Atlantis Lab AT-23 Pro Floorstanding Speakers Review: Big Bass and High-End Sound for Less
Can the Atlantis Lab AT-23 Pro deliver deep bass and room-filling dynamics without a subwoofer? Our review explains why it deserves attention.
Atlantis Labs AT-23 Pro Loudspeaker Front No Grille
Atlantis Lab may not be a familiar name to most American audiophiles, but the French loudspeaker manufacturer has been building high efficiency designs since 1998. Originally known as Atlantis Acoustique, the company was founded by Eric Buy with a focus on producing speakers that could deliver substantial output without requiring massive amounts of amplifier power.
That philosophy guided the company for nearly two decades before Atlantis shifted direction in 2017, bringing in a team of sound engineers to optimize its loudspeakers for professional studio use as well as home audio systems. The change also brought a new name and product lines that retained the efficiency of the earlier models while adding the heavy duty drivers, cabinets, and components more commonly associated with professional sound reinforcement equipment.
The result is a range of loudspeakers that are relatively easy to drive, built to withstand demanding use, and flexible enough to work in rooms where conventional designs can struggle. Tunable ports allow many Atlantis Lab models to sit closer to the wall without overwhelming the room with bass, helping the company build a loyal following across Europe.
The problem in the United States was never the product. It was finding one. Early availability was inconsistent, and dealer support was limited. With Decibel+ now representing Atlantis Lab, distribution and customer support have improved considerably. That should make the brand a far more common sight in American studios, showrooms, and listening rooms.
atlantis-labs-speaker-lineup
The current Atlantis Lab lineup includes the AT-13 Pro and AT-21 Pro bookshelf speakers, along with the AT-16 Pro, AT-18 Pro, AT-23 Pro, AT-31 Pro, and AT-38 Pro floorstanding models. The company also offers a dedicated home theater range with AT-13 and AT-21 center channels, the AT-22 satellite speaker, and the AT-33 subwoofer.
Taken together, the lineup covers nearly every room size and application, with prices starting at roughly $1,650 and climbing to $13,000 each for the flagship AT-38 Pro. That is a substantial range, but it also gives buyers the ability to select a model based on the room rather than trying to force an undersized or oversized loudspeaker into a space where it does not belong.
After speaking with Decibel+ about which model would make the most sense for this review, we settled on the AT-23 Pro as the best match for the room I had available. Positioned near the middle of the lineup, the AT-23 Pro retails for approximately $3,400 per speaker, depending on the selected options.
These are designed to fill a room rather than function as oversized nearfield monitors, so choosing the correct model for the space was important. I wanted to evaluate how the AT-23 Pro energized the entire room, not simply toe the speakers toward my listening position and judge them solely on their on-axis performance.
The AT-23 Pro Makes Its Presence Felt Before the Music Starts
atlantis-labs-at-23-pro-loudspeakers-front
Atlantis Labs AT-23 Pro (front without grilles)
Unboxing the AT-23 Pro is a challenge, as each speaker weighs 35 kilograms, or roughly 77 pounds. This is not a speaker you casually lift out of the box and carry across the room without first considering the condition of your back.
The front baffle is wrapped in black leather, although white leather is also available. Solid oak panels cover both sides of the cabinet and slope gently inward, making the enclosure slightly narrower at the top than at the base.
Each side panel is constructed from vertical oak slats measuring 54mm wide. Not every slat is made from a single piece of wood, so horizontal joints are visible in several places. The finished cabinet is certainly distinctive, although it may not be the easiest visual match for rooms with similarly colored hardwood floors or a lot of existing wood furniture.
The side panels are likely to be the most divisive aspect of the AT-23 Pro’s appearance. Some people I asked really liked the combination of leather and natural oak, while others felt the segmented wood panels detracted from the overall aesthetic. Offering a solid-color finish or a continuous veneer might make the AT-23 Pro easier to integrate into a wider range of listening spaces.
Pro Drivers With Room-Friendly Placement
atlantis-labs-at-23-pro-loudspeakers-front-back
Atlantis Labs AT-23 Pro (front and rear without grilles)
Starting at the top of the front baffle, the AT-23 Pro uses a 1-inch horn-loaded tweeter with a titanium diaphragm and a round waveguide offering 90-by-90-degree dispersion. Directly below it sits a 21cm midwoofer, paired with a second 21cm driver mounted in opposition on the rear of the cabinet.
