Wharfedale Elysian R Series Debuts: Flagship Speakers Get AMT Upgrades, New Finishes, and Deeper Bass
Wharfedale Elysian R Series debuts with upgraded AMT tweeters, revised drivers, SLPP bass loading, and flagship performance from $5,995.
Wharfedale Elysian R Series Loudspeakers in Grey
Wharfedale’s Heritage Series tends to get the loudest applause, and that is hardly surprising. Few loudspeaker brands play the vintage card with as much credibility, and commercial success. The Denton, Super Linton, Super Denton, Denton 1S, and Dovedale have helped make old-school British loudspeaker design feel relevant again rather than merely nostalgic.
But Wharfedale’s most technically ambitious loudspeakers do not live in the Heritage Series. That role belongs to Elysian, and the new Wharfedale Elysian R Series is now positioned at the top of the food chain in terms of technology, design execution, and claimed sonic performance.
wharfedale-elysian-4r-cr-home-theater-lifestyle-grey
Wharfedale Elysian 4R Floorstanding Loudspeakers with CR Center Speaker in Grey.
The Elysian R Series is not a ground-up replacement for the original Elysian lineup. Wharfedale describes it more as a disciplined evolution of the existing platform, with refinements to the AMT high-frequency driver, woven glass fibre matrix midrange and bass drivers, crossover network, cabinet construction, bass loading, finishes, and production tolerances.
In other words, this is Wharfedale reminding everyone that it can do more than walnut nostalgia and big boxes with wide baffles. The pipe-and-slippers crowd may want to take the night off before the AMT tweeter frightens the port.
The new range includes the Elysian 1R compact standmount, Elysian 2R reference standmount, Elysian 3R compact floorstander, Elysian 4R flagship floorstander, and Elysian CR centre channel speaker. Matching stands are available for the standmount and centre models.
Elysian R Series: What Has Changed?
wharfedale-elysian-r-series-speakers-grey-no-grilles
Wharfedale is carrying over the basic Elysian identity but has revisited the major acoustic and mechanical elements. The headline change is the further-developed AMT, or Air Motion Transformer, high-frequency driver. Instead of a conventional dome tweeter, the AMT uses a pleated diaphragm to move air more efficiently. For the R Series, Wharfedale specifies an ultra-lightweight PET diaphragm, an enlarged high-spec design, and an acoustically damped rear chamber intended to improve openness, extension, and treble control.
The midrange and bass drivers have also been refined. Wharfedale uses proprietary woven glass fibre matrix cones, with updates to cone construction, motor systems, phase plugs, and distortion control. The midrange driver includes an aluminium ring and custom phase plug to support dispersion and linearity, while the bass units use improved motor systems, large voice coils, die-cast chassis, and aluminium demodulation rings.
Bass loading remains a major part of the Elysian formula. Wharfedale’s Slot-Loaded Profiled Port system, or SLPP, has been further optimized for the R Series. The system is designed to equalize internal and external air pressure, improve bass extension and control, reduce distortion, and make the speakers less sensitive to room placement. That last point matters, because big speakers with serious bass can become a domestic negotiation very quickly.
The crossover has also been redesigned. Wharfedale specifies high-silicon iron-cored coils for bass, air-core coils for midrange and treble, polypropylene capacitors throughout the signal path, and low-inductance resistors. The components are mounted on newly designed “direct path” PCBs intended to shorten the signal route, with LC-OFC high-purity copper cabling used between the crossover and drive units.
Cabinet Design and Finishes
wharfedale-elysian-2r-series-speakers-lifestyle-walnut-angle
Wharfedale Elysian 4R Loudspeakers in high-gloss walnut finish
The Elysian R cabinet keeps the familiar sculpted look of the original Elysian models but introduces a more contemporary visual direction. Wharfedale has replaced the previous piano lacquer black and white finishes with matte black and matte grey options, while retaining the high-gloss walnut finish that has been central to the Elysian identity.
The new finishes are joined by matte-black trims, driver detailing, and metalwork. The goal is a cleaner and more architectural look without stripping away the luxury feel. The matching stands for the Elysian 1R, Elysian 2R, and Elysian CR follow the same matte black approach.
Internally, Wharfedale uses its multi-layer PROS, or Panel Resonance Optimisation System, cabinet construction. The company says this is intended to reduce cabinet resonance and energy leakage, improving structural integrity and allowing the drivers to work with less cabinet coloration. That is the promise, anyway. The proof will be whether these speakers sound more precise than the original Elysians without losing their scale and ease.
Wharfedale Elysian 1R: Compact Standmount
wharfedale-elysian-1r-series-speakers-grey-lifestyle
The Wharfedale Elysian 1R is the entry point into the new range, although “entry point” is doing a lot of work at this level. This is a two-way standmount loudspeaker using a coated glass fibre matrix bass/midrange driver and a 27 x 90mm AMT high-frequency driver, which measures roughly 1.1 x 3.5 inches.
