system is configured.
The seven bed-layer channels are reproduced by eight loudspeakers: one left front, two center speakers reproducing the center channel, one right front, one left surround, one right surround, one left rear, and one right rear.
The reason the system is listed as 7.0.4 rather than 7.1.4 is that the passive subwoofers are integrated with the main speaker channels rather than assigned to a dedicated LFE channel. In other words, the system delivers seven full-range channels with low-frequency reinforcement built into the speaker configuration instead of routing bass to a conventional “.1” subwoofer channel.
Four in-ceiling loudspeakers complete the system, providing the overhead channels required for the Dolby Atmos portion of the 7.0.4 configuration.
Focal 1000 Series Goes Inside the Walls
Focal 1000 Series in-wall and in-ceiling speakers and subwoofer
The loudspeakers used throughout the home theater demonstration come from Focal’s 1000 Series, the French manufacturer’s high-end custom-installation lineup. Designed to disappear into walls and ceilings, the 1000 Series provides an alternative to conventional freestanding loudspeakers without abandoning the performance expectations of a serious music or home theater system.
And Focal is not exactly being shy with the speaker count.
  • 8 x Focal 1000 IWLCR Utopia ($8,499 each) — Three-way in-wall loudspeaker
  • 10 x Focal 1000 IWSUB Utopia ($3,299 each) — Passive sealed in-wall subwoofer
  • 4 x Focal 1000 ICLCR5 ($2,699 each) — Two-way in-ceiling loudspeaker
The 1000 IWLCR Utopia is the flagship in-wall model in the series and incorporates seven drivers, including four woofers, two midrange drivers, and a Beryllium tweeter. It can be installed vertically or horizontally and used for left, center, or right-channel duties.
The 1000 IWSUB Utopia uses three 6.5-inch W-cone woofers in a passive sealed enclosure. Multiple units can be combined with the 1000 IWLCR Utopia, which explains how this particular CEDIA system can employ 10 subwoofers without using a dedicated LFE channel.
Four 1000 ICLCR5 in-ceiling loudspeakers handle the overhead channels. Their adjustable design allows the drivers to be aimed toward the listening position, making them particularly suitable for Dolby Atmos installations.
Barco Runar Brings 171 Inches of MicroLED to the Party
For the visual half of this home theater demonstration, Barco is bringing out the Runar LED Wall, a 171-inch direct-view display designed specifically for luxury residential cinema installations.
barco-runar-led-wall-lifestyle
Barco has now confirmed that the 171-inch display being demonstrated at CEDIA is the new Runar HDR, an expansion of the Runar family introduced for 2026. It uses the same Micro LED in Package (MIP) technology and 0.9 mm pixel pitch as the existing Runar DCI, with a native 4,096 x 2,160 resolution across a 3.84-meter-wide image. Unlike a conventional projection system, there is no projector, screen, or light path involved; the enormous LED wall is the display.
The important difference is what happens behind it. Runar DCI was designed around DCI-certified private cinema installations, while Runar HDR eliminates the need for DCI-compliant playback infrastructure and is intended to work more easily within premium residential systems. That broadens its appeal beyond dedicated cinema rooms to movies, sports, concerts and gaming.
Barco rates Runar HDR for up to 1,000 nits of brightness, a contrast ratio of up to 200,000:1, an ultra-low black level of 0.005 cd/m², and full DCI-P3 color gamut coverage. It can also accept HDMI 2.1 signals up to 4K/120 with 4:4:4 10-bit video, making it considerably more versatile than its private-cinema pedigree might suggest.
For those who find a 171-inch image somehow inadequate, Barco also offers a 205-inch Runar HDR Cinemascope configuration with 5,120 x 2,160 resolution and a 4.8-meter-wide image. Because apparently there is always one more wall in the house that hasn’t been completely monetized.
And the price?
Barco does not publish one. Runar HDR is sold through authorized dealers and custom installers on a quotation basis. If you have to ask, you probably can’t afford it. And if your installer casually suggests the 205-inch version instead, you might want to check whether the kids still need that college fund.
Or whether your attorney handles divorce cases.
