McIntosh CS7500 Streaming Preamplifier Brings Analog, Digital and Hi-Res Streaming Together for $12,500
Can McIntosh justify $12,500 for the CS7500? Its new streaming preamplifier combines hi-res streaming, DAC, HDMI ARC and analog control.
McIntosh CS7500 Streaming Preamplifier Front with Remote
At $12,500, the new McIntosh CS7500 Streaming Preamplifier is not McIntosh’s answer to WiiM, Eversolo, NAD, or FiiO. Those companies already offer increasingly sophisticated streaming components for considerably less money, and anyone shopping strictly on features-per-dollar can probably stop reading now.
That is not the customer McIntosh is chasing.
The CS7500 is aimed at listeners building a high-end two-channel system who want streaming, traditional analog and digital sources, and preamplifier control consolidated into a single component without stepping outside the world of luxury audio. Think less about the person debating which affordable streamer offers the best app and more about the buyer considering products from Esoteric, Innuos, or Naim, where system integration, engineering, build quality, dealer support, and brand loyalty carry considerably more weight.
A particularly relevant comparison is the new $13,000 Esoteric N-05XE, which combines a network streamer, DAC, preamplifier, and headphone amplifier in one high-end component. McIntosh is playing in that neighborhood with the CS7500, even if the feature sets and engineering approaches are not identical.
More importantly, the CS7500 gives owners considerable freedom in how they build the rest of the system. Connect its analog outputs to a separate power amplifier and a pair of passive loudspeakers; a McIntosh amplifier driving a pair of Sonus faber loudspeakers is hardly difficult to imagine, or connect it directly to compatible powered or active loudspeakers and eliminate the power amplifier entirely.
What the CS7500 does not do is power passive loudspeakers on its own. It is a streaming preamplifier, not an integrated amplifier.
And that distinction helps explain the $12,500 proposition. McIntosh is not trying to win the streamer price war. It is offering its existing high-end customer a way to make streaming the center of a serious music system without asking them to trade down in the rest of the chain.
mcintosh-cs7500-streaming-preamplifier-displays
Streaming
McIntosh recognizes that streaming has changed not only how people listen to music, but also how they access it. The CS7500 provides built-in support for Qobuz Connect, Spotify Connect (including Spotify Lossless), and TIDAL Connect (including TIDAL Max), allowing listeners to stream directly through the familiar apps they already use while supporting the highest available audio quality from each service.
To access music stored across personal devices, the CS7500 also supports Apple AirPlay, Bluetooth, and Google Cast. For higher-quality wireless playback, Bluetooth supports AAC, Qualcomm aptX HD, and Qualcomm aptX Adaptive. There is no support for LDAC or aptX Lossless which feels like a strange omission at this price point.
The CS7500 is also both Roon Ready and Roon Tested, providing seamless integration with the Roon music platform.
Analog & Digital Inputs / Outputs
mcintosh-cs7500-streaming-preamplifier-rear
While streaming is the main focus of the CS7500, it also provides six analog inputs, including two balanced, three unbalanced, and a dedicated switchable MM/MC phono input.
In addition, the CS7500 also has seven physical digital inputs, including USB, which supports native DSD512 and DXD up to 384kHz, while coaxial and optical inputs support PCM playback up to 24-bit/192kHz.
Another key aspect of the CS7500 is its built-in Quad Balanced, 8-channel, 32-bit digital-to-analog converter (DAC) engineered to deliver wide dynamic range with extremely low distortion, preserving clarity and detail across digital sources.
The CS7500 also extends the listening experience beyond music. An HDMI (ARC) input allows it to connect directly to a compatible TV, bringing higher-quality two-channel sound to movies, television programs, concerts, and other on-screen entertainment.
Pro Tip: Dolby and DTS multi-channel soundtracks are downmixed to two-channel audio for playback through the CS7500.
Audio outputs include two pairs of balanced and unbalanced variable outputs, along with a fixed unbalanced output for connection to a range of power amplifiers. A provided second set of balanced and unbalanced outputs can also be assigned to a single mono or pair of stereo subwoofers for added low-frequency performance.
Classic McIntosh Design, With the Blue Meters Intact
mcintosh-cs7500-streaming-preamplifier-closeup
The CS7500 incorporates McIntosh’s signature black glass front panel, illuminated logo, precision rotary controls, and unmistakable blue meters. A mirror-polished stainless steel lower chassis is paired with a hairline-brushed black titanium stainless steel upper chassis, adding visual depth and contrast.
