Apple has officially unveiled AirPods 5, and the biggest surprise is not another AI feature or a marginal change to the charging case. Active Noise Cancellation is now standard on Apple’s least-expensive AirPods, with the new open-ear wireless earbuds starting at $129.
That is a significant change from AirPods 4, where consumers had to spend $179 to get ANC. Apple is also offering AirPods 5 with a Wireless Charging Case for $149, making the more expensive version $30 cheaper than the previous AirPods 4 with ANC while adding longer battery life and on-stem volume control.
Apple lowering the barrier to entry rather than moving it higher? Somewhere, an accountant in Cupertino needs to have their temperature checked.
ANC Is Now Standard on AirPods 5
The biggest change is straightforward: both AirPods 5 models include Active Noise Cancellation.
Apple claims the new earbuds can remove up to 50 percent more external noise than AirPods 4 with ANC, thanks to an all-new multiport acoustic architecture and improved computational audio algorithms. Apple is calling it the industry’s best ANC in an open-ear wireless headphone, although that claim is based on its own July 2026 testing against the bestselling open-ear wireless headphones commercially available at the time.
Open-ear ANC has always been a tricky proposition because the earbuds do not create the passive acoustic seal provided by silicone or foam eartips. Apple managed to make it surprisingly effective on AirPods 4 with ANC, and a claimed 50 percent improvement would be meaningful if real-world performance gets anywhere close.
AirPods 5 also include an improved Transparency mode designed to reproduce surrounding voices and environmental sounds more naturally. Adaptive Audio dynamically blends ANC and Transparency based on ambient conditions, while Conversation Awareness automatically lowers media volume when the wearer starts speaking.
That brings Apple’s complete noise-control suite into its $129 AirPods for the first time.
New Acoustic Architecture Targets Better Sound
ANC might dominate the headline, but Apple has also re-engineered the acoustic system.
AirPods 5 use an all-new multiport acoustic architecture inspired by AirPods Pro 3, combined with Apple’s next-generation Adaptive EQ. According to Apple, the system is designed to provide richer and more detailed sound across a wider range of ear geometries.
That last part matters more with an open-ear design than it might sound. Without an eartip creating a consistent seal, the relationship between the earbud, the listener’s ear, and the acoustic output can have a significant impact on bass response and tonal balance.
Adaptive EQ attempts to compensate for those differences electronically, while the redesigned acoustic architecture handles airflow and sound delivery mechanically. Apple also says the changes make Personalized Spatial Audio more immersive and dynamic.
We will reserve judgment on all of that until somebody actually puts them in their ears. Our review of the AirPods Pro 3 found its expanded feature set impressive but its sonic balance less convincing than AirPods Pro 2, which proved that more computational horsepower does not automatically produce better music reproduction.
AirPods 5 Get Siri AI and Live Translation
Apple is also turning AirPods into a more important hands-free interface for Apple Intelligence.
When paired with an Apple Intelligence-supported iPhone, AirPods 5 can access Apple’s new Siri AI, which begins rolling out in beta with iOS 27. The upgraded assistant can use personal context from messages, emails, photos, and other information while also accessing broader world knowledge and performing supported actions inside apps.
That means users could ask Siri to play a song recommended in a message or find directions to a restaurant based on a reservation confirmation buried inside an email. Siri Interactions also allow users to respond by nodding their head for yes or shaking it for no, which has the additional benefit of making everyone around you wonder why you are suddenly arguing silently with yourself.
Siri AI launches in beta in English on September 14, with French, Japanese, Korean, Portuguese, and Spanish support scheduled for October. Apple notes that some functionality will vary by region and device, and Siri AI will not initially be available in the EU on iOS, iPadOS, or watchOS.
Live Translation is also supported on AirPods 5. After downloading the required languages in Apple’s Translate app, users can start a translation session by pressing both stems simultaneously, asking Siri, or using the Action button on an iPhone.
The feature uses ANC and computational audio to make translated speech easier to hear and requires a compatible Apple device running current software with Apple Intelligence enabled. Language and regional availability vary.
AirPods 5 With Wireless Charging Case Adds More Than Charging
The $149 version is where Apple’s two-model strategy becomes slightly more complicated.
AirPods 5 with Wireless Charging Case add wireless charging compatibility with Apple Watch chargers and Qi-compatible chargers while retaining USB-C. The $149 version also receives a redesigned battery that provides up to five hours of playback with ANC enabled, one hour longer than AirPods 4 with ANC. Total listening time with ANC reaches up to 22 hours when the charging case is included.
There is another useful difference: volume control.
The $149 AirPods 5 add a force sensor with volume swipe, allowing users to adjust playback volume by sliding a finger up or down the stem. This is the first time Apple has offered that control on its open-ear AirPods.
For only $20 more than the standard version, wireless charging, longer battery life, and direct volume adjustment make the $149 model look like the obvious choice unless saving twenty bucks is the primary objective.
AirPods 5 vs AirPods 4
Apple’s new pricing substantially changes the value proposition compared with the previous generation.
AirPods 4 launched at $129 without ANC, while AirPods 4 with Active Noise Cancellation cost $179. That second model also included the more capable wireless charging case.
AirPods 5 put ANC into both versions while keeping the base price unchanged.
