Lyngdorf’s $2,999 LCR-2 Puts a Full Home Theater Speaker on the Wall Without Taking Over the Room
Lyngdorf’s $2,999 LCR-2 is a shallow Danish on-wall speaker for left, center, right, or surround duty with up to 117 dB output.
2026 Lyngdorf Audio LCR-2 On-Wall Speakers in black
At $2,999 each, the Lyngdorf Audio LCR-2 is a shallow passive on-wall speaker that can handle left, center, right, or surround duties while giving FR-2 owners a properly matched route into multichannel home theater. A three-speaker front stage costs $8,997 before amplification or subwoofers, so this is not Danish flat-pack territory, but its 4.33-inch depth and claimed 117dB peak output make it an appealing option for serious systems that still have to share space with an actual living room.
More Than a Matching Center Channel
The LCR-2 was created to complete the company’s FR-2 loudspeaker system, but Lyngdorf has wisely avoided limiting it to center-channel duty.
LCR stands for Left, Center and Right, and the new speaker can be used beneath a television, as part of a three-speaker front array, or for surround channels. Using identical speakers across the front can improve tonal consistency as voices, music and effects move across the screen. There is less chance of the center channel sounding like it was borrowed from another system because somebody ran out of cabinet space.
lyngdorf-lcr-2-on-wall-speaker-with-fr-2-speakers-white
Lyngdorf Audio LCR-2 with FR-2 floorstanding speakers in white with mocca.
The LCR-2 uses the same two 6.5-inch aluminum-cone midrange and woofer drivers found in the FR-2, along with a 1.1-inch fabric soft-dome tweeter. That shared driver architecture should make it easier to build a coherent system around a pair of FR-2 loudspeakers without introducing a center channel with a completely different dispersion pattern or tonal balance.
There is one important difference. The FR-2 uses a downward-firing bass-reflex port and reaches a claimed 45Hz, while the smaller LCR-2 employs a sealed enclosure and is rated down to 80Hz. Translation: the LCR-2 was designed to hand the bottom octaves to a subwoofer, and Lyngdorf is not pretending otherwise.
Designed to Work Against the Wall
Many conventional loudspeakers are designed with the expectation that owners will pull them away from room boundaries. That is perfectly reasonable in a dedicated listening room and somewhat less realistic in a family room where people also expect to walk around without colliding with the front speakers.
Lyngdorf takes the opposite approach. The LCR-2 is specifically tuned for wall placement, with its drivers positioned close to the surface behind it. The closed, internally braced MDF cabinet measures 26 inches wide, 12.6 inches tall and only 4.33 inches deep, with a supplied wall mount. It weighs 23.8 pounds, so this is still a proper loudspeaker and not an acoustic picture frame with an ambitious press release.
The two aluminum-cone midrange and woofer drivers use 35mm voice coils, vented magnets and vented die-cast aluminum baskets. Lyngdorf positions the drivers and tweeter close together to create a more controlled sound beam and improve integration through the crossover region. The crossover point is set at 1.7kHz.
Lyngdorf rates sensitivity at 92dB, maximum output at 117dB peak at one meter and power handling at 250 watts IEC. Nominal impedance is 4 ohms, with a minimum of 3.7 ohms. That sensitivity should help the speaker achieve substantial output without absurd amounts of power, but the impedance suggests pairing it with an AVR or power amplifier that is comfortable driving 4-ohm loudspeakers.
Passive Means Passive
lyngdorf-lcr-2-rear
The LCR-2 has gold-plated binding posts and requires external amplification.
There is no HDMI eARC input, wireless connection, streaming platform or built-in RoomPerfect processing. Lyngdorf is known for digital amplification and room correction, but none of that lives inside the speaker. RoomPerfect would need to come from a compatible Lyngdorf processor or amplifier elsewhere in the system.
That will disappoint anyone hoping to mount three speakers, connect the television and declare victory before dinner. It will make considerably more sense to buyers already considering a premium AVR, multichannel processor or separate power amplifier.
For its Audio Advice Live demonstration, Lyngdorf will use three LCR-2 loudspeakers across the front with D-60 surrounds, D-5 height channels, REL subwoofers, an MP-60 2.1 processor and MXA-8400 eight-channel amplifier. In other words, the company is presenting the LCR-2 as part of a genuine high-output theater system, not as an expensive replacement for the speakers inside your television.
