Marshall Launches Bromley 450 Party Speaker With Vintage Vibes
At $799, the Marshall Bromley 450 packs 360-degree sound, 40+ hour battery, and mic inputs in a 27 pound portable party speaker box.
Marshall Bromley 450 Party Speaker Lifestyle
Marshall has just introduced a smaller variant of its largest party speaker for $500 less. The new Marshall Bromley 450 ($799) follows the Bromley 750 ($1,299) from last year, while keeping the same design, light show and retro style in smaller footprint.
The Bromley 450 also maintains very similar specifications including True Stereophonic 360-degree sound, over 40 hours of battery life, and integrated stage lighting that leans hard into vintage concert vibes without feeling like a gimmick. Wrapped in water-based PU leather with reinforced corners and a metal grille, it’s built to survive actual parties—not just look good in marketing shots.
Designed for both indoor and outdoor use, the Bromley 450 delivers wide, room-filling sound with a portable footprint and built-in handle that makes it easy to haul from backyard to beach. Add in dual combo inputs for microphones or instruments, and it’s clear Marshall isn’t just chasing the Bluetooth crowd, it’s going after anyone who thinks a speaker should do more than just sit there.
Last year, we launched our first-ever party speaker, and we’re excited about growing that family of Marshall speakers already this Spring,” said Hanna Wallner, Product Manager at Marshall Group. “Bromley 450 is the natural continuation and smaller sibling of Bromley 750. This speaker is smaller and more affordable yet still packed with impressive features, including sound that hits every corner, a stage light-inspired light show, and our unique Marshall design.”
marshall-bromley-750-450-party-speakers-black-front
Marshall Bromley 450 Features
True Stereophonic 360° Sound: Designed for both indoor and outdoor use, the Bromley 450 uses multi-directional driver placement to deliver consistent sound coverage around the speaker. This helps maintain a balanced listening experience without requiring a fixed listening position.
40+ Hours of Portable Playtime: The Bromley 450 can operate on AC power or its built-in rechargeable battery. On battery, it provides over 40 hours of playback, depending on volume levels and usage. An optional spare battery can be used to extend listening time.
Integrated Stage Lights: The speaker includes built-in lighting with three selectable presets. One provides ambient illumination, while the others respond dynamically to the music to add visual elements to playback.
marshall-bromley-450-party-speaker-rear-inputs
Marshall Bromley 450 rear inputs
Mic and Instrument Inputs: The Bromley 450 includes inputs for microphones and instruments, enabling use for karaoke or live performance. Additional connectivity includes RCA and USB-C inputs for external audio sources.
Bluetooth Connectivity: The Bromley 450 supports wireless Bluetooth playback from smartphones, tablets, and computers. It is also compatible with Auracast, allowing it to pair with other supported speakers through the Marshall Bluetooth app for expanded coverage.
Dirt and Splash Resistance: Rated IP55, the Bromley 450 is protected against dust and low-pressure water exposure. This makes it suitable for outdoor use in environments such as backyards, parks, or festivals, where light splashes or debris may be present.
marshall-bromley-450-party-speaker-carry
Built-in Handle: The Bromley 450 includes an integrated handle for easier transport. Its size and design make it practical to carry between locations or load into a vehicle for outdoor use.
Replaceable Battery: The speaker uses a replaceable LFP battery with adaptive charging designed to help maintain long-term battery health. Replacement batteries are available through Marshall.
Recycled Materials: The Bromley 450 is constructed with 15% recycled material by weight, reducing the environmental impact associated with raw material sourcing and processing.
With Bromley 450, our goal was to take everything we loved about the Bromley 750 and bring it into a more compact form,” said Malcolm Kennedy, Director of Audio & Acoustics at Marshall Group. “It delivers the same signature sound: fast, powerful bass, clean mids, and detailed highs. Thanks to our unique 360-degree True Stereophonic design, it can always be the center of the party, preserving the depth and atmosphere of your favorite music.”