Barco Runar LED Wall Specifications:
Barco ModelRunar HDR
Product Type LED Wall
PriceConsult Dealer/Installer
Resolution Native DCI 4K (4,096 x 2,160 pixels)
Pixel Pitch0.9 mm
Screen Size171” diagonal (3.84 m wide)
Display TechnologyMicro LED in Package (MIP)
HDR SupportConsumer-grade HDR at 1,000 nits
Black Level0.005 cd/m²
DCI-P3 CoverageFull
InputsHDMI 2.1 (up to 4K 120p 444 10bit) – 2D up to 4K 120fps (DCI SDR/HDR)  – 3D up to 4K 24/48/60fps per eye  – (DCI SDR/HDR) Bitrate 1,250 Mbps
Dimensions (WHD) 3840 x 2025 x 75.5 mm
12.6’ x 6.6’ x 0.25’
Weight 235 kg / 518 lbs
For complete specifications and additional technical information, refer to the official Barco Runar product page.
Focal Astral 16 Takes Control of the Home Theater
Focal Astral 16 ($23,999) is a high-end 16-channel AV processor and amplifier designed for custom home theater and multi-room installations. Developed in partnership with StormAudio (Immersive Audio Technologies), the Astral 16 combines Focal branding and system integration with StormAudio’s multichannel processing platform.
focal-astral-16-lifestyle-angle
The Astral 16 incorporates Pascal Audio Class D amplification and supports 16 audio channels. Twelve channels are internally amplified, while four additional channels are provided through balanced XLR preamp outputs for connection to external amplification.
It also supports Dolby Atmos, DTS, and Auro-3D, along with filtering, equalization, and bass-management tools for configuring more complex theater systems. Dirac Live room calibration is included to help compensate for speaker placement and room acoustics, while compatibility with Control4, Crestron, ELAN, Savant, and RTI makes the Astral 16 particularly well suited to professionally installed systems.
Astral Specifications
Focal Model Astral 16
Product Type 16-Channel AV Processor/Amplifier
Price$23,999
Number of Amplified Channels 12
Power Output (for each of 12 channels)200W (8ohms) / 300W (4ohms)
Number of Unamplified Channels4 (XLR outputs for external amps)
Number of Decoded/Processed Channels16
Surround Sound Format SupportDolby Atmos / DTS:X / Auro-3D
Room Calibration Dirac Live – (mic and tripod included) – also includes license
HDMI Inputs (ver 2.0)7
HDMI Ouputs3 (one with HDMI-eARC)
HDR SupportHDR10, HLG
Setup Management Configurable multi-theater management
Configurable audio zones management
Unlimited Theater and audio zones listening presets
Backup and restore of setup
Firmware update via USB/network
Custom Control OptionsCrestron, Control4, Savant, RTI home automation
Front Panel DisplayTFT LCD 4.3″
Dimensions with stands (hwd))19.10 x 47.90 x 49 cm
7.52 x 18.86 x 19.29 Inches
Net weight – with stands (kg/lbs) 20.0 / 44.1
Naim CI Series Adds Power and Streaming
Providing additional amplification and streaming support, Naim is contributing two products from its CI Series to the CEDIA demonstration.
Naim Audio CI Series 2024
The Naim CI Series was developed specifically for the custom installation market and to complement Focal’s integrated loudspeakers. The range combines compact rack-friendly designs with high-output amplification, system configuration tools, and integration with professionally installed audio systems.
4 x Naim CI-NAP 101 ($1,999 each) — The CI-NAP 101 is a rack-mountable mono power amplifier capable of operating with conventional low-impedance loudspeakers or 70V/100V distributed audio systems. It delivers up to 500 watts into 8 ohms and 800 watts into 4 ohms, with outputs of 150 watts on a 70V line and 240 watts on a 100V line.
That flexibility is particularly relevant to this installation. Naim specifically identifies the CI-NAP 101 as suitable for driving Focal’s 1000 IWLCR Utopia together with two 1000 IWSUB Utopia passive subwoofers, which closely mirrors the configuration being demonstrated at CEDIA.
The CI-Uniti 102, discussed below, can work alongside the CI-NAP 101 as a streaming source, amplifier, and system-control component, but it does not provide 70V/100V amplification itself.
1 x Naim CI-Uniti 102 ($1,499) — The CI-Uniti 102 is a compact streaming amplifier designed for custom installations, delivering 150 watts into 8 ohms while adding network streaming, DSP, HDMI, Dante, and flexible system control.
