A/V Furniture & Accessories
SVS SoundPath Multi-Band Wireless Audio Adapter Could Make Long Audio Cables Disappear
The $229.99 SVS SoundPath Multi-Band adapter kit claims to transmit 24-bit stereo up to 165 feet with only 15 milliseconds of latency.
2026 SVS SoundPath Multi-Path Wireless Audio Adapters
Subwoofer placement can make or break the low-frequency performance of a home theater system, but the location that measures best is not always conveniently located within a few feet of an AV receiver.
Running a long RCA cable through a finished wall is one solution. Running it across the floor and pretending nobody will trip over it is another.
SVS has a better idea.
The new SVS SoundPath Multi-Band Wireless Audio Adapter can transmit a full-range stereo signal at 24-bit/48kHz up to 165 feet (50 meters) line-of-sight, while automatically switching across 46 wireless channels between the 5.2 GHz and 5.8 GHz bands to maintain a stable connection in crowded RF environments.
SVS is exhibiting at CEDIA Expo 2026, where that 165-foot range should be sufficient to put your subwoofer several booths away and still annoy the installer next door.
The SoundPath Multi-Band Wireless Audio Adapter is available now for $229.99 and includes one transmitter and one receiver.
It Does More Than Make a Subwoofer Wireless
svs-soundpath-multi-band-pair
Wireless subwoofer adapters are hardly new, and SVS already offers other SoundPath models. The interesting part of the new Multi-Band adapter is that it is not restricted to an LFE signal.
It supports a left/right stereo signal with a rated frequency response of 3Hz to 20kHz ±0.5 dB, which means it can also be used with powered speakers, power amplifiers and other compatible line-level audio equipment.
That flexibility requires an important explanation.
The SoundPath Multi-Band Wireless Audio Adapter does not turn every SVS loudspeaker into a completely wireless speaker. The transmitter accepts a line-level analog signal through RCA inputs, that signal is transmitted wirelessly at 24-bit/48kHz, and the receiver provides line-level RCA outputs at the other end.
A powered subwoofer or powered loudspeaker with compatible RCA inputs can therefore connect directly to the SoundPath receiver.
A passive loudspeaker cannot.
Conventional passive SVS speakers, including Prime and Ultra Evolution models, still require amplification. In that application, the SoundPath receiver connects to a power amplifier positioned near the speakers, and conventional speaker cable runs from that amplifier to the passive loudspeakers.
The same principle applies to passive surround speakers. The adapter can eliminate the long line-level connection between the processor and a remotely located amplifier, but it does not eliminate the amplifier, AC power at the receiving location, or the short speaker cables running from that amplifier to the speakers.
SVS’s own manual illustrates exactly this type of installation, with the SoundPath receiver feeding the line-level inputs of a power amplifier that then drives conventional loudspeakers.
What About SVS Prime Wireless Pro Speakers?
SVS Prime Wireless Pro Powered Speakers Black Lifestyle
SVS Prime Wireless Pro Powered Speakers (Black)
The SVS Prime Wireless Pro Powered Speaker Pair can also accept an incoming SoundPath signal because the active speaker includes left/right RCA line-level inputs.
There is still a cable involved, however.
Prime Wireless Pro uses one active speaker and one passive companion speaker. The passive speaker remains connected to the active speaker using the supplied interconnect cable, so SoundPath does not make the two speakers independently wireless.
That distinction is worth making because “wireless speaker” has become one of the more elastic phrases in consumer audio.
Why the Multi-Band Approach Matters
Most homes now contain routers, mesh Wi-Fi systems, televisions, security cameras, Bluetooth products and enough connected appliances to make your refrigerator an unwilling member of the IT department.
SVS is trying to make the wireless link more reliable by avoiding the heavily populated 2.4 GHz band and operating instead across 5.2 GHz and 5.8 GHz. The system automatically switches across 46 available channels to maintain the most stable connection.
SVS describes the adapter as highly resistant to interference from Wi-Fi routers, security cameras, smart TVs and other wireless devices.
That is a more defensible description than calling any wireless product “impervious” to interference. SVS’s own manual still recommends maintaining line-of-sight where possible and keeping the transmitter away from potential RF interference sources. Walls, distance and the surrounding wireless environment can still affect performance.
The quoted 165-foot range is also specifically a line-of-sight measurement, not a promise that the signal will travel through 165 feet of walls, concrete and kitchen appliances.
What About Latency?
SVS rates the SoundPath Multi-Band Wireless Audio Adapter at less than 15 milliseconds of latency, an improvement over the previous SoundPath Tri-Band Wireless Audio Adapter, which is rated at less than 19 milliseconds.
That delay is low enough for home theater and stereo applications, but it is not literally instantaneous. SVS notes that an AV processor may compensate for the wireless delay by displaying a subwoofer distance approximately 14 to 20 feet greater than its actual physical distance. That is normal and reflects the processor accounting for the additional signal delay introduced by the wireless connection.
For systems using automated room correction or distance compensation, the processor should handle that adjustment during setup.
How Does It Compare With the Previous SVS Tri-Band Adapter?
The new Multi-Band model is not simply the Tri-Band adapter with another sticker on the box.
The $199.99 SoundPath Tri-Band Wireless Audio Adapter transmits 16-bit/48kHz audio up to 130 feet line-of-sight, operates across 2.4 GHz, 5.2 GHz and 5.8 GHz, and is rated for latency below 19 milliseconds. It can also pair one transmitter with as many as six receivers.
