JBL PartyBox Ultimate 2 Has 1,500 Watts, Weighs 105 Pounds and Still Needs an Outlet
The $1,800 JBL PartyBox Ultimate 2 packs 1,500 watts, Wi-Fi 6, Roon, AI karaoke and a touchscreen into a light show speaker that isn’t all that “portable.”
2026 JBL PartyBox Ultimate 2 Party Speaker Lifestyle
There are Bluetooth speakers for the kitchen, Bluetooth speakers for the beach, and Bluetooth speakers small enough to disappear into a backpack.
The JBL PartyBox Ultimate 2 is none of those things.
Priced at $1,799.95, JBL’s new flagship PartyBox delivers a claimed 1,500 watts RMS, weighs just over 105 pounds, stands more than 41 inches tall, and uses dual 10-inch woofers, dual 5-inch midrange drivers, and a pair of horn-loaded PEN tweeters derived from JBL’s professional-audio experience. JBL says it can provide sound across an area equivalent to four basketball courts. Your neighbors have been warned.
The Ultimate 2 replaces the original PartyBox Ultimate, increasing output from 1,100 to 1,500 watts while also substantially revising the acoustic architecture. The previous model used dual 9-inch woofers, 4.5-inch midrange drivers, and larger conventional tweeters; the Ultimate 2 moves to bigger woofers and mids while adding professional-style horn-loaded high-frequency drivers.
So this is more than JBL finding another number to print in a larger font.
What Makes the PartyBox Ultimate 2 Different?
Raw power is only part of the story.
AI Sound Boost monitors the incoming audio in real time and adjusts the speaker’s output to maintain clarity and reduce distortion as volume increases. JBL has also added Smart EQ Mode, while the frequency response now reaches a claimed 28Hz to 20kHz (-6dB).
jbl-partybox-ultimate-2-party-speaker-touchscreen
The Ultimate 2 is also the first PartyBox with an integrated touchscreen. The top-mounted volume control doubles as a display and controller for music, lighting, and other settings rather than forcing users to reach for a phone every time someone decides the room needs more flashing lights.
And there are plenty of those.
JBL’s revised light show adds full-panel ripple effects, multilayer illumination, and floor projection, because apparently illuminating the speaker itself was no longer sufficient.
Karaoke users get EasySing AI Vocal Removal, which can reduce vocals from existing tracks, along with microphone and guitar inputs. There is also an optical input for TV-based karaoke and an XLR line input for connecting DJ equipment.
That combination moves the Ultimate 2 closer to a self-contained event system than a conventional wireless speaker.
Streaming Gets Surprisingly Serious
The connectivity may be the most unexpected part.
The PartyBox Ultimate 2 supports Wi-Fi 6, Bluetooth 6.0, Bluetooth LE Audio, Auracast, AirPlay, Google Cast, Spotify Connect, and JBL’s ONE app. JBL also lists support for services including TIDAL Connect, Qobuz Connect, and Roon Ready through its Wi-Fi platform.
USB Type-C supports lossless audio playback, while Auracast allows compatible JBL speakers to be linked for larger installations.
In other words, this $1,800 rolling light show has better network-audio credentials than some components sold to people who use the phrase “reference system” without irony.
jbl-partybox-ultimate-2-party-speaker-angle
There Is One Small Portability Problem
JBL calls the Ultimate 2 transportable, and technically that is true.
It has larger wheels and a substantial handle. It also weighs 105.12 pounds and measures 18.37 x 41.44 x 19.42 inches (W x H x D). More importantly, there is no internal battery. The Ultimate 2 requires AC power.
So you can move it around. You just cannot move it very far from an electrical outlet.
The enclosure carries an IPX4 splash-resistance rating, which should handle drinks, light rain, and the usual hazards of a party, but it is not designed for serious exposure to water.
What Does $1,800 Buy Versus the Competition?
The main competitor to JBL PartyBox Ultimate 2 is Sony’s new ULT Tower MAX, which was just released last month for $300 less. ULT Tower Max is a half-inch taller and tacks on another 19 lbs and has more total speaker drivers. Both support Auracast for connecting multiple units together, and both support karaoke, but neither comes with a microphone.
Smaller options include the Marshall Bromley 750 ($1,299), which also uses dual 10-inch woofers and weighs a much more manageable 52.7 pounds. It delivers a claimed 127dB maximum SPL, 360-degree sound, stage lighting, Auracast, microphone/instrument inputs, IP54 protection, and — critically — more than 40 hours of battery life.
Marshall does not offer JBL’s Wi-Fi streaming ecosystem, touchscreen, AI vocal removal, or elaborate floor-projection light show. It is also considerably easier to take somewhere without requiring both a friend and an extension cord.
The SOUNDBOKS 4 ($1,199), strips away much of the visual theater and focuses on ruggedness and output. It reaches a claimed 126dB, weighs about 35.5 pounds, uses a swappable battery, and is designed for outdoor abuse rather than turning your basement into a nightclub.
