Epson Debuts Affordable 3LCD Home Cinema LS5000, LS6000 and LS7500 4K Laser Projectors
Priced from $1,999 to $2,699, Epson’s new line of 4K home theater projectors feature 120Hz gaming, laser light source, and brightness from 2500 to 3500 lumens.
2026 Epson Home Cinema LS Series 3LCD 4K Projectors
The rapid growth of extra-large TVs measuring 85 inches and larger has put real pressure on the home projector category. Today’s biggest TVs are brighter, smarter, and increasingly affordable, making them a compelling alternative for buyers who once would have automatically considered projection.
Projectors still hold one major advantage, however: sheer image size. In dedicated home theaters and larger multipurpose rooms, projection can deliver a 100-inch, 120-inch, or even larger image without pushing prices into the stratosphere.
Following the launch of its higher-end Pro Cinema Q-Series 4K Laser Projectors in 2024, Epson is now bringing more attention to its step-down Home Cinema lineup with the new LS5000, LS6000, and LS7500 4K HDR laser projectors. The three models sit below the flagship Q-Series but retain a number of the technologies and features that made those projectors noteworthy.
epson-home-cinema-projector-2026-lifestyle
The new LS Series models are built around Epson’s 3-Chip 3LCD technology and use a laser light engine. For owners of older lamp-based projectors, the move to laser brings a longer-lasting light source, more consistent brightness over time, and faster startup and shutdown.
The new models complement Epson’s established Home Cinema projector lineup, which is currently headed by the Home Cinema LS11000, introduced in 2022. Epson says the new Home Cinema projectors are designed to balance image performance with flexible installation and easier integration across a wide range of home entertainment spaces.
“As TVs get bigger, they can also become a design challenge, leaving a large black rectangle that dominates the room when not in use. Projection offers a discreet alternative that virtually disappears when the entertainment ends, while creating immersive experiences not possible with a traditional TV – from everyday 16:9 content to cinematic 21:9 and IMAX-style viewing,” said Fernando Tamashiro, product manager at Epson America, Inc. “By expanding our Home Cinema lineup with these new 4K HDR laser projectors, we’re offering an even broader range of solutions for today’s home entertainment spaces. Combining our unique 3-Chip 3LCD technology with our latest laser light source, Epson projectors are the optimal choice for customers looking to create a big-screen experience tailored to their viewing preferences, space and budget.”
Designed for movies, sports, and immersive gaming, Epson’s new Home Cinema laser projector lineup can display 4K HDR images at screen sizes ranging from 40 to 300 inches.
epson-home-cinema-ls5000-projector-2026
Epson LS5000
What the Epson LS5000, LS6000, and LS7500 Have in Common
Image Display Technologies: All three projectors use an advanced Epson Picture Processor, proprietary 4K display technology that produces a full 8.29-million-pixel on-screen image via Quad Pixel Shifting, and a 3-Chip 3LCD projection engine powered by a laser-array light source.
Light Output: The three projectors produce between 2,500 and 3,500 lumens of equal Color Brightness (IDMS Rated) and White Brightness (ISO Rated), depending on the model. Epson says the result is a bright, vivid image with strong color performance and deep black levels.
Advanced HDR Capability: Full 10-bit color processing supports HDR10 and HLG content. Additional HDR processing is provided by Epson’s Automatic HDR Scene Correction.
Multiple Aspect Ratios: From 16:9 HDTV content to cinematic 21:9 presentations, the new Home Cinema LS projectors are designed to support a range of screen formats and viewing environments.
epson-home-cinema-projector-comparison-2026-short-throw-lens
Lenses: The Home Cinema LS5000 and LS6000 incorporate Epson Cinema standard-throw lenses, while the Home Cinema LS7500 features a short-throw lens that allows the projector to be positioned closer to the screen than conventional long-throw models. That makes the LS7500 better suited to larger screen sizes in rooms where projector placement is more limited.
High Black Contrast: Producing convincing black levels while maintaining shadow detail has long been a challenge for projectors. Epson specifies dynamic contrast ratios ranging from 800,000:1 to 1,200,000:1 across the three new LS models, depending on the projector. The goal is greater differentiation between bright and dark portions of the image while preserving detail in darker scenes.
epson-home-cinema-ls5000-ls6000-rear
LS5000 and LS6000 have the same rear inputs
epson-home-cinema-ls7500-rear
LS7500 adds Trigger Out and RS-232C ports on rear
HDMI Connectivity: All three projectors include dual HDMI inputs supporting refresh rates up to 120Hz, with one HDMI port providing eARC for audio passthrough to a compatible AV receiver or soundbar.
