In-Ceiling Speakers
Wisdom Audio Debuts 3 Ways To Hide Your Speakers at CEDIA 2026
Wisdom Audio’s ICS3FR in-ceiling speakers, SUB2 in-wall subwoofer and customizable P3m Series speakers enable audiophile sound that stays hidden.
Wisdom Audio Insight Series P3M
Wisdom Audio is coming to CEDIA Expo 2026 with three new products aimed squarely at one of the fastest-growing and increasingly competitive segments of residential AV: high-performance loudspeakers and subwoofers designed to disappear into walls and ceilings or integrate cleanly with a room’s architecture. Custom installation audio has moved well beyond background music, with Monitor Audio, KEF, Sonus faber, Theory Audio Design, DALI, Lyngdorf Audio and other established high-end manufacturers offering increasingly sophisticated architectural speakers for stereo, multi-room audio and immersive home theater systems.
Against that increasingly crowded backdrop, Wisdom Audio will showcase three new CI products at CEDIA 2026: the Sage Series ICS3FR in-ceiling loudspeaker, the SUB2 passive subwoofer, and the Insight P3m series of customizable speakers and soundbars. The objective is not simply to hide the hardware; it is to deliver the kind of performance expected from a high-end music or home theater system while giving integrators considerably more freedom over placement, aesthetics and room design.
Wisdom’s ICS3FR, for example, uses the company’s planar magnetic technology in an architectural design, while the SUB2 was specifically developed to add low-frequency extension while maintaining a minimal visual footprint.
The ISC3FR
wisdom-audio-ics3fr
The ICS3FR is a “full-range” in-ceiling solution designed to provide an architecture-friendly, minimal-appearance installation while delivering high-resolution playback and matching 3-inch to 4-inch recessed round or square lighting fixtures.
The ICS3FR incorporates a Spiral Planar Magnetic Driver designed to provide ultra-wide dispersion, with a 120-degree circular coverage angle (-6 dB), and reproduce frequencies down to 40Hz using its 6.5-inch woofer. Its rated frequency response is 40Hz to 20kHz (+/-3 dB), with an F10 point of 30Hz (-10 dB), where meaningful bass output effectively ends. The ICS3FR requires no additional EQ or PEQ, only a high-pass crossover set between 35Hz and 40Hz.
The ICS3FR ships with everything required for 3-inch round or square and 4-inch round or square installations, as well as hard-surface and gypsum mounting. Custom-colored metal grilles and custom wood grilles are also available separately.
“The ICS3FR was created for projects where exceptional sound quality is essential, but the loudspeaker itself should virtually disappear into the architecture,” said Ron Rouse, Vice President of Sales and Marketing at Wisdom Audio. “At its heart is our Spiral Planar Magnetic Driver, which provides the ICS3FR with best-in-class off-axis dispersion, delivering wide, consistent coverage and exceptional clarity throughout the listening area. Combined with its full-range performance, minimal-appearance design, and flexible grille and mounting options, the ICS3FR gives integrators an ideal solution for projects where outstanding sound and refined aesthetics are equally important.”
Wisdom Audio Model Sage Series ISC3FR
Product TypeFull Range Minimal Appearance Speaker
PriceDealer Consultation
Frequency Response40Hz – 20kHz +/- 3dB
Low Frequency Extension30Hz (-10dB)
Impedance4 ohms
Sensitivity83dB / 2.83V / 1m
Minimum Recommended Power100 Watts
Maximum Recommended Power375 Watts
Coverage Angle (-6dB)120° Circular
Included Gypsum / Plaster GrillesRound 3.04″ [ 7.7cm ]
Square 3.07″ [ 7.8cm ]
Round 3.97″ [ 10cm ]
Square 3.95″ [ 10cm ]
Included Solid Surface GrillesRound 3.26″ [ 8.3cm ]
Square 3.275″ [ 8.3cm ]
Round 3.94″ [ 10cm ]
Recommended High Pass Crossover For Optional Subwoofer80Hz 24dB Linkwitz–Riley
Dimensions L x W18.95″ x 9.375″ [48.1cm x 23.8cm]
Total Product Depth With Grille7.625″ [194mm]
Required Ceiling Installation Depth Behind Finished Surface (Designed for 2×8 Stud Depth)Maximum: 7.15″ [182mm] with 0.5″ [12.5mm] Solid Surface
Minimum: 5.75″ [146mm] with 2″ [50mm] Solid Surface
Typical: 6.875″ [174.63mm] when used with 5/8 [16mm] Drywall
Ceiling Joist Width16″ [383mm] On-Center Nominal
Installation Width Inside Ceiling Support Joists14.5″ [368mm] Nominal – 16″ OC Joist
23″ [584mm] MAX – 24″ OC Joist
9.375″ [238mm] MINIMUM – 12″ OC Joist
Gypsum / Mud-in Finished Surface Thickness1/2″ and 5/8″ [12.5mm and 16mm] standard as shipped
Solid Surface Finished Surface Thickness1/2″ Minimum to 1-7/8″ Maximum [12.5mm – 48mm]
1/8″ [3.25mm] increments
Minimum Grille Distance from Wall4.55″ [116mm] OC to Long Side
6.00″ [152mm] OC to Short Side
Weight17lbs [7.7kg]
Shipping Weight21lbs [9.5kg]
SUB2 Minimal Appearance Subwoofer
wisdom-audio-sub2-side-view
The SUB2 is a passive subwoofer designed to complement the Sage Series ICS3FR minimal-appearance loudspeaker and is available as an optional addition. It provides additional low-frequency support, extending bass response down to 37Hz through a 3-inch opening.
