Marshall Upgrades Acton IV and Stanmore IV Retro Styled Bluetooth Speakers
2026 Marshall Stanmore IV and Acton IV Wireless Speakers Front Black
Marshall built its reputation on guitar amplifiers used by everyone from rock legends to garage bands still waiting for the neighbors to appreciate the setlist. In recent years, however, the company has expanded well beyond the stage with portable Bluetooth speakers, party speakers, headphones, and its first soundbars, the Heston 120 and Heston 60.
That consumer audio push now continues with the Marshall Acton IV and Stanmore IV, the latest fourth-generation models in the company’s home Bluetooth speaker lineup.
Both speakers retain Marshall’s familiar guitar amplifier styling while adding upgraded tweeters, redesigned bass ports, Dynamic Loudness processing, Bluetooth 5.3 with Auracast and LC3 support, a revised brass control panel, a customizable M button, and more replaceable components.
The Acton IV and Stanmore IV will compete for attention with premium home speakers from Sonos, JBL, and Denon, although Marshall continues to place greater emphasis on Bluetooth connectivity, physical controls, analog inputs, and visual appeal than on a fully integrated Wi-Fi multi-room ecosystem.
Let’s take a closer look at what has changed.
Related Reviews:
Acton IV and Stanmore IV Shared Features and Upgrades
marshall-stanmore-iv-controls
Brass Control Panel: Marshall’s familiar brass control panel returns with an improved media jog dial, its signature power switch, and tactile knobs for volume, bass, and treble. A new customizable M button provides instant access to personalized EQ settings or Spotify Tap.
marshall-stanmore-iv-connection
Connectivity: Both speakers include RCA and 3.5 mm AUX inputs for physical sources such as CD players and turntables, although an external phono preamp may be required depending on the model. Wireless connectivity includes Bluetooth with LDAC support, along with Auracast through Marshall’s Heddon streaming hub.
Acoustic Design: Both speakers feature redesigned, downward-firing aerodynamic bass ports, allowing them to sit closer to a wall without significantly compromising bass performance. Upgraded tweeters are also intended to deliver a wider soundstage.
Dynamic Loudness: Marshall’s Dynamic Loudness processing automatically adjusts the tonal balance at different listening levels, helping the speakers maintain a fuller and more consistent sound at both low and high volumes.
marshall-app
Marshall App: Both speakers provide access to the Marshall App, which not only allows users to adjust EQ, but also provides a room calibration option to better optimize speaker sound in your space.
Repairability: Both speakers are designed to support the replacement of selected external components, which should help extend their useful life rather than sending the entire speaker to the dumpster when one part fails.
Sustainability: The Acton IV and Stanmore IV incorporate FSC-certified wood and recycled materials as part of Marshall’s broader sustainability efforts.
Pro Tip: Although both speakers are compact enough to move from room to room, they require AC power and do not include built-in batteries. That is the reason Marshall classifies them as home speakers rather than portable models.
Marshall Acton IV vs. Stanmore IV: Key Differences
Although the Marshall Acton IV and Stanmore IV share many of the same features, their differences in size, bass extension, and maximum output may determine which model is better suited to your listening space.
Size and Weight:
  • The Acton IV is the more compact of the two, measuring 260 x 171 x 150 mm (10.24 x 6.73 x 5.91 inches) and weighing 2.65 kg (5.84 pounds). Its smaller footprint makes it better suited to bedrooms, kitchens, offices, and other modestly sized spaces.
  • The larger Stanmore IV measures 350 x 203 x 185 mm (13.78 x 7.99 x 7.28 inches) and weighs 3.99 kg (8.79 pounds). That additional cabinet volume makes it the more appropriate choice for larger rooms or listeners who want greater scale and bass output.
Woofer Size: The Acton IV uses one 4-inch woofer and two 0.75-inch tweeters with waveguides. The Stanmore IV uses the same tweeter configuration but steps up to a larger 5-inch woofer.
Audio Performance: The Stanmore IV’s larger woofer and cabinet allow it to reach slightly deeper, with a claimed frequency response of 36 Hz to 38 kHz, compared with 37 Hz to 38 kHz for the Acton IV. It also reaches a higher maximum output of 97 dB SPL at one meter, versus 95 dB for the Acton IV. The Acton IV should be more than sufficient for smaller spaces, while the Stanmore IV is designed to deliver greater bass weight and room-filling output.
