JMGO N3 Ultimate 4K Laser Projector Debuts World’s First 3-in-1 Optical System with Up to 5,800 Lumens
JMGO N3 Ultimate delivers triple laser color, a 3-in-1 optical system, and up to 5,800 ISO lumens for screen sizes from 40 to 300 inches. Is this its best yet?
JMGO N3 Ultimate 4K Lifestyle Projector
Projectors are shrinking, shifting, and finally making some sense for real rooms. The surge in so-called “lifestyle” models isn’t about chasing trends; it’s about fixing long-standing headaches like placement, portability, and footprint without gutting performance. JMGO leaned into that shift in 2024 with its N1S lineup, pairing a compact chassis with a genuinely useful integrated stand that doubles as a carry handle. It’s a practical rethink of the category—one that trades ceiling mounts and guesswork for flexibility you can actually use.
jmgo-n3-ultimate-front
The JMGO N3 Ultimate
For 2026, JMGO is pushing further into that territory with the N3 Ultimate, a 4K projector built around what it claims is the world’s first 3-in-1 integrated optical system and rated up to 5,800 ISO lumens. That’s real brightness and image stability in a form factor that doesn’t demand a dedicated theater or a permanent install. Like its predecessor, it’s designed to move easily between rooms or even outdoors while minimizing the usual headaches around placement, angle, and setup.
JMGO says the N3 Ultimate’s 3-in-1 optical system combines key projection elements into a single integrated architecture, reducing optical path complexity while improving efficiency, alignment, and overall image consistency.
  • Four-way lens shift (Vertical ±130%, Horizontal ±53%)
  • Wide-range optical zoom (0.88–1.7:1)
  • Precision AI-powered gimbal (Vertical 150°, Horizontal 360°)
By integrating these elements into a single system, the JMGO N3 Ultimate adapts to different positions and surfaces with far less effort than traditional designs. What used to involve multiple manual adjustments like angle, focus, and keystone is streamlined into a one click setup process that removes most of the friction from getting a clean, properly aligned image.
jmgo-n3-ultimate-projector-rear
Who Needs Keystone Correction?
In real world use, almost every projector ends up off center. Unlike many models that rely on digital keystone correction to fix placement and screen geometry which can reduce resolution and brightness, the JMGO N3 Ultimate leans into optical adjustment first, preserving more of the original image quality while still accommodating less than perfect placement.
Optical Image Optimization: The features allow images to be aligned instantly while maintaining clarity, detail, and brightness, even from off-center positions.
AI Spatial Image Memory:  This feature remembers your space using AI Spatial Image Memory. This means that the JMGO N3 Ultimate allows users to instantly switch projection between different walls and screens without touching the projector. From the front wall to the ceiling or surrounding walls, the N3 Ultimate stores preferred screen sizes, optimized image settings, and the corresponding app for each scenario.
The Single Click: With a single click, the N3 Ultimate restores the optimal setup and launches the relevant app – making setup and viewing hassle-free.
Great Color, High Brightness, and 4K UHD Resolution
jmgo-triple-laser-engine
To support true spatial freedom across different environments, the N3 Ultimate delivers up to 5,800 ISO lumens, powered by JMGO’s MALC (Microstructure Adaptive Laser Control) 5.0 triple laser system, ensuring bright, vivid visuals even during daytime viewing. Key features of JMGO’s MALC include: Triple Laser, Reduced Speckling, Improved Uniformity, and a Compact Design.
With a color accuracy of ΔE ≈ 0.7 and 110% BT.2020 color gamut coverage, the N3 Ultimate is designed to support the reproduction of native colors, further enhanced by 4K Ultra HD resolution (achieved via pixel shifting), Dolby Vision, and Dolby Audio for an immersive viewing experience.
Great for Movies, Sports, and Gaming
The N3 Ultimate incorporates the MT9679 SoC and 8445 Driver (laser controller), and provides support for  Variable Refresh Rate (VRR), 1ms ultra-low latency, and up to 240Hz refresh rate, delivering smooth, responsive visuals across movies, sports, and gaming, further enhanced by upgraded MEMC motion performance.
Wireless and Wired Connectivity
The JMGO N3 Ultimate includes two-way Bluetooth 5.2 connectivity. You can use the projector as a Bluetooth speaker or connect it to external Bluetooth speakers/headphones. A Bluetooth remote with voice capabilities is also included.
Wi-Fi is provided for easy access to streaming content (such as Licensed Netflix) as well as wired content via HDMI (with eARC) and USB 3.0.
