Wharfedale Nova Subwoofers Go From 8 to 15 Inches and You Can Have Any Color You Want as Long as It’s Black
Wharfedale’s Nova subs pack DSP, passive radiators, high-level inputs and 8- to 15-inch drivers into a serious fight with SVS and REL.
2026 Wharfedale NOVA Subwoofers Front Black
Wharfedale has spent much of 2026 demonstrating that it has no intention of living entirely on the considerable success of the Linton, Denton and the rest of its Heritage Series.
We have already covered the Denton 1S, Heritage Centre, and substantially more ambitious Elysian R Series. Our recent Super Denton review also reinforced why Wharfedale remains one of our safer loudspeaker recommendations below $1,500.
The latest expansion heads south. Very south.
The new Wharfedale Nova Series consists of four active subwoofers ranging from the Nova 8 to the imposing Nova 15. They are intended for both two-channel systems and home theater, with Wharfedale focusing on extension, output and system integration rather than simply building four increasingly large boxes designed to rearrange the contents of your kitchen cabinets.
Four Sizes, One Common Architecture
All four Nova models use newly developed long-throw active drivers with coated paper cones, die-cast chassis, oversized surrounds and high-excursion motor systems. An aluminum shorting ring is incorporated into the motor structure to improve linearity and reduce distortion as excursion increases.
Rather than using conventional bass-reflex ports, Wharfedale pairs each active woofer with a downward-firing, mass-loaded Auxiliary Bass Radiator (ABR). The passive radiator is intended to extend low-frequency output without introducing the turbulence and port noise that can affect reflex designs at higher playback levels.
The Nova 8 is the unusual member of the family because its 8-inch active driver is partnered with a larger 10-inch passive radiator. The Nova 10, Nova 12 and Nova 15 use passive radiators matching the diameter of their respective active woofers.
DSP Without Turning Your Subwoofer Into Another Computer
Each Nova combines its driver, cabinet loading, Class D amplifier and DSP as part of a single system. Wharfedale’s Dynamic EQ adjusts low-frequency behavior according to playback level, preserving more bass extension at lower volumes while controlling driver excursion as output increases.
Wharfedale also provides dedicated Music and Movie DSP modes, along with adjustable crossover, phase and output level controls. What you will not find is app-based setup or automated room correction, so some actual human involvement remains required.
All four models provide stereo RCA inputs, with the right channel supporting LFE, plus speaker-level inputs using binding posts. Stereo RCA outputs, a 12V trigger and USB connectivity for firmware updates are also standard across the range.
Those speaker-level inputs are particularly useful for two-channel systems built around integrated amplifiers without dedicated subwoofer outputs. Owners of Wharfedale Heritage speakers can therefore add one without replacing amplification that is already working perfectly well.
Wharfedale Nova 8
The Nova 8 is the most compact model and the logical starting point for smaller rooms or stereo systems where floor space is limited. Its most interesting engineering detail is the larger 10-inch passive radiator working beneath the 8-inch active woofer.
wharfedale-nova-8-subwoofer-lifestyle
Nova 8 Specifications
  • Active Driver: 8-inch coated paper cone
  • Passive Radiator: 10-inch downward-firing coated paper cone
  • Low-Frequency Extension: 33Hz (-6dB)
  • Amplification: 200 watts nominal / 500 watts peak
  • Crossover Range: 40Hz to 160Hz
  • Inputs: Stereo RCA with LFE support; speaker-level binding posts
  • Outputs: Stereo RCA
  • Other Connections: 12V trigger; USB for firmware updates
  • Dimensions (H x W x D): 13.7 x 12.6 x 14.2 inches
  • Weight: 35.9 pounds
  • Finish: Matte Black
  • U.S. Price: $1,099
Wharfedale currently positions the Nova 8 as the model for compact systems and smaller rooms, although $1,099 makes it very clear that this is not the company’s entry-level subwoofer.