The front-firing driver is an Eighteen Sound model with a paper cone selected for greater transparency, while the rear driver uses the company’s Kevlar cone to add depth and impact. This arrangement gives the AT-23 Pro a more substantial low-frequency presentation without relying on a conventional collection of front-facing woofers.
A tunable port at the bottom of the front baffle allows the speaker to be adjusted for placement closer to or farther away from the rear wall. That flexibility makes the AT-23 Pro particularly useful in rooms where the speakers need to sit near a wall to avoid blocking walkways or consuming too much floor space.
The leather finish continues across the rear of the cabinet as a single uninterrupted piece running from the bottom of the front baffle, over the top, and down the back. This creates a cleaner visual contrast with the more segmented appearance of the oak side panels.
The rear-facing 21cm Kevlar driver is positioned roughly halfway up the cabinet. Below it, a single pair of binding posts accepts bare wire or banana plugs. The through-hole design can accommodate bare speaker cable up to approximately 10 gauge, which should be more than sufficient for nearly any domestic installation.
Easy to Drive, Hard to Overwhelm
The AT-23 Pro is a 4-ohm loudspeaker rated to handle 300 watts continuously and 600 watts peak. Atlantis Lab specifies a frequency response of 33Hz to 20kHz, but my in-room testing found output remained within roughly 1dB down to 28Hz before the roll-off became more pronounced. That makes the AT-23 Pro entirely usable without a subwoofer for most music systems, although home theater users may still want one for the lowest effects.
One of the original design goals was to combine the performance of the AT-21 loudspeaker and AT-33 subwoofer in a single cabinet. Based on the measurements and what I heard in the room, Atlantis Lab largely succeeded.
The adjustable port provides another level of control over the low end. I found that slightly increasing the tube length from its default setting produced the best balance in my listening room. The adjustment is simple, and the audible difference is substantial enough to be useful. This is not a gimmick. It is a legitimate room-tuning tool.
With a rated sensitivity of 96.5dB, the AT-23 Pro can also be paired with a much wider range of amplifiers than its size and power handling might suggest. It worked equally well with lower-powered tube amplifiers and far more muscular solid-state designs. I expected it to favor one end of that spectrum, but it remained composed and engaging regardless of which amplifier I used.
My first test platform was a modified Dynaco ST-70 producing roughly 32 watts per channel, with peak output reaching into the 70-watt range before distortion begins to take a meaningful toll on sound quality. I then moved to the opposite extreme and connected the AT-23 Pro speakers to my main system, which uses a pair of Mark Levinson No. 23.5 amplifiers capable of delivering 400 watts without much effort.
Those two systems represent something close to the practical lower and upper limits most owners are likely to consider. The AT-23 Pro handled both without complaint, which says a great deal about its efficiency, power handling, and overall versatility.
Atlantis Lab AT-23 Pro Specifications
  • Type: High-efficiency floorstanding loudspeaker
  • Configuration: 3-driver, bass-reflex design
  • Tweeter: 1-inch titanium-diaphragm, horn-loaded tweeter
  • Waveguide dispersion: 90 x 90 degrees
  • Front driver: 21cm Eighteen Sound paper-cone midwoofer
  • Rear driver: 21cm Eighteen Sound Kevlar-cone woofer
  • Bass tuning: Adjustable front-firing reflex port
  • Frequency response: 33Hz to 20kHz
  • Measured bass extension: Approximately 28Hz at -1dB in-room
  • Sensitivity: 96.5dB
  • Nominal impedance: 4 ohms
  • Continuous power handling: 300 watts
  • Peak power handling: 600 watts
  • Connections: Single pair of binding posts
  • Compatible terminations: Banana plugs and bare wire up to approximately 10 gauge
  • Cabinet finishes: Oak side panels with black or optional white leather baffle
  • Dimensions (HxWxD): 111 x 40 x 40 cm (43.7 x 15.75 x 15.75 inches)
  • Weight: 35 kg / 77 lbs each
Listening
atlantis-labs-at-23-pro-loudspeakers-front-side
The AT-23 Pro speakers effortlessly bring a room together with their captivating sound quality. At AXPONA, it was evident that while the cabinetry might stir some debate among enthusiasts, the sound quickly shifts the focus back to what truly matters: pure, immersive listening enjoyment.
The AT-23 Pro delivers robust, solid bass that often forced me to remind myself that my subwoofers were disconnected. The bass is not only quick but also richly textured, displaying an impressive level of detail that one might not expect from relatively small drivers paired with a large reflex port.