Comparison
jmgo-n3-n1s-ultimate
JMGO Model N3 Ultimate (2026)N1S Ultimate (2024)
Product Type4K UHD Laser Projector4K UHD Laser Projector
MSRP$2,999$2,199
Light Source Tri-Color Laser Tri-Color Laser
Display TechnologyDLPDLP
DMD Size 0.47 0.47
Resolution4K UHD4K UHD
Processing Chip MT9679 MT9629
RAM4GB2GB
ROM64GB32GB
Screen Size40″-300″ (Optimized for 120-150 inch screens, even in moderately lit environments)40″-300″ (Optimized for 60-150 inch screens, even in moderately lit environments)
Throw Ratio Optical Zoom 0.88-1.7: 1 1.2:1
Lens Shift Vertical 130%
Horizontal 53%
Not Supported
Not Supported
Gimbal AI GimbalAI Gimbal
Storage 4+64GB 32 GB
Gaming VRR (Variable Refresh Rate)
Low Latency
Pro Game Mode
Not Supported
Low Latency
Game Mode
HDR Dolby Vision, HDR10 HDR10
Brightness (Lumens)5800 ISO 3300 ISO
Color Gamut 110% BT2020 110% BT2020
Color Accuracy Delta E ≈0.7 Not Indicated
Contrast Ratio (FOFO Contrast) 20,000: 1 1,600:1
Shadow Detail Enhancement SupportedNot Indicated
AI Dynamic Black SupportedNot Indicated
Space-Freedom Solution Optical Image Optimization
AI Spatial Memory
Not Indicated
Not Indicated
Real-Time AI Adjustment Auto-Screen Fitting
Shift-Auto Screen Fitting
Auto Keystone Correction
Auto Focus
Auto Obstacle Avoidance
Auto Eyes Protection
Wall Color Adaptation
Instant Auto Keystone
Instant Auto Focus
Smart Eye Protection
Noise Level<26dB<26dB
OSGoogle TV with Native NetflixGoogle TV with Native Netflix
Connectivity2x HMDI 2.1 ( one supports eARC ), USB 3.02x HMDI 2.1 ( one supports eARC ), 1x USB-A 2.0
Audio Power Output2 x 12.5W (25W)Powerful audio with a 20W subwoofer, 45Hz deep bass.
Audio Format SupportDolby Audio, DTS:X Dolby Digital Plus, DTS-HD Master Audio
Dimensions308.3 x 229.85 x 274.13 mm
12.14 x 9.1 x 10.8 inches
243 x 210 x 238 mm
9.57 x 8.3 x 9.37 inches
Weight6.95 kg / 15.3 lbs4.5 kg / 10 lbs
jmgo-n3-ultimate-connections
The Bottom Line
The JMGO N3 Ultimate builds on the earlier N1S line with a similar lifestyle friendly design but raises the bar with up to 5800 ISO lumens and more refined AI assisted setup tools. The goal is simple: reduce reliance on keystone correction and minimize the need for lens shift by getting the image right through smarter positioning and optical control.
On the audio side, support for Dolby Audio and DTS:X is included, but expectations should be realistic. For a proper home theater experience, you will still want to connect it to an external soundbar or AVR over HDMI eARC. It also supports wireless Bluetooth headphones and can double as a standalone Bluetooth speaker when you are not watching anything, which adds some flexibility beyond movie night.
At $3000, it is not inexpensive for a compact projector, but the combination of high brightness, simplified setup, and portability makes it a viable option for apartment dwellers, flexible living spaces, and even outdoor viewing. Just do not assume it has the category to itself. Brands like XGIMI, Hisense, and Dangbei are all circling the same space with aggressive alternatives that deserve a look before you commit.
Pricing & Availability
Shoppers can save 20% off regular pricing with early-bird savings until May 13, 2026.
Our favorite home theater projectors of 2026 deliver best-in-class performance across UST, lifestyle, and long throw categories.
XGIMI’s new HORIZON 30 projectors combine brighter RGB triple-laser light engines, improved contrast and 4K/120Hz gaming in a flexible lifestyle design.
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Priced from $2,300 to $3,800, Hisense C3 lifestyle 4K projectors offer triple laser imaging, up to 5,000 lumens, Dolby Vision and 240Hz gaming.
Projectors & Screens
Samsung Freestyle+ arrives for $1,200 with 1080p resolution, 430 ISO lumens, AI screen setup, Gaming Hub and Q-Symphony support.
Leica's $2,000 Cine Compact 1 adds RGB laser, 4K pixel shifting, Dolby Vision, smart streaming, and a Summicron lens. Worth the red dot premium?