Model ANC Wireless Charging Battery Life Stem Volume Control Price AirPods 4 – – 5 Hours – $129 AirPods 4 with ANC Yes Yes 5 hours – $179 AirPods 5 Yes – 4 hours – $129 AirPods 5 with Wireless Charging Case Yes Yes 5 hours Yes $149
What Makes AirPods 5 Unique?
The combination of an open-ear design and serious Active Noise Cancellation remains the defining feature.
Most high-performance ANC earbuds rely on silicone or foam eartips to create a seal that provides substantial passive isolation before their microphones and DSP do anything. AirPods 5 attempt to deliver meaningful noise reduction without sealing the ear canal, which should appeal to listeners who dislike the pressure, isolation, or fit of traditional in-ear designs.
Apple’s other advantage remains ecosystem integration. Siri AI, Live Translation, Personalized Spatial Audio, Adaptive Audio, Conversation Awareness, head gestures, and seamless integration with Apple devices combine into a feature set that is difficult for competitors to duplicate across an entire hardware and software ecosystem.
That doesn’t automatically make AirPods 5 the best-sounding wireless earbuds for $129 or $149. Sony, Technics, Bose, Samsung, Nothing, and other brands have turned this part of the market into a knife fight, and Apple’s continued reliance on its own ecosystem rather than broader high-resolution Bluetooth codec support will still matter to some listeners.
But bringing ANC to $129 changes the conversation rather dramatically.
AIrPods Compared
| Specification | AirPods 4 | AirPods 4 with Active Noise Cancellation | AirPods 5 | AirPods 5 with Wireless Charging Case |
| Year introduced | Sept. 2024 | Sept. 2024 | Sept. 2026 | Sept. 2026 |
| MSRP | $129 | $179 | $129 | $149 |
| Headphone chip | H2 | H2 | H2 | H2 |
| Active Noise Cancellation | – | Yes | Yes | Yes |
| Adaptive Audio | – | Yes | Yes | Yes |
| Transparency mode | – | Yes | Yes | Yes |
| Conversation Awareness | – | Yes | Yes | Yes |
| Voice Isolation | Yes | Yes | Yes | Yes |
| Personalized Spatial Audio | Yes, with dynamic head tracking | Yes, with dynamic head tracking | Yes, with dynamic head tracking | Yes, with dynamic head tracking |
| Adaptive EQ | Yes | Yes | Yes | Yes |
| Bluetooth | Bluetooth 5.3 | Bluetooth 5.3 | Bluetooth 5.3 | Bluetooth 5.3 |
| Dust, sweat, and water resistance | IP54 | IP54 | IP57 | IP57 |
| Listening time per charge | Up to 5 hours | Up to 4 hours with ANC | Up to 4 hours with ANC | Up to 5 hours with ANC |
| Total listening time with case | Up to 30 hours | Up to 20 hours with ANC | Up to 20 hours with ANC | Up to 22 hours with ANC |
| Five-minute charge | Around 1 hour | Around 1 hour | Around 1 hour | Around 1 hour |
| Case charging | USB-C | USB-C, Apple Watch charger, or Qi-certified charger | USB-C | USB-C, Apple Watch charger, or Qi-certified charger |
| Charging case speaker | – | Yes | – | Yes |
| Find My support | – | Yes | Limited/no case speaker | Yes |
| Earbud controls | Force sensor | Force sensor | Force sensor | Force sensor with volume swipe |
| Live Translation | Yes | Yes | Yes | Yes |
| Siri Interactions | Yes | Yes | Yes | Yes |
Compatibility & Availability
AirPods 5 can be preordered starting September 9 in the U.S. and more than 65 countries and regions. Both models arrive in stores on Friday, September 18.
Apple says full feature functionality requires AirPods 5 to be paired with an Apple device running the latest operating-system software. Personalized Spatial Audio requires a compatible iPhone with a TrueDepth camera to create the personalized listening profile.
Apple Intelligence launches with iOS 27 on September 14 on supported hardware and in supported languages. Live Translation also requires Apple Intelligence to be enabled and is not available in every country, region, or language.
The Bottom Line
AirPods 5 are a more meaningful upgrade than their familiar appearance might suggest. Putting Active Noise Cancellation into the $129 model removes one of the biggest compromises associated with Apple’s least-expensive AirPods, while the new acoustic architecture, Adaptive EQ, improved Transparency mode, Live Translation, and Siri AI substantially expand what Apple’s mainstream wireless earbuds can do.
The $149 AirPods 5 with Wireless Charging Case look even more compelling. For only $20 more, buyers get wireless charging, up to five hours of ANC playback, 22 hours with the case, and on-stem volume control while still spending $30 less than the previous AirPods 4 with ANC.
None of that tells us whether AirPods 5 actually sound better, and Apple’s claim of best-in-class open-ear ANC deserves independent testing before anyone starts engraving the trophy. But Apple has made its most affordable AirPods significantly more capable without raising the $129 starting price.
Bose And Sony have been put on notice.
For more information: apple.com/airpods-5/
Related Reading:
- Apple AirPods 5 Could Launch In September As Apple Tightens Its Audio Ecosystem
- Apple AirPods With Cameras: Are AI-Powered Earbuds The Next Big Thing Or A Privacy Problem Waiting To Happen?
- Apple AirPods Pro 3 Bring Improved ANC, Workout Tracking, And Hands-Free Live Translation
