Marshall Bromley 150 Party Speaker Packs Stage Lights Into a More Compact Design
Marshall’s $499.99 Bromley 150 party speaker combines 360-degree sound, stage lighting, 40+ hour battery life, Auracast, and mic and instrument inputs.
2026 Marshall Bromley 160 Party Speaker Lifestyle
Following the release of the Bromley 450 and Bromley 750, Marshall has expanded its growing party speaker lineup with the Bromley 150, its smallest and most portable model in the series.
Party speakers have become a popular alternative to traditional portable Bluetooth speakers for listeners who want higher output, deeper bass, longer listening sessions, and a little more spectacle when friends show up. They occupy the increasingly crowded space between compact wireless speakers and full-blown PA systems, combining simple wireless connectivity with enough power and durability for larger rooms, patios, and parties.
The Bromley 150 takes the core approach of its larger siblings and shrinks it into a more manageable cabinet. Marshall has retained the family’s emphasis on sound, connectivity, and convenience, along with integrated stage lighting positioned behind the grille that reacts to the music. The cabinet is constructed from FSC 100%-certified wood, wrapped in PU leather, and protected by soft TPU corner caps designed to handle the occasional encounter with a wall, table leg, or overly enthusiastic party guest.
“Bromley 150 delivers the same exceptional performance and craftsmanship as the Bromley 450 and 750 in a more compact form. By repositioning the control panel to the side while retaining the tactile controls users love, we’ve freed up the entire front panel for what matters most: powerful sound and immersive stage lighting,” said Emma Rydahl, Senior Industrial Designer at Marshall Group.
marshall-bromley-150-party-speaker-front-angle
Marshall Bromley 150 Key Features
True Stereophonic 360° Sound: Designed for both indoor and outdoor use, the Bromley 150 uses front- and rear-facing drivers to deliver consistent sound coverage around the speaker. This helps maintain a balanced “sweet spot” without requiring a fixed listening position.
40+ Hours of Portable Playtime: The Bromley 150 can operate on AC power or its built-in rechargeable battery. The battery provides more than 40 hours of playback, depending on volume levels and usage. An optional spare battery can be easily swapped in to extend listening time.
marshall-bromley-150-party-speaker-battery
Battery replacement
Mic and Instrument Inputs: The Bromley 150 includes two inputs for microphones and instruments, making it suitable for karaoke and live performances. Additional connectivity includes Aux RCA and USB Type-C inputs for external audio sources.
Bluetooth Connectivity: The Bromley 150 supports wireless Bluetooth playback from smartphones, tablets, and computers. It is also compatible with Auracast, allowing it to connect with other supported speakers through the Marshall Bluetooth app for expanded sound coverage.
Integrated Stage Lights: The speaker includes built-in lighting with three presets. One provides ambient illumination, while the others respond dynamically to the music, adding a visual element that helps elevate the energy of a gathering.
Dirt & Splash Resistant: The Bromley 150 carries an IP55 rating, providing protection against dust and low-pressure water exposure. This makes it suitable for outdoor use in backyards, parks, or festivals, where light splashes or debris may be encountered.
Built-in Handle: The Bromley 150 includes a built-in handle for easier transport. When pressed down, the handle retracts into the cabinet, allowing multiple speakers to be stacked securely on top of one another.
Recycled Materials: The Bromley 150 is constructed from 19% recycled material by weight, helping reduce the environmental impact associated with sourcing and processing raw materials.
Comparison
marshall-bromley-150-450-750-party-speakers
Marshall ModelBromley 150 (2026)Bromley 450 (2026)Bromley 750 (2025)
Product TypeParty SpeakerParty SpeakerParty Speaker
Price$499.99$799.99$1,299.99
Power Amplifiers  1 x 90 W class D amplifier for the woofers
1  x 55 W class D amplifier for the full-range drivers
2 x 90 W class D amplifiers for the woofers
4 x 55 W class D amplifiers for the full-range drivers
2 x 100 W class D amplifiers for the woofers
2 x 50 W class D amplifiers for the mid-range drivers
4 x 50 W class D amplifiers for the tweeters
Drivers  1 x 6.5-inch 40 W Woofers
2 x 2-inch 6 W Full-ranges
1 x 7.5-inch passive radiator
2 x 6.5-inch 40 W Woofers
4 x 2-inch 6 W Full-ranges
2 x 8-inch passive radiators
2 x 10 inch 150 W Woofers
2 x 5.25 inch 50 W Mid-ranges
2 x 1 inch 7 W Tweeters
2 x 0.8 inch 14 W Tweeters
Driver TypeDynamic Dynamic  Dynamic