Designed for Rooms That Do Not Look Like Screening Rooms
lyngdorf-lcr-2-with-grille-mocca
Lyngdorf LCR-2 (mocca) with light gray grille
Lyngdorf offers the LCR-2 in six enclosure and front-baffle combinations: white with white, black with black, mocca with mocca, white with black, white with mocca, and black with mocca.
Optional exchangeable fabric covers are available in light gray and midnight gray using material from Danish textile supplier Gabriel. The cabinet has rounded edges and a front baffle that flows into the upper surface rather than looking like a rectangular MDF box bolted to the wall. Each LCR-2 is manufactured at Lyngdorf Audio in Denmark.
None of that changes how the speaker sounds, but this category lives or dies on integration. People willing to spend almost $9,000 on three passive speakers may also prefer that the front wall not resemble the commercial cinema at a regional shopping mall.
Lyngdorf LCR-2 Specifications
  • Price: $2,999 each
  • Design: Passive 2-way on-wall loudspeaker
  • Applications: Left, center, right, or surround channel
  • Tweeter: 1.1-inch (28mm) fabric soft dome
  • Midrange and woofers: Two 6.5-inch (180mm) aluminum-cone drivers
  • Enclosure: Sealed, internally braced MDF
  • Frequency response: 80Hz to 20kHz (-3dB)
  • Sensitivity: 92dB at 2.83V/1m
  • Maximum output: 117dB peak at 1 meter
  • Power handling: 250 watts (IEC)
  • Nominal impedance: 4 ohms (3.7 ohms minimum)
  • Crossover point: 1.7kHz
  • Connections: Gold-plated binding posts
  • Dimensions: 66.5 x 32 x 11 cm (26 x 12.6 x 4.33 inches)
  • Weight: 10.8 kg / 23.8 lbs
  • Mounting: Supplied wall bracket
What Makes the LCR-2 Different?
The LCR-2 is not the least expensive, shallowest or deepest-reaching on-wall loudspeaker in the category.
Its advantage is the combination of high sensitivity, dual 6.5-inch drivers, substantial claimed output, shallow wall-specific construction and direct compatibility with the FR-2. It can become a matching center channel for an existing stereo pair or serve as the foundation of an entire on-wall theater system.
The six finish combinations also provide more visual flexibility than the usual black-or-white decision. Apparently Denmark has discovered that home theater speakers can be engineered for a wall without being forced to dress like office equipment.
Competitors?
DALI RUBIKORE ON-WALL
DALI RUBIKORE On-Wall Speaker
The $2,500 DALI RUBIKORE ON-WALL is the closest competitor in national origin. It is also manufactured in Denmark and can serve as a left, center or right speaker.
RUBIKORE features a 6.5-inch Clarity Cone driver with a hybrid tweeter module, combining a 29mm soft dome with a planar element. The tweeter can be rotated, allowing the cabinet to operate in portrait or landscape orientation. It is rated from 59Hz to 34kHz, with 88.5dB sensitivity and maximum output of 108dB.
The DALI plays considerably deeper and offers greater placement flexibility. Although RUBIKORE On-Wall is smaller overall, its cabinet depth is over 1-inch thicker. Meanwhile, the Lyngdorf claims 9dB more maximum output, and both brands offer compatible floorstanding models for additional speaker pairings.
PSB PWM3
PSB Speakers Imagine T65 Tower Loudspeaker Black Angle with PWM3 Soundbar
PSB Imagine T65 Loudspeakers with PWM3 Soundbar
The $2,599 PSB PWM3 is less expensive and even shallower at 3.5 inches with its grille installed. It uses seven drivers: four 4-inch carbon-fiber woofers, two 3-inch carbon-fiber midrange drivers and a 1-inch titanium-dome tweeter.
The PWM3 can be mounted vertically or horizontally and used for every channel in a five-channel or seven-channel on-wall system. Its frequency response is rated from 60Hz to 35kHz, with an 8-ohm nominal impedance and 86dB anechoic sensitivity.
PSB provides greater orientation flexibility, a friendlier load for many AVRs and a lower price. The Lyngdorf counters with larger woofers, higher sensitivity, a more compact overall width.
