In-Wall Speakers
JL Audio Pavilion Thin-line Subwoofers Bring Big Bass to Walls and Ceilings Without the Big Box
Hide a subwoofer in your walls or ceiling with JL Audio Pavilion Thin-line 8-inch Subwoofers at $1,000 each.
JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed
Garmin is expanding JL Audio’s custom-install speaker lineup with the new Pavilion Thin-line Subwoofers, a compact in-wall and in-ceiling series designed to deliver stronger bass without eating up floor space. Built around 8-inch drivers and promoted under the slogan “Powerful bass in any space,” the new models are aimed at homeowners, integrators, and outdoor entertainment spaces where traditional subwoofers are either too bulky, too visible, or just plain awkward.
The pitch is simple: high-performance JL Audio bass, a slimmer form factor, and flexible installation for indoor and outdoor systems where clean design matters almost as much as impact.
Slimmer Design, Lower Distortion, Bigger Installation Flexibility
JL Audio’s Pavilion Thin-line Subwoofers use the company’s DMA-optimized motor and suspension design to support long, linear excursion with lower distortion. The goal is tighter, cleaner bass from a compact driver platform that can still deliver meaningful output in space-constrained installations.
The design also incorporates JL Audio’s Concentric Tube Suspension technology, which helps reduce mounting depth without giving up the control and excursion needed for high-performance bass. That matters for in-wall and in-ceiling applications, where available space is often limited and traditional subwoofer enclosures are not always practical.
jl-audio-thin-line-subwoofers-round-square
Easy Installation
The JL Audio Pavilion Thin-line Subwoofers are optimized for in-wall or in-ceiling installation, featuring a shallow 3.8-inch mounting depth and infinite baffle construction that allows for seamless placement without requiring a dedicated enclosure.
A dog-leg mounting system provides users with the flexibility to install the subwoofers in a variety of materials and locations, indoors or outdoors, without needing a backplate.
Pavilion speakers are built to last and deliver strong sound by using marine-grade materials specifically constructed to withstand harsh environments. They meet or exceed ASTM standards for salt-fog and UV exposure, giving listeners added peace of mind when installing them outdoors.
External Design Features
Homeowners can choose from several design options. The flush-mount speaker grille is available in square or round shapes, with white or black finishes that can also be painted to better match a home’s décor.
The ultra-thin, fine-mesh grille attaches magnetically and matches the look of JL Audio’s Pavilion outdoor in-ceiling speakers. New construction brackets are also available to help prepare mounting locations during the framing and drywall stages of a new home build or renovation.
Engineered for practical use indoors or outdoors, the subwoofers carry an IPX5 rating for protection against water exposure, adding another layer of durability for covered outdoor installations.
Specifications
JL Audio ModelPavilion
Product TypeThin Line Subwoofer
Price (each)$1,000
Sizes8″ (Round)
8″ (Square)
ColorSatin Black or Satin White
Physical dimensions (Diameter)10″ (254 mm)
Physical dimensions (Depth)8″ (Round): 4.2″ (107 mm)
8″ (Square): 4.1″ (105 mm)
Weight7.5 lbs (3.4 kg)
Water and Dust RatingIPX5
Speaker TypeInfinite Baffle
Continuous Power Handling (RMS)250 W
Sensitivity (SPL @ 1 W/1 m)83.2 dB
Nominal Impedance8 Ω
Recommended Amplifier Power (RMS)50-250 W
Cone MaterialInjection-molded, mica-filled polypropylene
Electrical FeaturesCompass-safe distance 93″ (235 cm)
Speaker ConnectionsSpade Connectors
Mounting Panel ThicknessMinimum: 0.25″ (6 mm)
Maximum: 1.625″ (41 mm)
Mounting Depth Clearance3.8″ (97 mm)
Frontal Grille Protrusion8″ (Round): 0.4″ (10 mm)
8″ (Square): 0.34″ (9 mm)
Mounting Hole8.96″ (229 mm)
Driver Displacement0.054 cu ft (1.53 L)
Free Air Resonance (FS)37.98 Hz
Electrical “Q” (Qes)0.731
Mechanical “Q” (Qms)9.471
Total “Q” (Qts)0.679
Equivalent Compliance (Vas)0.61 cu ft (17.31 L)
One-way Linear Excursion One-way linear excursion (Xmax; specs are derived via one-way voice coil overhang method with no correction factors applied) 0.40″ (10 mm)
Effective piston area (SD)32.705 in² (0.0211 m²)
DC resistance (RE)7.24 Ω
Sealed Enclosure Specifications (if a sealed enclosure is used)Volume (net int.) 2.00 cu ft (56.6 L)
-3 dB cutoff frequency (F3)40.9 Hz
System resonance (FC)53.66 Hz
System Q at resonance (QTC)0.784
Ported Enclosure Specifications (if a ported enclosure is used)Volume (net int.) 1.5 cu ft (42.5 L)
Internal port diameter (ID) 4″ (102 mm)
Port length (L) 13.5″ (343 mm)
Tuning frequency (FB) 37 Hz
-3 dB cutoff frequency (F3) 29.6 H
The Bottom Line
JL Audio’s Pavilion Thin-line Subwoofers are built for homeowners and custom installers who want real bass without giving up floor space or visual cleanliness. The shallow 3.8-inch mounting depth, infinite baffle design, marine-grade construction, IPX5 rating, and paintable magnetic grilles make them more flexible than a conventional subwoofer, especially for whole-home audio, home theater, and covered outdoor spaces. Just don’t treat placement like hanging a picture frame. Once you start cutting into walls or ceilings, “oops” gets expensive fast.
Price & Availability
JL Audio Pavilion thin-line subwoofers are available in square and round form factors in the choice of black and white finish options, priced at $1,000 each at JL Audio.
In-Wall Speakers
Can Monitor Audio hide serious home theater bass? Creator Series in-wall subs use 10- and 12-inch drivers with DSP amplification up to 750 watts.
In-Ceiling Speakers
Wisdom Audio's ICS3FR in-ceiling speakers, SUB2 in-wall subwoofer and customizable P3m Series speakers enable audiophile sound that stays hidden.
Editors’ Choice 2025: The best in-wall and in-ceiling speakers for home theater and whole-home audio—reference-level performance, properly installed.
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
At $43,600, Grimani Systems' Psi v3 is four subwoofer system that goes in each corner of a home theater for generating up to 115...
In-Wall Speakers
Enjoy low bass performance down to 30Hz from subwoofers hidden in your wall that are only 4-inches deep.
The iws12-6 and iws12-9 are extremely flexible architectural subwoofers ideal for any residential and commercial installations where deep, tight, bass is desired.