Gaming: In addition to supporting refresh rates up to 120Hz, the new LS projectors include Auto Low Latency Mode (ALLM) and input lag rated below 20ms. That combination makes them suitable for gaming with compatible consoles and PCs where faster response times are important.
Flexible Installation: A compact design with quiet, front-exiting airflow provides additional placement flexibility. Manual lens shift of ±21% horizontally and ±59% vertically also makes it easier to position the projector in a variety of home theater and multipurpose spaces.
Bluetooth: Bluetooth connectivity is still not standard across the projector category, but the Home Cinema LS5000, LS6000, and LS7500 include Bluetooth 6.0. This allows audio from HDMI-connected sources to be streamed to compatible wireless headphones or speakers.
Comparison
Epson ModelLS5000
(2026)
LS6000
(2026)
LS7500
(2026)
LS11000
(2022)
Product TypeVideo ProjectorVideo ProjectorVideo ProjectorVideo Projector
Price$1,999.99$2,199.99$2,699.99$3,999.99
Projection System Epson 3LCD Epson 3LCD Epson 3LCD Epson 3LCD
Chip Design (Architecture) 3-chip 3-chip 3-chip 3-chip
Light Source True Laser Diode Array True Laser Diode Array True Laser Diode Array Laser/Phosphor
Projection Method Front, front-ceiling, rear, rear-ceiling Front, front-ceiling, rear, rear-ceiling Front, front-ceiling, rear, rear-ceiling Front, front-ceiling, rear, rear-ceiling
Product Color White White White White
Driving Method Poly-Silicon TFT Active Matrix, 0.62″ wide panel Poly-Silicon TFT Active Matrix, 0.62″ wide panel Poly-Silicon TFT Active Matrix, 0.62″ wide panel Poly-silicon TFT Active Matrix, 0.74″ wide panel
Output Resolution 4K Display Technology1 3840 x 2160 (dual axis: 1920 x 1080) 4K Display Technology1 3840 x 2160 (dual axis: 1920 x 1080) 4K Display Technology1 3840 x 2160 (dual axis: 1920 x 1080) 4K Display 3840 x 2160 (dual-axis: 1920 x 1080) – Upgraded from earlier version that employed PRO UHD
Maximum Input Resolution 4096 x 2160 4096 x 2160 4096 x 2160 4096 x 2160
Supported Resolutions 3840 x 2160, Full HD 1080p/i, HD 720p, 576p/i, 480p/i 3840 x 2160, Full HD 1080p/i, HD 720p, 576p/i, 480p/i 3840 x 2160, Full HD 1080p/i, HD 720p, 576p/i, 480p/i 3840 x 2160, Full HD 1080p/i, HD 720p, 576p/i, 480p/i
Native Aspect Ratio 16:9 widescreen 16:9 widescreen 16:9 widescreen 16:9 widescreen
Color Brightness (IDMS Rated) 2,500 Lumens 3,400 Lumens 3,500 Lumens 2,500 Lumens
White Brightness (ISO Rated) 2,500 Lumens 3,400 Lumens 3,500 Lumens 2,500 Lumens
Contrast Ratio Up to and over 800,000:1, with dynamic contrast in Normal and Auto Iris On Up to and over 800,000:1, with dynamic contrast in Normal and Auto Iris On Up to and over 1,000,000:1, with dynamic contrast in Normal and Auto Iris On Up to and over 1,200,000:1, with Dynamic Contrast in Normal or High Speed setting
White Balance Not IndicatedNot IndicatedNot Indicated14-point temperature adjustment
Color Reproduction Full-color (up to 1.07 billion colors) Full-color (up to 1.07 billion colors) Full-color (up to 1.07 billion colors) Full-color (up to 1.07 billion colors)
Size (Projected Distance) 40″ to 300″ (at 45″ to 28.8′) 40″ to 300″ (at 45″ to 28.8′) 40″ to 300″ (at 45″ to 28.8′) – (Zoom: Wide and Zoom: Tele) 50″ to 300″ (at 58″ to 62’4″)
HDR Color Processing Full 10-bit Full 10-bit (Partial 12-Bit)Full 10-bit Full 10-bit(Partial 12-Bit)
Light Source Life Normal Mode: Up to 20,000 hours Normal Mode: Up to 20,000 hours Normal Mode: Up to 20,000 hours Normal Mode: Up to 20,000 hours
Medium Mode: Up to 20,000 hours
Eco Mode: Up to 20,000 hours
Epson Cinema Lens Multi-element precision glass structure Multi-element precision glass structure Multi-element precision glass structure 15-element precision glass structure (AGS)