Frequency range40Hz – 20kHz 42Hz – 20kHz   20Hz – 20,000Hz
Cabinet Principle Sealed with passive radiator Closed system  Closed system
Maximum Sound Pressure Level   97 dB @ 1 m 100 dB @ 1 m  127 dB @ 1 m
Equalizer  Yes Yes Yes
Stereo/Mono  Stereo Stereo Stereo
Bluetooth  Bluetooth 5.3, Auracast Bluetooth 5.3, Auracast Bluetooth 5.3, Auracast
Bluetooth Audio Codecs  SBC, AAC-MPEG-2, and LC3 SBC, AAC-MPEG 2, and LC3 SBC, AAC-MPEG 2, and LC3
Bluetooth Multipoint Connectivity  Yes Yes Yes
Bluetooth range > 70 m (229 feet) in free field > 70 m (229 feet) in free field> 70 m (229 feet) in free field
Wired connectivity Audio:
AUX 3.5mm (Input and Output)
USB-C
Mic / Instrument:
 2 XLR/6.35 mm combo jack
Audio:
USB-C, RCA
Mic / Instrument:
2 XLR/6.35 mm combo jacks
Audio
AUX 3.5mm (Input and Output),
USB-C, RCA
Mic / Instrument:
Power Input  100-140V 50/60Hz 100W 100-240V, 50/60Hz  100-240V, 50/60Hz
USB-C charging port   5V⎓3.0A 5V⎓3.0A  5V⎓3.0A
Battery Playtime40+ hours 40+ hours 40+ hours
Quick charge 20 minutes gives 5 hours of playtime 20 minutes gives 6 hours of playtime 20 minutes gives 5 hours of playtime
Charging time  3 hours to full recharge 3.5 hours to full recharge3.5 hours to full recharge
Exchangeable battery Yes Yes Yes
Battery information Rechargeable, replaceable, LFP battery (LiFePO4) Rechargeable, replaceable, LFP battery (LiFePO4)  Rechargeable, replaceable, LFP battery (LiFePO4)
Light Show YesYes  Yes
Handle YesYes Yes
Wheels NoNo Yes
Water resistance IP55 IP55 IP54
Compatible AppsMarshall Bluetooth appMarshall Bluetooth appMarshall Bluetooth app
Materials 19% recycled material by weight15% recycled material by weight Not Indicated
Repair Service YesYes  Yes
Dimensions290 x 290 x 208 mm
11.4 x 11.4 x 8.19 in
360 x 261 x 492 mm
14.2 x 10.28 x 19.37
652 x 413 x 355 mm
 25.7 x 16.3 x 14 in
Weight [kg] 6.3 kg / 14lbs12.2 kg / 26.8 lbs23.9 kg / 52.7 lbs
Colorways Black and Brass Black and Brass Black and Brass
Competition
SOUNDBOKS offers similar industrial style from its three-model lineup consisting of the Rider, Mix, and SOUNDBOKS 4. JBL also competes aggressively at similar price points with the Boombox 4 at $549.95 and PartyBox On-The-Go 2 Plus at $419.95, while Sony’s ULT Tower 7 moves further toward the larger party speaker end of the category at $649.
Newer competitors are making the segment even more crowded. The Tronsmart Halo 300 costs $349, the TCL TP300K is $399, and the Hisense Party Thunder Pro comes in at $399.99. Those lower prices put additional pressure on Marshall, but the Bromley 150 is not competing on price alone. Its appeal rests on delivering much of the Bromley 450 and 750 experience in a size that is easier to carry, position, and actually live with.
marshall-bromley-150-party-speaker-controls
The Bottom Line
Following the Bromley 750 and 450, the Marshall Bromley 150 takes most of the features that define the larger models and packages them in a smaller, more portable party speaker. True Stereophonic 360° sound, more than 40 hours of battery life, a replaceable battery, microphone and instrument inputs, integrated stage lighting, and Bluetooth with Auracast give it considerably more flexibility than a conventional portable Bluetooth speaker.
At $499.99, the Bromley 150 is aimed at listeners who want enough output and functionality for indoor or outdoor gatherings without moving up to one of the much larger party speakers that can dominate both the room and your storage space. Its combination of Marshall’s familiar design language, front and rear driver arrangement, retractable handle, stage lighting, and PA-style connectivity also gives it a distinct identity in a category increasingly filled with black plastic boxes competing to see which one can shake the neighbor’s windows first.
Pricing & Availability
2026 Steinway & Sons Model O Loudspeaker near wall lifestyle
The $299 Bumpboxx Retroboom packs 200 watts of peak power, Bluetooth, RGB lighting and 30-hour battery life into a retro boombox without tapes or...
Jamo's $399 HYG 5 WiFi speaker offers Qobuz Connect, TIDAL Connect, AirPlay 2, Google Cast and three active drivers in a Scandinavian design.
Nothing's $59 milk carton delivers surprisingly good sound, Auracast, and over 17 hours of battery life. Got milk? This one's got swagger.
CMF’s first Bluetooth speakers combine Nothing-style design with Auracast, USB-C audio, IP68 protection and prices starting at just $59.
TDM Neo headphones twist into a Bluetooth speaker, offering one device for private listening and the occasional need to become everyone’s DJ.
Edifier’s affordable studio monitors combine balanced tuning, useful connectivity, app control, and impressive bass for their size.
The $599 SOUNDBOKS Rider delivers 118dB, a swappable battery and IP66 protection without requiring a hand truck to move it.
