REL Planar On-Wall Subwoofers Could Change Where Bass Lives in Your Room
Can REL’s on-wall Planar PL-1 and PL-2 subwoofers deliver serious bass without putting a big box on the floor?
REL Acoustics Planar PL-2 On-Wall Subwoofer White Lifestyle
REL Acoustics is taking aim at one of the biggest reasons people avoid subwoofers: placement. The new Planar Series moves the sub off the floor and onto the wall with two thin models, the PL-1 and PL-2, each measuring just 5.7 inches deep and using a mix of active and passive drivers to generate low-frequency output without the usual big black cube parked in the corner like it pays rent. The larger PL-2 uses an 8-inch active woofer with a 10-inch passive radiator, while the smaller PL-1 uses dual 6.5-inch active drivers with the same 10-inch rear passive radiator.
That makes the concept especially interesting for hi-fi and home theater users who want bass support without sacrificing floor space or triggering a domestic zoning dispute. But the idea also raises real questions about installation, wall vibration, apartment and rental use, and whether on-wall bass can deliver the impact and integration REL is known for.
rel-planar-subwoofers-grille-on-off
REL Planar PL-2 (left) with grille and PL-1 (right) without grille
Both units weigh under 50 pounds, making DIY wall mounting a realistic option for users who are comfortable with the installation. REL also offers an optional cart wheel, allowing the Planar models to be moved more easily before final placement or mounting.
Update: In our conversation with a REL representative, we have confirmed a few things. Both REL Planar subwoofers include built-in wireless connectivity and come with an AirShip Direct transmitter module ($399 value). The wireless receiving module is cleverly concealed in the side panel, and swappable should technology change.
A wall-mount is included with purchase, but the cart/wheel/stand will cost extra (price TBD). Wall-mounting is the preferred implementation because it sets the desired wall gap to maximize performance. Alternatively, cart setups for floor placement solve two issues: wall spacing and stability. An included spacer ensures ideal proximity to back wall, while the cart/stand raises the unit off the floor for improved fidelity.
How low can they go? Because the PL-1 and PL-2 are designed for proximity-to-wall or on-wall placement, REL uses that boundary reinforcement to its advantage. The PL-2 is rated down to 24Hz, while the PL-1 reaches 31Hz, both measured at -6dB. That gives the larger model a clear advantage for deeper bass extension, while the smaller model is aimed more at systems where space, placement flexibility, and visual discretion matter just as much as output.
REL Planar Subwoofer Comparison
PL-2PL-1
Active Drivers1 x 8-inch (205mm),
FlatPiston active long-throw, steel chassis
2 x 6.5-inch (165mm),
FibreAlloy cone, long-throw, steel chassis
Passive Driver1 x 10-inch (250mm),
FibreAlloy cone, steel chassis
1 x 10 inch (250mm),
Low Frequency Extension*-6 dB at 24 Hz, in room-6 dB at 31 Hz, in room
Dimensions (W x H x D)25.6 x 18.9 x 5.7 in.
(650 x 480 x 144mm)
20.6 x 19.4 x 5.7 in.
(522 x 492 x 144mm)
Net Weight44.6 lbs (20.25 kg)41.6 lbs (18.9 kg)
*Correction (May 6, 2026): A previous version of the article stated Low Frequency Extension was higher at 27 Hz (PL-2) and 38 Hz (PL-1). The corrected numbers are now listed above.
rel-planar-subwoofers-black-white-2026
REL Planar PL-1 (front row) and PL-2 (back row)
rel-planar-pl-2-on-wall-white-cloth-grille-lifestyle
REL Planar PL-2 with white cloth grille
The Bottom Line
REL’s Planar PL-1 and PL-2 are not just “thin subwoofers.” They rethink where a subwoofer can live in a hi-fi or home theater system. With walnut or white grille options, a 5.7-inch-deep cabinet, on-wall placement, active/passive driver designs, and claimed extension down to 24 Hz or 31 Hz depending on model, the Planar Series is clearly aimed at listeners who want real bass support without a large box taking over the room like it won the lease in court.
What we don’t know yet matters: pricing and how they perform in real rooms. Although they can be connected wirelessly, they are not completely cable-free solutions because its power cable still requires a nearby outlet. Custom integrators, however, should have a field day with these. For homeowners building cleaner media rooms, living rooms, or lifestyle-friendly hi-fi systems, REL may have found a smarter way to hide the subwoofer in plain sight.
rel-pl1-pl2-front-back-black-white
REL Planar PL-1 (back in black, front in white)
Price & Availability
REL Acoustics’ all-new Planar PL-1 and PL-2 subwoofers will be available May 20, 2026. However, pricing has yet to be announced. We’ll update this story as soon as it’s released.
For more information: rel.net
Developers have found a way to restore Dolby Atmos height effects from Blu-ray soundtracks on Apple TV 4K. It's an impressive technical achievement, but...
Berliner Philharmoniker now streams live concerts in Dolby Atmos with 4K video, an extensive archive and no extra fee for subscribers.
Apple may unveil a new Apple TV 4K, HomePod mini and smart home hub on October 13, potentially creating its most complete living room...
C SEED and Bugatti turn a folding 4K MicroLED television into a 137-inch kinetic sculpture with Tourbillon design and Wisdom Audio.
Apple TV is adding Dolby Atmos to Formula 1 beginning with the 2026 U.S. Grand Prix, creating a serious 4K Dolby Vision home theater...
