Dongle DACs
iFi UP Play Max Brings aptX Lossless Bluetooth to iPhones and More for $89
2026 iFi Audio UP Play Max Bluetooth Transmitter
You can spend $1,000 or more on a flagship smartphone, another $500 on wireless headphones, subscribe to a lossless streaming service, and still discover that Bluetooth is the weakest link in the chain.
For iPhone owners, the issue is especially obvious. Apple continues to rely on AAC and SBC for conventional Bluetooth audio, which means headphones capable of aptX Lossless, aptX Adaptive, or LDAC cannot use those codecs when connected directly to an iPhone. Android is less restrictive, but codec support varies considerably between manufacturers and devices.
That is the problem the new iFi UP Play Max is designed to solve.
The $89 USB Type-C Bluetooth transmitter plugs into a smartphone, tablet, computer, or compatible gaming device and bypasses the source device’s native Bluetooth codec limitations. Its headline feature is aptX Lossless, which can deliver lossless 16-bit/44.1kHz audio when paired with a compatible receiving device. It also supports other higher-quality Bluetooth codecs for broader compatibility.
Because apparently buying expensive wireless headphones and then discovering your equally expensive phone cannot use their best codec is still something we are doing in 2026.
ifi-up-play-max-angle
iFi UP Play Max
More Than Just aptX Lossless
The UP Play Max is not the first USB Type-C transmitter to give iPhone users access to better Bluetooth codecs. What makes it interesting is the collection of additional features iFi has packed into a device weighing only 3 grams.
iFi includes K2 Technology, licensed from JVCKENWOOD, which the company says reconstructs harmonic information lost during digital processing. It can be switched on or off through the iFi Nexis app, so listeners who would rather leave the signal alone are not being held hostage by somebody else’s idea of sonic improvement.
ifi-up-play-max-before-after
There is also a dedicated low-latency mode using aptX Adaptive for gaming and television viewing. A built-in microphone adds Qualcomm noise and echo suppression for calls and in-game chat, making the UP Play Max more practical for gamers than a transmitter focused exclusively on music playback.
Two pairs of conventional Bluetooth headphones can also be connected simultaneously, although dual-headphone listening is limited to the SBC codec.
Auracast Is Coming Too
The UP Play Max will also support Auracast, allowing one source to broadcast Bluetooth audio to multiple compatible receivers.
That feature will not be available immediately. iFi says Auracast will arrive through a firmware update shortly after launch, so consider it a promised feature rather than something to check off on day one.
The Nexis app handles codec selection, paired devices, K2, low-latency mode, Auracast controls, and over-the-air firmware updates.
iFi UP Play Max Specifications:
  • Type: Portable Bluetooth transmitter
  • Connection: USB Type-C
  • Bluetooth: 5.4
  • Chipset: Qualcomm QCC5181
  • Maximum Resolution: 24-bit/96kHz
  • Codecs: aptX Lossless, aptX Adaptive, aptX HD, aptX, LDAC, AAC, SBC
  • Dual Headphone Pairing: Yes, using SBC
  • Auracast: Yes, via post-launch firmware update
  • Low Latency Mode: Yes, via aptX Adaptive
  • Microphone: Built in with Qualcomm noise and echo suppression
  • App: iFi Nexis for iOS and Android
  • Dimensions: 27.6 x 20.8 x 8 mm
  • Weight: 3 grams
ifi-up-play-max-bottom
Competition?
The FiiO BT1 remains a formidable alternative. It also uses Qualcomm’s QCC5181 chipset, supports aptX Lossless, LDAC, and aptX Adaptive, weighs 3 grams, and launched at just $44.
The Questyle QCC Dongle Pro2 is even closer conceptually. At $99, it supports aptX Lossless, LDAC, LHDC, LC3, Bluetooth 6.1, and Auracast, making it one of the strongest direct competitors to the UP Play Max.
iFi’s advantage is therefore not that nobody else has solved the codec problem. They have. The UP Play Max differentiates itself by combining lossless Bluetooth transmission with K2 processing, a microphone, dual-headphone support, low-latency operation, and upcoming Auracast in one very small device.
The Bottom Line
The obvious audience here is iPhone and iPad users with premium wireless headphones or Bluetooth DACs that support aptX Lossless or other codecs Apple does not provide natively.
It also makes sense for Android users whose phones lack a particular codec, laptop owners dealing with mediocre Bluetooth implementations, and gamers who want lower latency without abandoning their existing wireless headphones.
There is one important limitation: the UP Play Max cannot manufacture codec support at the receiving end. To use aptX Lossless, your headphones, earbuds, or Bluetooth DAC must also support aptX Lossless.
Price & Availability
The iFi UP Play Max is priced at $89 USD, $149 CAD, £89, and €99 and will be available through iFi and authorized dealers and ifi-audio.com.
Dongle DACs
Who needs another dongle? The $79 iFi GO Cable packs a DAC, amp, mic, and controls into one IEM cable. We test its sound,...
Dongle DACs
Questyle's QCC Dongle Pro2 brings LDAC, Bluetooth 6.1, and low-latency gaming to more devices. Is the wireless upgrade worth its compromises?
Our favorite portable Bluetooth speakers of 2026 survived rain, snow, beach and boating adventures with impressive sound, durability and design.
Sennheiser's flagship wireless earbuds for 2026 deliver warm sound, capable ANC, and replaceable batteries. At $299, can they compete with Sony's best?
Nothing's $59 milk carton delivers surprisingly good sound, Auracast, and over 17 hours of battery life. Got milk? This one's got swagger.
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
T+A Solitaire T Pro adds Dolby Atmos, aptX Lossless and premium DAC technology, but are luxury wireless headphones becoming too expensive?
Headphones
Can Auracast change movie theater accessibility? Vue has installed Auri across 200+ screens while major North American chains still use legacy receivers.