The new $229.99 Multi-Band adapter increases rated range to 165 feet, moves to 24-bit/48kHz transmission, extends its specified low-frequency response from 6Hz to 3Hz and reduces rated latency to below 15 milliseconds.
It also drops the 2.4 GHz band and lowers the maximum number of paired receivers from six to four.
So this is not a case where every number became larger because a new model arrived. The emphasis has shifted toward longer range, higher bit depth and operation exclusively within the 5 GHz spectrum.
Up to four receivers can be paired with one transmitter, allowing the same source signal to be sent to multiple compatible subwoofers, powered speakers or amplifier locations. Those are not four independently controlled audio zones; they receive the same transmitted source.
svs-soundpath-multiband-visual
Setup
The transmitter and receiver arrive paired from the factory.
For a subwoofer installation, the transmitter connects to the appropriate line-level or LFE output on an AV receiver, preamplifier or processor, while the receiver connects to the powered subwoofer’s RCA input.
For stereo applications, left/right RCA connections can be used between a compatible source and the transmitter and between the receiver and a powered speaker or amplifier.
Both units require power and can be powered from compatible USB sources or the included power adapters. SVS also provides two mono RCA cables, two USB power cables and two USB power adapters in the box.
There is no app or home-network configuration involved. Once powered, the pre-paired transmitter and receiver establish their direct wireless connection automatically.
Who Else Offers Something Similar?
SVS is not alone in wireless audio adapters, although finding another product that duplicates the entire feature set of the SoundPath Multi-Band Wireless Audio Adapter is more difficult.
RSL Speakers offers a Wireless Audio Connection Kit ($100) that can transmit low-level RCA signals over a low-latency 2.4GHz band up to 50 feet. One transmitter can simultaneously connect to up to 4 receivers, which run an extra $50 each.
The Dynasty ProAudio WSA-5TR-V2 ($97.99 at Amazon) operates across the 5.2 GHz and 5.8 GHz bands, automatically selects among 106 RF channels, supports 24-bit/48kHz uncompressed stereo audio, and has a rated operating range of 100 feet line-of-sight or 50 feet through walls, ceilings, and floors, with actual performance dependent on the environment.
REL Acoustics offers several wireless alternatives primarily designed for their own line of subwoofers. The REL HT-Air MKII ($149 at Crutchfield) operates over 5.8 GHz, supporting stereo RCA low-level input with up to a 40 foot range and latency of 17 milliseconds. Additional wireless solutions from REL include the REL AirShip Direct ($399 at Best Buy) and REL Arrow Wireless ($249 at Crutchfield), which are each are compatible with specific REL subs.
svs-soundpath-multi-band-pair-contents
The Bottom Line
The competition makes it clear that 5 GHz wireless audio, automatic channel selection, 24-bit/48kHz transmission, and wireless subwoofer connectivity are not individually unique to SVS.
What stands out is the combination.
For $229.99, the SoundPath Multi-Band Wireless Audio Adapter combines 24-bit/48kHz full-range stereo transmission, a 3Hz to 20kHz rated frequency response, automatic switching across 46 channels in the 5.2 GHz and 5.8 GHz bands, a claimed 165-foot line-of-sight operating range, and support for as many as four receivers from one transmitter. It can be used with powered subwoofers, powered loudspeakers, power amplifiers, and other compatible line-level components rather than being restricted to one type of speaker or one manufacturer’s ecosystem.
That is the argument for the SoundPath Multi-Band Wireless Audio Adapter. It is not reinventing wireless audio. It is trying to make one adapter useful in a much wider range of installations.
Price & Availability
The SVS SoundPath Multi-Band Wireless Audio Adapter is available now for $229.99 and includes one transmitter and one receiver.
Up to four receivers can be paired with a single transmitter.
2026 CMF Speaker S and M by Nothing
CMF’s first Bluetooth speakers combine Nothing-style design with Auracast, USB-C audio, IP68 protection and prices starting at just $59.
2026 Horizon 30 Pro Lifestyle Projector in living room 2026 Horizon 30 Pro Lifestyle Projector in living room
XGIMI’s new HORIZON 30 projectors combine brighter RGB triple-laser light engines, improved contrast and 4K/120Hz gaming in a flexible lifestyle design.
2026 Fosi Audio DAP Neo in pocket 2026 Fosi Audio DAP Neo in pocket
DAPs
The $80 Fosi Audio DAP Neo delivers iPod nostalgia, lossless playback, Bluetooth and expandable storage. Can it win over the streaming generation?
2026 JMGO Iris Ultra Projectors 2026 JMGO Iris Ultra Projectors
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Silkland H96 HDMI 2.2. Cables Silkland H96 HDMI 2.2. Cables
Apple may unveil a new Apple TV 4K, HomePod mini and smart home hub on October 13, potentially creating its most complete living room...
Apple TV is adding Dolby Atmos to Formula 1 beginning with the 2026 U.S. Grand Prix, creating a serious 4K Dolby Vision home theater...
Edifier’s affordable studio monitors combine balanced tuning, useful connectivity, app control, and impressive bass for their size.
Priced from $2,300 to $3,800, Hisense C3 lifestyle 4K projectors offer triple laser imaging, up to 5,000 lumens, Dolby Vision and 240Hz gaming.
The 2026 CEDIA Expo was held last week in Denver and eCoustics was there in force to check out the latest in home theater...