Comparison
Marshall Bromley 750 (left) and Bromley 450 (right) party speakers
Bromley 750
(2025)
Bromley 450
(2026)
Product TypeParty SpeakerParty Speaker
Price$1,299.99$799.99
Width413mm / 16.26″261mm / 10.28″
Height652mm / 25.7″492mm / 19.37″
Depth355mm / 14″366mm / 14.41″
Weight23.9 kg / 52.7 lbs12.2 kg / 26.8 lbs
Power Amplifiers2 x 100W woofers
2 x 50W mid-range
4 x 50W tweeters
2 x 90W woofers
4 x 55W full-range drivers
Drivers2 x 10″ woofers
2 x 5.25″ mid-ranges
2 x 1″ tweeters
2 x 0.8″ tweeters
2 x 6.5″ woofers
4 x 2″ full-range drivers
2 x 8″ Passive radiators
Driver TypeDynamicDynamic
Frequency range20Hz – 20,000Hz42Hz – 20kHz
Cabinet PrincipleClosed systemClosed system
Maximum Sound Pressure Level127 dB @ 1 m100 dB @ 1 m
EqualizerYesYes
Stereo/MonoStereoStereo
BluetoothBluetooth 5.3, AuracastBluetooth 5.3, Auracast
Bluetooth Audio CodecsSBC, AAC-MPEG 2, and LC3SBC, AAC-MPEG 2, and LC3
Bluetooth Multipoint ConnectivityYesYes
Bluetooth range>70m (229 feet) in free field>70m (229 feet) in free field
Wired connectivityAUX 3.5mm
USB-C
RCA
2 XLR/6.35 mm combo jack
AUX 3.5mm
USB-C
RCA
Power Input100-240V, 50/60Hz100-240V, 50/60Hz
USB-C charging port5V⎓3.0A5V⎓3.0A
Battery Playtime40+ hours40+ hours
Quick charge20 minutes gives 5 hours of playtime20 minutes gives 6 hours of playtime
Charging time3.5 hours to full recharge3.5 hours to full recharge
Exchangeable batteryYesYes
Battery informationRechargeable, replaceable, LFP battery (LiFePO4)Rechargeable, replaceable, LFP battery (LiFePO4)
Light ShowYesYes
HandleYesYes
WheelsYes
Water resistanceIP54IP55
Compatible AppsMarshall Bluetooth appMarshall Bluetooth app
ColorwaysBlack and BrassBlack and Brass
marshall-bromley-750-450-party-speakers-pickup-truck
Marshall Bromley 750 (left) and Bromley 450 (right) party speakers in back of pickup truck
The Bottom Line
The Marshall Bromley 450 stands out by combining PA-style functionality with consumer-friendly design. True Stereophonic 360-degree sound, long battery life, replaceable power, and support for microphones and instruments make it more flexible than a typical Bluetooth speaker. Auracast compatibility also gives it room to scale beyond a single unit, which is becoming more relevant as multi-speaker ecosystems evolve.
What it does not emphasize is app-driven smart features, voice assistants, or advanced streaming platform integration. This is not a Wi-Fi multi-room speaker or a high-resolution streaming hub. It is focused on local playback, physical inputs, and straightforward Bluetooth use.
It’s designed for users who want a portable, durable speaker that can handle social settings, small events, or outdoor gatherings without needing additional gear. It will appeal to those who value physical connectivity and long battery life over smart features, and who want something that can function as both a speaker and a simple event system for under $800.
Marshall Bromley 450 (rear)
Price & Availability
For more information, visit Marshall’s party speaker page.
2026 Kaleidescape Compact Terra Prime 246TB SSD Movie Server
If you're looking for a big powerful party speaker that can be used virtually anywhere, you may want to check out Sony's new Ult...
Sony just did a major refresh to the top models in their ULT Tower party speaker lineup, blurring the line between "pro" and "party."
Klipsch Odyssey Limited Edition Bluetooth Speaker pairs premium portable audio with a sword-inspired design for Christopher Nolan’s The Odyssey. Limited to 2,500 pieces.
JBL PartyBox 330 and 130 add upgraded drivers, Auracast, mic and guitar inputs, fast charging, and party-ready power from $449.95.
Is the KEF Muo the best portable Bluetooth speaker under $250 for clear vocals, premium build, strong battery life, and real outdoor projection?
