beyerdynamic AVENTHO Y Debuts at IFA 2026 and Makes Wireless Headphones Less Disposable
Can beyerdynamic shake up $150 wireless headphones? AVENTHO Y adds ANC, 90 hour battery life, Bluetooth 6.0 and replaceable parts.
2026 Beyerdynamic AVENTHO Y Wireless Headphones in white lifestyle
Wireless headphones have spent the past decade becoming smarter, more convenient and considerably harder to repair. Batteries are usually sealed inside, ear pads eventually deteriorate, and too many otherwise functional headphones become disposable once one critical component wears out.
That is starting to change. A small but important group of manufacturers is putting greater emphasis on replaceable batteries, removable ear pads and serviceable components, and beyerdynamic is leaning directly into that idea with the new AVENTHO Y.
Introduced at IFA 2026 for $149.99, the closed-back wireless over-ear headphone offers active noise cancellation, Bluetooth 6.0 multipoint connectivity, 45mm dynamic drivers, app-based EQ and up to 90 hours of battery life. None of those features alone makes it unusual, but beyerdynamic has taken a different approach to durability and long-term ownership that deserves more attention.
What Makes the AVENTHO Y Different?
beyerdynamic-aventho-y-wireless-headphones-blue-fusion
Wireless headphones eventually develop the same problem as every other rechargeable product: batteries wear out. On many models, that can turn an otherwise perfectly functional headphone into electronic waste or an expensive repair project.
Beyerdynamic has designed the AVENTHO Y with a user-replaceable battery, magnetic interchangeable ear pads, aluminum sliders and stainless-steel hinges. The company also offers optional black or gray velour ear pads, while an upgrade package adds a low-latency USB-C dongle and detachable boom microphone. An integrated compartment inside the earcup can store the optional dongle or a spare battery.
That modular approach is probably the AVENTHO Y’s strongest differentiator. The optional dongle and microphone also broaden its usefulness beyond commuting and music listening, giving owners the ability to configure it for gaming, video calls or work without purchasing a separate headset.
ANC, Bluetooth 6.0 and 45mm Drivers
beyerdynamic-aventho-y-wireless-headphones-peach-blush-side
The AVENTHO Y uses 45mm dynamic drivers in a closed-back, foldable over-ear design with a specified frequency response of 20 Hz to 20 kHz. Active noise cancellation is joined by a Transparency mode, while two integrated microphones use environmental noise cancellation to reduce background noise during calls.
Bluetooth 6.0 supports multipoint connectivity and a claimed range of up to 20 meters. The beyerdynamic app provides firmware updates, adjustable controls and a 5-band equalizer, allowing users to alter the headphone’s tonal balance rather than being locked into the factory tuning.
There is one specification worth examining more closely. The AVENTHO Y supports SBC and AAC, but beyerdynamic does not list aptX, aptX Adaptive, aptX Lossless or LDAC. Bluetooth 6.0 is the current version of the wireless standard, but the version number should not be confused with automatic support for higher-bitrate Bluetooth audio codecs.
beyerdynamic-aventho-y-wireless-headphones-black
Battery Life Should Be a Major Selling Point
Beyerdynamic rates the AVENTHO Y for up to 90 hours of playback with ANC switched off and up to 60 hours with ANC active. A full charge takes approximately one hour, while five minutes of fast charging can provide up to six additional hours of playback.
Those figures put it near the top of the category, although Audio-Technica’s ATH-S300BT essentially matches them with up to 90 hours without ANC and 60 hours with it. The Audio-Technica requires approximately 2.5 hours for a full charge, however, versus one hour for the beyerdynamic.
The AVENTHO Y weighs 316 grams, which is worth considering for anyone planning to wear it throughout the workday or on long flights. Beyerdynamic is offering four finishes: Liquid Black, Blue Fusion, Soft Jade and Peach Blush.
Plenty of Competition at $150
The AVENTHO Y is entering a much tougher part of the wireless headphone market than its $149.99 price might suggest. Final’s UX3000 SV sells for the same $149.99 and takes a more sound-focused approach, combining custom 40mm drivers with hybrid ANC, multipoint connectivity and support for aptX and aptX HD. Battery life is considerably shorter at 35 hours without ANC and 25 hours with it, but Final has built much of its reputation around tuning rather than winning the specification-sheet contest.