Wharfedale Nova 10
The Nova 10 moves to a matching 10-inch active woofer and 10-inch passive radiator while increasing amplifier output and extending bass response to a claimed 29Hz at -6dB. The cabinet also grows substantially, but it remains a manageable option for medium-sized rooms.
wharfedale-nova-10-subwoofer-lifestyle
Nova 10 Specifications
  • Active Driver: 10-inch coated paper cone
  • Low-Frequency Extension: 29Hz (-6dB)
  • Amplification: 230 watts nominal / 500 watts peak
  • Dimensions (H x W x D): 15.4 x 14.3 x 16.1 inches
  • Weight: 48.9 pounds
  • U.S. Price: $1,299
The Nova 10 might prove to be the most broadly useful model in the lineup. It digs lower than the Nova 8 without making the significant jump in size and weight required by the two larger models.
Wharfedale Nova 12
The Nova 12 is where things begin getting considerably more serious. A 12-inch active woofer and matching passive radiator are backed by 280 watts of nominal power and 770 watts peak, while the cabinet tips the scales at almost 65 pounds.
wharfedale-nova-12-subwoofer-lifestyle
Nova 12 Specifications
  • Active Driver: 12-inch coated paper cone
  • Passive Radiator: 12-inch downward-firing coated paper cone
  • Low-Frequency Extension: 28Hz (-6dB)
  • Amplification: 280 watts nominal / 770 watts peak
  • Dimensions (H x W x D): 17.4 x 17.1 x 19.2 inches
  • Weight: 64.6 pounds
  • U.S. Price: $1,599
Interestingly, the claimed low-frequency extension only improves by 1Hz compared with the Nova 10. The reason to move up is therefore more likely to be output capability and room-filling scale than chasing a dramatically lower frequency number.
Wharfedale Nova 15
And then there is the Nova 15.
The flagship uses a 15-inch active woofer and equally large downward-firing passive radiator inside a cabinet weighing 105.4 pounds. At more than 21 inches in both height and width, nobody is hiding this behind a ficus.
wharfedale-nova-15-subwoofer-lifestyle
Nova 15 Specifications
  • Active Driver: 15-inch coated paper cone
  • Passive Radiator: 15-inch downward-firing coated paper cone
  • Amplification: 360 watts nominal / 770 watts peak
  • Dimensions (H x W x D): 21.6 x 21.3 x 23.9 inches
  • Weight: 105.4 pounds
  • U.S. Price: $1,999
The Nova 15 shares the Nova 12’s claimed 28Hz (-6dB) extension, so the larger driver and cabinet are again about greater displacement and potential output rather than winning a specification-sheet contest over the lowest printed frequency.
Calling it compact would require an extremely forgiving editor.
Any Color You Want
Wharfedale has become rather adventurous with finishes elsewhere in its lineup. The Denton 1S comes in matte black, white and blue, while Elysian R buyers can choose walnut high gloss, matte black or lunar grey.
Nova buyers face a somewhat shorter decision tree.
Matte Black.
That is currently the entire selection across all four models. It makes practical sense for a subwoofer designed to disappear visually into a room, although anyone hoping to perfectly match a walnut Linton or mahogany Super Denton will have to embrace the concept of contrast.
Henry Ford would presumably approve.
wharfedale-nova-subwoofer-series-dimensions
The Bottom Line
Wharfedale is entering a brutally competitive part of the subwoofer market with the Nova Series. Once the price crosses $1,000, buyers are no longer choosing between a decent subwoofer and a better one. They are choosing between established specialists offering very different approaches to low-frequency reproduction.
We have covered that market extensively, and the competition gets serious almost immediately. The $1,299 SVS SB-3000 R|Evolution uses a 13-inch driver, 1,200-watt RMS amplifier, extensive DSP and app control, with claimed extension to 17Hz ±3dB. Move up to the $1,799 PB-3000 R|Evolution and SVS adds a ported enclosure with claimed extension to 16Hz ±3dB. Those numbers make the Nova 10, 12 and 15 specifications look relatively conservative on paper, although frequency-extension figures alone tell us very little about how well a subwoofer actually integrates with a system or room.
