Sonos Unveils Play and Era 100 SL Wireless Speakers Designed for Music That Moves With You
Sonos unveils the $299 Play and $189 Era 100 SL wireless speakers designed for flexible listening at home or on the go. Are these the most versatile Sonos speakers yet or a simplified intro for new customers?
Sonos Era 100 SL and Sonos Play Wireless Speakers 2026
After a relatively quiet stretch on the product front, Sonos appears ready to reset the conversation in 2026. The wireless audio pioneer spent much of the past year refining its ecosystem and taking stock of a market that has become far more competitive than when it first defined the multiroom category. Now, with the introduction of the Sonos Play and Sonos Era 100 SL, the company is returning to the core idea that built its reputation: simple speakers powered by a deeply capable whole home audio platform.
The timing matters. While Sonos has been recalibrating, the wireless speaker space has grown crowded with credible alternatives from established rivals like Denon, Bluesound, and Klipsch, along with fast rising streaming focused brands such as WiiM. Each has taken aim at the same promise Sonos popularized two decades ago: music that follows you effortlessly from room to room.
With Sonos Play and Sonos Era 100 SL, Sonos is clearly signaling that 2026 will look very different from the past year. Both speakers focus on flexibility and ease of expansion, reinforcing the company’s long standing philosophy that great sound should move with you throughout the home and beyond it.
What Sonos Play & Era 100 SL Actually Add to the Sonos Ecosystem
The new Sonos Play and Era 100 SL target two different entry points into the Sonos ecosystem, but both are built around the same goal: making it easier to start a system and expand it over time without replacing what you already own. Rather than introducing a completely new category, these speakers focus on practical flexibility that works within the broader Sonos platform.
sonos-play-dimensions
Sonos Play
Sonos Play is designed as a hybrid speaker that works both inside and outside the home. When connected over Wi-Fi, it functions like a traditional Sonos speaker that can be grouped across rooms or paired in stereo. It can also operate as a portable Bluetooth speaker with up to 24 hours of battery life and an IP67-rated design for outdoor use. A charging base keeps it ready at home, while a removable utility loop and built-in power bank allow it to double as a mobile device charger when you’re away from an outlet. The speaker also supports multi-speaker grouping from a Bluetooth source, allowing multiple compatible Sonos speakers to sync together even when away from a home network.
sonos-era-100-sl-dimensions
Sonos Era 100 SL
Era 100 SL takes a more straightforward approach focused on system expansion. It’s a simplified version of the Era 100 platform with a microphone-free design and a streamlined feature set aimed at users who want a dedicated Wi-Fi speaker that integrates easily into the Sonos ecosystem. It works as a standalone speaker in a single room but can also be paired for stereo sound, grouped across multiple rooms, or used as part of a home theater setup.
Together, the two speakers reinforce the core idea behind the Sonos platform: products that work well individually but become more useful as more rooms and devices are added to the system. Instead of replacing existing gear, they are meant to build on it.
Sonos Play: Portable Speaker With WiFi, Bluetooth, and All Day Battery Life
Sonos Play is designed to serve as both a portable Bluetooth speaker and a full member of the Sonos multiroom ecosystem. At home, it connects over WiFi and integrates with other Sonos products for multiroom playback or stereo pairing. When you leave the house, it can switch to Bluetooth operation so it functions like a traditional portable speaker without relying on your home network.
sonos-play-pool-lifestyle
Sonos Play
Under the hood, Sonos Play uses three Class H digital amplifiers tuned specifically for the enclosure. The acoustic design combines two angled tweeters for stereo separation and detailed high frequencies with a single midwooferresponsible for midrange clarity and bass output. To reinforce low frequencies without increasing cabinet size, Sonos adds dual force cancelling passive radiators, which help extend bass performance while minimizing cabinet vibration.
The speaker also includes a far field microphone array with beamforming and multichannel echo cancellation for voice control and Trueplay tuning. Users can toggle the microphones off with a physical hardware switch. Through the Sonos app, listeners can adjust bass, treble, and loudness settings, while Automatic Trueplay software continuously adapts the speaker’s sound profile based on its surroundings and the content being played.
From a portability standpoint, Sonos Play is built for outdoor use with an IP67 dust and water resistant enclosure, meaning it can survive temporary submersion in up to one meter of water for 30 minutes. The cabinet measures 7.56 inches high, 4.43 inches wide, and 3.02 inches deep, and weighs 2.87 pounds (1.3 kg). It is available in black or white with a matte finish and includes physical controls for playback, volume, grouping, and voice assistant muting, along with LED indicators that display connection status, battery level, and microphone activity.
Power and connectivity options reflect the hybrid nature of the speaker. Sonos Play supports WiFi 6 and works with 2.4 GHz and 5 GHz networks using 802.11a/b/g/n/ac/ax standards. For portable listening, it includes Bluetooth 5.3 for wireless audio streaming from phones, tablets, and laptops.
A 35Wh battery delivers up to 24 hours of playback, and the speaker includes a USB Type-C port that can charge a phone or connect to an external audio source using the optional Sonos Line In Adapter. Ethernet connectivity is also possible through the optional Sonos Combo Adapter.
sonos-play-white-charging-base
Sonos Play with Charging Base
At home, Sonos Play rests on the included Charging Base, which keeps the speaker powered and ready for use as part of a stationary multiroom system. The base requires a USB C PD compatible power adapter rated at 18 watts or higher, which is sold separately.
