Focal Diva Alta Utopia: $210K Wireless Flagship Speaker Takes All-in-One Hi-Fi to the Extreme
Weighing 236 pounds per speaker, Focal Diva Alta Utopia combines PRISM tweeter tech, M-profile W midrange, UWB wireless, and 600 watts of Naim amplification in a $210K flagship.
2026 Focal Diva Alta Utopia Loudspeakers in Grey Felt
Focal did not show the Diva Alta Utopia at High End Vienna 2026. There was no private-room tease, no covered prototype, and not even the usual carefully vague French whisper over espresso that something ruinously expensive was hiding behind the curtain. Same story at AXPONA 2026, although perhaps we should have paid more attention when Focal and Naim suggested that something was coming that would push wireless hi-fi into far more serious territory.
Now we know what that something is: the Focal Diva Alta Utopia, a new flagship wireless loudspeaker system for 2026 and the third model in the company’s rapidly expanding Diva Utopia family. Following the original Diva Utopia in 2024 and the larger Diva Mezza Utopia in 2025, the Diva Alta Utopia takes the same basic promise; a high-end Focal loudspeaker with Naim electronics, streaming, amplification, and system control built in, and pushes it into the kind of price category where most people start checking property taxes.
At $210,000 per pair, the Diva Alta Utopia is not a lifestyle speaker unless your lifestyle involves gated driveways, dedicated listening rooms, and debating whether to turn grandma’s guest room into a pickleball court. But the price also needs some context. A passive Focal/Naim system built around Utopia loudspeakers, high-end Naim amplification, cabling, racks, source components, and proper installation can easily live in the same financial neighborhood.
focal-diva-alta-utopia-speakers-ivory-felt-grille-on-off
Focal Diva Alta Utopia in Ivory Felt with grille off/on
Looked at that way, the Diva Alta Utopia may be outrageous, but it might also be the cleaner, smarter, and possibly less expensive route in the long run for someone who wants a no-compromise Focal/Naim system without a stack of boxes.
You will still need a turntable. Civilization has limits. Bugger.
Related News:
Directly inspired by Focal’s flagship Grande Utopia EM Evo passive loudspeaker, the Diva Alta Utopia adapts several of its core acoustic ideas for an active wireless platform rather than simply duplicating the passive design. Its architecture includes a four-way driver layout, Focal’s Focus Time technology, fine-tuned filtering, and a new M-profile “W” midrange driver developed for this model. Focal says the Diva Alta Utopia is optimized for rooms ranging from 538 to 1,292 square feet.
Pro Tip: For comparison, the original Diva Utopia is optimized for rooms up to 861 square feet, while the Diva Mezza Utopia is rated for spaces up to 1,076 square feet.
What’s New Inside The Diva Alta Utopia
Although the Diva Alta Utopia draws heavily from its predecessors, it also incorporates new technologies that represent Focal’s most advanced loudspeaker engineering to date.
focal-diva-alta-utopia-midrange-tweeter
New M-profile “W” Midrange and PRISM Tweeter
New PRISM Tweeter: The Diva Alta Utopia introduces a new-generation Focal PRISM tweeter. According to Focal, this tweeter combines a multi-material substrate with an advanced micro-structuring process, delivering greater rigidity than beryllium while maintaining a careful balance of lightness, damping, and rigidity. Developed through a major research program, patented, and manufactured in France, PRISM allows Focal to sculpt tweeter membranes with unprecedented precision. More than 20 years after the introduction of the company’s beryllium tweeter, PRISM marks a major step forward in Focal loudspeaker driver development.
New M-profile “W” Midrange: Previously used primarily in Focal’s Utopia M monitors, the M-profile “W” midrange driver makes its debut in the Diva Utopia range with the Diva Alta Utopia. Focal says the new driver improves midrange precision and transparency, while added carbon reinforcement in the Diva Alta Utopia is designed to push performance even further.
Streaming, Inputs, and High-Resolution Format Support
collage-519
Beyond its advanced acoustic architecture, the Diva Alta Utopia is designed as a complete Focal/Naim wireless hi-fi system with integrated amplification, streaming, and physical connectivity built in. Inputs include HDMI eARC, optical, RCA, and USB, giving owners the ability to connect a TV, digital source, analog component, or computer without building a traditional rack-based system around the speakers.