Type Optical Zoom (manual)/Focus (manual) Optical Zoom (manual)/Focus (manual) Optical Zoom (manual)/Focus (manual) Powered focus/optical zoom/lens position
F-Number 1.49 – 1.77 1.49 – 1.77 1.49 – 1.61 2.0 – 3.0
Focal Length 18.2 mm – 29.2 mm 18.2 mm – 29.2 mm 13.9 mm – 18.1 mm 22.5 – 46.7 mm
Zoom Ratio 1 – 1.62 1 – 1.62 1 – 1.31 – 2.1
Throw Ratio Range 1.32 – 2.15 1.32 – 2.15 1.0 – 1.3 1.35 – 2.84
Keystone CorrectionNot IndicatedNot IndicatedNot IndicatedVertical/Horizontal: ± 30 degrees
Lens Shift Vertical: -59.0% to +59.0% (H center, manual)
Horizontal: -21.0% to +21.0% (V center, manual)
Vertical: -96.3% to +96.3% (H center, powered)
 Horizontal: -47.1% to +47.1% (V center, powered
Lens Cover Cap Cap Cap Powered, slide lens shutter
Connections 2x HDMI 2.1 (HDCP 2.3), one supporting eARC/ARC
1x USB Type-A 5 V 2.0 A (for power supply)
1x USB Type-A (for Firmware updates)
1x Mini USB (service only)
1x Audio out mini plug (3.5 mm)
 1x LAN RJ45 (Projector Control Only
2x HDMI® 2.1 (HDCP 2.3); one supporting eARC/ARC
1x USB Type-A (for optical HDMI cable; 300 mA maximum power supply only)
1x USB Type-A 5 V, 2.0 A for power and firmware
1x LAN RJ45 (control only)
1x RS-232C (DB-9)
1x Trigger out (On, Off) 12 V DC, 200 mA maximum (3.5mm mono or stereo mini-jack)
Dynamic Range Support HDR10, HLG HDR10, HLG HDR10, HLGHDR10, HDR10+, HLG
HDR Adjustment  On/Off On/Off On/Off 16 steps, real-time
Color Modes Dynamic, Vivid, Cinema, Natural Dynamic, Vivid, Cinema, Natural Dynamic, Vivid, Cinema, NaturalDynamic, Vivid, Cinema, Natural
Aspect Ratio  Adjustment Yes (Full, Super Zoom) Yes (Full, Super Zoom) Yes (Full, Super Zoom, Anamorphic Wide, Horizontal Squeeze) Yes (Auto/Full/Zoom)
1.9:1 (4096 x 2160)
21:9 (2560 x 1080)
4:3 (1600 x 1200)
9:6 (720 x 480)
5:4 (720 x 576)
compatible with Normal, Full or Zoom Mode
Input Signal 480p, 576p, 720p, 1080i, 1080p, 2160p 480p, 576p, 720p, 1080i, 1080p, 2160p 480p, 576p, 720p, 1080i, 1080p, 2160p 480p, 576p, 720p, 1080i, 1080p, 2160p
Operating Temperature 41 °F to 95 °F (5 °C to 35 °C) 41 °F to 95 °F (5 °C to 35 °C) 41 °F to 95 °F (5 °C to 35 °C) 41 °F to 95 °F (5 °C to 35 °C)
Power Supply Voltage 100 V – 240 V AC ± 10%, 50/60 Hz 100 V – 240 V AC ± 10%, 50/60 Hz 100 V – 240 V AC ± 10%, 50/60 Hz 100 V – 240 V AC ± 10%, 50/60 Hz
Power Consumption Normal Mode: 330 W
Quiet Mode: 217 W
Normal Mode: 330 W
Quiet Mode: 217 W
Normal Mode: 330 W
Quiet Mode: 217 W
Normal Mode: 311 W
Medium Mode: 243 W
Fan Noise 22 db – 25 db 22 db – 25 db 22 db – 25 db 22 – 30 dB
Wireless LAN Built-in, Wi-Fi® 6E, for Firmware update only Built-in, Wi-Fi® 6E, for Firmware update only Built-in, Wi-Fi® 6E, for Firmware update only Not supported – Ethernet only
Bluetooth Built-in, supports A2DP, AVRCP, Apt-X Built-in, supports A2DP, AVRCP, Apt-X, Bluetooth LE  Built-in, supports A2DP, AVRCP, Apt-X Not Supported
Dimensions (WDH – Including Feet) 17.3″ x 12.4″ x 6.3″ 17.3″ x 12.4″ x 6.3″ 17.3″ x 13.1″ x 6.3″20.5″ x 17.6″ x 7.6″
Weight (Approximate) 17.6 lb (stationary) 17.6 lb (stationary) 18.2 lb (stationary) 28.0 lb
What’s Included 1 x Projector
1 x Power Cable
1x Remote Control
2 x Control Batteries (AA)
1 x Quick Start Guide
1 x Warranty Sheet
1 x Projector
1 x Power Cable
1x Remote Control
1 x Warranty Sheet
1 x Projector
1 x Power Cable
1x Remote Control
1 x Warranty Sheet
1 x Projector
1 x Power cord
1 x Remote Control
Quick Setup Guide
epson-home-cinema-ls6000-projector-2026
Epson LS6000
The Bottom Line
Epson’s position as the world’s top-selling projector brand did not happen by accident. Its lineup stretches from classrooms and conference rooms to dedicated home theaters, and the new Home Cinema LS5000, LS6000, and LS7500 fill an important spot just below the company’s more expensive Pro Cinema Q-Series.