REL presents a different challenge. The $1,299 T/7x and $1,699 T/9x are aimed heavily at two-channel listeners and, like the Nova models, provide high-level connectivity. The T/9x also combines a 10-inch active driver with a downward-firing 10-inch passive radiator, so Wharfedale is hardly alone in pursuing that particular approach. REL also offers black, white and grey finishes on the T/9x, which seems almost recklessly extravagant compared with Nova’s one-color democracy.
The MartinLogan Dynamo 10 creates another problem for the $1,099 Nova 8 and $1,299 Nova 10. At $1,199.99, it includes a 10-inch driver, app-based setup, built-in wireless connectivity and compatibility with Anthem Room Correction. Wharfedale’s more conventional controls will appeal to listeners who do not want another app in their lives, but buyers who value automated room integration are getting considerably more setup technology from MartinLogan at essentially the same price.
And then there is RSL. We have been recommending the Speedwoofer 12S for years, and its current $885 price makes the comparison rather uncomfortable. Its 12-inch driver, 500-watt RMS amplifier and claimed 16Hz ±3dB extension come in well below the price of even the smallest Nova. Our own testing found the Speedwoofer 12S capable of competing with considerably more expensive products, which means Wharfedale cannot rely on value alone to make its case.
KEF also occupies this territory with its Kube MIE range. The Kube 12 MIE is currently $1,099.99, exactly where the Nova 8 begins, while the 15-inch Kube 15 MIE sells for $1,499.99. KEF offers sealed enclosures, placement-dependent DSP and multiple finish options, making it another established alternative for buyers who want something easier to integrate visually and physically.
That does not leave the Wharfedale Nova Series without an argument. The combination of passive-radiator loading, Dynamic EQ, Music and Movie modes, speaker-level inputs and four cabinet sizes makes these more flexible than a basic LFE box. They should also attract existing Wharfedale owners who want a subwoofer designed within the same engineering ecosystem as their loudspeakers.
But familiarity with the badge is not enough at these prices.
The Nova 8 has to compete with MartinLogan and KEF at roughly the same money. The Nova 10 runs directly into the SVS SB-3000 R|Evolution and REL T/7x. The $1,599 Nova 12 sits perilously close to the REL T/9x and SVS PB-3000 R|Evolution, while the $1,999 Nova 15 costs exactly the same as the formidable SVS SB-5000 R|Evolution, which uses a 15-inch driver, 2,000 watts RMS of amplification and is rated to 17Hz ±3dB.
That is a very tough neighborhood.
Wharfedale therefore has to prove that Nova’s real advantage is not a bigger driver, a lower number on the frequency-response chart, or another DSP mode. It has to be how convincingly these subwoofers disappear into a two-channel system while still having enough output for home theater — something the company’s loudspeaker customers will understandably care about more than winning an arms race on a specification sheet.
We will know that only after listening to them.
Until then, Wharfedale has produced an interesting series of subwoofers and dropped them into a market where nobody gets a free pass.
Not even if the subwoofer matches your speakers.
Assuming your speakers are black.
For more information: wharfedaleusa.com
The best bookshelf speakers of 2026, tested by eCoustics. Our Editors’ Choice picks include DALI, Q Acoustics, Wharfedale, Revel, Paradigm, and ATC.
From Q Acoustics and Wharfedale to DALI, Vera-Fi, and ATC, these bookshelf speakers prove design and voicing matter. Five radically different paths to great...
Can serious home theater disappear into the room? Sonance pairs an 82.7-inch soundbar with redesigned PowerPipe X hidden subwoofers.
Can DALI’s $800 BASIK SUB bring better bass to compact hi-fi systems without dominating the room?
A/V Furniture & Accessories
The $229.99 SVS SoundPath Multi-Band adapter kit claims to transmit 24-bit stereo up to 165 feet with only 15 milliseconds of latency.