Wireless support includes Wi-Fi, AirPlay 2, Google Cast, UPnP, Bluetooth 5.3, Spotify Connect, TIDAL Connect, Qobuz Connect, and QQ Music via QPlay. Bluetooth codec support includes aptX Adaptive, SBC, and AAC.
The Diva Alta Utopia also supports internet radio through HLS, DASH, and OGG streaming containers, with MP3, AAC, Vorbis, and FLAC codec support, along with Icecast, Shoutcast, and Xperi Extended Metadata.
File support is extensive, including WAV, FLAC, AIFF, and ALAC up to 24-bit/384kHz, MP3 and AAC up to 48kHz/320kbps, OGG up to 48kHz, and DSD64/DSD128. Focal also specifies smooth gapless playback across all supported formats.
focal-diva-alta-utopia-rear-inputs
UWB Inter-Speaker Connection: To simplify setup between the primary and secondary speakers, the Diva Alta Utopia uses Ultra Wideband, or UWB, technology. This allows the two speakers to communicate wirelessly at 96 kHz/24-bit, with no compression, no signal loss, and very low latency.
Pro Tip: For 192 kHz/24-bit playback between the two speakers, Focal provides a wired inter-speaker connection. Wireless UWB tops out at 96 kHz/24-bit.
Control Options: Like its Diva Utopia predecessors, the Diva Alta Utopia can be controlled using the supplied remote, the Focal & Naim app, supported voice assistants including Google Assistant and Siri, and smart home control systems such as Control4, Crestron, Savant, and RTI.
Focal/Naim App
ADAPT Technology: You can have the most luxurious speaker system, but it can’t perform at its best unless the speakers work well with your room. With this in mind, the Diva Utopia wireless speaker line provides the ADAPT room acoustic correction system, incorporating each user’s individual hearing perception.
What’s On The Outside
The Diva Alta Utopia is not only packed with the technology needed for a serious wireless, and wired, high-end listening experience; it is also designed to make a very visible statement in the room.
focal-diva-alta-utopia-side-angle
Ivory Felt (left side view) vs. Off White (right angle view) finishes
Focal gives the Diva Alta Utopia sculptural lines, balanced proportions, and a commanding, almost architectural presence. At 58 1/4 x 18 1/8 x 24 3/8 inches, or 148 x 46 x 62 cm, and 236 pounds, or 107 kg, per speaker, this is not a compact lifestyle product pretending to be high-end hi-fi. It is a full-scale luxury loudspeaker system that happens to remove the need for a traditional stack of electronics.
The Diva Alta Utopia also features interchangeable floating side panels, allowing owners to change the speaker’s appearance without altering the speaker itself. Finish options include felt panels in Grey or Ivory, along with lacquer panels in Black High Gloss, Off-White High Gloss, and Dune High Gloss.
Focal has clearly designed the Diva Alta Utopia to elevate both the listening experience and the living space it occupies. Just make sure the living space is ready for a pair of 236-pound French loudspeakers that do not exactly disappear behind a ficus or your collection of Charlotte Gainsbourg records.