What makes these three interesting is not simply that they use laser light sources or can throw a 300-inch image. Epson combines its 3-Chip 3LCD architecture with equal rated color and white brightness, output ranging from 2,500 to 3,500 lumens, Quad Pixel Shifting for an 8.29-million-pixel 4K image, HDR processing with tone mapping, and gaming features that include 120Hz support and ALLM. The LS7500 also adds a short-throw lens for installations where putting a conventional projector farther back in the room simply isn’t practical.
That combination gives the LS Series a legitimate point of differentiation from many single-chip DLP competitors, where white-light output and color-light output can differ substantially. It also gives buyers much of the functionality they actually need for movies, sports, and gaming without forcing them into Epson’s considerably more ambitious Pro Cinema Q-Series.
Competition from Sony, Hisense, Leica, JMGO, Optoma, and others is substantial, and some alternatives offer more light output, different installation options, or integrated entertainment features. But for someone trying to build a genuinely large-screen home theater without entering flagship-projector territory, the LS5000, LS6000, and LS7500 make a strong case for staying with traditional projection. A 98-inch TV might be getting easier to justify; a 150-inch one remains something of a financial incident.
Pro Tip: None of the three projectors includes a built-in speaker system or projection screen, so those need to be factored into the total system cost. Bluetooth is available for wireless audio, but anyone building a serious home theater will still want to budget for an external audio system and an appropriate screen.
epson-home-cinema-ls7500-projector-2026
Epson LS7500
Price & Availability
The new Epson Home Cinema LS Projectors are available through Epson’s Online Store and Select Retailers.
2027 Technics SL-1210MKX DJ Turntable Lifestyle
Technics SL-1210MKX brings improved isolation, precise pitch control, and professional refinements to the iconic SL-1200 platform for $1,899.
Esoteric K1XE CD Player and PS1XE Power Supply Esoteric K1XE CD Player and PS1XE Power Supply
CD Players
CDs are making a comeback, and Esoteric isn't holding back. The $45,000 Grandioso K1XE SACD player adds a new G2 DAC and an optional...
Bumpboxx Retroboom Portable Boombox in Red, Silver, Black Bumpboxx Retroboom Portable Boombox in Red, Silver, Black
The $299 Bumpboxx Retroboom packs 200 watts of peak power, Bluetooth, RGB lighting and 30-hour battery life into a retro boombox without tapes or...
Esprit Generation 10 Cables Esprit Generation 10 Cables
Audio Cables
Esprit Generation 10 cables arrive in the U.S. with redesigned conductors, connectors, and insulation. Nine ranges span $499 to $59,999.
2026 Goldmund Mimesis Statement Preamplifier 2026 Goldmund Mimesis Statement Preamplifier
Goldmund's Mimesis Statement uses three chassis, separate channel power supplies and redesigned analog circuitry. A flagship with a startling price.
2026 Jamo HYG 5 WiFi Speaker Dark Grey Lifestyle 2026 Jamo HYG 5 WiFi Speaker Dark Grey Lifestyle
Jamo's $399 HYG 5 WiFi speaker offers Qobuz Connect, TIDAL Connect, AirPlay 2, Google Cast and three active drivers in a Scandinavian design.
Berliner Philharmoniker now streams live concerts in Dolby Atmos with 4K video, an extensive archive and no extra fee for subscribers.
Apple may unveil a new Apple TV 4K, HomePod mini and smart home hub on October 13, potentially creating its most complete living room...
C SEED and Bugatti turn a folding 4K MicroLED television into a 137-inch kinetic sculpture with Tourbillon design and Wisdom Audio.
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Apple TV is adding Dolby Atmos to Formula 1 beginning with the 2026 U.S. Grand Prix, creating a serious 4K Dolby Vision home theater...
Priced from $2,300 to $3,800, Hisense C3 lifestyle 4K projectors offer triple laser imaging, up to 5,000 lumens, Dolby Vision and 240Hz gaming.