Focal On-Wall 302
Focal On-wall 302 Front Speakers Black Front Lifestyle
Focal On-wall 302
The $1,749 Focal On Wall 302 is the value option in this group, although “value” becomes an interesting word once the invoice passes four figures per speaker.
Made in France, it uses four 4-inch Flax midbass drivers and a 1-inch aluminum-magnesium inverted-dome tweeter. The cabinet is only 3.56 inches deep and can be positioned vertically or horizontally. Focal rates it from 50Hz to 28kHz, with 91dB sensitivity and recommended amplifier power of 40 to 180 watts.
The Focal costs considerably less, extends deeper and offers flexible mounting, but its 49-inch length makes it a much larger visual object. The Lyngdorf is almost half as wide, uses larger midrange and woofer drivers and offers a claimed peak-output specification aimed at more demanding theater installations.
Who Is It For?
The LCR-2 makes the most sense for:
  • Lyngdorf FR-2 owners adding a center or surround channels
  • Premium multipurpose media rooms where floor space is limited
  • Home theaters using acoustically visible on-wall speakers
  • Buyers who want identical speakers across the front soundstage
  • Systems built around capable external amplification and one or more subwoofers
  • Interior-conscious installations that need more than black or white cabinets
Who Should Avoid It?
The LCR-2 is harder to justify for anyone building a value-focused theater or expecting full-range performance without a subwoofer.
It is also not an all-in-one or wireless product. Buyers looking for HDMI, amplification, streaming or wireless surround operation should look elsewhere because the LCR-2 supplies none of them.
Renters may also want to consider the installation requirements before attaching 23.8 pounds of Danish loudspeaker to a wall their security deposit technically still belongs to.
lyngdorf-lcr-2-on-wall-speaker-black-closeup
Lyngdorf LCR-2
The Bottom Line
The Lyngdorf LCR-2 fills an obvious gap in the company’s lineup. The FR-2 finally has a matching center and surround option, while custom installers gain a compact speaker that can be repeated across an entire front wall.
Its 80Hz lower limit means a subwoofer is not optional in a home theater system, and the $2,999 price makes a complete LCR array an $8,997 proposition before the processor, amplification and bass system arrive.
That is expensive, but the LCR-2 offers something more focused than another oversized center speaker balanced on furniture. It is designed for the wall, matches Lyngdorf’s existing loudspeakers, produces substantial output and looks like somebody considered the room before drawing the cabinet.
In high-end home theater, that last part remains surprisingly uncommon.
Price & Availability
The Lyngdorf Audio LCR-2 will retail for $2,999 each and is scheduled to begin shipping in the United States in August 2026.
It will make its North American public debut at Audio Advice Live in Raleigh, North Carolina, from August 7 through August 9, 2026.
For more information: lyngdorf.steinwaylyngdorf.com
2026 JMGO Iris Ultra Projectors
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Silkland H96 HDMI 2.2. Cables Silkland H96 HDMI 2.2. Cables
A/V Furniture & Accessories
2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle 2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle
2026 Wattson Audio Madison Phono Angle 2026 Wattson Audio Madison Phono Angle
Can digitizing vinyl improve a phono stage? Wattson Audio’s $5,495 Madison Phono supports MM, MC, DS Audio and multiple historic EQ curves.
Can ASCENDO’s new Panoramic Surface speaker solve beaming and dispersion problems in immersive home cinema systems?
What did Focal and Naim bring to Audio Advice Live 2026? A $210K Diva Alta Utopia, Scala’s North American debut, Hekla and a $5,297...
What is Playback Distribution bringing to Audio Advice Live 2026? Three rooms featuring a Vienna Acoustics North American loudspeaker debut, PMC Speakers, CANVAS HiFi,...
Klipsch debuts Reference Premiere III at Audio Advice Live 2026 with Onkyo, a 7.4.4 Atmos system, anniversary Klipschorn and Rebellion.
ASCENDO, Trinnov and Christie bring a 9.7.4-channel home cinema with WaveForming bass and 10,000-lumen 4K projection to Audio Advice Live 2026.
The $1,099 Q Acoustics 3040c brings twin C3 drivers to smaller rooms, but costs only $100 less than the larger 3050c in the U.S.