As we found in our recent Naim CI-Uniti 102 review, its strengths are speed, clarity, system integration, and the ability to drive a wide range of loudspeakers without taking up much rack space. In this CEDIA system, it provides streaming access and works alongside the CI-NAP 101 amplifiers to support the larger Focal installation.
Additional Components Used in the Home Theater Demo
Kaleidescape Movie Player (model not specified) — Provides downloaded 4K HDR movies at very high bitrates, with picture and sound quality that can rival or, depending on the title, exceed Ultra HD Blu-ray.
Apple TV 4K — Provides access to additional video and music streaming services, giving the system a more conventional streaming source alongside Kaleidescape.
Barco Vali NT0.9-I Meets Focal Diva Alta Utopia in the Second CEDIA Demo
focal-diva-alta-utopia-front-views-900
The second demonstration takes a different approach, pairing Focal’s $210,000 Diva Alta Utopia active wireless loudspeakers with Barco’s Vali NT0.9-I direct-view LED video wall in a contemporary living room setting. Unlike the larger Runar HDR installation, Vali is designed to fit more easily into media rooms and multipurpose entertainment spaces where a massive dedicated cinema wall might be overkill.
The Vali NT0.9-I uses a 0.9 mm pixel pitch and Barco’s Infinipix processing, with brightness up to 1,000 nits. Barco says its Flip Chip LED technology also reduces power consumption and heat output, while the fine pixel pitch allows viewing from approximately six feet away. The broader Vali NT-I family is available in 0.9, 1.2, and 1.5 mm pixel pitches.
Focal will also showcase $210,000 Diva Alta Utopia, the company’s flagship active wireless speakers, which combine Utopia-derived acoustic engineering with integrated Naim streaming, amplification, DAC, and DSP technology.
This is not simply a larger and more expensive version of the Diva Utopia formula. The Diva Alta Utopia pushes Focal and Naim’s active wireless concept into true ultra-high-end territory with a four-way architecture, new PRISM tweeter, M-profile “W” midrange driver, Ultra Wideband inter-speaker connectivity, extensive streaming support, and 600 watts of Naim-developed Class A/B amplification inside each loudspeaker.
And then there is the $210,000-per-pair price, which makes the word “wireless” feel rather less casual than usual.
The Bottom Line
The real significance of this CEDIA 2026 showcase is not the individual hardware, but the fact that Barco now owns Focal and Naim and can present video, loudspeakers, amplification, streaming, and custom integration as one luxury AV ecosystem.
The first demo shows that strategy at full scale with a 171-inch Runar LED Wall, Focal 1000 Series architectural speakers and subwoofers, and Naim CI electronics. The second takes a different approach, pairing Barco’s Vali NT0.9-I LED wall with the $210,000 Focal Diva Alta Utopia active wireless system in a more contemporary living space.
For luxury integrators and clients who want high performance with minimal visible hardware, that combination is the real differentiator. The products are expensive, but the larger story is how much of the system can now come from three brands under the same corporate umbrella.
Price & Availability
All products available through Authorized Barco, Focal, or Naim Dealers:
  • Barco Runar LED Wall – Consult with Dealer/Installer
  • Focal 1000 IWLCR Utopia – $8,499
  • Focal 1000 IWSUB Utopia – $3,299
  • Focal 1000 ICLCR5 – $2,699
  • Focal Astral 16 – $23,999
  • Naim CI NAP-101 –  $1,999
  • Naim CI Uniti-102  – $1,499
  • Diva Alta Utopia (2 speaker set) – $210,000
The Barco. Focal, Naim demos will be in Booth 3123 in the Colorado Convention Center, Denver, Colorado from Sept 2-4, 2026.
Discover the best wireless speakers of 2026, from portable Bluetooth models to high-end stereo systems.
Our favorite wireless speakers of 2025 include models from Audioengine, Denon, Devialet, Edifier, Q Acoustics and Ruark.
Car Audio
The Bentley Torcal pairs 28 Naim speakers and 1,780 watts with Dolby Atmos 7.1.4 and an EV soundtrack performed using real instruments.
NextLevel's Mantelbar hides a Sonos Arc soundbar or speakers inside the fireplace mantel. Clever architecture, or has the mantel finally earned its keep?
The 2026 CEDIA Expo was held last week in Denver and eCoustics was there in force to check out the latest in home theater...
This episode covers the Best of CEDIA Expo 2026 with Caleb Denison, of CalebRated, including MicroLED video walls, 4K TVs and more.