Wharfedale specifies 89dB sensitivity, a recommended amplifier power range of 25 to 175 watts, and a peak SPL of 108dB. Frequency response is rated at 49Hz to 22kHz, with bass extension down to 44Hz and a crossover frequency of 2.6kHz.
The cabinet volume is 21.6 litres. The Elysian 1R stands 490mm tall on its plinth, or about 19.3 inches, with a width of 263mm, or about 10.4 inches. Net weight is 15kg per speaker, or about 33.1 pounds.
Matching stands are available and measure 476mm tall, 340mm wide, and 287mm deep with badge, or about 18.7 x 13.4 x 11.3 inches.
Wharfedale Elysian 2R: Reference Standmount
wharfedale-elysian-2r-series-speakers-lifestyle-grey
The Wharfedale Elysian 2R is the larger and more ambitious standmount model in the lineup. Unlike most standmount speakers, this is a three-way design using a coated glass fibre matrix low-frequency driver, a coated glass fibre matrix midrange driver, and a 27 x 90mm AMT high-frequency driver, or roughly 1.1 x 3.5 inches.
Wharfedale rates the Elysian 2R at 89dB sensitivity, with a recommended amplifier power range of 25 to 250 watts and a peak SPL of 109dB. Frequency response is specified at 35Hz to 22kHz, with bass extension down to 28Hz.
Crossover points are 360Hz and 2.9kHz, with cabinet volumes of 17.5 litres and 43.6 litres. The Elysian 2R stands 700mm tall, or about 27.6 inches, with a width of 334mm, or about 13.1 inches.
Net weight is 30.5kg per speaker, or about 67.2 pounds, so this is not exactly a “bookshelf” speaker unless your bookshelf was built by a shipyard.
The matching Elysian 2R stands measure 428mm tall, 402mm wide, and 435mm deep with badge, or about 16.9 x 15.8 x 17.1 inches.
Wharfedale Elysian 3R: Compact Floorstander
ELYSIAN 3R Standard Black_I3
The Wharfedale Elysian 3R is the smaller of the two floorstanding models, but it still uses a proper three-way architecture. It features two coated glass fibre matrix bass drivers, a coated glass fibre matrix midrange driver, and a 27 x 90mm AMT high-frequency driver, roughly 1.1 x 3.5 inches.
Wharfedale specifies 89dB sensitivity, a recommended amplifier power range of 30 to 200 watts, and a peak SPL of 108dB. Frequency response is rated at 44Hz to 22kHz, with bass extension down to 35Hz.
The crossover frequencies are 375Hz and 2.9kHz, with cabinet volumes of 9.4 litres and 35 litres. The Elysian 3R stands 1050mm tall on its plinth, or about 41.3 inches, with a width of 263mm, or about 10.4 inches.
Net weight is 28.45kg per speaker, or about 62.7 pounds. It is the most room-manageable floorstander in the series, offering the full AMT, dedicated midrange, and dual-bass-driver layout without the size and weight of the flagship Elysian 4R.
Wharfedale Elysian 4R: Flagship Floorstander
wharfedale-elysian-4r-floorstanding-loudspeakers-walnut-lifestyle
The Wharfedale Elysian 4R sits at the top of the range and is the largest, most sensitive, and deepest-reaching model in the new series. It is a three-way floorstanding loudspeaker using two coated glass fibre matrix bass drivers, a coated glass fibre matrix midrange driver, and a 27 x 90mm AMT high-frequency driver, or approximately 1.1 x 3.5 inches.
Wharfedale rates the Elysian 4R at 92dB sensitivity, with a recommended amplifier power range of 15 to 250 watts and a peak SPL of 110dB. Frequency response is specified at 30Hz to 22kHz, with bass extension down to 24Hz.
Crossover frequencies are 340Hz and 3.1kHz, with cabinet volumes of 38 litres and 79.4 litres. The Elysian 4R stands 1188mm tall on its plinth, or about 46.8 inches, with a width of 402mm, or about 15.8 inches.
Net weight is 49.5kg per speaker, or about 109.1 pounds. That makes it the model most likely to deliver the full Elysian R scale and low-frequency authority, but also the one that will demand the most from the room, amplifier, and the person foolish enough to move it alone.
Wharfedale Elysian CR: Centre Channel
ELYSIAN CR Walnut_I2
The Wharfedale Elysian CR is the centre channel speaker in the range, designed for matching Elysian R home cinema systems. It is a three-way design using dual coated glass fibre matrix low-frequency drivers, a coated glass fibre matrix midrange driver, and a smaller 27 x 45mm AMT high-frequency driver, or roughly 1.1 x 1.8 inches.
Wharfedale specifies 91dB sensitivity, a recommended amplifier power range of 25 to 250 watts, and a peak SPL of 110dB. Frequency response is rated at 35Hz to 22kHz, with bass extension down to 27Hz.