Comparison
focal-diva-alta-mezza-utopia-speakers
Left to right: Focal Diva Alta Utopia, Diva Mezza Utopia, Diva Utopia
Focal ModelDIVA ALTA UTOPIA
(2026)
DIVA MEZZA UTOPIA
(2025)
DIVA UTOPIA
(2024)
MSRP/pair$210,000$69,000$39,999
Type 4-way bass-reflex active3-way bass-reflex active3-way bass-reflex active
Bass 4 x ‘W’ 8″ (20.5cm) with push-push configuration 4 x ‘W’ 8″ (20.5cm) push-push configuration 4 x ‘W’ 6-1/2″ (16.5cm) push-push configuration
Midbass ‘W’ 6-1/2″ (16.5cm) with TMD suspension and NIC motor‘W’ 6-1/2″ (16.5cm) with TMD surround and NIC motor ‘W’ 6-1/2″ (16.5cm) with TMD surround and NIC motor
Midrange5-1/8″ (13cm) W with M profile
Tweeter PRISM 1-1/16″ (27mm) M-profile inverted dome with IAL2IAL2 1-1/16″ (27mm) pure beryllium ‘M’ shaped inverted dome IAL2 1-1/16″(27mm) pure beryllium ‘M’ shaped inverted dome
Bandwidth  (+/-3dB) 23Hz – 40kHz 27Hz – 40kHz 27Hz – 40kHz
Low-frequency cut-off (-6dB)20Hz 22Hz 24Hz
Maximum SPL per pair @1m122 dB120 dB116 dB
Amplification Type Class A/BClass A/BClass A/B
Amplifier OutputLF: 280W
MF: 100W
HF: 90W
MB: 130W
LF: 280W
MF: 130W
HF: 90W
LF: 250W
MF: 75W
HF: 75W
Power supply 110–120V / 220–240V ~50/60Hz 110-120V/220-240V ~50/60Hz 110-120V/220-240V ~50/60Hz
Power consumption 360W 320W 280W
Network standby mode <2W <2W <2W
No-network standby mode<0.5W <0.5W <0.5W
Internet Radio YesYesYes
Dimensions (HxLxD) 58-1/4 x 18-1/8 x 24-3/8″
(148 x 46 x 62 cm)
50 x 18-1/8 x 24-7/16″
(127 x 46 x 62 cm)
47-5/8 x 16-1/2 x 22″
(121 x 42 x 56 cm)
Net Weight 236 lbs (107kg)192 lbs (90kg)141 lbs (64kg)
Weight (with packaging) 427 lbs (194kg)238 lbs (108kg)174 lbs (79kg)
focal-diva-alta-utopia-tweeter-closeup
Focal Diva Alta Utopia Tweeter Closeup
Features in Common
  • Primary loudspeaker inputs:
    • HDMI eARC, CEC
    • Optical TOSLINK
    • Analogue RCA
    • USB 2.0 Type A
    • RJ45 Ethernet
    • RJ45 Speaker Link
  • Secondary loudspeaker:
    • RJ45 Speaker Link
  • Audio formats:
    • WAV, FLAC and AIFF – up to 24 bits/384 kHz
    • ALAC (Apple Lossless Audio Codec) – up to 24 bits/384 kHz
    • MP3 – up to 48 kHz/320 kbps (16 bits)
    • AAC – up to 48 kHz/320 kbps (16 bits)
    • OGG and AAC – up to 48kHz (16 bits)
    • DSD64 and DSD128
    • Bluetooth – aptX Adaptive, SBC, AAC
    • Note: support for smooth, continuous playback on all formats
      Multiroom Synchronizes up to 32 Focal & Naim streamers,
      controlled from the Focal & Naim app
  • Wireless streaming:
    • AirPlay
    • Google Cast
    • UPnP
    • Bluetooth 5.3
    • Spotify via Spotify Connect
    • TIDAL via TIDAL Connect
    • QQ Music via QPlay
    • Qobuz via Qobuz Connect
  • Music streaming services via the Focal & Naim app:
    • TIDAL
    • Qobuz
    • Internet radio
    • Podcasts depend on services available in each country
  • Network: Ethernet (1000/100/10 Mbps), Wi-Fi (Wi-Fi 6)
  • Wireless connection: UWB 96kHz/24bits
  • Connection with Hi-Res Link: 192kHz/24-bits
  • Handheld:
    • Integrated remote control
    • Dedicated control app on iOS and Android
  • Remote control: Zigbee
Focal Diva Alta Utopia in Grey Felt
The Bottom Line
The Focal Diva Alta Utopia is not merely a larger, more expensive version of the Diva Utopia formula. It is Focal and Naim pushing the active wireless loudspeaker concept into true ultra-high-end territory, with a four-way architecture, new PRISM tweeter, new M-profile “W” midrange driver, UWB inter-speaker connectivity, extensive streaming support, and 600 watts of Naim Class A/B amplification inside each speaker.
Based on our experience listening to the earlier Diva Utopia models at recent shows, including AXPONA, the promise here is not theoretical. Those systems filled a large hotel ballroom with surprising ease, even with a crowd in the room and multiple display areas competing for attention. If the Diva Alta Utopia delivers greater dynamic headroom, higher resolution, a larger soundstage, more refined low-end control, and even better midrange presence, it is clearly aimed at larger rooms and buyers who want scale without the traditional tower of electronics.
