Hisense C3 Lifestyle 4K Projectors Take Aim at Big-Screen TVs With Up to 300-inch Images
Priced from $2,300 to $3,800, Hisense C3 lifestyle 4K projectors offer triple laser imaging, up to 5,000 lumens, Dolby Vision and 240Hz gaming.
2026 HIsense C3 Video Projector Family - C3 Pro, C3 Ultra, C3 Ultra MAX
In late 2024, Hisense introduced its C2 projector series, combining a practical gimbal design with high-end performance. For 2026, Hisense has revealed its successor, the C3 projector family, consisting of the C3 Pro, C3 Ultra, and C3 Ultra MAX.
First shown at IFA 2026, the C3 family refines the C2 formula with support for images up to 300 inches, higher brightness, improved placement flexibility, and immersive sound, all within the same compact lifestyle projector form factor.
What the Hisense C3 Projectors Have in Common
All three projectors in the C3 family share a substantial number of features. Here is a rundown.
Form Factor: As mentioned at the top of the article, the C3 family incorporates a gimbal-style design that provides 360° horizontal rotation and 135° vertical tilt, making it easier to project images onto screens, walls, or ceilings.
Image Projection: All three C3 projectors use DLP imaging technology to display 4K UHD resolution (via pixel shifting), combined with an RGB triple-laser light source rated for more than 25,000 hours of operation. The C3 family can project images ranging from 65 to 300 inches and is rated for 118% coverage of the BT.2020 color gamut. All three models are also rated for contrast up to 5,000:1 using Hisense’s iris system.
hisense-c3-pro-projector-rear
Hisense C3 Pro and C3 Ultra are the same size and have the same rear inputs.
HDR Support: All three projectors support Dolby Vision, HDR10+, HDR10, and HLG, along with IMAX Enhanced and Filmmaker Mode. The entire C3 family also supports Active 3D playback.
Gaming Support: The C3 family is designed for more than movies and sports, with gaming features that include HSR240, VRR, ALLM, and support for refresh rates up to 240Hz. Hisense also claims response times as low as 1ms, depending on the operating mode. FreeSync Premium support is included across the lineup.
Auto Magic AI Adjusting 3.0: Hisense’s automated image setup system includes autofocus, automatic keystone correction, obstacle avoidance, screen fit, and wall-color adaptation, reducing the amount of manual adjustment required when repositioning the projector.
Audio Support: The Hisense C3 projector family includes an integrated 2.1-channel audio system with a built-in subwoofer and 56 watts of total output, along with Devialet-tuned sound.
Streaming Support: The Hisense C3 projectors provide built-in access to streaming services through the company’s VIDAA OS. Connectivity includes Wi-Fi 7, Bluetooth 5.4, Apple AirPlay 2, and Miracast.
hisense-c3-pro-projector-angle
Hisense C3 Pro and C3 Ultra are the same size and look the same.
hisense-c3-ultra-max-projector
Hisense C3 Ultra Max is larger with extra front panel sensor.
The Differences Between the C3 Models
As you can see, all three C3 projectors share a substantial number of features. The most obvious difference is brightness, which may help determine which model is best suited to your viewing environment. However, the C3 Ultra MAX also adds several hardware and installation upgrades that distinguish it from the other two models.
C3 Pro: Considered the entry-level model in the Hisense C3 family, the C3 Pro is rated at 3,000 ANSI lumens. It features a 0.9-1.5 throw ratio and lens shift of ±100% vertically and ±35% horizontally.
C3 Ultra: Occupying the middle position in the C3 family, the C3 Ultra increases light output to 4,000 ANSI lumens while retaining the same 0.9-1.5 throw ratio and ±100% vertical and ±35% horizontal lens shift as the C3 Pro.
hisense-c3-ultra-max-projector-rear
Hisense C3 Ultra MAX is larger in size with different rear panel layout.
C3 Ultra MAX: The flagship of the C3 family increases light output to 5,000 ANSI lumens and adds a more flexible optical system, with a 0.85-1.7 throw ratio and expanded lens shift of ±120% vertically and ±47% horizontally. It also adds liquid cooling, a 3D ToF sensor for its Auto Magic AI 3.0 system, and Hisense’s additional Cinema technology designed to reduce rainbow artifacts and laser speckle. Refer to our comparison chart below for the complete differences.