The result is immediately recognizable as McIntosh — modernized for a streaming-focused component, but still very much rooted in the company’s traditional industrial design.
mcintosh-cs7500-streaming-preamp-front-angle
McIntosh CS7500 Specifications
McIntosh Model CS7500
Product TypeStreaming Preamplifier
MSRP$12,500 USD
Streaming Services Apple AirPlay, Bluetooth, Google Cast, Qobuz Connect, Roon Ready, Roon Tested, Spotify Connect, TIDAL Connect
DAC8-channel, 32‑bit/384kHz PCM/DSD, Quad Balanced
Number of Channels 2
Total Harmonic Distortion 0.005%
Frequency Response: +0, ‑0.5dB from 20Hz to 20kHz
+0, ‑3dB from 15Hz to 100kHz
Maximum Volts Out (Balanced / Unbalanced) 16V RMS/8V RMS
Sensitivity High Level (Balanced / Unbalanced) 900mV / 450mV
Sensitivity (Phono)Moving Coil: 0.45mV
Moving Magnet: 4.5mV
Signal To Noise Ratio (Phono) Moving Coil: 80dB
Moving Magnet: 82dB
Signal To Noise Ratio (High Level): 100dB
Voltage Gain High Level – 15dB
Phono – Selectable 40dB, 46dB, 52dB, 58dB, or 64dB
Input Impedance (Balanced / Unbalanced) 44K ohm, 22K ohm
Balanced Inputs2
Unbalanced Inputs3
Phono Input 1 (configurable as Moving Coil or Moving Magnet)
Digital Inputs 2 x Coaxial
2 x Optical
1 x MCT
1 x USB
1 x HDMI (ARC)
Analog Ouputs2 x Balanced Variable
1 x Unbalanced Fixed
2 x Unbalanced Variable
Unbalanced Analog Connector Type Standard
Headphone Output 1/4” High Drive with Headphone Crossfeed Director (HXD)
Input Level Match Yes, +/‑ 6dB
Home Theater PassThru Yes
Service Port: 1
Network Connections 1
Digital Sample Rates Coaxial Input – 24‑bit/44.1kHz to 192kHz
Optical Input – 24‑bit/44.1kHz to 192kHz
MCT Input – 16‑bit/44.1kHz (CD) DSD64 (SACD)
USB Input – 32‑bit/44.1kHz to 384kHz
(PCM) DSD64, DSD128, DSD256, DXD352.8kHz, DXD384kHz
Network/Wi-Fi Input – 24‑bit/44.1kHz to 192kH
ControlTone Controls: Bass and Treble
Tone Bypass and Input Assign
RS232 Control Input
Power Control Outputs: 1 Main, 2 Trigger
Rear Panel Data Ports: 4
Rear Panel IR Sensor Inputs
Power Consumption (On)30 Watts
Unit Dimensions (WxHxD) 17.5  x 6  x 17 inches
(44.45 x 15.2 x 43.2 cm)
Unit Weight 25 lbs (11.3 kg)
mcintosh-cs7500-streaming-preamp-front-low
The Bottom Line
The McIntosh CS7500 stands out for how much it consolidates without forcing buyers into an all-in-one amplifier. It handles streaming, digital conversion, source switching, volume control, HDMI ARC, and wireless playback, while leaving amplification and loudspeaker choice entirely open.
Its biggest omission is also intentional: there is no built-in power amplifier, so passive speakers require separate amplification. Buyers using active loudspeakers can connect directly.
At this price, the most relevant alternatives come from Esoteric, Linn, and Naim, all of which approach high-end digital playback and system control differently. The CS7500’s appeal is simpler: it gives McIntosh owners a modern digital front end without asking them to abandon the amplifiers, loudspeakers, or system architecture they already prefer.
Price & Availability
The McIntosh CS7500 Streaming Preamplifier is available through authorized McIntosh dealers at a price of $12,500 USD / $17,750 CAD.
Schiit Audio is finally building a music streamer with Forkbeard and 10 years of software support. Hell hasn't frozen over, but CanJam Dallas might...
Jamo's $399 HYG 5 WiFi speaker offers Qobuz Connect, TIDAL Connect, AirPlay 2, Google Cast and three active drivers in a Scandinavian design.
$9,499 for the ultimate Roon music server includes OCXO clocking, DSD512 and up to 8TB storage because apparently ordinary music servers were getting complacent.
Silent Angel’s $849 H1 combines dual ESS DACs, streaming, local storage, high-res playback, and VitOS in one compact digital hub.
Hi-Fi Components
Why has Fidelity Imports UK selected Matrix Audio as its second brand, and what does the digital audio specialist add to its UK launch?
Can IDEON justify $35,000 for the Nous streamer/DAC/preamp when so many capable digital front ends cost far less?
Esoteric’s $28,000 N-01XE inherits the Grandioso N1’s discrete DAC and G4 network engine. Is flagship digital performance getting cheaper?