The new EarFun Wave Pro X may be an even more direct threat. Originally shown at CES 2026 and priced at $129.99, it uses a dual-driver configuration with 40mm DLC and 10mm LCP drivers, Bluetooth 6.0 and an unusually comprehensive codec package that includes aptX Adaptive, aptX Lossless, LDAC and LE Audio. Auracast, multipoint connectivity, hybrid ANC, an eight-microphone call system and up to 90 hours of battery life make the absence of anything beyond SBC and AAC on the AVENTHO Y considerably more noticeable.
Nothing’s 2026 Headphone (a) sits slightly higher at a $199 MSRP, although Nothing is currently selling it for $159 in the U.S. It offers adaptive ANC, LDAC, USB-C and 3.5mm wired playback, an 8-band EQ and a remarkable claimed 135 hours of playback without ANC or 75 hours with it engaged. At 310 grams, it is also very close to the 316-gram beyerdynamic, making the comparison considerably more relevant than the lightweight Sony WH-CH720N.
What the AVENTHO Y has that none of those models can match as a complete package is its emphasis on long-term ownership. The user-replaceable battery, magnetic ear pads, stainless-steel hinges and optional low-latency dongle and boom microphone give it an upgrade and repair path that most wireless headphones still lack. That is a stronger reason to consider the beyerdynamic than Bluetooth 6.0 or another hour-counting exercise.
beyerdynamic-aventho-y-wireless-headphones-black-lifestyle
Key Specifications
  • Type: Wireless closed-back over-ear
  • Drivers: 45mm dynamic
  • Frequency response: 20 Hz to 20 kHz
  • ANC: Yes
  • Transparency mode: Yes
  • Bluetooth: 6.0 with multipoint
  • Codecs: SBC, AAC
  • Wireless range: Up to 20 meters
  • Battery life with ANC: Up to 60 hours
  • Battery life without ANC: Up to 90 hours
  • Charging time: Approximately 1 hour
  • Fast charging: 5 minutes for up to 6 hours
  • EQ: 5-band via beyerdynamic app
  • Battery: User replaceable
  • Ear pads: Magnetic and interchangeable
  • Weight: 316 grams
  • Colors: Liquid Black, Blue Fusion, Soft Jade, Peach Blush
  • Price: $149.99
beyerdynamic-aventho-y-wireless-headphones-black-lifestyle-rear
Pricing & Availability
The beyerdynamic AVENTHO Y is priced at $149.99 in the United States and will be sold through beyerdynamic.com and Amazon.
At that price, the replaceable battery might matter more than another Bluetooth codec or marketing feature. Wireless headphones have become better and considerably more affordable, but relatively few are designed around the idea that owners might still want to use them after the original battery has reached the end of its useful life. Beyerdynamic appears to have noticed that problem, and the AVENTHO Y offers a rather sensible solution.
For more information: beyerdynamic.com
1 Comment
1 Comment
  1. ORT
    September 4, 2026 at 5:18 pm
    Common sense is anything but common. ’tis about time a replaceable battery came stock on wireless, ANC, BlooToofed headphones.
    Well done Beyerdynamic! ’nuff said!
    ORT
Splurge Audio Video Hi-Fi Tech Gifts 2026
The best wireless headphones of 2026, tested by eCoustics. Our Editors’ Choice picks from Sony, Bose, Focal, DALI and more cover ANC, sound and...
Shopping for wireless noise cancelling over-ear headphones in 2025? Here are our picks for the best you can buy on any budget.
TDM Neo headphones twist into a Bluetooth speaker, offering one device for private listening and the occasional need to become everyone’s DJ.
Can Noise challenge Bose and Sony? Master Buds Open combine Sound by Bose with 10mm drivers, Bluetooth 5.4 and a lightweight 4-gram clip design.
AI has become the garnish nobody ordered on almost every new consumer electronics product, but Soundcore is taking a somewhat different approach at IFA...
Can AWOL's $5,999 LuxVision change premium UST projection with 4K/120Hz, 6,000 ISO lumens, 10,000:1 contrast and optical image shift?
Can CANVAS HiFi turn BACCH 3D into a true Dolby Atmos theater? Almando InMedio adds 7.1.4 expansion, WiSA HT and open speaker support at...