The earlier models were already as impressive as some of the $250,000 systems we heard at the show, which makes the Alta’s price easier to understand, even if it still requires a very deep wallet and possibly a quick lie-down afterward. How French.
The price might be the hard part. At $210,000 per pair, the Diva Alta Utopia three times than the Diva Mezza Utopia and over five times more than the original Diva Utopia. That puts it in the same conversation as the Bang & Olufsen Beolab 90, not the usual premium wireless speaker category. But a passive Utopia-based Focal system with high-end Naim amplification, source components, cabling, racks, and installation can also become a six-figure exercise very quickly. In that context, the Diva Alta Utopia may be outrageous, but not automatically irrational.
What is missing? Vinyl listeners will still need a turntable and a proper phono stage unless their deck already has one built in. This is also not a replacement for a full multi-channel home theater system, and at 236 pounds per speaker, nobody is casually repositioning them after dinner. The Diva Alta Utopia is for the buyer who wants ultra-high-end Focal/Naim performance without the traditional tower of electronics. Everyone else can admire it from a safe financial distance.
focal-diva-alta-utopia-colors
Focal Diva Alta Utopia in Black High Gloss, Grey Felt, and Off White High Gloss Finishes.
Price & Availability
The Focal Diva Alta Utopia will be available beginning August 2026, exclusively through the Focal Powered by Naim network of authorized retailers for $210,000 USD and $260,000 CAD per pair.
Finishes include grey and ivory felt, three lacquered and varnished finishes, Black High Gloss, Off-White High Gloss, and Dune High Gloss. All finishes are hand-crafted in the Focal Ebénisterie Bourgogne workshop.
The Diva Utopia ($39,000/pair) and Diva Mezza Uptopia ($69,000/pair) are also currently available through Focal Powered by Naim Network and authorized dealers.
1 Comment
1 Comment
  1. Cheapskate Anton
    June 18, 2026 at 6:26 pm
    $210,000. Jesus Murphy. And he left town.
    I have a hard time believing it is twice as good as the previous flagship that sounded fantastic at the past two shows I’ve listened to it.
2026 Apple iPhone Duo in Star White Open
Can Apple’s $1,999 iPhone Duo replace an iPhone and iPad with a 7.6 inch foldable display, A20 Pro and iOS 27 multitasking?
2026 Apple AirPods 5 with Charging Case 2026 Apple AirPods 5 with Charging Case
Are Apple AirPods 5 a better value at $129 and $149? Apple cuts the price of its wireless-charging model by $30 for 2026.
2026 Audio-Technica ARH-AL5NC Wireless Headphones 2026 Audio-Technica ARH-AL5NC Wireless Headphones
Can open-back headphones work as everyday wireless cans? Audio-Technica’s ATH-AL5NC add LDAC, ANC, wired playback and up to 75 hours of battery life.
2026 Marantz MCR 60n CD Player and Streaming Amplifier in Black 2026 Marantz MCR 60n CD Player and Streaming Amplifier in Black
Marantz MCR 60n combines a CD player and streaming amplifier with HDMI eARC, MM phono and optional Dirac Live. Is this the all-in-one hi-fi...
Sony Headphone Launch - September 2026 Sony Headphone Launch - September 2026
2026 Layer Audio Design Gen-300B Integrated Tube Amplifier Front 2026 Layer Audio Design Gen-300B Integrated Tube Amplifier Front
Layer's GEN-300B delivers 10 watts of Class A tube power for speakers and headphones from $1,499. Can it challenge far pricier 300B amps?
In-Wall Speakers
What happens when Barco, Focal, and Naim combine a 171-inch LED wall with a 7.0.4 Focal Utopia home theater and Naim electronics at CEDIA...
Can 64 Audio’s $3,999 Ocean flagship IEM justify its price with isobaric bass and 32 passive tuning combinations?
What did Focal and Naim bring to Audio Advice Live 2026? A $210K Diva Alta Utopia, Scala’s North American debut, Hekla and a $5,297...