For Apple users, the speaker also supports Apple AirPlay 2 on devices running iOS 11.4 or later, alongside compatibility with the Sonos app, voice services, and streaming integrations such as Spotify Connect.
Era 100 SL: A Simpler Sonos Speaker Built for Everyday Listening
Era 100 SL is positioned as a more streamlined entry point into the Sonos ecosystem, aimed at listeners who want the core Sonos experience without extra hardware they may never use. It is based on the same general acoustic platform as the Era 100, but removes the built in microphones and keeps the focus on music playback, system expansion, and straightforward wireless connectivity.
sonos-era-100-sl-with-turntable
Stereo pair of Sonos Era 100 SL speakers with turntable
Inside, the speaker uses three Class D digital amplifiers tuned for its cabinet and driver layout. Its acoustic system includes two angled tweeters for stereo separation and high frequency detail, along with one midwoofer that handles vocals, midrange information, and bass. Through the Sonos app, users can adjust bass, treble, and loudness, while Trueplay room tuning can fine tune the speaker’s EQ based on the acoustics of the room, although that feature requires WiFi and a compatible iOS device.
The feature set is clearly aimed at consumers who want flexibility without overcomplication. Era 100 SL can function as a standalone speaker, but it can also be paired with a second unit for stereo sound, grouped with other Sonos speakers in a multiroom setup, or used as rear surrounds in a Sonos home theater system.
It supports streaming over Wi-Fi through the Sonos app, along with Bluetooth 5.3, Apple AirPlay 2, and Spotify Connect. There is also a USB Type-C connection for adding an external source such as a turntable or other audio component through the optional Sonos Line In Adapter, and Ethernet connectivity is available through the optional Sonos Combo Adapter.
sonos-era-100-sl-white-rear-speakers
Sonos Era 100 SL can be used as rear speakers in a Sonos surround sound system.
Physically, the speaker remains compact enough for shelves, desks, and smaller rooms. It measures 7.2 inches high, 4.72 inches wide, and 5.14 inches deep, and weighs 4.31 pounds (1.95 kg). It is offered in black or white with a matte finish, and uses capacitive touch controls on the top panel for playback, volume, and grouping functions. An LED indicator shows connection and mute status, while a dedicated Bluetooth button handles wireless pairing.
On the power and networking side, Era 100 SL supports Wi-Fi 6 and works with 2.4 GHz and 5 GHz networks using 802.11a/b/g/n/ac/ax standards. It uses an internal 100 to 240V, 50/60Hz power supply, so unlike Sonos Play, this is a speaker intended to remain plugged in rather than travel with you. Sonos also says the model is built with recycled plasticand ships in recyclable FSC certified paper packaging, which may matter to buyers paying closer attention to sustainability.
The Bottom Line
The Sonos Play and Era 100 SL focus on what Sonos has historically done best: simple speakers that become more capable as part of a larger multiroom system. Play is the more distinctive of the two, functioning as both a portable Bluetooth speaker and a WiFi Sonos speaker when docked at home, while Era 100 SL offers a more affordable, microphone free version of the Era platform for expanding a room, stereo pair, or surround system.
At $299 , Sonos Play sits in the premium portable category but adds deeper integration with the Sonos ecosystem. Era 100 SL at $189 is priced competitively for buyers looking to build a multiroom system one room at a time.
What feels missing will depend on the buyer. Some may want native Ethernet, built in line input without adapters, or broader high resolution audio support, especially as competitors push those features. Still, these speakers are clearly aimed at first time Sonos buyers and existing users adding more rooms, reinforcing the platform rather than reinventing it.
Where to buy:
2026 JMGO Iris Ultra Projectors
JMGO’s IRIS Series lifestyle projectors feature 4K at 120Hz output with optical zoom and lens shift for gamers who want a bigger picture without...
Silkland H96 HDMI 2.2. Cables Silkland H96 HDMI 2.2. Cables
A/V Furniture & Accessories
2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle 2026 Sony ECM-AX10 Spatial Audio Microphone with Eclipsa Lifestyle
2026 Wattson Audio Madison Phono Angle 2026 Wattson Audio Madison Phono Angle
Can digitizing vinyl improve a phono stage? Wattson Audio’s $5,495 Madison Phono supports MM, MC, DS Audio and multiple historic EQ curves.
Exclusive Videos
The $699 Sonos Beam Ultra 7.1.2 compact soundbar delivers class-leading sound and versatility, but does buying one still require a leap of faith in...
NextLevel's Mantelbar hides a Sonos Arc soundbar or speakers inside the fireplace mantel. Clever architecture, or has the mantel finally earned its keep?
Marshall’s $499.99 Bromley 150 party speaker combines 360-degree sound, stage lighting, 40+ hour battery life, Auracast, and mic and instrument inputs.
The $599 SOUNDBOKS Rider delivers 118dB, a swappable battery and IP66 protection without requiring a hand truck to move it.
The 2026 CEDIA Expo was held last week in Denver and eCoustics was there in force to check out the latest in home theater...
Hisense takes on JBL, Sony, Marshall, LG and TCL with four new Bluetooth and party speakers led by the $399.99 Party Thunder Pro.
Is it possible for a $60 Bluetooth speaker to improve your TV's sound? IKEA’s BADKRUKA adds optical input, stereo pairing, 25W output and Spotify...