Comparison
marshall-acton-iv-stanmore-iv-front
Marshall Model Acton IVStanmore IV
Product TypePowered SpeakerPowered Speaker
Price$329 $429
Cabinet PrincipleBass-reflexBass-reflex
Drivers1x 4-inch woofer
2x 0.75-inch tweeters with waveguides
1x 5-inch woofer
Frequency range37–38,000 Hz36–38,000 Hz
Maximum sound pressure level (SPL)95 dB SPL @ 1 m97 dB SPL @ 1 m
Stereo/MonoStereoStereo
Amplification (Class D)1x 60-watt amp for the Woofer
2x 25-watt amps for the tweeters
Wireless connectivityBluetooth 5.3
Auracast
Bluetooth 5.3
Auracast
Bluetooth Codec SupportSBC, AAC (MPEG-2), LDAC, LC3SBC, AAC (MPEG-2), LDAC, LC3
Bluetooth range10m / 32.8ft10m / 32.8ft
Bluetooth Multipoint ConnectivityYesYes
Wired connectivityAUX 3.5 mm
AUX RCA
AUX 3.5 mm
AUX RCA
Top Panel ControlsBass
Treble
Volume
Power switch
Media jog
M-button
Source button
Bass
Treble
Volume
Power switch
Media jog
M-button
Source button
Microphone SystemNoNo
Power Input100–240 V100–240 V
DimensionsWidth 171mm / 6.73″
Height 150mm / 5.91″
Depth 260mm / 10.24″
Width 350mm / 13.78″
Height 203mm / 7.99″
Depth 185mm / 7.28″
Weight2.65 kg / 5.84 lb3.99 kg / 8.79 lb
ColorwaysBlack
Cream
Black
Cream
Box ContentsActon IV speaker
Mains lead
Quick start guide
Legal and safety
information
Stanmore IV speaker
Mains lead
Quick start guide
Legal and safety information
Companion AppMarshall appMarshall app
marshall-acton-iv-lifestyle
Marshall Acton IV
The Bottom Line
The Marshall Acton IV and Stanmore IV stand out by combining the company’s unmistakable guitar-amplifier styling with tactile controls, analog inputs, modern Bluetooth support, and a more repairable design. They are aimed at listeners who want a powered home speaker that looks like part of the room rather than another anonymous black box.
The smaller Acton IV is better suited to bedrooms, offices, and kitchens, while the Stanmore IV offers greater scale and bass output for larger spaces. Neither model includes HDMI ARC, USB audio, a phono stage, or a built-in battery, so buyers looking for TV integration, network streaming, or portable operation will need to look elsewhere. Another thing to keep in mind is that even though both speakers are compact, they require AC power to operate so there is no built-in battery system for portable “on-the-go” use. However, Marshall does offer the Killburn III, which is a great portable Bluetooth speaker option, both visually and audibly.
Price & Availability
The Acton IV ($329) and Stanmore IV ($429) are available in Black or Cream on Marshall’s official website and select retailers.
Discover the best wireless speakers of 2026, from portable Bluetooth models to high-end stereo systems.
Dongle DACs
Questyle's QCC Dongle Pro2 brings LDAC, Bluetooth 6.1, and low-latency gaming to more devices. Is the wireless upgrade worth its compromises?
Our favorite portable Bluetooth speakers of 2026 survived rain, snow, beach and boating adventures with impressive sound, durability and design.
Nothing's $59 milk carton delivers surprisingly good sound, Auracast, and over 17 hours of battery life. Got milk? This one's got swagger.
Headphones
Can Auracast change movie theater accessibility? Vue has installed Auri across 200+ screens while major North American chains still use legacy receivers.
CMF’s first Bluetooth speakers combine Nothing-style design with Auracast, USB-C audio, IP68 protection and prices starting at just $59.
EarFun's flagship wireless noise cancelling headphones for 2026 offer adaptive ANC, Auracast, aptX Lossless, 90-hour battery life and custom EQ.