Its compact, minimal-appearance design also makes the SUB2 well suited for in-wall installations and other space-constrained applications where conventional subwoofer placement may not be practical.
wisdom-audio-sub2-tube-ceiling-plate
Wisdom Audio Model SUB 2
Product TypeMinimal Appearance Subwoofer
Frequency Response37Hz – 140 Hz +/- 3dB
Impedance, Planar Section8 ohms
Sensitivity85 dB / 2.83 V / 1m
Recommended Amplifier Power100 Watts
Maximum Amplifier Power300 Watts
Dimensions (HWD) – (Woofer Enclosure)7.9” x 10.5” x 19.25” (20.066cm x 26.67cm x 48.895cm)
Port Tube Length3″ x 24″ (7.62cm x 60.96cm)
Gypsum Finished ThicknessShipped with mud plates for installation in both 1/2″ and 5/8″ (12.5 to 16mm)
Solid Surface Finished ThicknessInstallation (wood, stone, tile, etc.), from 1/2″ to 1-7/8″ (12.5mm – 48mm)
Recommended High Pass Crossover35Hz 24dB Linkwitz-Riley
Recommended Low Pass Crossover80Hz 24dB Linkwitz-Riley
Product Weight25.4 lbs (11.5 kg)
Shipping Weight30 lbs (13.6 kg)
Wisdom Audio Insight P3m Series
Separate from the in-ceiling Sage Series ICS3FR and SUB2, Wisdom Audio is also showcasing its new Insight P3m Series of customizable soundbars and individual loudspeakers at CEDIA 2026.
The Insight P3m Series includes the passive P3m-V vertical mono, P3m-C horizontal mono, P3m-LR stereo, and P3m LCR configurations. Each model can be custom-built in lengths or heights of up to 100 inches (2,540mm), with custom color options also available.
The P3m models use a Spherical Planar Magnetic Driver for high frequencies, extending down to 900Hz, while 4.5-inch woofers handle the lower frequencies.
The P3m Series also incorporates distinctive crescent-shaped woofer apertures that function as acoustic lenses. These help smooth the front baffle to reduce tweeter diffraction while making the two woofers behave as though they are positioned closer together. The result is improved dispersion, reduced interference through the crossover region, and greater low-frequency extension from the woofers.
Behind each aperture sits Wisdom Audio’s patent-pending Dual Helmholtz Resonator, which uses two slightly different tuning points to control unwanted resonances more effectively despite normal manufacturing variations.
These technologies help flatten the woofer response, reduce distortion, improve speaker-to-speaker consistency, and deliver more uniform tonal balance across the listening area.
“With the Insight P3m Series, we set out to create a loudspeaker that delivers the performance people expect from Wisdom Audio while giving integrators far greater design flexibility,” said Ron Rouse, Vice President of Sales and Marketing at Wisdom Audio. “Its customizable dimensions, color options, and multiple configurations allow the P3m to complement virtually any display or interior without compromising sound quality. We believe it is the ideal solution for clients who want exceptional performance in a beautifully integrated, highly versatile loudspeaker.”
Pro Tip: Detailed specifications have not been provided for the Insight P3m Series. The official product links (refer to our availability section) are expected to go live on August 26, 2026, which will include more detailed information and specifications.  Optional TV VESA mounts will be sold separately
The Bottom Line
Wisdom Audio’s new CEDIA 2026 lineup is aimed at integrators and homeowners who want high-performance audio without conventional speakers dominating the room. The ICS3FR and SUB2 stand out for delivering wide-dispersion, low-frequency-capable performance through extremely discreet ceiling openings, while the customizable P3m Series gives installers unusual flexibility in size, orientation, and finish. These are purpose-built CI products for premium stereo and home theater installations where sound quality, architectural integration, and aesthetics carry equal weight.
Price & Availability
The ICS3FR speaker and SUB2 are available through Authorized Dealers – consult dealer for pricing.
The P3m-C, P3m-V,. P3m-LR, and P3m-LCR will be available through authorized dealers beginning August 26, 2026, starts in October 2026.
Linear Tube Audio Aero+ DAC Angle
2026 Adam Audio H715 Reference Open-back Studio Headphones 2026 Adam Audio H715 Reference Open-back Studio Headphones
AT $699, ADAM Audio's flagship H715 Reference headphones, combine Sonnox calibration, balanced Hi-Fi mode, and studio monitoring in one design.
2026 Audio-Technica ATH-AWX7000 Headphones 2026 Audio-Technica ATH-AWX7000 Headphones
Audio-Technica's $3,800 ATH-AWX7000 combines Japanese Cypress wood, luxury craftsmanship, and new 58mm drivers. Can it challenge the best closed-back headphones?
Would you spend $5,000 on a CANVAS HiFi all-in-one soundbar system without hearing it? Playback Distribution is bringing the Danish TV audio system to...
In-Ceiling Speakers
Theory Professional’s p9 Pendant Loudspeaker combines a 9-inch driver, Theorem waveguide, 120-degree dispersion, and 45Hz to 20kHz response.
Hi-Fi Components
Audio Advice acquires Miami's Sound Components, expanding its high-end audio, home theater, and custom-installation footprint into South Florida.
In-Wall Speakers
Hide a subwoofer in your walls or ceiling with JL Audio Pavilion Thin-line 8-inch Subwoofers at $1,000 each.
ASCENDO’s DSP4-6602 amplifier delivers 6,600W RMS, DSP control, and 5Hz output for custom home theaters using passive subwoofers.
miniDSP Tide16 adds Dirac Live ART, 16 channel processing, and advanced room correction. Is this the smarter AV processor play?