Comparison
Hisense ModelC3 Ultra MAX C3 UltraC3 Pro
Product TypeVideo ProjectorVideo ProjectorVideo Projector
Price$3,797.97$2,797.97$2,297.97
Projector Type4K Laser Projector4K Laser Projector4K Laser Projector
Light SourceTri-Color Laser Tri-Color Laser Tri-Color Laser
Laser Life20,000 Hours20,000 Hours20,000 Hours
DLP Imaging ChipYes – 0.47” DMDYes – 0.47” DMDYes- 0.47” DMD
Brightness (ANSI Lumens)5000 ANSI Lumens (WLO)4000 ANSI Lumens (WLO)3000 ANSI Lumens (WLO)
Contrast Ratio (Native)5000:1 5000:1 5000:1
Wide Color GamutYesYesYes
HDR SupportHDR, HDR10, HDR10+, HLG, Dolby VisionHDR, HDR10, HDR10+, HLG, Dolby VisionHDR, HDR10, HDR10+, HLG, Dolby Vision
3D SupportYesYesYes
Resolution 4K Ultra HD 3840×2160 4K Ultra HD 3840×2160 4K Ultra HD 3840×2160
Filmmaker ModeYesYesYes
IMAX EnhancedYesYesYes
MEMC (Motion Estimation/Motion Compensation)YesYesYes
Throw Ratio0.86 – 1.710.9 – 1.5:1  0.9 – 1.5:1
Optical Zoom2x1.67x 1.67x
Lens Shift±120% vertical
±47% horizontal
±100% vertical
±35% horizontal
±100% vertical
±35% horizontal
Keystone CorrectionAuto/Manual Auto/Manual –
Projection Screen Size65 to 300 inches65 to 300 inches65 to 300 inches
Eye ProtectionYes – AutoYes – AutoYes – Auto
Easy Setup Features (Auto Magic AI Adjusting 3.0)Seamless Auto Focus
Seamless Auto Keystone
Correction
Auto Obstacle Avoidance
Intelligent Eye Protection
Auto Screen Fit
Intelligent Wall Color Adaptation
Seamless Auto Focus
Correction
Auto Screen Fit
Seamless Auto Focus
Correction
Auto Screen Fit
HDMI222
HDMI ARC, CECYesYesYes
ALLMYesYesYes
USBYes – 2Yes – 2Yes – 2
Audio Output Power56 Watts Total56 Watts Total56 Watts Total
Surround SoundDTS Virtual:XDTS Virtual:XDTS Virtual:X
Sound TuningDevialetDevialetDevialet
Analog Audio Output (3.5mm)Yes – 1Yes – 1Yes – 1
Digital Audio OutputYes – 1Yes – 1Yes – 1
Subwoofer Output111
RF Antenna Input/TV TunerNoNoNo
Smart TV PlatformVIDAA U9 VIDAA U9 VIDAA U9
App StoreYesYesYes
Streaming Service SupportNetflix, YouTube, Prime Video, Disney+, FIFA, and more…Netflix, YouTube, Prime Video, Disney+, FIFA, and more…Netflix, YouTube, Prime Video, Disney+, FIFA, and more…
BluetoothYesYesYes
Media Player (Audio, Images, Video)YesYesYes
Gaming SupportGame Mode Pro
Xbox Cloud Gaming
FreesyncPremium
VIDAA Games
Game Mode Pro
Xbox Cloud Gaming
FreesyncPremium
VIDAA Games
Game Mode Pro
Xbox Cloud Gaming
FreesyncPremium
VIDAA Games
Ethernet (LAN)YesYesYes
Wi-FiIEEE 802.11 a/b/g/n/ac-2.4G, 5G IEEE 802.11 a/b/g/n/ac-2.4G, 5G IEEE 802.11 a/b/g/n/ac-2.4G, 5G
AirPlay 2YesYesYes
Voice AssistantVIDAA VoiceVIDAA VoiceVIDAA Voice
RemoteYesYesYes
Quick Start Guide / ManualYesYesYes
Console Dimensions (WHD)256 x 315 x 256mm
10.08 x 12.4 x 10.08 inches
271 x 279 x 245mm
10.67 x 10.98 x 9.65 inches
271 x 279 x 245mm
Weight11.7 kg 8 kg7.8  kg
hisense-c3-ultra-projector-angle-low
Hisense C3 Ultra
The Bottom Line
The Hisense C3 family builds on the previously released C2 Series, retaining its practical gimbal design and support for projected images up to 300 inches.
For consumers, choosing between the three C3 models will largely come down to how much light output you need and how much installation flexibility you want. All three should provide sufficient brightness for a wide range of viewing environments, but if you plan to use the projector in a room with some ambient light, project onto a wall rather than a dedicated screen, or watch a lot of 3D movies, the 5,000 ANSI lumens offered by the C3 Ultra MAX could make a meaningful difference. Its wider lens shift and expanded throw-ratio range also provide greater placement flexibility.
There is plenty of competition, however. If you like the C3’s gimbal design, the Dangbei MP1 Max is another option worth considering, with its own 360° horizontal rotation and 135° vertical tilt. If you prefer a more traditional projector form factor or are susceptible to DLP rainbow effects, the 2026 Epson 3LCD Home Cinema LS Series offers an alternative based on 3-chip 3LCD imaging.
Pricing & Availability
The 2026 Hisense C3 Projector Family is available at the following prices:
2026 Nagra AMP II-S Stereo Power Amplifier
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro
Can RayNeo turn AR glasses into a private home theater? GT Max offers a 307-inch virtual screen, 120Hz Micro-OLED and Dolby Vision via Pocket...
Grado Signature S150 Headphones Grado Signature S150 Headphones
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
2026 Schiit Mani 3 Phono Preamp 2026 Schiit Mani 3 Phono Preamp
Schiit Mani 3 phono preamp adds front-panel controls, MM/MC cartridge flexibility, and improved circuitry without raising the price.
2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle 2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle
Head Units
Pioneer's 2026 Heritage Collection in-dash head unit and box speaker set combines retro looks with modern convenience for your car.
2027 Technics SL-1210MKX DJ Turntable Lifestyle 2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
Developers have found a way to restore Dolby Atmos height effects from Blu-ray soundtracks on Apple TV 4K. It's an impressive technical achievement, but...
Our favorite home theater projectors of 2026 deliver best-in-class performance across UST, lifestyle, and long throw categories.
Our favorite projectors of 2025 offer the best picture quality and value at their price across UST, lifestyle and standard throw models.
Berliner Philharmoniker now streams live concerts in Dolby Atmos with 4K video, an extensive archive and no extra fee for subscribers.
Which TVs are worth buying in 2026? Our hands-on tested Editors’ Choice winners cut through the hype to reveal the best OLED, Mini LED...
Our picks for best televisions of 2025 offer the best picture quality and value at their price and size.