JBL charges substantially more than all three. What it offers in return is the broadest combination of raw amplifier power, Wi-Fi streaming, party lighting, DJ connectivity, karaoke processing, touchscreen control, and multi-speaker networking.
jbl-partybox-ultimate-2-vs-sony-ult-tower-max
JBL PartyBox Ultimate 2 (left) vs. Sony ULT Tower MAX (right, grille removed)
Specifications Compared
JBL PartyBox Ultimate 2Sony ULT TOWER MAX (SRS-ULT3000)
ReleasedOct 2026Sept 2026
MSRP$1,799$1,499
Drivers2 x 10″ woofers
2 x 5″ midrange
2 x 1″ tweeters
3 x 11″ woofers
2 x 4.8″ midrange
2 x 1″ tweeters
2 x 1.6″ tweeters
Power / Output1500 W310 W
BatteryNo, AC power onlyNo, AC power only
Bluetooth6.05.3
Wi‑Fi802.11 b/g/n/ax–
Frequency response28 Hz – 20 kHz (-6 dB)Not listed
InputsUSB-C, aux-in, mic-in, guitar-in, line-in (XLR)USB-A, USB-C, MIC 6.3 mm, LINE 1 (RCA), LINE 2 (XLR)
Outputs–LINE OUT (XLR), DC OUT USB-A, DC OUT USB-C
AuracastYesYes
Party LightsYesYes
App supportJBL OneSony Sound Connect
Splash ratingIPX4Top surface only
Carrying featuresWheels, handleWheels, handle
Vocal removalEasySing AI Vocal Removal–
EQ / sound modeSmart EQ Mode,
AI Sound Boost
10-band EQ,
ULT button
Dimensions (W x H x D)18.37 x 41.44 x 19.42 in
(466.7 x 1052.5 x 493.3 mm)
21.1 x 41.9 x 18.6 in
(534 x 1,062 x 472 mm)
Weight105 lbs (47.68 kg)124 lbs (56.3 kg)
jbl-partybox-ultimate-2-party-speaker-karaoke
The Bottom Line
The JBL PartyBox Ultimate 2 makes sense for people hosting very large parties, event spaces, DJs, karaoke enthusiasts, clubs, gyms, and anyone who needs a speaker capable of moving a lot of air without assembling a traditional PA system.
It makes considerably less sense for someone looking for an actual portable Bluetooth speaker. At 105 pounds with no battery, the wheels are not an accessory. They are a survival mechanism.
The $1,799.95 price also pushes the Ultimate 2 well beyond competitors we have covered from Marshall, Sony, and SOUNDBOKS. Those alternatives are lighter and, in some cases, genuinely portable.
But none combines this much power with JBL’s Wi-Fi platform, Roon support, professional inputs, AI karaoke, touchscreen controls, and enough synchronized lighting to make your homeowners association draft an emergency amendment.
The PartyBox Ultimate 2 is excessive and that appears to be the point.
Where to buy:
Tip: JBL’s previous PartyBox Ultimate is currently on sale at Amazon while supplies last.
3 Comments
3 Comments
  1. ORT
    October 7, 2026 at 12:30 pm
    An epiphany…Not just any epiphany but a truly cosmic one. I saw the photo and the world around me disappeared only have revealed before me the ancient mystery of just WTI (What The Intercourse) the “Dawn of Man” scene from Kubrick’s Magnum Dopus, “2001: A Space Odyssey” truly was…The mystical monolith was a…Party Speaker.
    To quote Emperor Joseph II – “Well. There it is.” We call all die peacefully now…
    Gaius Petronius ORTbiter
    • Ian White
      October 7, 2026 at 2:51 pm
      ORT,
      Tell that to my neighbors. To be continued…
      IW
  2. My Boy Blue
    October 7, 2026 at 8:56 pm
    Look at the size of that thing. Two of those could fill an auditorium or giant backyard rave.
    It’s weird watching all these companies jump into this market, but I suppose more people will buy this than $10,000 speakers.
Moon 341 Integrated Amplifier Black Angle
2026 Audiolab PPA7 Phono Preamp Black LIfestyle 2026 Audiolab PPA7 Phono Preamp Black LIfestyle
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
2026 T+A Solitaire T Pro Wireless Headphones 2026 T+A Solitaire T Pro Wireless Headphones
T+A Solitaire T Pro adds Dolby Atmos, aptX Lossless and premium DAC technology, but are luxury wireless headphones becoming too expensive?
2026 Vinnie Rossi Canta Integrated Amplifier Angle 2026 Vinnie Rossi Canta Integrated Amplifier Angle
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
2026 NAD C 359S Integrated Amplifier 2026 NAD C 359S Integrated Amplifier
NAD's $1,299 C 359S combines 70W Class AB amplification, BluOS and HDMI eARC with power supply technology from its Masters Series. Who said Class...
2026 NAD C 569 CD Player 2026 NAD C 569 CD Player
CD Players
NAD's mid-priced CD player adds QRONO d2a, Dynamic Digital Headroom and an ESS SABRE DAC. Is it the smarter buy than the pricier C...
Headphones
Can Auracast change movie theater accessibility? Vue has installed Auri across 200+ screens while major North American chains still use legacy receivers.
CMF’s first Bluetooth speakers combine Nothing-style design with Auracast, USB-C audio, IP68 protection and prices starting at just $59.
EarFun's flagship wireless noise cancelling headphones for 2026 offer adaptive ANC, Auracast, aptX Lossless, 90-hour battery life and custom EQ.
Bose brings Auracast, LC3 and LE Audio to its $449 QuietComfort Ultra Gen 2, although Android compatibility and beta restrictions still apply.
Nothing's $399 Headphone (1) Pro uses three drivers, xMEMS treble and Flat EQ. Clever engineering, or has Nothing finally over-engineered something useful?
The 2026 CEDIA Expo was held last week in Denver and eCoustics was there in force to check out the latest in home theater...
Dongle DACs
Can JBL Cove challenge Sonos, HEOS and Bluesound with Whole Home audio, Dolby Atmos and automatic room tuning?
