Center Speakers
Wharfedale Heritage Centre Channel Speaker Announced: A Matching Center Channel for the Heritage Series at Last
Wharfedale Heritage Centre Channel finally delivers a matching center speaker for Linton, Super Denton, and Heritage Series home theater systems.
Wharfedale Heritage Centre Speaker in cabinet
The Wharfedale Heritage Series has been one of the safer bets in modern hi-fi; models like the Linton, Super Linton, Wharfedale Super Denton, and Wharfedale Denton 85th Anniversary have earned their place in systems that handle both music and TV without any set-up drama. They look right, sound rather authoritative, and don’t require a $10,000 power amplifier to come alive.
I’ve seen them in more homes than just about any other high-end speaker in recent memory. Peter Comeau, Wharfedale’s Director of Acoustic Design, has had the good sense to keep the industrial design and engineering consistent across the range; an approach that, unlike so many in this industry, resists the urge to fix what was never broken.
But there’s been one very obvious gap, and Heritage Series owners (raises hand) have been complaining about it for years. If you wanted a proper home theater setup, there was no dedicated center channel that matched these speakers sonically or visually. You could mix and match from elsewhere in the Wharfedale lineup, but it never quite lined up. Timbre mismatch, aesthetic mismatch, pick your poison.
That changes now. Inspired by years of end-user demand, Wharfedale has finally introduced the $999 Heritage Centre Channel speaker—a long overdue addition that completes the lineup for multichannel music and home cinema without breaking the character that made the series popular in the first place.
wharfedale-heritage-centre-mahogany-angle
Wharfedale Heritage Centre (mahogany)
Design & Engineering: Made to Match, Not Approximate
The Wharfedale Heritage Centre is a dedicated center channel designed to match the rest of the Heritage Series in both sound and appearance. That’s been the gap—until now, there wasn’t a true companion for models like the Wharfedale Linton or Wharfedale Super Denton when building out a home theater system.
It uses a three-way design, which separates bass, midrange, and treble duties across dedicated drivers. That matters for a center channel because the midrange driver handles dialogue, keeping voices clear and anchored without being influenced by the woofers.
The driver layout includes:
  • Dual 6.5-inch Kevlar woofers for low frequencies
  • 2-inch soft-dome midrange for vocals
  • 1-inch soft-dome tweeter for high frequencies
These materials and design choices are consistent with the rest of the Heritage lineup, which helps maintain tonal balance across the front stage. The crossover is set to keep the midrange focused on the vocal band, which is the primary job of a center channel.
The cabinet is a rear-ported bass reflex design with internal bracing to control resonance. As with the other Heritage models, Wharfedale sticks to real wood veneers; Walnut, Mahogany, and Black Oak, so it integrates visually without standing out.
wharfedale-heritage-centre-mahogany-back
Specifications:
  • Design: 3-way, bass reflex (rear-ported) center channel
  • Bass: 2 × 6.5″ (165mm) Kevlar cones
  • Midrange: 2″ (50mm) soft dome
  • Tweeter: 1″ (25mm) soft dome
  • Frequency Response: 54Hz – 20kHz (±3dB)
  • Bass Extension: 47Hz (-6dB)
  • Crossover Frequencies: 900Hz, 2.7kHz
  • Sensitivity: 90dB (2.83V @ 1m)
  • Impedance: 6Ω nominal (4Ω minimum)
  • Recommended Power: 25-150W
  • Maximum SPL: 106dB
  • Cabinet: Rear-ported bass reflex, Internally braced
  • Dimensions (W x H x D): 21.65″ × 9.84″ × 12.6″ (550 × 250 × 320 mm)
  • Weight: 30.9 lbs (14 kg)
wharfedale-heritage-centre-black-front
The Bottom Line
The Wharfedale Heritage Centre is designed with a clear purpose, and the specs reflect that. The three-way layout with a dedicated midrange and crossover points at 900Hz and 2.7kHz indicate a focus on dialogue clarity and stability, which is exactly what a center channel needs to handle.
With 90dB sensitivity and a 6 ohm nominal impedance, it’s not a difficult load, but speakers in this family like the Wharfedale Linton and Wharfedale Super Denton tend to perform better with more capable amplification. It will work with most A/V receivers, but a unit with solid power delivery will maintain better control and consistency, especially at higher volumes.
The dual 6.5-inch woofers and 47Hz bass extension provide enough low-end support for voices and effects, though it’s still intended to be used with a subwoofer for full-range home theater use. A maximum SPL of 106dB is sufficient for typical room sizes.
This is the logical match for existing Heritage Series systems built around the Linton, Super Linton, Super Denton, and Denton 85th. It maintains a consistent tonal balance across the front stage without requiring a mix of different speaker designs.
wharfedale-heritage-centre-channel-speaker-walnut
Wharfedale Heritage Centre (walnut)
As with the rest of the series, the voicing leans slightly warm, so pairing with overly relaxed amplification may dull the presentation. A more neutral or slightly forward amplifier will likely produce better balance.
At $999, it fills a gap in the lineup with a solution that aligns with the rest of the series in both performance and design.
For more information: wharfedale.co.uk
Where to buy: $999 at Crutchfield
2 Comments
2 Comments
  1. Mike Cornell
    April 26, 2026 at 12:30 pm
    Can a “Heritage” subwoofer be next? (and yes, I know you could use an REL Classic or two)!
    • Ian White
      April 26, 2026 at 12:33 pm
      Mike,
      I would be surprised if that happened. Wharfedale does not have a strong track record in the category.
      IW
Splurge Audio Video Hi-Fi Tech Gifts 2026
The best bookshelf speakers of 2026, tested by eCoustics. Our Editors’ Choice picks include DALI, Q Acoustics, Wharfedale, Revel, Paradigm, and ATC.
Wharfedale’s Nova subs pack DSP, passive radiators, high-level inputs and 8- to 15-inch drivers into a serious fight with SVS and REL.
Are the $1,499 Wharfedale Super Denton truly the British Bulldog of standmount speakers, and do they justify their place in the Heritage lineup?
Triangle Solstice replaces Esprit with new horn tweeters, French made drivers, revised cabinets, and stereo to home cinema options.
Wharfedale Elysian R Series debuts with upgraded AMT tweeters, revised drivers, SLPP bass loading, and flagship performance from $5,995.
Wharfedale Denton 1S brings coaxial point source design, wall mounting, Brilliance EQ, and Heritage Series style for $999. Is this the smarter small speaker?
Daily Deals
Focal Omada bookshelf, floorstanding, and center speakers are on sale through June 21, 2026. Save up to 35% while supplies last.