Contrary to expectations, there is minimal distortion, which is a common issue when smaller drivers attempt to mimic larger ones. The low-end capabilities of these speakers make them an excellent option for rooms where subwoofer placement is problematic or impossible. Those looking for true home theater impact, or listeners who favor heavy EDM, can add a subwoofer to take the slam and rumble to another level.
Midrange frequencies are reproduced with excellent clarity and above-average dynamics, allowing horns and strings to resonate with convincing energy and life. Acoustic guitar and piano are rendered with a level of realism that many more expensive loudspeakers struggle to duplicate.
My usual classical and jazz playlists were a joy to experience through the AT-23 Pro. Even when I switched to the dense, complex layers of Miles Davis’ “Bitches Brew,” I remained thoroughly engrossed by the nuanced presentation of each horn and the speaker’s ability to keep individual instruments distinct within the mix.
Vocal reproduction through the AT-23 Pro is generally excellent, although it highlights the importance of both recording quality and careful system matching. The horn-loaded tweeter can emphasize brightness when paired with similarly voiced electronics, but it also reveals just how well, or poorly, a recording was engineered.
Recordings handled by engineers such as Rudy Van Gelder and Bruce Swedien sounded open, detailed, and remarkably lifelike. Poorly mastered tracks were far less forgiving, with harshness and compression brought more clearly into focus.
That sensitivity is better understood as a reflection of the AT-23 Pro’s resolving ability than an inherent flaw. Pair it thoughtfully and feed it quality recordings, and the speaker rewards the effort.
The dynamic range and engaging character of the AT-23 Pro are undeniable. The speakers handle the delicate passages of Tchaikovsky’s “The Sleeping Beauty” with grace and air, then power through Mussorgsky’s “The Great Gate of Kiev” with explosive energy and precision.
With the right recordings and complementary electronics, the AT-23 Pro delivers a thrilling and highly immersive listening experience.
The Bottom Line
The Atlantis Lab AT-23 Pro is a versatile floorstanding speaker for medium to larger rooms, especially for listeners who want deep, authoritative bass without adding a subwoofer. Its high sensitivity, tunable port, and ability to perform closer to the rear wall also make it easier to place than many speakers of this size.
The AT-23 Pro combines detailed highs, precise midrange performance, and substantial low-end output in a package that reminds me of the Vandersteen Treo CT at close to half the price. The Treo still offers greater treble refinement, and the AT-23 Pro’s oak-slat cabinetry will not appeal to everyone, but neither issue diminishes how engaging these speakers are.
They are not yet widely known in the United States, but improved distribution through Decibel+ should change that. Anyone shopping in this price range should make the effort to hear them. They are easy to drive, difficult to ignore, and even easier to get lost in.
Pros:
  • Deep, powerful bass that often eliminates the need for a subwoofer
  • Clear, realistic midrange with excellent dynamics
  • High sensitivity makes amplifier matching relatively easy
  • Tunable port allows more flexible near-wall placement
  • Engaging, room-filling presentation with strong value for the price
Cons:
  • Horn tweeter can sound bright with aggressive electronics or recordings
  • Oak-slat cabinetry will be visually divisive
  • Large, heavy cabinets require help during setup
  • Treble is not quite as refined as some more expensive competitors
Our Ratings:
★★★★★★★★★★ Sound Quality
★★★★★★★★★★ Build Quality
★★★★★★★★★★ Aesthetics
★★★★★★★★★★ Value
Where to buy:
Magico rebuilds the A3 with M9-derived engineering, new drivers and a new cabinet. The other upgrade? Entry-level Magico now costs $25,000.
Can 20 watts be enough? The $11,828 Neoson Evolution pairs Class A KT88 tube power with rich tonality, and strong detail.
Can Buchardt’s MK2 Upgrade Kit make older active speakers better without replacing them? New amps, DSP, connectivity, and tweeters offer an alternative.
The $1,099 Q Acoustics 3040c brings twin C3 drivers to smaller rooms, but costs only $100 less than the larger 3050c in the U.S.
Loudspeakers
NEAD will distribute Jamo, Energy, Juke Audio, XLO and OXS across the U.S. and Canada as two familiar speaker brands plan their return.
Best in Show at T.H.E. Show SoCal 2026: the most impressive high end hi-fi systems, from active speakers to tube powered analog rigs.