Crossover frequencies are 360Hz and 2.9kHz, with cabinet volumes of 5.7 litres and 64 litres. The Elysian CR measures 320mm tall and 830mm wide, or about 12.6 inches tall and 32.7 inches wide.
Net weight is 30.2kg, or about 66.6 pounds. Matching stands are available and measure 496mm tall, 618mm wide, and 372mm deep with badge, or about 19.5 x 24.3 x 14.6 inches.
This is clearly not a token centre speaker added to complete the brochure; it is a large, heavy, full-range centre channel intended for serious multichannel systems.
Wharfedale Elysian 2R stand-mount speakers in high-gloss walnut finish
Pricing & Availability
The Wharfedale Elysian R Series is expected to be available in June in the U.S., with five models covering both stereo and home cinema systems. UK pricing listed in the supplied Wharfedale document shows the range scheduled for April 2026 availability in that market.
The Elysian 1R Compact standmount is the entry point into the lineup. It is a two-way design priced at $5,995 per pair in the U.S. and £3,499 in the UK. The larger Elysian 2R Reference standmount moves to a three-way configuration and is priced at $8,495 per pair in the U.S. and £4,999 in the UK.
For listeners looking for floorstanding models, the Elysian 3R Compact floorstander is a three-way design priced at $9,995 per pair in the U.S. and £5,599 in the UK. The Elysian 4R Flagship floorstander sits at the top of the range and is priced at $11,995 per pair in the U.S. and £6,999 in the UK.
Wharfedale is also offering the Elysian CR Centre channel, a three-way design intended for matching home cinema systems, priced at $5,995 in the U.S. and £3,499 in the UK.
Available finishes include walnut high gloss, matte black, and lunar grey. The walnut finish preserves the more traditional luxury loudspeaker look, while matte black and lunar grey give the Elysian R Series a cleaner, more contemporary direction.
The Bottom Line
The Elysian R Series is Wharfedale’s strongest modern engineering play, not another exercise in walnut-finished nostalgia. The refinements are meaningful: upgraded AMT tweeters, revised glass fibre matrix drivers, redesigned crossovers, improved SLPP bass loading, and resonance-controlled cabinet construction.
What makes the range compelling is the value equation. With the flagship Elysian 4R priced at $11,995 per pair in the U.S. and £6,999 in the UK, Wharfedale is competing in a category where many rivals now cost three to five times more and do not always offer more speaker for the money.
The lineup is missing a dedicated subwoofer, surround speaker, and height channel option, so it is not a complete home theater ecosystem. But as a high-end stereo range with a serious matching center channel, Elysian R looks like a very strong technical and financial argument. Not cheap, but increasingly rare in 2026: expensive for a reason.
Canor Crius H5S Preamp DAC Headphone Amp with Headphones and Tablet
2026 Nagra AMP II-S Stereo Power Amplifier 2026 Nagra AMP II-S Stereo Power Amplifier
Nagra's AMP II-S replaces the Classic AMP with 120 watts per channel, a redesigned power supply, and Reference-derived circuitry.
RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro RayNeo GT Max Glasses with Dolby Vision and Pocket TV Pro
Can RayNeo turn AR glasses into a private home theater? GT Max offers a 307-inch virtual screen, 120Hz Micro-OLED and Dolby Vision via Pocket...
Grado Signature S150 Headphones Grado Signature S150 Headphones
Grado's $295 Signature S150 brings a new 44mm driver, detachable cables, and improved comfort to its open-back headphones.
2026 Schiit Mani 3 Phono Preamp 2026 Schiit Mani 3 Phono Preamp
Schiit Mani 3 phono preamp adds front-panel controls, MM/MC cartridge flexibility, and improved circuitry without raising the price.
2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle 2026 Pioneer SXT-C10PS Retro Head Unit Lifestyle
Head Units
Pioneer's 2026 Heritage Collection in-dash head unit and box speaker set combines retro looks with modern convenience for your car.
Magico rebuilds the A3 with M9-derived engineering, new drivers and a new cabinet. The other upgrade? Entry-level Magico now costs $25,000.
Wharfedale’s Nova subs pack DSP, passive radiators, high-level inputs and 8- to 15-inch drivers into a serious fight with SVS and REL.
Can the Atlantis Lab AT-23 Pro deliver deep bass and room-filling dynamics without a subwoofer? Our review explains why it deserves attention.
Are the $1,499 Wharfedale Super Denton truly the British Bulldog of standmount speakers, and do they justify their place in the Heritage lineup?
Focal’s $50,000 Scala Utopia Evo M loudspeakers add a PRISM tweeter, M-profile midrange, and redesigned bass system to its iconic French floorstander.
Jean-Marie Reynaud’s AURALIS flagship pairs a tuned triangular transmission line, 120 mm AST tweeter, and hand-wired crossover for fall 2026.
We heard the Bowers & Wilkins 801 D5 in a proper demo room at High End Vienna 2026. So, is it a worthy successor...
